Author Topic: Need Help with LTspice Circuit for Simulating a Spark Gap  (Read 1762 times)
Offline bobfrancis1980
« on: November 16, 2023, 10:45:35 PM »
LTspice does not have a native spark gap component so I copied the one from this video on youtube:
If I click on the Cap text in the schematic the scope shows a climb up to 3.3kV after about 14ms which makes sense since I the dielectric strength of air is defined as a constant in the schematic.
I have two problems. One, I can't figure out how to get it to show the output voltage pulse for when the spark gap breaks down.
Two, there is also only one capacitor charge up when there should be many, not sure what I am doing wrong. I have attached the LTspice schematic in a zip file, I would appreciate any help you can give me :)
Bob
P.S. I enabled visuals for all voltage related phenomenon and I can see that the 6,000V is constant for the entire time frame under the label V(n001). That probably refers to the voltage source V1 in the schematic.
« Last Edit: November 16, 2023, 11:37:05 PM by bobfrancis1980 »
Re: Need Help with LTspice Circuit for Simulating a Spark Gap
« Reply #1 on: November 17, 2023, 12:11:14 AM »
That circuit has no output.  Spark gap shorts capacitor.  If you want an output, you need to model the load of that output and connect it in series with the spark gap.
Circuit didn't simulate at all until I reversed instance name and value for Sgap.  Once I reversed those two labels, worked fine.  Produces a series of cap discharges at ~68Hz.
That model includes a slight breakdown voltage increase with time.  Is that to model electrode wear increasing gap?
What features of a spark gap are important to you?  In other words, what needs to be modeled?  Gap resistance is quite non-linear rather than fixed 100 ohms.  Small bits of noisy corona discharge likely occur before gap triggers.  If retriggered rapidly, remaining ionized air from previous trigger will reduce breakdown voltage.  A simpler model should be possible if only basic gap switching is sufficient.  Adding more effects adds complexity.
« Reply #2 on: November 17, 2023, 12:59:33 AM »
Thank you so much!!!
The Youtube image had the S1 on top and Sgap on the bottom.
I also figured out why the V(cap) was going off at 3300volts. Because that was the breakdown voltage. If I want to see ~6000volts from the charging capacitor I have to increase the breakdown voltage (and in a marx gen the electrode distance) to compensate.
The youtube author had two simulations for the spark gap, one that assumed no growth rate and one that did. I will be using compressed air from an air tank so I can probably go ahead with the no growth rate circuit.
Now I am going to turn the circuit into a component and use it in the marx gen circuit I made.
Thanks again, you saved my bacon :)
Bob
« Reply #3 on: November 17, 2023, 05:52:48 AM »
I am stuck again :(
I am not seeing the voltage rise times when I run the 2 stage marx simulation while attempting to use my componentified Spark Gap.
I am just trying to get the basic marx circuit working, then make it 20 stages and play with the resistor and capacitor values to figure out my design.
Any help you can offer would be greatly appreciated  :P
Bob
« Last Edit: November 17, 2023, 05:55:03 AM by bobfrancis1980 »
« Reply #4 on: November 17, 2023, 07:34:33 PM »
Spark gap circuit still has values referenced to ground, not all floating.
For Marx simulation, it would be simpler to use plain switches.  Wire all controls to a common pulsed voltage source.  Set voltage source for say 100us pulses every 10ms or whatever fire rate you need.  Then adjust charging circuit to get desired voltage at firing time.  The important part of Marx simulation will be modeling wiring inductance and especially parasitic capacitance between stages and to ground.
post Wierd ud 1.3 driver with no ocd regulation?
ItsChloeUwU
Today at 10:46:39 AM
post Re: Crystal Radio germanium diode smackdown
Today at 02:46:43 AM
post Re: SCR rating for capacitor dump
September 07, 2024, 09:00:36 AM
September 07, 2024, 06:21:32 AM
September 07, 2024, 04:41:21 AM
post Re: 8kW CW DRSSTC driven by ZVS (Mazzilli) oscillator
September 07, 2024, 01:19:36 AM
post SCR rating for capacitor dump
September 07, 2024, 12:59:54 AM
September 06, 2024, 07:26:02 PM
September 06, 2024, 06:34:25 AM
post Crystal Radio germanium diode smackdown
September 05, 2024, 01:24:39 AM
post Re: Help with grounding an SSTC & safely storing PCB while coil is operating
September 04, 2024, 06:15:20 AM
September 04, 2024, 02:13:27 AM
post Help with grounding an SSTC & safely storing PCB while coil is operating
fillertext
September 03, 2024, 08:44:30 PM
post Re: FFEDBACK INDUCTION HEATER
September 03, 2024, 04:43:37 PM
radbloke
September 03, 2024, 06:08:20 AM
September 03, 2024, 05:28:46 AM
September 03, 2024, 01:34:25 AM
post Re: Questions about electronic tube oscillators
曹靖
September 02, 2024, 07:00:38 AM
September 02, 2024, 05:26:07 AM
September 01, 2024, 11:58:45 PM
September 01, 2024, 11:14:46 PM
曹靖
September 01, 2024, 08:52:49 AM
post Questions about electronic tube oscillators
曹靖
September 01, 2024, 08:51:22 AM
post Re: High pressure sodium lamp phosphorescence
September 01, 2024, 03:19:47 AM
post Re: what should i use for insulators between igbt's and heatsink?
