Author Topic: First drsstc project, looking for recommendations  (Read 3877 times)
Offline costas_p
Re: First drsstc project, looking for recommendations
« Reply #20 on: May 29, 2022, 02:03:40 PM »
First test is completed , it wanted around 70V ac from variac to start oscillating, there is a buzzing sound coming from the coffeepot, after 1 minute of run on 70V ac everything was cool to the touch,
actual measurements not done cause my tools are on work place at the moment. I am verry happy nothing exploded yet
https://youtube.com/shorts/fxLiGhJB-ZI?feature=share
« Last Edit: May 29, 2022, 08:14:16 PM by Mads Barnkob »
Papadakis Costas
Offline AstRii
« Reply #21 on: May 30, 2022, 03:06:16 AM »
(Anyone had issues with UD2.7 outputs being stressed by the low frequency signal of non-oscillation resulting in GDT saturation?)
While we're at it, how does one recognize if GDT is saturating?
I usually check primary current of a transformer to see if it doesn't peak way above nominal current, but current flowing to transistor's gates is by definition a high current peak, rendering my method useless in this case.
How do output waveforms of a GDT look like if it's saturating?
Marek Novotny
www.uhvlab.org
« Reply #22 on: May 31, 2022, 06:20:18 AM »
Normal peak GDT input current is during voltage switching.  Saturation current is highest just before voltage reversal, and typically lasts longer, from the time of saturation until voltage reversal.  So, time of peak current is the key.  Saturation current will show up as relatively-rapid charging of coupling capacitor in UD2.7 output circuit and in higher output FET voltage drop.
Offline costas_p
« Reply #23 on: June 18, 2022, 10:32:43 AM »
I finally managed to assemble the coil, and make some tests, coil achieved first light.
https://youtube.com/shorts/_saYnn-gCiA?feature=share
Phase lead is not yet tuned.
I managed to supply full ac mains power throught a variac without blowing anything, however the spark length did not had big difference from eg 70v (start oscillating) to full 220v.
What is the recommendation: make coupling factor higher, or start adjusting primary coil tap point ?
Papadakis Costas
« Reply #24 on: June 18, 2022, 07:28:11 PM »
If coupling is still at your original 0.12, I recommend increasing it to at least 0.14.  Even higher might be good, especially for initial testing.
Tuning would be easier with a scope.  Adjusting tuning will likely help too.  Higher coupling will allow success with a bit more detuning.  Thus I'd increase coupling first.
Offline costas_p
« Reply #25 on: June 18, 2022, 08:29:17 PM »
By the way, when we talk about coupling factor, what is the correct way?
In my case I am using 1/4" copper tubing for primary coil, so to measure coupling I measure distance from top/bottom or middle of primary and the start of secondary winding ?
Papadakis Costas
« Reply #26 on: June 18, 2022, 08:34:32 PM »
I'd guess that JavaTC is based on middle of primary winding.  However, someone else will need to answer this more definitively.
Offline costas_p
« Reply #27 on: June 22, 2022, 02:16:02 PM »
I did all calculation from the beginning, my coupling factor as it is right now is 0.126, due to construction  I can remove another 5mm of secondary coil height for a maximum 0.138 coupling.
While playing midi (6 turn tap + 0.126 coupling) the coil happily output around 20cm sparks at 70-80v input , increasing the voltage from variac the OCD led starts flashing like crazy so I decrease voltage to lower.
I will experiment further in order to be able to use full main voltage.
Mean while doom theme song:
Papadakis Costas
« Reply #28 on: June 23, 2022, 03:49:07 AM »
Increased coupling will likely reduce OCD events, allowing higher voltage.
