Author Topic: Variac Tripping Outlet GFCI  (Read 3036 times)
Offline MrScrOggs
  • High Voltage & Power, Black Metal, Storm Chasing
« on: April 12, 2021, 02:24:09 PM »
I bought an old variac to use for a VTTC and when I plug the variac into the outlet in my garage the GFCI trips every time without fail. Is the variac broken, or am I just doing something wrong?
not sure why picture is upside down
« Last Edit: April 12, 2021, 07:10:34 PM by Mads Barnkob »
Evan
Offline TMaxElectronics
Re: Variac Tripping Outlet GFCI
« Reply #1 on: April 12, 2021, 04:25:28 PM »
I'd guess some loose wire or something like that is shorting the live to earth. You can measure the resistance between the earth connection and live to get an estimate for what it is. A dead short would point to some loose wire (and probably pop the main breaker too) but something in the kOhm range is more likely to be something else. I've had rust from liquid damage cause leakage to earth and pop the RCD for example.
But you will probably have to open it to have a look at what is going on inside to cause the damage.
« Reply #2 on: April 12, 2021, 05:31:54 PM »
I have an almost identical variac.  See where yours has a 2-slot receptacle?  I bet the 3-prong plug, on unusually short cord, is not the original.  Make sure there is no connection in the variac between the ground prong and neutral prong.
Offline MrScrOggs
« Reply #3 on: April 13, 2021, 03:16:21 PM »
Here's some photos, it looks like there is a a solid wire shorting neutral and ground on purpose...?
Evan
« Reply #4 on: April 13, 2021, 04:34:24 PM »
Whoever put that plug on didn't understand electric wiring rules.
Now the return current from variac will be resistively divided between the white and green wires in wall.
Of course the GFCI will trip immediately.
Get rid of that jumper wire in the plug.  And if it's a two-wire cord, get rid of the ground prong so nobody thinks the variac enclosure is grounded.  Note: These changes will increase the electric shock hazard when variac is plugged into a non-GFCI outlet.
I was not the first responder here to say where you should look.
You have a very good old variac.  Here's a thread about replacing the cord on one like it:
https://highvoltageforum.net/index.php?topic=1266.0
« Last Edit: April 13, 2021, 04:50:55 PM by klugesmith »
Offline MrScrOggs
« Reply #5 on: April 13, 2021, 08:22:17 PM »
Interesting, your variac is rated at 10 amps but mine is only for 7.5. Did you ground the chasse to ground with the new cable?
Evan
Offline imp
« Reply #6 on: September 11, 2021, 06:51:15 PM »
Most variacs have numerous bare connections for individual taps. Occasionally dust collection on and about those areas accumulates moisture which can conduct current to grounded areas, thus affecting gfi protection. Not the case here, but good to know.
post Re: capacitor and diodes. Voltage values for a CW
Alberto
Today at 01:01:12 PM
post Re: Big Coil Build Log
Today at 05:47:34 AM
Today at 04:45:07 AM
Today at 04:18:27 AM
post Push Pull VTTC
janno288
Today at 01:10:08 AM
Alberto
March 27, 2024, 10:54:52 PM
markus
March 27, 2024, 11:53:42 AM
post Re: OCD Triggering Early + Low Output
March 27, 2024, 05:14:36 AM
post Re: Is the UD2.7C under voltage lock out basically worthless?
March 27, 2024, 04:47:48 AM
post Re: DRSSTC Questions
March 27, 2024, 04:41:59 AM
March 27, 2024, 12:04:34 AM
post Re: Super flat QCW simulation (does this look reasonable?)