August 31, 2024, 08:36:20 PM
post LabCoatz Staccato QCW don't work with Primary/Antenna Feedback
August 31, 2024, 08:28:14 PM
post Re: Neon sign + an -?
August 31, 2024, 05:16:06 PM
post Neon sign + an -?
kenw232
August 31, 2024, 02:31:02 PM
post Re: 2800W server power supply help
August 30, 2024, 12:56:57 PM
SunboX
August 30, 2024, 07:47:55 AM
post Re: Comments and questions on Staccato controller circuit
August 30, 2024, 05:20:42 AM
Unrealeous
August 30, 2024, 03:38:24 AM
Sando3450
August 30, 2024, 02:33:31 AM
August 30, 2024, 01:41:49 AM
August 30, 2024, 01:34:01 AM
Unrealeous
August 30, 2024, 12:23:43 AM
August 29, 2024, 10:21:08 PM
August 29, 2024, 08:54:20 PM
post Comments and questions on Staccato controller circuit
Sando3450
August 29, 2024, 05:26:43 PM
post Re: Relationship between Filament and high Volatge on a grounded Cathode Oxford Tube
PhotonLab
August 29, 2024, 09:52:48 AM
post Re: sky-guided single-circuitboard plasma toroid
sky-guided
August 29, 2024, 05:38:42 AM
post Re: designing VTTC
unrealcrafter2
August 29, 2024, 12:17:30 AM
post Re: Need feedback on this circuit (flyback driver)
August 28, 2024, 11:59:34 PM
post Re: FPS4000
buxdahu
August 28, 2024, 05:39:06 PM
August 28, 2024, 12:36:22 PM
MikeD99
August 28, 2024, 06:53:54 AM
sky-guided
August 28, 2024, 04:39:27 AM
August 28, 2024, 04:23:23 AM
post Re: Plasma Toroid
sky-guided
August 28, 2024, 03:18:13 AM
post sky-guided single-circuitboard plasma toroid
sky-guided
August 28, 2024, 03:16:44 AM
Domo
August 28, 2024, 12:44:17 AM
post Re: Building my first DRSSTC
Mathieu thm
August 27, 2024, 10:31:05 PM
August 27, 2024, 07:16:09 PM
August 27, 2024, 02:58:53 PM
drobotk
August 27, 2024, 12:06:52 PM
August 27, 2024, 12:51:27 AM
Domo
August 26, 2024, 11:01:55 PM
drobotk
August 26, 2024, 07:05:33 PM
August 26, 2024, 06:53:06 PM
post Re: Found an old coil full bridge that i did't remember i had... will it work?
ItsChloeUwU
August 26, 2024, 06:50:51 PM
August 26, 2024, 06:43:24 PM
August 26, 2024, 02:38:49 PM
PhotonLab
August 26, 2024, 01:31:13 PM
post DIY X-RAY generator made of eBay parts - New pictures
PhotonLab
August 26, 2024, 01:10:18 PM
PhotonLab
August 26, 2024, 11:45:00 AM
post Found an old coil full bridge that i did't remember i had... will it work?
ItsChloeUwU
August 26, 2024, 09:00:16 AM
sky-guided
August 26, 2024, 06:47:35 AM
post Need feedback on this circuit (flyback driver)
Domo
August 26, 2024, 05:14:48 AM
post Best Wire for Step-up Transformer?
TheMadHatter
August 26, 2024, 04:29:12 AM
post Re: Big linear power supply and some design questions
August 26, 2024, 04:14:35 AM
post Re: 7809 IC Is Getting Super Hot on the UD 2.7 rev. C
verliebt_in_neukölln17
August 26, 2024, 03:01:07 AM
post Using the functional dies of a blown IGBT brick.
August 26, 2024, 02:31:29 AM
August 25, 2024, 07:53:51 PM
August 25, 2024, 06:49:37 PM
post 2800W server power supply help
August 25, 2024, 06:29:53 PM
August 25, 2024, 04:33:05 PM
post Teardown of a 3kVA APC Smart-UPS X SMX3000
August 25, 2024, 04:30:42 PM
August 25, 2024, 01:07:43 PM
August 25, 2024, 01:06:11 PM
August 24, 2024, 11:48:04 PM
August 24, 2024, 10:55:02 PM
August 24, 2024, 09:00:23 PM
August 24, 2024, 05:38:13 PM
post Oscilloscope recommendation for SSTC?
Damaged1
August 24, 2024, 03:52:15 PM
post Re: IFF Testset teardown and analysis
August 24, 2024, 11:19:59 AM
August 24, 2024, 11:11:09 AM
August 23, 2024, 06:40:03 AM
post Re: How to wire my flyback?
August 23, 2024, 05:23:58 AM
August 23, 2024, 04:21:47 AM
kenw232
August 23, 2024, 02:39:08 AM
post 7809 IC Is Getting Super Hot on the UD 2.7 rev. C
ItsChloeUwU
August 22, 2024, 10:33:43 PM
Matyáš Suchý
August 22, 2024, 09:30:42 PM
August 22, 2024, 07:09:31 PM
kenw232
August 22, 2024, 06:58:03 PM
August 22, 2024, 06:15:03 PM
kenw232
August 22, 2024, 03:41:44 PM
August 22, 2024, 03:23:48 PM
post How to wire my flyback?
kenw232
August 22, 2024, 01:35:41 AM
post Re: Repairing a pinhole in aluminum pot
August 21, 2024, 10:20:32 PM
August 21, 2024, 07:59:53 PM
