Author Topic: DRSSTC No Breakout On Topload  (Read 502 times)
Offline Dhaygoh
« on: May 03, 2022, 03:17:29 AM »
This is my first attempt at a DRSSTC. I am unable to generate a spark from the breakout wire placed on top of the toroid (difficult to see in the video, but it is there). However if I hold a metal wire about 6" from the secondary and halfway up its length, I get what you see in the video below.
Any suggestions would be greatly appreciated, thank you!
Some additional information:
Secondary Tank Circuit
Secondary Inductor:
- 20" wound length,
- 3.5" outer diameter (PVC)
- Inductance: 19.83 mH ( ESR 47.93 Ohms )
Topload:
- Spun aluminum toroid
Measured Secondary Resonant Frequency (fsec): 264 kHz
Primary Tank Circuit
MMC Capacitance: 0.27 uF
Primary Planar Inductor Number of Turns: 3
Target Primary Resonant Frequency (fpri_target): fsec - 10% ~= 238 kHz
Measured Primary Resonant Frequency (fpri): 227 kHz
Primary coil to secondary coil vertical distance: ~1.25"
Inverter
Input: 120 VAC
Topology: Full-bridge
Vbus: ~340 V (voltage doubler)
Driver Settings
PRF: 120 Hz
Pulse Width: 200 usec
OCD Set Point: ~270 Amp (max)
I have applied 10 coats of Polyurethane to the secondary (by brush application).
The counterpoise seen in the foreground is a 30" x 50" plastic sheet covered with aluminum tape and connected to the secondary RF ground via a 14 gauge wire (about 1' in length). Strike rail is also connected to secondary RF ground via 14 gauge wire (~6" length).
To prevent undue stress to my cheap IGBTs, I have the driver set to only generate 250 cycles of the PRF on each trigger (done via BLE). That is why you hear the the signal start and stop.
« Last Edit: May 03, 2022, 03:25:26 AM by Dhaygoh »
Re: DRSSTC No Breakout On Topload
« Reply #1 on: May 03, 2022, 04:06:30 AM »
If I understand correctly, this testing is at 340Vbus.  You are doing well to be testing at that bus voltage and not fried any IGBTs yet.
Do you have an oscilloscope or access to one?  Debugging DRSSTCs is much easier with scope captures.
That's 2.6 ohms at 227kHz, too low for a 340V 270A H-bridge.  Lower capacitance and higher inductance would be better.  That also makes primary lead wire inductance less important (lower fraction of total primary inductance).
Coupling factor is likely on the low side of optimum too.  Use JavaTC to calculate coupling factor (and other parameters) based on your coil geometry.  0.14 to 0.145 is a good target for DRSSTC coupling.
Less detuning (primary frequency ~5% below secondary) is easier for getting initial breakout.  Once your circuitry is working well, more detuning will improve performance.
I recommend against testing this way.  Risks drawing an arc to secondary, damaging polyurethane coating.  BTW, getting higher voltage part way up the secondary than at the top suggests oscillation at a higher secondary harmonic frequency.  Scoping currents will indicate if this is indeed the case here.
Good luck!
Offline Dhaygoh
« Reply #2 on: May 03, 2022, 04:25:02 PM »
First off, thanks for the quick reply and recommendations. It is much appreciated.
Yes, what you see is testing at 340Vbus. I have the input fed via a variac, what voltage do you recommend throttling down to while still being able to accurately characterize the system?
And yes, I have a scope. Was going to start digging in next, but wanted to check in here first to see if I was doing something wrong that was blatantly obvious.
What primary impedance at resonance should I target given my setup?
Will look into it. Hard to see, but the primary coil and strike rail holder is 3D printed and allows me to move the primary coil plane up/down the legs by ~0.5" increments.
Good to know, will try to get closer to the secondary resonant frequency. And just to confirm, I should be measuring the primary and secondary tank circuit resonant frequencies while they are decoupled from each other (e.g. not in the presence of each other and thus de-tuning one another) ?
Agreed. I thought so too, I figured a standing wave was forming at a portion of the length due to being at a higher harmonic. I moved the tap on primary (greatly increasing the inductance) to try to influence the secondary resonance but the height at which the breakout occurred didn't seem to change much. I'm assuming the low coupling is playing a factor, and possibly the delta induced would be hard to notice without careful observation.
