Author Topic: FPS1000HD unboxing and first impression  (Read 2928 times)
« on: December 08, 2017, 11:15:54 PM »
I ordered the FPS1000 platinum back in April 2015 on kickstarters backerkit site, then in March decided to upgrade to the platinum double.
Fast forward 1½ years and the projects stalls, a new kickstarter for the FPS1000HD was started (which was a new name for the platinum double), it was offered to get a refund or camera from the original kickstarter, but only when time and money in the company allowed for it.
I ordered Samsung INR18650 batteries when I had the tracking number for the package, but the camera arrived faster than the batteries, which are still not arrived at I write this.
I also bought a adapter that had multiply different barrel jacks, some of them specced at 2.1 and 2.5 mm, which I too late discovered was the inner hole diameter and not the outer.
First impressions on a camera that I can not yet turn on.
- Looks and feels good
- Stock lens seems a little too cheap, but that is just from looking at it, no idea about actual performance
- The back cover plastic part around the LCD has sharp edges all around it, sharp enough to give a cut in the finger :(
- The screws mounting the fans on the front is not aligned with the surface of the front plate, so they go above the surface and can get stuck in things since its concave heads
- Manual is missing more specific information, especially on what power adapter to use and what kind of power plug it actually has!
- There really should have been a power supply with it, it is a expensive product and the hassle with finding a suitable one already set me back one power supply not usable since I just had to guess on the jack size from pictures.
I will return with more information once I have the camera powered up :)
« Last Edit: January 26, 2018, 11:10:39 AM by Mads Barnkob »
Re: FPS1000HD unboxing and first impression
« Reply #1 on: January 26, 2018, 11:16:47 AM »
Here is a new video with a explanation of the setup I have used with the camera and what my first impressions are so far.
I have used the stock 35mm lens a couple of times, but most of the time I find it much better to use my huge Ernitec F1.8 16-160mm lens, it does however has it limits as it can not focus below 50 mm, but this is not really a practical issue as it is used for gaining a lot of range to whatever it is I am filming, this is nice if its explosions or electrical discharges.
Battery life is around 1 hour as expected, get a fast charger! USB chargers are simply too slow for 2500mA batteries.
Reading the manual is a must (I never thought I should say that) as the user interface is not intuitive when it comes to the advanced commands.
The PC software is simple but does its job very well, after I got a USB3 cable there will be no more saving data to SD card unless I am forced to do that, the transfer speed of the USB3 is about 100 times greater!
I just need 3 things. Light, light and more light :)
Bonus, here is some lensporn pictures of the setup used in recording the fireworks in the new year special video: https://www.youtube.com/watch?v=NyrSnRc63RM
« Last Edit: January 27, 2018, 09:58:22 PM by Mads Barnkob »
Offline Nadun19
« Reply #2 on: July 20, 2020, 05:13:37 AM »
Hi
Does anyone have a copy of the GUI used to control the camera, if so can I please get a copy of it!
Thanks
Nadun
« Reply #3 on: July 20, 2020, 02:16:03 PM »
Hi
Thanks
Nadun
Hi Nadun and welcome to HVF
What camera do you have? What firmware version does it have? (if its possible to see) and do you have any of the mentioned problems with it, in the other threads?
Offline missoum0514
« Reply #4 on: August 01, 2020, 11:57:24 PM »
Hello Mads Barnkob,
I Missoum, I live in France and I just had an FPS1000HD.
Can you help me use it? :
What is the USB 3 cable used for and how to use it? With what software? (Under Win10 64bit)
Can you advise me on a good power supply?
Excuse me for asking you all these questions.
I thank you in advance.
Offline Kamui
« Reply #5 on: November 26, 2021, 05:12:14 AM »
Hi there!
I have a fps1000  high speed camera. But I do not have the relevant drivers/software to copy images from it into my PC (windows 10 64 bit) through USB3.0, thus it is showing up as "FTDI SuperSpeed FIFO Bridge" in my Windows Device Manager.
May I ask if anyone has the relevant drivers/software to work with the fps1000 high speed camera? Would you be so kind as to share it with me?
Thank you in advance!
