Author Topic: Voltage mulitplier grounding  (Read 2091 times)
« on: February 21, 2021, 08:56:33 PM »
I am getting close to the completion of my 14-stage CW voltage multiplier. I have one remaining question. Does anyone ground one side of the multiplier stack AC input? Would it serve any purpose? I am primarily going to just be drawing arcs so it will have current-limiting resistors. I plan on drawing arcs through use of a separate discharge tower that I've made. The discharge tower consists only of an aluminum toroid on top of a PVC tube. The discharge tower will be connected to one of the AC input terminals at the bottom of the CW stack.
The power source is two AC flybacks in parallel driven by a ZVS driver. I am concerned about damage to the ZVS driver and possibly to the SMPS DC power supply. It would be most convenient to not ground anything other than the SMPS.
Re: Voltage mulitplier grounding
« Reply #1 on: February 21, 2021, 10:01:10 PM »
I recommend grounding one side of the CW stack.  Even with discharges going to the other tower, there is still capacitance to ground (to space).  Voltage at the bottom of the stack will depend on the ratio of capacitance to space/ground at the top to capacitance to ground at the bottom.  Bottom capacitance will be higher, but you still may get 20-25% of top voltage at the bottom, which might damage flyback insulation.
Offline ElectroXa
« Reply #2 on: February 21, 2021, 10:18:07 PM »
Hi !
I would definitely ground the multiplier on one side of the AC input  :)
(I would ground the diode side, to avoid DC pulses in flyback secondary, to "try" reducing back emf)
I would also ground this multiplier through a small 110- 220V transformer primary used as an inductor choke, to block the AC flyback from leaking, but pass the DC, both to ground
indeed, I noticed on my multiplier that most of the AC leaked, leading to bad output.
adding this choke greatly increased the output  :D
cheers
« Reply #3 on: February 23, 2021, 10:19:46 PM »
Hi !
cheers
Does the attached schematic show the placement of the small choke that you describe?
Offline ElectroXa
« Reply #4 on: February 23, 2021, 11:34:46 PM »
I would rather put this choke to earth, and the discharge tower directly to the bottom of the multiplier, or else the choke will arc over due to voltage peak
I did that, and it works great  ;)
Edit : I left the secondary open circuit
« Last Edit: February 24, 2021, 10:20:30 PM by ElectroXa »
« Reply #5 on: February 23, 2021, 11:37:29 PM »
Thanks. I'll try it that way.
« Reply #6 on: February 24, 2021, 10:12:44 PM »
Did you short the secondary winding of the grounding transformer or leave it open?
Today at 04:57:47 AM
ethanwu0131
Today at 03:40:53 AM
post Re: First DRSSTC SKM100
Today at 01:31:17 AM
Michelle_
April 15, 2024, 11:19:52 PM
Michelle_
April 15, 2024, 11:10:19 PM
April 15, 2024, 11:04:19 PM
April 15, 2024, 11:02:05 PM
Michelle_
April 15, 2024, 10:57:59 PM
Michelle_
April 15, 2024, 10:55:46 PM
April 15, 2024, 10:37:32 PM
April 15, 2024, 10:05:00 PM
April 15, 2024, 09:28:50 PM
April 15, 2024, 09:06:42 PM