Thanks again for the suggestions.
« Last Edit: May 03, 2022, 04:26:45 PM by Dhaygoh »
Offline Dhaygoh
« Reply #3 on: May 03, 2022, 07:16:08 PM »
In regards to the surge impedance, is the value proposed by Steve Conner in a 4vh.org thread a good starting point?
Source: https://4hv.org/e107_plugins/forum/forum_viewtopic.php?86591
I choose the surge impedance to be about 10 times the inverter's output impedance, but Steve Ward's newer coils have a lower impedance and seem to work great, so now I'd say 5 times. Anything between 5 and 10 seems to work, though.
The formula I use for the inverter output impedance is (4/pi)*(DC bus voltage/current limit) but since it's just a rough estimate, you can leave out the 4/pi.
And if it were a half bridge inverter, you'd need to divide the impedance by 2.
« Reply #4 on: May 04, 2022, 05:26:17 PM »
Yes, it is a good starting point for typical coupling values. Steve Conners formula provide roughly the same results as the suggestions in this thread: https://highvoltageforum.net/index.php?topic=113.msg657#msg657
« Reply #5 on: May 05, 2022, 04:19:47 AM »
PRF: 120 Hz
Low duty cycle as you have is good for testing.  I'd start even lower, PRF <= 10Hz, at least for initial full-voltage testing.
If you have an isolated supply option (ie. bench supply) for VBus testing, that allows scoping gate waveforms (Vge).  I'd verify good Vge waveforms and phase lead (H-bridge outputs switching slightly before primary current zero-crossing times) before running at full voltage and higher duty cycles.  Phase lead will change slightly as VBus increases, but not too much.  I'd also verify that secondary ground current (or scope probe used as an antenna to pick up secondary voltage) matches primary frequency, not some harmonic of it.  Once everything looks roughly correct at low voltage, say 50V for VBus, then just double-check that phase lead doesn't change too much as VBus is increased.
Yes, correct.
Offline Dhaygoh
« Reply #6 on: May 05, 2022, 05:14:32 PM »
Ok, thank you for the additional resource.
Offline Dhaygoh
« Reply #7 on: May 05, 2022, 05:26:27 PM »
Thank you for the recommendations. I think I am definitely running at a higher harmonic. Didn't save the waveforms but the noise pick up I saw on the scope probes at the PRF interval was several integer multiples of the measured secondary resonance frequency. I am also monitoring the square-wave output of the ZVC circuit using a microcontroller, and the computed frequencies were much higher than expected but I had assumed that I had a bug in my firmware.
Will run the system at a much lower voltage and confirm the output of the ZVC circuit using the scope, then continue downstream as recommended.
Thanks again.
post Re: Aluminium Nitride Thermal Pads
Today at 08:33:16 AM
post Re: Feedback problems
Mike
Today at 04:20:00 AM
Today at 02:25:07 AM
Today at 02:18:56 AM
post Re: Problem with VTTC Staccato interrupter PLZ HELP
Today at 01:57:37 AM
Today at 01:54:04 AM
Today at 12:09:56 AM
post Re: Half-bridge for my first sstc
August 13, 2022, 10:14:40 PM
post Problem with VTTC Staccato interrupter PLZ HELP
NerdlabsMadScience
August 13, 2022, 09:32:08 PM
LoOdaK
August 13, 2022, 09:11:03 PM
August 13, 2022, 08:45:41 PM
LoOdaK
August 13, 2022, 08:20:01 PM
August 13, 2022, 08:00:14 PM
August 13, 2022, 07:41:45 PM
post A little idea I had for my dual full bridge design
Overlordcheese
August 13, 2022, 06:42:34 PM
post Feedback problems
August 13, 2022, 06:17:43 PM
LoOdaK
August 13, 2022, 03:18:05 PM
August 12, 2022, 11:03:52 PM
LoOdaK
August 12, 2022, 10:53:44 PM
August 12, 2022, 10:13:02 PM
LoOdaK
August 12, 2022, 09:35:29 PM
August 12, 2022, 08:28:28 PM
August 12, 2022, 07:26:41 PM
August 12, 2022, 06:52:58 PM
August 12, 2022, 06:39:27 PM
August 12, 2022, 06:38:44 PM
August 12, 2022, 05:57:00 PM
August 12, 2022, 12:44:20 PM
LoOdaK
August 12, 2022, 08:36:23 AM
post Aluminium Nitride Thermal Pads
August 12, 2022, 04:31:17 AM
post Re: Helpy Trying to Replicate This Strange Slittle DRSSTC? PLS
ItsChloeUwU
August 12, 2022, 02:55:27 AM
post Re: Small DRSSTC Questions
Mike
August 12, 2022, 01:27:14 AM
August 11, 2022, 11:51:42 PM
August 11, 2022, 11:35:43 PM
post Say what -- arcing TO polycarbonate!