Today at 05:24:42 AM
7824c5a4
Today at 03:08:12 AM
Today at 02:43:23 AM
June 08, 2023, 03:28:43 AM
June 08, 2023, 01:36:47 AM
June 07, 2023, 10:34:32 AM
June 07, 2023, 05:04:43 AM
June 06, 2023, 11:16:55 AM
June 06, 2023, 07:05:39 AM
post Re: A few questions
June 05, 2023, 01:41:45 AM
June 05, 2023, 01:38:02 AM
ako
June 05, 2023, 01:04:41 AM
June 05, 2023, 12:55:10 AM
June 04, 2023, 10:25:53 PM
YSPACE Labs
June 04, 2023, 09:04:00 PM
June 04, 2023, 04:17:14 PM
June 04, 2023, 01:20:51 PM
June 04, 2023, 04:09:52 AM
June 04, 2023, 03:23:08 AM
ako
June 04, 2023, 02:20:40 AM
June 04, 2023, 12:13:41 AM
Boilerbots
June 03, 2023, 11:27:50 PM
NickyLee
June 03, 2023, 09:57:35 PM
June 03, 2023, 08:16:03 PM
June 03, 2023, 07:00:02 AM
June 03, 2023, 06:24:39 AM
June 03, 2023, 05:31:49 AM
June 03, 2023, 04:40:21 AM
breezetix
June 03, 2023, 02:13:24 AM
June 02, 2023, 11:11:58 PM
June 02, 2023, 10:21:50 PM
June 02, 2023, 09:06:34 PM
June 02, 2023, 08:31:37 PM
June 02, 2023, 07:19:37 PM
June 02, 2023, 06:55:39 PM
June 02, 2023, 06:34:00 PM
June 02, 2023, 05:27:03 PM
nsled
June 02, 2023, 05:16:15 PM
June 02, 2023, 04:38:17 PM
nsled
June 02, 2023, 04:11:41 PM
June 02, 2023, 05:52:52 AM
June 02, 2023, 05:20:44 AM
June 02, 2023, 04:19:51 AM
June 02, 2023, 03:53:33 AM
June 02, 2023, 03:17:52 AM
ako
June 02, 2023, 02:33:51 AM
June 01, 2023, 09:34:26 PM
June 01, 2023, 08:39:13 PM
ako
June 01, 2023, 08:29:30 PM
June 01, 2023, 07:39:52 PM
June 01, 2023, 07:32:38 PM
ako
June 01, 2023, 02:57:06 PM
June 01, 2023, 07:41:02 AM
Boilerbots
June 01, 2023, 07:11:05 AM
post Re: Bridge output
June 01, 2023, 04:52:33 AM
June 01, 2023, 04:27:21 AM
June 01, 2023, 04:21:42 AM
June 01, 2023, 04:18:52 AM
June 01, 2023, 02:05:59 AM
June 01, 2023, 12:26:35 AM
nsled
May 31, 2023, 06:44:47 PM
May 31, 2023, 04:31:36 AM
May 31, 2023, 04:25:19 AM
Manz
May 31, 2023, 01:27:17 AM
May 31, 2023, 01:14:49 AM
May 30, 2023, 11:44:22 PM
ElectroNex
May 30, 2023, 11:21:52 PM
Felix M.
May 30, 2023, 11:20:23 PM
ElectroNex
May 30, 2023, 11:06:42 PM
Felix M.
May 30, 2023, 11:03:31 PM
Manz
May 30, 2023, 10:19:14 PM
May 30, 2023, 09:52:24 PM
ElectroNex
May 30, 2023, 09:22:10 PM
May 30, 2023, 09:19:37 PM
ElectroNex
May 30, 2023, 08:48:34 PM
ElectroNex
May 30, 2023, 08:41:34 PM
Felix M.
May 30, 2023, 08:30:51 PM
ElectroNex
May 30, 2023, 08:15:12 PM
Felix M.
May 30, 2023, 08:02:34 PM
ElectroNex
May 30, 2023, 06:36:54 PM
ElectroNex
May 30, 2023, 06:35:22 PM
Felix M.
May 30, 2023, 06:32:46 PM
May 30, 2023, 04:05:24 PM
ElectroNex
May 30, 2023, 12:48:19 PM
May 30, 2023, 11:11:38 AM
ako
May 30, 2023, 10:43:53 AM
May 30, 2023, 04:58:50 AM
May 30, 2023, 04:54:19 AM
May 30, 2023, 04:28:11 AM
May 30, 2023, 04:14:20 AM
May 30, 2023, 04:06:53 AM
NickyLee
May 30, 2023, 04:05:35 AM
May 30, 2023, 03:58:51 AM
May 30, 2023, 02:04:44 AM
May 30, 2023, 01:58:34 AM
May 30, 2023, 01:48:06 AM
May 29, 2023, 10:44:47 PM
May 29, 2023, 10:40:20 PM
Kizmo
May 29, 2023, 10:31:11 PM
RubyWindow
May 29, 2023, 09:11:37 PM
