Author Topic: First DRSSTC  (Read 399 times)
Offline balazs
First DRSSTC
« on: November 22, 2021, 05:30:02 PM »
Hi every one!
I want to build a DRSSTC. I alredy build a SGTC and a SSTC. I found this tesla coil https://www.loneoceans.com/labs/drsstc1/, and i found the universal driver. But i can't found the inverter circuit. He ever shared? And this DRSSTC is good for the first DRSSTC?
Offline alan sailer
Re: First DRSSTC
« Reply #1 on: November 22, 2021, 07:16:43 PM »
The half bridge inverter power section is the same as the circuit for an SSTC. The DRSSTC uses a smaller capacitor in the tank section to allow a resonance between the primary and secondary. Tuning the frequency of the tank LC is the magic that makes the DR part of DRSSTC real.
The write-up for the DRSSTC1 describes this in a bit more detail. There is also a link to loneoceans SSTC2 which gives the schematic of the inverter circuit.
Cheers.
Offline balazs
Re: First DRSSTC
« Reply #2 on: November 22, 2021, 09:12:25 PM »
Thanks for the reply!
If I take out the voltage doubler and put in a full bridge rectifier. I will replace the 2 capacitors with mkp capacitors. And I take out the 2 diodes. Can i run it 230VAC?
It works?
Offline alan sailer
Re: First DRSSTC
« Reply #3 on: November 23, 2021, 01:33:38 AM »
I have not built a half bridge DRSSTC. So my advice might miss some subtleties. The two capacitors
you want to replace with MKP are the buss caps?
If so, that will not work. MKP capacitors are low capacitance. You will need hundreds to thousands of
microfarads for the buss caps. Unless you only want to make tiny sparks...
Mads DRSSTCII is a half bridge design running at 220VAC. Check out his schematic.
https://kaizerpowerelectronics.dk/tesla-coils/kaizer-drsstc-ii/
Cheers.
Offline balazs
Re: First DRSSTC
« Reply #4 on: November 23, 2021, 06:35:39 PM »
Hi!
I thought to do this way without the voltage dublear but i didin't discribe it well. Working this inverter if i replace the igbts and the cmm  capacitor and the primary, and use the inverter to loneoceans DRSSTC1 whit 230VAC main voltage input?
Offline alan sailer
Re: First DRSSTC
« Reply #5 on: November 23, 2021, 07:41:59 PM »
Maybe it's a language thing but I could not make any sense of your second sentence.
In any case, the information I gave you in my last post should be enough to answer your question.
 It may take some time to read and understand but that is what tesla coils are all about.
Cheers.
Re: First DRSSTC
post Re: Self Starting Coil (Not)
Today at 03:55:07 PM
post Re: Mixing PID loops
Today at 12:00:50 PM
post Re: Hi! 811 A tesa coil
304er
Today at 09:05:40 AM
post Mixing PID loops
Today at 07:28:01 AM
jpvvv123
Today at 04:13:06 AM
Today at 03:34:15 AM
post Self Starting Coil (Not)
January 23, 2022, 10:45:46 PM
post Re: GDT Slow Rise/Fall times even with resistor shorted
January 23, 2022, 09:06:49 PM
post GDT Slow Rise/Fall times even with resistor shorted
SalinsLV
January 23, 2022, 07:18:56 PM
304er
January 23, 2022, 06:18:13 PM
post Re: 120VAC Mains Ramped Builds
January 22, 2022, 11:20:55 AM
January 22, 2022, 07:07:09 AM