April 15, 2024, 08:46:32 PM
April 15, 2024, 08:38:39 PM
sky-guided
April 15, 2024, 08:23:40 PM
Bobakman
April 15, 2024, 06:43:23 PM
April 15, 2024, 06:29:10 AM
Michelle_
April 15, 2024, 05:21:53 AM
Michelle_
April 15, 2024, 05:15:33 AM
April 15, 2024, 04:07:54 AM
April 15, 2024, 03:49:03 AM
April 14, 2024, 09:46:30 PM
Michelle_
April 14, 2024, 07:31:00 PM
April 14, 2024, 02:26:19 PM
post Re: mg75q2ys40 IGBT
April 14, 2024, 07:20:54 AM
April 14, 2024, 07:18:20 AM
Michelle_
April 13, 2024, 06:46:40 AM
Michelle_
April 13, 2024, 04:18:42 AM
April 13, 2024, 03:24:20 AM
April 13, 2024, 03:20:46 AM
Michelle_
April 13, 2024, 03:13:22 AM
post Re: Capacitor Blowout
lbattraw
April 12, 2024, 09:14:58 PM
post mg75q2ys40 IGBT
thedark
April 12, 2024, 08:40:18 PM
April 12, 2024, 07:20:30 PM
April 12, 2024, 07:12:43 PM
ethanwu0131
April 12, 2024, 04:47:33 PM
April 12, 2024, 11:43:36 AM
April 12, 2024, 12:49:02 AM
April 12, 2024, 12:41:16 AM
April 12, 2024, 12:22:41 AM
Michelle_
April 11, 2024, 10:45:53 PM
April 11, 2024, 07:39:30 PM
April 11, 2024, 07:24:52 PM
sky-guided
April 11, 2024, 06:09:30 PM
April 11, 2024, 12:55:16 PM
April 11, 2024, 03:40:00 AM
sky-guided
April 11, 2024, 03:05:07 AM
Michelle_
April 11, 2024, 02:57:33 AM
April 11, 2024, 01:44:32 AM
Michelle_
April 11, 2024, 01:31:40 AM
OmGigaTron
April 11, 2024, 01:11:00 AM
April 11, 2024, 12:58:52 AM
Michelle_
April 11, 2024, 12:31:37 AM
April 11, 2024, 12:30:21 AM
April 10, 2024, 11:41:46 PM
April 10, 2024, 11:33:32 PM
Michelle_
April 10, 2024, 10:41:33 PM
April 10, 2024, 10:31:31 PM
Michelle_
April 10, 2024, 09:56:35 PM
unrealcrafter2
April 10, 2024, 08:59:26 PM
markus
April 10, 2024, 06:35:30 PM
April 10, 2024, 05:35:14 PM
post Drsstc voltage spike question
unrealcrafter2
April 10, 2024, 03:07:02 PM
Michelle_
April 10, 2024, 03:42:12 AM
Michelle_
April 10, 2024, 03:41:04 AM
sky-guided
April 10, 2024, 02:50:23 AM
Unrealeous
April 10, 2024, 01:32:17 AM
OmGigaTron
April 10, 2024, 01:26:29 AM
OmGigaTron
April 10, 2024, 01:18:35 AM
post Re: Big Coil Big Sparks
April 09, 2024, 07:34:19 PM
April 09, 2024, 06:14:27 PM
markus
April 09, 2024, 06:08:53 PM
markus
April 09, 2024, 05:15:19 PM
Michelle_
April 09, 2024, 05:11:04 PM
April 09, 2024, 06:32:16 AM
post DRSSTC V1 using BSM150
Unrealeous
April 09, 2024, 04:04:47 AM
April 09, 2024, 03:27:11 AM
April 09, 2024, 03:25:47 AM
OmGigaTron
April 09, 2024, 03:01:40 AM
sky-guided
April 09, 2024, 02:46:46 AM
OmGigaTron
April 08, 2024, 09:32:57 PM
OmGigaTron
April 08, 2024, 09:25:11 PM
April 08, 2024, 08:45:15 PM
OmGigaTron
April 08, 2024, 08:24:13 PM
post Big Coil Big Sparks
April 08, 2024, 04:02:48 PM
April 08, 2024, 03:45:30 AM
thedark
April 08, 2024, 03:35:32 AM
April 08, 2024, 03:12:45 AM
April 08, 2024, 03:03:26 AM
April 08, 2024, 02:24:41 AM
thedark
April 08, 2024, 01:29:53 AM
April 08, 2024, 12:55:50 AM
April 08, 2024, 12:38:52 AM
April 07, 2024, 11:56:02 PM
April 07, 2024, 07:49:29 PM
thedark
April 07, 2024, 06:28:12 PM
post First DRSSTC SKM100
April 07, 2024, 06:13:59 PM
April 07, 2024, 05:44:55 AM
April 07, 2024, 12:45:52 AM
