Author Topic: Schmitt trigger schematic question  (Read 697 times)
Offline Michelle_
« on: May 14, 2024, 09:45:38 PM »
So in the attached schematic I think both of the right facing triangle symbols are part of the same Schmitt inverter, the numbers are the pins; pin 2 is connected to pin 3. Is that right?
I'm assuming both of the triangles represent a channel of the Schmitt inverter, why is one channel going into another one then out? What's going on here exactly?
This is part of Steve Ward's SSTC5 schematic (https://www.stevehv.4hv.org/SSTC5/miniSSTCfnlsch.JPG) and the only part that I am not really following. I think the purpose of this is to convert the feedback from the antenna into a square wave.
Offline Benjamin Lockhart
Re: Schmitt trigger schematic question
« Reply #1 on: May 14, 2024, 11:00:00 PM »
Yes that's correct. 2 of the inverters are being used so the signal is inverted then uninverted again. You can actually omit the inverters though because the UCC gate drive ICs have hysteresis on the inputs already. Also I prefer to use current transformer secondary base feedback for SSTCs.
Here is the schematic of my small half bridge SSTC which is similar but very simplified and works great.
The schematic shows a 12V regulator for the gate drive supply but you could use 15V as well it would probably be better. The single UCC27425 works fine as long as you're only driving a half bridge with it. For a full bridge that requires twice the drive current I would use the 2 separate UCC chips.
You can see the little coil here. It does about 6" sparks but the secondary is about 400kHz which is a bit high, putting the primary impedance higher than it would be with a lower frequency.
Offline Michelle_
« Reply #2 on: May 14, 2024, 11:12:22 PM »
Thanks that's very helpful! I wonder why he included the inverters then, just good practice?
You aren't the first person that's suggested secondary feedback over the antenna. Would you use the same kind of ferrite core as the gate driver? What kind of wire do you use to make 50 turns, magnet wire? And does the secondary just pass through the middle or does it need a loop? (sorry for all the question lol).
Thanks again for the answer by the way. I see what you mean about the single UCC as well.
« Reply #3 on: May 15, 2024, 04:58:02 AM »
The inverters don't hurt but it works fine without them, and then you don't need the 5V rail to power just one inverter IC.
Yes the same kind of ferrite as the gate drive transformer is good for feedback current transformers. I used an N87 core for both, material 77 and 75 are also good.
You can use quite a small core for a CT and the secondary base wire passes through only once, no loops. Turns are counted by the number of times the wire passes through the core.
If you have some CAT5 cable you can use an individual wire from it, or just use any hookup wire. I would avoid magnet wire though, some people had problems with it arcing to the core.
The UCC27425 is an inverting and non inverting gate driver in one, but it's only rated for 4A instead of 9A like the UCC27322/UCC37321.
The questions are all good, when you're new to electronics things that are easy for many to take for granted are not always obvious.
Offline Michelle_
« Reply #4 on: May 15, 2024, 03:32:57 PM »
Thank you this is very helpful. You're right that many things aren't always obvious when you're new, even if the overall concept is understandable!
post Wierd ud 1.3 driver with no ocd regulation?
ItsChloeUwU
Today at 10:46:39 AM
post Re: Crystal Radio germanium diode smackdown
Today at 02:46:43 AM
post Re: SCR rating for capacitor dump
September 07, 2024, 09:00:36 AM
September 07, 2024, 06:21:32 AM
September 07, 2024, 04:41:21 AM
post Re: 8kW CW DRSSTC driven by ZVS (Mazzilli) oscillator
September 07, 2024, 01:19:36 AM
post SCR rating for capacitor dump
September 07, 2024, 12:59:54 AM
September 06, 2024, 07:26:02 PM
September 06, 2024, 06:34:25 AM
post Crystal Radio germanium diode smackdown
September 05, 2024, 01:24:39 AM
post Re: Help with grounding an SSTC & safely storing PCB while coil is operating
September 04, 2024, 06:15:20 AM
September 04, 2024, 02:13:27 AM
post Help with grounding an SSTC & safely storing PCB while coil is operating
fillertext
September 03, 2024, 08:44:30 PM
post Re: FFEDBACK INDUCTION HEATER
September 03, 2024, 04:43:37 PM
radbloke
September 03, 2024, 06:08:20 AM
September 03, 2024, 05:28:46 AM
September 03, 2024, 01:34:25 AM
post Re: Questions about electronic tube oscillators
曹靖
September 02, 2024, 07:00:38 AM
September 02, 2024, 05:26:07 AM
September 01, 2024, 11:58:45 PM
September 01, 2024, 11:14:46 PM
曹靖
September 01, 2024, 08:52:49 AM
post Questions about electronic tube oscillators
曹靖
September 01, 2024, 08:51:22 AM
post Re: High pressure sodium lamp phosphorescence
September 01, 2024, 03:19:47 AM
post Re: what should i use for insulators between igbt's and heatsink?
August 31, 2024, 08:36:20 PM
post LabCoatz Staccato QCW don't work with Primary/Antenna Feedback
August 31, 2024, 08:28:14 PM
post Re: Neon sign + an -?