post Re: GDT Testing
January 22, 2022, 05:27:37 AM
January 22, 2022, 04:27:38 AM
jpvvv123
January 22, 2022, 12:53:04 AM
January 21, 2022, 07:36:07 PM
post Re: Muon Decay
January 21, 2022, 07:27:23 PM
January 21, 2022, 02:05:52 PM
January 21, 2022, 09:08:18 AM
post Re: Muon Decay
January 21, 2022, 08:42:54 AM
January 21, 2022, 03:00:04 AM
post Re: Muon Decay
January 21, 2022, 02:16:57 AM
January 20, 2022, 06:56:35 PM
post Re: Muon Decay
January 20, 2022, 05:19:26 PM
post Re: Muon Decay
January 20, 2022, 03:53:54 PM
post Re: Muon Decay
January 20, 2022, 01:20:19 PM
post Re: Muon Decay
January 20, 2022, 10:11:21 AM
post Re: Muon Decay
January 19, 2022, 08:22:49 PM
post Re: Muon Decay
January 19, 2022, 06:49:36 PM
hardboiled99
January 19, 2022, 07:37:27 AM
January 18, 2022, 10:34:48 PM
post Re: Muon Decay
January 18, 2022, 08:46:53 PM
post Re: Muon Decay
January 18, 2022, 08:08:53 PM
January 18, 2022, 07:15:22 PM
post Muon Decay
January 18, 2022, 06:49:48 PM
304er
January 18, 2022, 08:47:53 AM
January 17, 2022, 09:13:32 PM
January 17, 2022, 09:05:56 PM
January 17, 2022, 07:45:48 PM
post Re: General Questions
January 17, 2022, 07:41:34 PM
January 17, 2022, 07:38:25 PM
January 17, 2022, 07:31:03 PM
January 17, 2022, 07:28:02 PM
January 16, 2022, 09:00:02 PM
January 16, 2022, 07:35:26 PM
Bambinz
January 16, 2022, 12:21:40 PM
January 15, 2022, 07:10:03 PM
Bambinz
January 15, 2022, 06:31:33 PM
January 14, 2022, 08:47:43 PM
January 14, 2022, 08:39:07 PM
January 14, 2022, 08:14:17 PM
January 14, 2022, 08:12:13 PM
January 14, 2022, 05:51:52 PM
304er
January 14, 2022, 08:51:57 AM
Bambinz
January 13, 2022, 08:20:02 PM
January 13, 2022, 05:27:40 AM
January 13, 2022, 03:10:32 AM
304er
January 12, 2022, 06:18:15 PM
January 12, 2022, 05:45:26 PM
January 12, 2022, 03:29:04 PM
January 12, 2022, 01:30:38 PM
304er
January 12, 2022, 09:09:13 AM
January 11, 2022, 08:05:27 PM
January 11, 2022, 07:42:12 PM
January 11, 2022, 07:33:15 PM
January 11, 2022, 06:19:49 PM
304er
January 11, 2022, 05:19:46 PM
January 11, 2022, 04:31:28 PM
January 11, 2022, 03:21:37 PM
January 11, 2022, 06:50:49 AM
January 11, 2022, 06:34:20 AM
January 11, 2022, 06:24:13 AM
January 11, 2022, 06:15:08 AM
January 11, 2022, 05:25:31 AM
January 11, 2022, 12:07:22 AM
January 10, 2022, 10:56:48 PM
January 10, 2022, 09:38:53 PM
January 10, 2022, 07:50:13 PM
January 10, 2022, 07:19:17 PM
January 10, 2022, 03:13:08 PM
January 10, 2022, 04:21:46 AM
304er
January 10, 2022, 03:59:09 AM
January 10, 2022, 03:54:59 AM
January 09, 2022, 11:45:09 PM
jpvvv123
January 09, 2022, 11:04:25 PM
January 09, 2022, 04:22:11 PM
January 09, 2022, 05:52:11 AM
January 09, 2022, 05:10:50 AM
January 09, 2022, 01:20:40 AM
post GDT Testing
January 09, 2022, 12:38:28 AM
January 08, 2022, 06:36:28 PM
Max Seiringer
January 08, 2022, 03:21:31 PM
304er
January 08, 2022, 09:05:41 AM
jpvvv123
January 07, 2022, 10:20:10 PM
304er
January 07, 2022, 05:56:28 PM
January 07, 2022, 05:15:38 AM
post Re: DRSSTC tuning
January 07, 2022, 05:01:21 AM
January 07, 2022, 04:59:59 AM
post Tophat QCW 1
January 07, 2022, 02:27:35 AM
January 07, 2022, 02:19:40 AM
