Author Topic: DIY MMA welder (aka stick welder)  (Read 2683 times)
Offline rikkitikkitavi
« on: July 11, 2018, 04:08:30 PM »
I have a couple of huge transformers (2kVA 20*2V) -C-core that is.
but it is the normal type, ie not possible to install magnetic shunts. I have  some large inductors (reactors)
I have humungs large rectifiers (400V 200A *16pcs) and heatsinks to match. Might even have some thyristors fitted for this...
A simple setup would be to use it as a current limited output for a MMA (stick) welder, AC or DC.
But it is difficult to adjust the output current this way.
 Also, the circuit needs to be designed with quite a large inductance in the reactor to compensate for the large open circuit voltage used for arc striking (about 50V+) compared to operating voltage on arc (about 15-25V)
One option is to use one of my even humungouser variacs (25A, ie 5kVA) to adjust output voltage and hence current draw as the welding arc voltage is not so affected by current through it.
This leads however to a less than mobile equipment. All together it packs up to 60 kg+ without casing. Or weelbarrow...
I never intended to have a inverter style portable welder but what options are there to replace the variac? How to build a variable  inductance for current limit easy way?
I have also some iron cores EI-150 size etc, and a good set of angle grinders :)
What ideas to use for increasing the voltage for arc striking but still having a low voltage output?
Re: DIY MMA welder (aka stick welder)
« Reply #1 on: July 14, 2018, 05:54:41 AM »
Sounds like an awesome project. I'm not big into welding but one thing you can try to get a higher start voltage is to have a HF start box. This would allow a few kv to jump from the stick to the work surface to get an easier start, similar to the way a tig welder initiates the arc.
A quick google search has found this:
 https://www.dudley.nu/projects/hfstart/
i had to repair the hf start in my tig welder and this is what i replaced the step-up transformer and circuitry with:
 https://www.ebay.com.au/itm/Boost-Step-up-Module-High-voltage-Generator-Converter-DC3-7v-7-4v-to-400KV-EU/222903670891?hash=item33e618186b:g:H8kAAOSwXXVavZbv
« Reply #2 on: July 16, 2018, 10:17:34 AM »
Hmm, good idea.
Using a high voltage design, low resistance reactor in series to block the voltage but the problem is that it needs to block only the HF .  This is how any normal TIG is used.
DC welding , typically electronic inverter to be able to control current properly and with inert electrodes and protection gas.
It can therefore only be used with DC, but fortunately most MMA welding is used with DC (AC demands AC welding pins) , either positive or negative to the work piece.
Will look into it further. The protection reactor might demand some design for high impendance and high voltage design at HF, but low impendance at DC.
post Re: Kaizer VTTC 1
Today at 10:23:02 AM
post Re: Capacitor in Parallel with Primary Coil
Today at 10:17:34 AM
post Capacitor in Parallel with Primary Coil
Today at 10:01:41 AM
post Re: Re-chargeable 1.5 volt lithium ion AAA batteries
Today at 04:47:35 AM
Today at 03:59:27 AM
March 28, 2024, 09:15:11 PM
post Re: capacitor and diodes. Voltage values for a CW
March 28, 2024, 01:01:12 PM
post Re: Big Coil Build Log
March 28, 2024, 05:47:34 AM
March 28, 2024, 04:45:07 AM
March 28, 2024, 04:18:27 AM
post Push Pull VTTC
janno288
March 28, 2024, 01:10:08 AM
March 27, 2024, 10:54:52 PM
March 27, 2024, 11:53:42 AM
post Re: OCD Triggering Early + Low Output
March 27, 2024, 05:14:36 AM
March 27, 2024, 04:47:48 AM
post Re: DRSSTC Questions
March 27, 2024, 04:41:59 AM
March 27, 2024, 12:04:34 AM
post Re: Super flat QCW simulation (does this look reasonable?)