toooldforthis
March 26, 2024, 11:08:14 PM
March 26, 2024, 11:07:20 PM
March 26, 2024, 10:46:29 PM
post OCD Triggering Early + Low Output
March 26, 2024, 09:03:43 PM
March 26, 2024, 08:46:59 PM
March 26, 2024, 05:02:18 PM
March 26, 2024, 03:16:03 PM
March 26, 2024, 01:41:49 PM
March 26, 2024, 04:48:22 AM
post Re: Re-chargeable 1.5 volt lithium ion AAA batteries
March 26, 2024, 04:16:37 AM
March 26, 2024, 04:16:24 AM
post Re: Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 26, 2024, 04:13:02 AM
March 26, 2024, 04:00:43 AM
March 26, 2024, 03:19:18 AM
March 26, 2024, 01:50:42 AM
March 25, 2024, 08:05:02 PM
March 25, 2024, 07:41:29 PM
March 25, 2024, 06:45:46 PM
March 25, 2024, 05:44:25 PM
March 25, 2024, 04:47:17 PM
March 25, 2024, 04:27:22 PM
post Re-chargeable 1.5 volt lithium ion AAA batteries
March 25, 2024, 03:57:34 PM
markus
March 25, 2024, 02:06:41 PM
March 25, 2024, 04:43:25 AM
March 25, 2024, 02:39:40 AM
March 25, 2024, 12:47:09 AM
Alberto
March 24, 2024, 07:36:32 PM
Alberto
March 24, 2024, 07:27:24 PM
March 24, 2024, 04:25:23 AM
Alberto
March 23, 2024, 10:47:35 PM
March 23, 2024, 09:30:21 PM
Alberto
March 23, 2024, 04:34:31 PM
March 23, 2024, 03:04:25 PM
Alberto
March 23, 2024, 01:38:34 PM
March 23, 2024, 04:20:03 AM
March 23, 2024, 12:54:30 AM
March 23, 2024, 12:05:57 AM
post capacitor and diodes. Voltage values for a CW
Alberto
March 22, 2024, 11:45:03 PM
OmGigaTron
March 22, 2024, 11:30:09 PM
post Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 22, 2024, 10:20:35 PM
post Re: Where's all this voltage coming from?
March 22, 2024, 09:21:13 PM
March 22, 2024, 03:37:11 PM
post What actually kills MOSFETs?
March 22, 2024, 05:09:20 AM
March 22, 2024, 03:57:54 AM
March 22, 2024, 02:59:25 AM
March 21, 2024, 06:31:42 PM
post Re: 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 21, 2024, 03:08:01 PM
post Re: [WTS] IGBT, Ferrite, Capacitors, Tools, PSU, Industrial components and parts
March 21, 2024, 01:37:32 PM
Alberto
March 21, 2024, 11:42:07 AM
post Re: Phase Lead Questions
March 21, 2024, 04:09:14 AM
March 21, 2024, 02:15:31 AM
post My Homemade Structural Analysis X-Ray Machine
March 21, 2024, 01:35:40 AM
March 20, 2024, 10:40:00 PM
March 20, 2024, 08:03:41 PM
March 20, 2024, 07:51:57 PM
March 20, 2024, 10:39:47 AM
March 20, 2024, 04:09:59 AM
March 20, 2024, 01:13:23 AM
March 20, 2024, 12:45:16 AM
March 20, 2024, 12:30:30 AM
March 19, 2024, 11:12:24 PM
Late
March 19, 2024, 09:47:49 PM
Late
March 19, 2024, 09:44:19 PM
post Phase Lead Questions
March 19, 2024, 06:52:09 PM
March 19, 2024, 05:02:44 PM
March 19, 2024, 05:01:41 PM
March 19, 2024, 04:31:02 PM
March 19, 2024, 03:59:54 PM
March 19, 2024, 06:41:39 AM
March 19, 2024, 04:05:49 AM
OmGigaTron
March 18, 2024, 09:08:35 PM
post Re: Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 09:07:35 PM
March 18, 2024, 08:57:06 PM
March 18, 2024, 03:51:33 PM
Late
March 18, 2024, 02:59:46 PM
Late
March 18, 2024, 02:33:25 PM
post Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 11:02:12 AM
March 18, 2024, 02:36:11 AM
post Re: Best forum for vacuum tube amplifiers?
March 17, 2024, 07:42:55 PM
Michelle_
March 17, 2024, 04:15:14 PM
Michelle_
March 17, 2024, 05:05:04 AM
March 17, 2024, 04:50:51 AM
March 17, 2024, 04:45:17 AM
post 2x Panasonic Inverter Microwaves - what to salvage, dangers?
Michelle_
March 17, 2024, 04:17:51 AM
post Where's all this voltage coming from?
March 17, 2024, 01:29:32 AM
March 17, 2024, 12:33:06 AM
March 16, 2024, 08:46:20 PM
post Re: Bleeder resistor for MMC
March 16, 2024, 08:39:24 PM
March 16, 2024, 08:21:44 PM