« Reply #6 on: November 27, 2021, 07:51:01 AM »
I have gathered all the information I have on my website: https://kaizerpowerelectronics.dk/tools/fps1000hd-high-speed-camera/ and here on the forum: https://highvoltageforum.net/index.php?topic=171.0
post Re: Self Starting Coil (Not)
Today at 03:55:07 PM
post Re: Mixing PID loops
Today at 12:00:50 PM
Today at 09:05:40 AM
post Mixing PID loops
Today at 07:28:01 AM
Today at 04:13:06 AM
Today at 03:34:15 AM
post Self Starting Coil (Not)
January 23, 2022, 10:45:46 PM
post Re: GDT Slow Rise/Fall times even with resistor shorted
January 23, 2022, 09:06:49 PM
post GDT Slow Rise/Fall times even with resistor shorted
SalinsLV
January 23, 2022, 07:18:56 PM
January 23, 2022, 06:18:13 PM
post Re: 120VAC Mains Ramped Builds
January 22, 2022, 11:20:55 AM
January 22, 2022, 07:07:09 AM
post Re: GDT Testing
January 22, 2022, 05:27:37 AM
January 22, 2022, 04:27:38 AM
January 22, 2022, 12:53:04 AM
January 21, 2022, 07:36:07 PM
post Re: Muon Decay
January 21, 2022, 07:27:23 PM
January 21, 2022, 02:05:52 PM
January 21, 2022, 09:08:18 AM
post Re: Muon Decay
January 21, 2022, 08:42:54 AM
post 120VAC Mains Ramped Builds
January 21, 2022, 03:00:04 AM
post Re: Muon Decay
January 21, 2022, 02:16:57 AM
January 20, 2022, 06:56:35 PM
post Re: Muon Decay
January 20, 2022, 05:19:26 PM
post Re: Muon Decay
January 20, 2022, 03:53:54 PM
post Re: Muon Decay
January 20, 2022, 01:20:19 PM
post Re: Muon Decay
January 20, 2022, 10:11:21 AM
post Re: Muon Decay
January 19, 2022, 08:22:49 PM
post Re: Muon Decay
January 19, 2022, 06:49:36 PM
hardboiled99
January 19, 2022, 07:37:27 AM
January 18, 2022, 10:34:48 PM
post Re: Muon Decay
January 18, 2022, 08:46:53 PM
post Re: Muon Decay
January 18, 2022, 08:08:53 PM
January 18, 2022, 07:15:22 PM
post Muon Decay
January 18, 2022, 06:49:48 PM
January 18, 2022, 08:47:53 AM
January 17, 2022, 09:13:32 PM
January 17, 2022, 09:05:56 PM
January 17, 2022, 07:45:48 PM
post Re: General Questions
January 17, 2022, 07:41:34 PM
January 17, 2022, 07:38:25 PM
January 17, 2022, 07:31:03 PM
January 17, 2022, 07:28:02 PM
January 16, 2022, 09:00:02 PM
January 16, 2022, 07:35:26 PM
Bambinz
January 16, 2022, 12:21:40 PM
January 15, 2022, 07:10:03 PM
Bambinz
January 15, 2022, 06:31:33 PM
January 14, 2022, 08:47:43 PM
January 14, 2022, 08:39:07 PM
January 14, 2022, 08:14:17 PM
January 14, 2022, 08:12:13 PM
January 14, 2022, 05:51:52 PM
January 14, 2022, 08:51:57 AM
Bambinz
January 13, 2022, 08:20:02 PM
January 13, 2022, 05:27:40 AM
January 13, 2022, 03:10:32 AM
January 12, 2022, 06:18:15 PM
January 12, 2022, 05:45:26 PM
January 12, 2022, 03:29:04 PM
AFreshLad
January 12, 2022, 01:30:38 PM
January 12, 2022, 09:09:13 AM
January 11, 2022, 08:05:27 PM
January 11, 2022, 07:42:12 PM
January 11, 2022, 07:33:15 PM
January 11, 2022, 06:19:49 PM
January 11, 2022, 05:19:46 PM
January 11, 2022, 04:31:28 PM
January 11, 2022, 03:21:37 PM
January 11, 2022, 06:50:49 AM
January 11, 2022, 06:34:20 AM
January 11, 2022, 06:24:13 AM
January 11, 2022, 06:15:08 AM
January 11, 2022, 05:25:31 AM
January 11, 2022, 12:07:22 AM
January 10, 2022, 10:56:48 PM
January 10, 2022, 09:38:53 PM
January 10, 2022, 07:50:13 PM
January 10, 2022, 07:19:17 PM
January 10, 2022, 03:13:08 PM
January 10, 2022, 04:21:46 AM
January 10, 2022, 03:59:09 AM
January 10, 2022, 03:54:59 AM
January 09, 2022, 11:45:09 PM
January 09, 2022, 11:04:25 PM
January 09, 2022, 04:22:11 PM
January 09, 2022, 05:52:11 AM
January 09, 2022, 05:10:50 AM
January 09, 2022, 01:20:40 AM
post GDT Testing
January 09, 2022, 12:38:28 AM
January 08, 2022, 06:36:28 PM
Max Seiringer
January 08, 2022, 03:21:31 PM
January 08, 2022, 09:05:41 AM
January 07, 2022, 10:20:10 PM
January 07, 2022, 05:56:28 PM
January 07, 2022, 05:15:38 AM
post Re: DRSSTC tuning
January 07, 2022, 05:01:21 AM
January 07, 2022, 04:59:59 AM
post Tophat QCW 1
January 07, 2022, 02:27:35 AM
January 07, 2022, 02:19:40 AM
