Author Topic: Air cored inductors proximity to conductive objects  (Read 1233 times)
Offline John123
  • All the gear, no idea. UK
« on: November 23, 2022, 01:10:17 AM »
Can air cored inductors be influenced by proximity to other conductive things such as heatsinks even if nothing actually enters the inside of the windings? I'm talking about simple ones such as this:
Re: Air cored inductors proximity to conductive objects
« Reply #1 on: November 23, 2022, 04:44:20 AM »
Yes, but much less so than similar ferrite-core inductors.  With air-core, most of the magnetic reluctance is where field is concentrated through core center.  With lots of area for field to return outside of the coil, blocking some of that return path has only a tiny effect.  Unless you block much of it, such as if you milled a slot in a heatsink and placed it over the coil blocking most field return paths.
« Reply #2 on: November 23, 2022, 09:29:01 AM »
It would be very dependent on the aspect ratio of the coil - long skinny vs wide flat.  This is how basic metal detectors work, after all, by using a wide flat coil.
Offline John123
« Reply #3 on: November 23, 2022, 11:27:18 PM »
Thanks Dave, here's some photos of it. Excuse the messy amateur DIY construction.
It's a single layer coil measuring 32.5mm x 15mm and about 26 turns of litz wire (was aiming for a couple uH). It's 12mm at its closest point from the grounded heatsink. Flying blue wire is circuit ground.
« Last Edit: November 23, 2022, 11:30:29 PM by John123 »
« Reply #4 on: November 24, 2022, 03:02:11 AM »
Looks fine.  Heat sink should have negligible effect on inductance of coil with that geometry.
post Re: Kaizer VTTC 1
Today at 10:23:02 AM
post Re: Capacitor in Parallel with Primary Coil
Today at 10:17:34 AM
post Capacitor in Parallel with Primary Coil
Today at 10:01:41 AM
post Re: Re-chargeable 1.5 volt lithium ion AAA batteries
Today at 04:47:35 AM
Today at 03:59:27 AM
March 28, 2024, 09:15:11 PM
post Re: capacitor and diodes. Voltage values for a CW
March 28, 2024, 01:01:12 PM
post Re: Big Coil Build Log
March 28, 2024, 05:47:34 AM
March 28, 2024, 04:45:07 AM
March 28, 2024, 04:18:27 AM
post Push Pull VTTC
janno288
March 28, 2024, 01:10:08 AM
March 27, 2024, 10:54:52 PM
March 27, 2024, 11:53:42 AM
post Re: OCD Triggering Early + Low Output
March 27, 2024, 05:14:36 AM
March 27, 2024, 04:47:48 AM
post Re: DRSSTC Questions
March 27, 2024, 04:41:59 AM
March 27, 2024, 12:04:34 AM
post Re: Super flat QCW simulation (does this look reasonable?)
toooldforthis
March 26, 2024, 11:08:14 PM
March 26, 2024, 11:07:20 PM
March 26, 2024, 10:46:29 PM
post OCD Triggering Early + Low Output
March 26, 2024, 09:03:43 PM
March 26, 2024, 08:46:59 PM
March 26, 2024, 05:02:18 PM
March 26, 2024, 03:16:03 PM
March 26, 2024, 01:41:49 PM
March 26, 2024, 04:48:22 AM
March 26, 2024, 04:16:37 AM
March 26, 2024, 04:16:24 AM
post Re: Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 26, 2024, 04:13:02 AM
March 26, 2024, 04:00:43 AM
March 26, 2024, 03:19:18 AM
March 26, 2024, 01:50:42 AM
March 25, 2024, 08:05:02 PM
March 25, 2024, 07:41:29 PM
March 25, 2024, 06:45:46 PM
March 25, 2024, 05:44:25 PM
March 25, 2024, 04:47:17 PM
March 25, 2024, 04:27:22 PM
post Re-chargeable 1.5 volt lithium ion AAA batteries
March 25, 2024, 03:57:34 PM
March 25, 2024, 02:06:41 PM
post Re: Odd MOSFET Driver Behavior
KrisPringle
March 25, 2024, 04:43:25 AM
March 25, 2024, 02:39:40 AM
KrisPringle
March 25, 2024, 12:47:09 AM
March 24, 2024, 07:36:32 PM
March 24, 2024, 07:27:24 PM
March 24, 2024, 04:25:23 AM
March 23, 2024, 10:47:35 PM
March 23, 2024, 09:30:21 PM
March 23, 2024, 04:34:31 PM
March 23, 2024, 03:04:25 PM
March 23, 2024, 01:38:34 PM
March 23, 2024, 04:20:03 AM
March 23, 2024, 12:54:30 AM
March 23, 2024, 12:05:57 AM
post capacitor and diodes. Voltage values for a CW
March 22, 2024, 11:45:03 PM
OmGigaTron
March 22, 2024, 11:30:09 PM
post Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 22, 2024, 10:20:35 PM
post Re: Where's all this voltage coming from?
March 22, 2024, 09:21:13 PM
March 22, 2024, 03:37:11 PM
post What actually kills MOSFETs?
March 22, 2024, 05:09:20 AM
March 22, 2024, 03:57:54 AM
March 22, 2024, 02:59:25 AM
March 21, 2024, 06:31:42 PM
post Re: 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 21, 2024, 03:08:01 PM
post Re: [WTS] IGBT, Ferrite, Capacitors, Tools, PSU, Industrial components and parts
March 21, 2024, 01:37:32 PM
March 21, 2024, 11:42:07 AM
post Re: Phase Lead Questions
March 21, 2024, 04:09:14 AM
March 21, 2024, 02:15:31 AM
post My Homemade Structural Analysis X-Ray Machine
Luca c.
March 21, 2024, 01:35:40 AM
March 20, 2024, 10:40:00 PM
March 20, 2024, 08:03:41 PM
March 20, 2024, 07:51:57 PM
March 20, 2024, 10:39:47 AM
March 20, 2024, 04:09:59 AM
March 20, 2024, 01:13:23 AM
Keybored
March 20, 2024, 12:45:16 AM
March 20, 2024, 12:30:30 AM
March 19, 2024, 11:12:24 PM
Late
March 19, 2024, 09:47:49 PM
Late
March 19, 2024, 09:44:19 PM
post Phase Lead Questions
March 19, 2024, 06:52:09 PM
March 19, 2024, 05:02:44 PM
March 19, 2024, 05:01:41 PM
March 19, 2024, 04:31:02 PM
March 19, 2024, 03:59:54 PM
March 19, 2024, 06:41:39 AM
March 19, 2024, 04:05:49 AM
OmGigaTron
March 18, 2024, 09:08:35 PM
post Re: Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 09:07:35 PM
March 18, 2024, 08:57:06 PM
March 18, 2024, 03:51:33 PM
Late
March 18, 2024, 02:59:46 PM
Late
March 18, 2024, 02:33:25 PM
post Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 11:02:12 AM
March 18, 2024, 02:36:11 AM
post Re: Best forum for vacuum tube amplifiers?
March 17, 2024, 07:42:55 PM
March 17, 2024, 04:15:14 PM
March 17, 2024, 05:05:04 AM
March 17, 2024, 04:50:51 AM
March 17, 2024, 04:45:17 AM
