Author Topic: More induction heating  (Read 14541 times)
Re: More induction heating
« Reply #40 on: March 10, 2023, 03:51:40 AM »
I suggest that you visit a website such as this one:
https://learnabout-electronics.org/PSU/psu12.php
Or:
https://www.physics.unlv.edu/~bill/PHYS483/power_supply_info.pdf
 or simply google:
"linear power supply design"   -since that appears to be what you want to use.
Offline Alberto
« Reply #41 on: March 10, 2023, 09:48:10 AM »
Or:
 or simply google:
Thank you!
EDIT: I have read the links. They explain very well how works the filter capacitors in a power supply. I have a idea about that. My problem is that I don´t know how much ripple is admisible to power the heater. I mean, of course the bigger the capacity the better but I don´t know how much it would be a acceptable value
« Last Edit: March 10, 2023, 02:47:24 PM by Alberto »
« Reply #42 on: March 10, 2023, 08:38:36 PM »
For your induction heating application with separate gate supply, no filter capacitor is probably best choice.  Induction coil current will go up and down at 2x line frequency.  That is the way induction cook-tops work.  I had a 1kW ZVS oscillator that ran that way too, with rectified line voltage and no filter cap.
Offline Alberto
« Reply #43 on: March 10, 2023, 09:42:29 PM »
Thank you
Nice!! So I'll rewound the secondary of a MOT untill I get 35VDC after rectifying
« Reply #44 on: March 11, 2023, 12:13:11 AM »
Just thought of one caution if using no filter caps on rectified transformer output:  Switch power on secondary side of transformer, either before or after rectifier.  If the transformer primary is switched off, transformer inductance will create a voltage spike.  MOTs are particularly bad in that respect, running large magnetization current, so producing large spikes when primary is disconnected.
If primary will be switched off with secondary connected, either a TVS diode or filter caps are needed to absorb the transient energy.  (The FETs may be able to handle that transient energy themselves.  However, if they are already running hot due to high load, then they have less avalanche energy capability.)
Offline Alberto
« Reply #45 on: March 12, 2023, 09:04:53 AM »
Thank you!
And another (probably) silly question. I said 15v to the gates because the guy in the video uses that, and you suggest using 60ohm resistors. But I have a lot 12V and 5v powers supply. Could I use one of these? In that case, wich resistor I should use?
And about the capacitors for the oscillator I have read that i should use WIMA MKP, but I have KEMET MKP X2 SH. Is there s problem with that?
And last, could anyone recommend me a book about learning basic electronics? I know ohm's law, the behavior of pasive components and that things.  But I'd like to learn more for example to stop asking these questions haha
« Last Edit: March 12, 2023, 11:29:14 AM by Alberto »
« Reply #46 on: March 12, 2023, 09:46:24 PM »
If you have three 5v supplies, wire them in series for 15V.  That presumes they are not grounded (have 2-prong plugs, not 3-prong).
12V might be OK, not less.  Trade-offs of lower (or higher) gate supply are a bit complex.  If 12V, reduce gate resistance as much as possible while remaining under 2W, so around 40 ohms.
WIMA vs KEMET doesn't matter.  Different MKP capacitors are designed for different purposes.  You need high AC current capability.  X2 caps aren't great in that respect (usually).  You could try them with good fan cooling.  If some overheat and fail, then buy replacements.  Look at RMS current rating in spec's.
I'm not much help here, having learned electronics many decades ago.  I do recommend trying things in analog simulation.  There are some fairly simple on-line simulators, and simulation programs free to download and use.  My favorite is LTSpice.  Probably not the easiest for novice learning, however.  There is good online forum help for LTSpice.  Whatever simulator you try, start very simple.  Verify Ohm's law with a voltage source and resistor, etc.
Offline Alberto
« Reply #47 on: March 12, 2023, 10:39:41 PM »
Thank you!!
Ok, since it will be difficult to me find a problem if it appears, I´ll stick with the exact components to get the best result. I don´t have 15V supply and you say 12V is not sure to be OK, but I have a lot 19V laptop power supply. Can I use it with a bigger resistor? wich resistance?
Thank you, I think I´ll get banned from this forum for making this questions
« Reply #48 on: March 12, 2023, 11:43:38 PM »
You can take 19 V laptop PS and reduce voltage to 15 V with a single-IC voltage regulator.  Should begin with an estimate of maximum current requirement.
« Reply #49 on: March 13, 2023, 12:21:01 AM »
19V laptop supplies are convenient, and free when I collect them from recycling bins at work.  I use them for many projects.