toooldforthis
March 26, 2024, 11:08:14 PM
March 26, 2024, 11:07:20 PM
March 26, 2024, 10:46:29 PM
post OCD Triggering Early + Low Output
March 26, 2024, 09:03:43 PM
March 26, 2024, 08:46:59 PM
March 26, 2024, 05:02:18 PM
March 26, 2024, 03:16:03 PM
March 26, 2024, 01:41:49 PM
March 26, 2024, 04:48:22 AM
March 26, 2024, 04:16:37 AM
March 26, 2024, 04:16:24 AM
post Re: Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 26, 2024, 04:13:02 AM
March 26, 2024, 04:00:43 AM
March 26, 2024, 03:19:18 AM
March 26, 2024, 01:50:42 AM
March 25, 2024, 08:05:02 PM
March 25, 2024, 07:41:29 PM
March 25, 2024, 06:45:46 PM
March 25, 2024, 05:44:25 PM
March 25, 2024, 04:47:17 PM
March 25, 2024, 04:27:22 PM
post Re-chargeable 1.5 volt lithium ion AAA batteries
March 25, 2024, 03:57:34 PM
March 25, 2024, 02:06:41 PM
post Re: Odd MOSFET Driver Behavior
KrisPringle
March 25, 2024, 04:43:25 AM
March 25, 2024, 02:39:40 AM
KrisPringle
March 25, 2024, 12:47:09 AM
March 24, 2024, 07:36:32 PM
March 24, 2024, 07:27:24 PM
March 24, 2024, 04:25:23 AM
March 23, 2024, 10:47:35 PM
March 23, 2024, 09:30:21 PM
March 23, 2024, 04:34:31 PM
March 23, 2024, 03:04:25 PM
March 23, 2024, 01:38:34 PM
March 23, 2024, 04:20:03 AM
March 23, 2024, 12:54:30 AM
March 23, 2024, 12:05:57 AM
post capacitor and diodes. Voltage values for a CW
March 22, 2024, 11:45:03 PM
OmGigaTron
March 22, 2024, 11:30:09 PM
post Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 22, 2024, 10:20:35 PM
post Re: Where's all this voltage coming from?
March 22, 2024, 09:21:13 PM
March 22, 2024, 03:37:11 PM
post What actually kills MOSFETs?
March 22, 2024, 05:09:20 AM
March 22, 2024, 03:57:54 AM
March 22, 2024, 02:59:25 AM
March 21, 2024, 06:31:42 PM
post Re: 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 21, 2024, 03:08:01 PM
post Re: [WTS] IGBT, Ferrite, Capacitors, Tools, PSU, Industrial components and parts
March 21, 2024, 01:37:32 PM
March 21, 2024, 11:42:07 AM
post Re: Phase Lead Questions
March 21, 2024, 04:09:14 AM
March 21, 2024, 02:15:31 AM
post My Homemade Structural Analysis X-Ray Machine
Luca c.
March 21, 2024, 01:35:40 AM
March 20, 2024, 10:40:00 PM
March 20, 2024, 08:03:41 PM
March 20, 2024, 07:51:57 PM
March 20, 2024, 10:39:47 AM
March 20, 2024, 04:09:59 AM
March 20, 2024, 01:13:23 AM
Keybored
March 20, 2024, 12:45:16 AM
March 20, 2024, 12:30:30 AM
March 19, 2024, 11:12:24 PM
Late
March 19, 2024, 09:47:49 PM
Late
March 19, 2024, 09:44:19 PM
post Phase Lead Questions
March 19, 2024, 06:52:09 PM
March 19, 2024, 05:02:44 PM
March 19, 2024, 05:01:41 PM
March 19, 2024, 04:31:02 PM
March 19, 2024, 03:59:54 PM
March 19, 2024, 06:41:39 AM
March 19, 2024, 04:05:49 AM
OmGigaTron
March 18, 2024, 09:08:35 PM
post Re: Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 09:07:35 PM
March 18, 2024, 08:57:06 PM
March 18, 2024, 03:51:33 PM
Late
March 18, 2024, 02:59:46 PM
Late
March 18, 2024, 02:33:25 PM
post Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 11:02:12 AM
March 18, 2024, 02:36:11 AM
post Re: Best forum for vacuum tube amplifiers?
March 17, 2024, 07:42:55 PM
March 17, 2024, 04:15:14 PM
March 17, 2024, 05:05:04 AM
March 17, 2024, 04:50:51 AM
March 17, 2024, 04:45:17 AM
