Author Topic: First drsstc project, looking for recommendations  (Read 1968 times)
Offline costas_p
Re: First drsstc project, looking for recommendations
« Reply #20 on: May 29, 2022, 02:03:40 PM »
First test is completed , it wanted around 70V ac from variac to start oscillating, there is a buzzing sound coming from the coffeepot, after 1 minute of run on 70V ac everything was cool to the touch,
actual measurements not done cause my tools are on work place at the moment. I am verry happy nothing exploded yet
https://youtube.com/shorts/fxLiGhJB-ZI?feature=share
« Last Edit: May 29, 2022, 08:14:16 PM by Mads Barnkob »
Papadakis Costas
Offline AstRii
« Reply #21 on: May 30, 2022, 03:06:16 AM »
(Anyone had issues with UD2.7 outputs being stressed by the low frequency signal of non-oscillation resulting in GDT saturation?)
While we're at it, how does one recognize if GDT is saturating?
I usually check primary current of a transformer to see if it doesn't peak way above nominal current, but current flowing to transistor's gates is by definition a high current peak, rendering my method useless in this case.
How do output waveforms of a GDT look like if it's saturating?
Marek Novotny
www.uhvlab.org
« Reply #22 on: May 31, 2022, 06:20:18 AM »
Normal peak GDT input current is during voltage switching.  Saturation current is highest just before voltage reversal, and typically lasts longer, from the time of saturation until voltage reversal.  So, time of peak current is the key.  Saturation current will show up as relatively-rapid charging of coupling capacitor in UD2.7 output circuit and in higher output FET voltage drop.
Offline costas_p
« Reply #23 on: June 18, 2022, 10:32:43 AM »
I finally managed to assemble the coil, and make some tests, coil achieved first light.
https://youtube.com/shorts/_saYnn-gCiA?feature=share
Phase lead is not yet tuned.
I managed to supply full ac mains power throught a variac without blowing anything, however the spark length did not had big difference from eg 70v (start oscillating) to full 220v.
What is the recommendation: make coupling factor higher, or start adjusting primary coil tap point ?
Papadakis Costas
« Reply #24 on: June 18, 2022, 07:28:11 PM »
If coupling is still at your original 0.12, I recommend increasing it to at least 0.14.  Even higher might be good, especially for initial testing.
Tuning would be easier with a scope.  Adjusting tuning will likely help too.  Higher coupling will allow success with a bit more detuning.  Thus I'd increase coupling first.
Offline costas_p
« Reply #25 on: June 18, 2022, 08:29:17 PM »
By the way, when we talk about coupling factor, what is the correct way?
In my case I am using 1/4" copper tubing for primary coil, so to measure coupling I measure distance from top/bottom or middle of primary and the start of secondary winding ?
Papadakis Costas
« Reply #26 on: June 18, 2022, 08:34:32 PM »
I'd guess that JavaTC is based on middle of primary winding.  However, someone else will need to answer this more definitively.
Offline costas_p
« Reply #27 on: June 22, 2022, 02:16:02 PM »
I did all calculation from the beginning, my coupling factor as it is right now is 0.126, due to construction  I can remove another 5mm of secondary coil height for a maximum 0.138 coupling.
While playing midi (6 turn tap + 0.126 coupling) the coil happily output around 20cm sparks at 70-80v input , increasing the voltage from variac the OCD led starts flashing like crazy so I decrease voltage to lower.
I will experiment further in order to be able to use full main voltage.
Mean while doom theme song:
Papadakis Costas
« Reply #28 on: June 23, 2022, 03:49:07 AM »
Increased coupling will likely reduce OCD events, allowing higher voltage.
Today at 06:48:18 AM
Hiemal
Today at 05:37:39 AM
Today at 05:00:02 AM
Today at 04:47:36 AM
boom198
Today at 04:03:53 AM
Today at 03:58:58 AM
Hiemal
Today at 03:36:19 AM
Razerwire
June 30, 2022, 10:46:33 PM
post Re: IGBT Hookup guide
June 30, 2022, 10:13:37 PM
June 30, 2022, 09:00:08 PM
post IGBT Hookup guide
ThePickledNerd
June 30, 2022, 07:56:18 PM
Mike
June 30, 2022, 01:04:19 PM
June 30, 2022, 06:41:10 AM
June 30, 2022, 05:41:21 AM
Razerwire
June 30, 2022, 05:19:18 AM
Hiemal
June 30, 2022, 01:32:12 AM
[Contests and Events]
June 29, 2022, 05:14:33 PM
June 29, 2022, 03:14:25 PM
Mike
June 29, 2022, 12:46:43 PM
boom198
June 29, 2022, 02:17:25 AM
June 28, 2022, 07:38:02 PM
June 28, 2022, 05:19:24 PM
June 28, 2022, 04:34:46 PM
June 28, 2022, 01:49:07 PM
Razerwire
June 28, 2022, 09:42:52 AM
June 28, 2022, 08:47:31 AM
post Re: Auto tuning primary?