Yes, I think 19V would be a fine choice for your ZVS gate supply.  100 ohm resistors will be just under 2W each.  One more detail:  At 19V and 100 ohms, power of 12V zener diodes in circuit will be about 0.42W.  Make sure zeners you use are rated for that with some margin, at least 0.5W rating.
Don't expect you will be banned, though you are correct that this forum is generally for users farther along in learning electronics.
I do hope someone else answers your previous request for beginner book recommendations.  Good luck with your project and with learning.
« Last Edit: March 13, 2023, 04:53:02 PM by davekni »
« Reply #50 on: March 13, 2023, 06:15:51 AM »
Re: "book to learn electronics":
I too, learned electronics a long time ago, starting in about 1948.
If I were starting out today, I think I'd get one of those "learn electronics kits"
Here's one example:
https://www.sciplus.com/electronic-playground-48491-p?
Offline Alberto
« Reply #51 on: March 13, 2023, 09:08:46 AM »
Thank to all of you!
I´ll use 3w 100ohm resistors to be safe (that is what I have) and the zener are 3w.
And this is why I´m making the triodes, for me that is the best way to learn.
Offline romy
« Reply #52 on: March 14, 2023, 03:00:36 PM »
yes, learning electronics:
i made several attempts in my life. first was before internet. lacking a systematic education in the field i always got stuck pretty fast. last effort was one month ago, concentrating on power supplies and resonnant cirquits. i started with maxwells equations and prepared a list of symbols (two full pages). by the time i got acquainted with messrs. laplace, naba, poynting, shin et al, their complex conjugates and dyadic products i was done. now the little "j"-devil is haunting me at night.
zct, sct, zvt, ccm, llc, svt, zvs, svt, zcvt, lcc, zcs, elt, sp, dab, pol, pr, vfc, hhc, nr, vco:  abbreviations dont make it any easier.
there is a lot of material on youtube. today im trying to wrap my mind around this:
« Last Edit: March 14, 2023, 04:42:00 PM by romy »
Offline Alberto
« Reply #53 on: March 14, 2023, 10:28:05 PM »
In my case is because I like, like learning english, I´m doing to travel and learn this things better, so in that case is easier
« Reply #54 on: March 14, 2023, 11:00:41 PM »
Not much of a riddle in that video by Professor S B-Y.
In that last picture, as current increased from unsaturated to saturated,
the incremental L value went down but the stored energy still went up.
We can't figure stored energy from (I^2 * L/2).
We can get it by integrating the input power during the whole inductor-charging ramp: I * E dt.
With optional refinement of subtracting the power loss due to wire resistance: I^2 R dt.
Kind of like figuring the energy to charge a MOSFET gate, when charge is not proportional to voltage.
Offline romy
« Reply #55 on: March 15, 2023, 03:53:31 PM »
its his method of teaching. see subsequent vid.
Offline romy
« Reply #56 on: March 15, 2023, 03:56:29 PM »
Or:
 or simply google:
Thank you!
i have been told 3% ripple by the seller on the 1800w heater.
Offline Alberto
« Reply #57 on: March 16, 2023, 12:17:32 AM »
Thank you for your answer.
Ok, it´s done
The 2 "loop" wires are conecting all the capacitors in parallel
A and B are the wires coming from the drains and fast diodes. My concern is, Does it matter in what point of the capacitor bank I connect A and B?
C goes to the 2 chokes and the induction coil
Thank you
« Reply #58 on: March 16, 2023, 01:30:31 AM »
Your connection of work coil to capacitor bank at point C is not ideal.
The closest capacitor will get largest share of current, and the 20th capacitor will get smallest share of current.  It really matters, if you compare inductance and high-frequency resistance of the 20-capacitor bus wire pair to inductance of the work coil.
The connection of driver, at A and B, is much less important because the current is much smaller.
There's a good diagram of this issue in instructable by imsmooth.   Or just scroll down on this page:
http://inductionheatertutorial.com/inductionheater/induction3.html
Can you build the 20-capacitor bank cordwood style (look it up) with two sheets of copper clad perf board?
« Reply #59 on: March 16, 2023, 05:32:24 AM »
I agree that it is much less important.  However, I have experienced issues if wires to drains are too long.  Can end up oscillating at a much higher frequency than intended, one defined by drain capacitance and wire inductance.  Not likely an issue for you unless wires are longer than in the images shown.
Also agree that current between coil and capacitors needs to be better balanced.  Even just adding wires between the two banks at the coil end would help greatly.  Copper (heavy foil or sheet) for cap to coil connections is even better.
post Wierd ud 1.3 driver with no ocd regulation?