August 11, 2022, 10:56:28 PM
August 11, 2022, 07:40:03 PM
post Re: Huge Mistake Designing My Coil
MarcusFunt
August 11, 2022, 06:54:14 PM
August 11, 2022, 05:07:28 PM
post Half-bridge for my first sstc
LoOdaK
August 11, 2022, 11:13:20 AM
post Huge Mistake Designing My Coil
MarcusFunt
August 11, 2022, 10:03:54 AM
Mike
August 11, 2022, 06:12:48 AM
post Re: Painfully Amazing Stuff
August 11, 2022, 03:14:55 AM
55#sofcopper
August 11, 2022, 02:55:16 AM
post Painfully Amazing Stuff
August 10, 2022, 10:47:09 PM
post Re: HV AC Current Measurement
August 10, 2022, 07:51:16 PM
August 10, 2022, 06:36:23 PM
August 10, 2022, 01:34:40 AM
post Re: High Voltage pcb
FonziDaytona
August 09, 2022, 10:17:24 PM
August 09, 2022, 10:16:33 PM
post Re: How To Varnish A Tesla Coil Secondary Coil
August 09, 2022, 09:22:37 PM
August 09, 2022, 09:19:26 PM
FonziDaytona
August 09, 2022, 08:32:08 PM
August 09, 2022, 08:26:32 PM
post Re: Coherent VersaPulse VPW - what should I do with it?
August 09, 2022, 08:15:54 PM
post High Voltage pcb
FonziDaytona
August 09, 2022, 08:15:10 PM
post Top load material selection
55#sofcopper
August 09, 2022, 04:44:43 PM
August 09, 2022, 04:20:01 PM
post Loneoceans UD 2.7 rev c issue
mthome4
August 09, 2022, 03:11:56 PM
post Re: A big-ish diy xformer
August 09, 2022, 07:30:29 AM
August 09, 2022, 07:06:52 AM
August 09, 2022, 07:06:34 AM
August 09, 2022, 06:28:49 AM
August 09, 2022, 06:18:56 AM
August 09, 2022, 06:08:53 AM
August 09, 2022, 04:29:49 AM
post HV AC Current Measurement
August 09, 2022, 02:18:35 AM
August 09, 2022, 12:42:21 AM
August 09, 2022, 12:31:47 AM
August 09, 2022, 12:22:26 AM
August 09, 2022, 12:00:39 AM
post Coherent VersaPulse VPW - what should I do with it?
August 08, 2022, 11:24:45 PM
post Re: Optic fiber interrupter in EU
August 08, 2022, 10:07:08 PM
August 08, 2022, 10:01:56 PM
August 08, 2022, 10:00:22 PM
August 08, 2022, 09:52:09 PM
August 08, 2022, 09:51:09 PM
post Re: Where To Get "Free" TO-247 IGBTs and MOSFETs
August 08, 2022, 09:50:49 PM
post How To Varnish A Tesla Coil Secondary Coil
August 08, 2022, 09:47:24 PM
August 08, 2022, 09:44:04 PM
August 08, 2022, 09:43:38 PM
August 08, 2022, 09:42:37 PM
August 08, 2022, 09:27:10 PM
post Optic fiber interrupter in EU
ItsChloeUwU
August 08, 2022, 08:09:38 PM
post Helpy Trying to Replicate This Strange Slittle DRSSTC? PLS
ItsChloeUwU
August 08, 2022, 04:10:00 PM
August 08, 2022, 07:54:27 AM
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
alexhanyuan
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
alexhanyuan
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
post Re: Can someone help, am not getting any plasma :-) much appreciated
ItsChloeUwU
August 06, 2022, 07:49:05 PM
post Re: Primary Wire Getting Hot, Secondary flashovers, RSG Not Alway Fireing? Help pls.
ItsChloeUwU
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