June 28, 2022, 08:45:41 AM
June 28, 2022, 05:35:15 AM
June 28, 2022, 05:30:25 AM
June 28, 2022, 05:09:25 AM
June 28, 2022, 05:05:27 AM
boom198
June 28, 2022, 04:51:22 AM
June 28, 2022, 01:19:41 AM
June 27, 2022, 10:25:55 PM
June 27, 2022, 09:15:26 PM
June 27, 2022, 09:10:43 PM
post Auto tuning primary?
Overlordcheese
June 27, 2022, 08:36:46 PM
Overlordcheese
June 27, 2022, 08:31:45 PM
June 27, 2022, 06:14:48 PM
June 27, 2022, 05:30:22 PM
June 27, 2022, 02:51:14 PM
June 27, 2022, 08:57:52 AM
June 27, 2022, 05:48:47 AM
post DRSSTC trips GFCI outlet
boom198
June 27, 2022, 03:47:49 AM
June 26, 2022, 05:59:04 PM
[Static Electricity]
June 26, 2022, 12:49:14 PM
June 25, 2022, 11:23:08 PM
June 25, 2022, 03:43:12 PM
June 25, 2022, 12:02:13 PM
June 25, 2022, 07:37:22 AM
post Re: Bipolar CW
Vdekje
June 25, 2022, 05:05:20 AM
June 24, 2022, 08:32:54 PM
June 24, 2022, 06:28:10 PM
June 24, 2022, 05:52:55 PM
Mike
June 24, 2022, 12:56:41 PM
June 24, 2022, 04:32:42 AM
June 23, 2022, 11:51:16 PM
June 23, 2022, 10:12:26 PM
June 23, 2022, 10:11:07 PM
Manz
June 23, 2022, 06:10:14 PM
Mike
June 23, 2022, 01:36:42 PM
June 23, 2022, 01:30:29 PM
post Re: Is this good GDT ?
LoOdaK
June 23, 2022, 01:03:35 PM
June 22, 2022, 06:30:42 PM
post Re: Problem with SSTC
June 22, 2022, 03:57:54 AM
June 21, 2022, 09:14:34 PM
June 21, 2022, 08:06:08 PM
Nunu00
June 21, 2022, 04:44:13 PM
Tetris
June 21, 2022, 04:39:23 AM
post Re: ocd input
June 21, 2022, 03:41:25 AM
June 20, 2022, 08:45:35 PM
June 20, 2022, 08:28:48 PM
June 20, 2022, 07:30:18 PM
June 20, 2022, 07:06:54 PM
June 20, 2022, 06:42:56 PM
BenTesla
June 20, 2022, 06:33:53 PM
June 19, 2022, 11:56:23 PM
Nunu00
June 19, 2022, 11:00:41 PM
June 19, 2022, 10:33:14 PM
June 19, 2022, 09:50:27 PM
June 19, 2022, 09:42:02 PM
June 19, 2022, 09:30:38 PM
June 19, 2022, 09:01:09 PM
June 19, 2022, 08:58:16 PM
June 19, 2022, 08:56:18 PM
Nunu00
June 19, 2022, 07:50:17 PM
June 19, 2022, 07:09:52 PM
June 19, 2022, 06:49:26 PM
BenTesla
June 19, 2022, 02:04:01 PM
Nunu00
June 19, 2022, 11:48:17 AM
June 19, 2022, 06:16:42 AM
post Re: ocd input
June 19, 2022, 03:50:22 AM
June 19, 2022, 03:42:14 AM
Nunu00
June 19, 2022, 01:56:08 AM
post Re: ocd input
June 19, 2022, 12:49:55 AM
June 18, 2022, 11:07:46 PM
Nunu00
June 18, 2022, 09:55:23 PM
June 18, 2022, 09:30:46 PM