August 31, 2024, 05:16:06 PM
post Neon sign + an -?
kenw232
August 31, 2024, 02:31:02 PM
post Re: 2800W server power supply help
August 30, 2024, 12:56:57 PM
SunboX
August 30, 2024, 07:47:55 AM
post Re: Comments and questions on Staccato controller circuit
August 30, 2024, 05:20:42 AM
Unrealeous
August 30, 2024, 03:38:24 AM
Sando3450
August 30, 2024, 02:33:31 AM
August 30, 2024, 01:41:49 AM
August 30, 2024, 01:34:01 AM
Unrealeous
August 30, 2024, 12:23:43 AM
August 29, 2024, 10:21:08 PM
August 29, 2024, 08:54:20 PM
post Comments and questions on Staccato controller circuit
Sando3450
August 29, 2024, 05:26:43 PM
post Re: Relationship between Filament and high Volatge on a grounded Cathode Oxford Tube
PhotonLab
August 29, 2024, 09:52:48 AM
post Re: sky-guided single-circuitboard plasma toroid
sky-guided
August 29, 2024, 05:38:42 AM
post Re: designing VTTC
unrealcrafter2
August 29, 2024, 12:17:30 AM
post Re: Need feedback on this circuit (flyback driver)
August 28, 2024, 11:59:34 PM
post Re: FPS4000
buxdahu
August 28, 2024, 05:39:06 PM
August 28, 2024, 12:36:22 PM
MikeD99
August 28, 2024, 06:53:54 AM
sky-guided
August 28, 2024, 04:39:27 AM
August 28, 2024, 04:23:23 AM
post Re: Plasma Toroid
sky-guided
August 28, 2024, 03:18:13 AM
post sky-guided single-circuitboard plasma toroid
sky-guided
August 28, 2024, 03:16:44 AM
Domo
August 28, 2024, 12:44:17 AM
post Re: Building my first DRSSTC
Mathieu thm
August 27, 2024, 10:31:05 PM
August 27, 2024, 07:16:09 PM
August 27, 2024, 02:58:53 PM
drobotk
August 27, 2024, 12:06:52 PM
August 27, 2024, 12:51:27 AM
Domo
August 26, 2024, 11:01:55 PM
drobotk
August 26, 2024, 07:05:33 PM
August 26, 2024, 06:53:06 PM
post Re: Found an old coil full bridge that i did't remember i had... will it work?
ItsChloeUwU
August 26, 2024, 06:50:51 PM
August 26, 2024, 06:43:24 PM
August 26, 2024, 02:38:49 PM
PhotonLab
August 26, 2024, 01:31:13 PM
post DIY X-RAY generator made of eBay parts - New pictures
PhotonLab
August 26, 2024, 01:10:18 PM
PhotonLab
August 26, 2024, 11:45:00 AM
post Found an old coil full bridge that i did't remember i had... will it work?
ItsChloeUwU
August 26, 2024, 09:00:16 AM
sky-guided
August 26, 2024, 06:47:35 AM
post Need feedback on this circuit (flyback driver)
Domo
August 26, 2024, 05:14:48 AM
post Best Wire for Step-up Transformer?
TheMadHatter
August 26, 2024, 04:29:12 AM
post Re: Big linear power supply and some design questions
August 26, 2024, 04:14:35 AM
post Re: 7809 IC Is Getting Super Hot on the UD 2.7 rev. C
verliebt_in_neukölln17
August 26, 2024, 03:01:07 AM
post Using the functional dies of a blown IGBT brick.
August 26, 2024, 02:31:29 AM
August 25, 2024, 07:53:51 PM
August 25, 2024, 06:49:37 PM
post 2800W server power supply help
August 25, 2024, 06:29:53 PM
August 25, 2024, 04:33:05 PM
post Teardown of a 3kVA APC Smart-UPS X SMX3000
August 25, 2024, 04:30:42 PM
August 25, 2024, 01:07:43 PM
August 25, 2024, 01:06:11 PM
August 24, 2024, 11:48:04 PM
August 24, 2024, 10:55:02 PM
August 24, 2024, 09:00:23 PM
August 24, 2024, 05:38:13 PM
post Oscilloscope recommendation for SSTC?
Damaged1
August 24, 2024, 03:52:15 PM
post Re: IFF Testset teardown and analysis
August 24, 2024, 11:19:59 AM
August 24, 2024, 11:11:09 AM
August 23, 2024, 06:40:03 AM
post Re: How to wire my flyback?
August 23, 2024, 05:23:58 AM
August 23, 2024, 04:21:47 AM
kenw232
August 23, 2024, 02:39:08 AM
post 7809 IC Is Getting Super Hot on the UD 2.7 rev. C
ItsChloeUwU
August 22, 2024, 10:33:43 PM
Matyáš Suchý
August 22, 2024, 09:30:42 PM
August 22, 2024, 07:09:31 PM
kenw232
August 22, 2024, 06:58:03 PM
August 22, 2024, 06:15:03 PM
kenw232
August 22, 2024, 03:41:44 PM
August 22, 2024, 03:23:48 PM
post How to wire my flyback?
kenw232
August 22, 2024, 01:35:41 AM
post Re: Repairing a pinhole in aluminum pot
August 21, 2024, 10:20:32 PM
August 21, 2024, 07:59:53 PM