ItsChloeUwU
Today at 10:46:39 AM
post Re: Crystal Radio germanium diode smackdown
Today at 02:46:43 AM
post Re: SCR rating for capacitor dump
September 07, 2024, 09:00:36 AM
September 07, 2024, 06:21:32 AM
September 07, 2024, 04:41:21 AM
post Re: 8kW CW DRSSTC driven by ZVS (Mazzilli) oscillator
September 07, 2024, 01:19:36 AM
post SCR rating for capacitor dump
September 07, 2024, 12:59:54 AM
September 06, 2024, 07:26:02 PM
September 06, 2024, 06:34:25 AM
post Crystal Radio germanium diode smackdown
September 05, 2024, 01:24:39 AM
post Re: Help with grounding an SSTC & safely storing PCB while coil is operating
September 04, 2024, 06:15:20 AM
September 04, 2024, 02:13:27 AM
post Help with grounding an SSTC & safely storing PCB while coil is operating
fillertext
September 03, 2024, 08:44:30 PM
post Re: FFEDBACK INDUCTION HEATER
September 03, 2024, 04:43:37 PM
radbloke
September 03, 2024, 06:08:20 AM
September 03, 2024, 05:28:46 AM
September 03, 2024, 01:34:25 AM
post Re: Questions about electronic tube oscillators
曹靖
September 02, 2024, 07:00:38 AM
September 02, 2024, 05:26:07 AM
September 01, 2024, 11:58:45 PM
September 01, 2024, 11:14:46 PM
曹靖
September 01, 2024, 08:52:49 AM
post Questions about electronic tube oscillators
曹靖
September 01, 2024, 08:51:22 AM
post Re: High pressure sodium lamp phosphorescence
September 01, 2024, 03:19:47 AM
post Re: what should i use for insulators between igbt's and heatsink?
August 31, 2024, 08:36:20 PM
post LabCoatz Staccato QCW don't work with Primary/Antenna Feedback
August 31, 2024, 08:28:14 PM
post Re: Neon sign + an -?
August 31, 2024, 05:16:06 PM
post Neon sign + an -?
kenw232
August 31, 2024, 02:31:02 PM
post Re: 2800W server power supply help
August 30, 2024, 12:56:57 PM
SunboX
August 30, 2024, 07:47:55 AM
post Re: Comments and questions on Staccato controller circuit
August 30, 2024, 05:20:42 AM
Unrealeous
August 30, 2024, 03:38:24 AM
Sando3450
August 30, 2024, 02:33:31 AM
August 30, 2024, 01:41:49 AM
August 30, 2024, 01:34:01 AM
Unrealeous
August 30, 2024, 12:23:43 AM
August 29, 2024, 10:21:08 PM
August 29, 2024, 08:54:20 PM
post Comments and questions on Staccato controller circuit
Sando3450
August 29, 2024, 05:26:43 PM
post Re: Relationship between Filament and high Volatge on a grounded Cathode Oxford Tube
PhotonLab
August 29, 2024, 09:52:48 AM
post Re: sky-guided single-circuitboard plasma toroid
sky-guided
August 29, 2024, 05:38:42 AM
post Re: designing VTTC
unrealcrafter2
August 29, 2024, 12:17:30 AM
post Re: Need feedback on this circuit (flyback driver)
August 28, 2024, 11:59:34 PM
post Re: FPS4000
buxdahu
August 28, 2024, 05:39:06 PM
August 28, 2024, 12:36:22 PM
MikeD99
August 28, 2024, 06:53:54 AM
sky-guided
August 28, 2024, 04:39:27 AM
August 28, 2024, 04:23:23 AM
post Re: Plasma Toroid
sky-guided
August 28, 2024, 03:18:13 AM
post sky-guided single-circuitboard plasma toroid
sky-guided
August 28, 2024, 03:16:44 AM
Domo
August 28, 2024, 12:44:17 AM
post Re: Building my first DRSSTC
Mathieu thm
August 27, 2024, 10:31:05 PM
August 27, 2024, 07:16:09 PM
August 27, 2024, 02:58:53 PM
drobotk
August 27, 2024, 12:06:52 PM
August 27, 2024, 12:51:27 AM
Domo
August 26, 2024, 11:01:55 PM
drobotk
August 26, 2024, 07:05:33 PM
August 26, 2024, 06:53:06 PM
post Re: Found an old coil full bridge that i did't remember i had... will it work?
ItsChloeUwU
August 26, 2024, 06:50:51 PM
August 26, 2024, 06:43:24 PM
August 26, 2024, 02:38:49 PM
PhotonLab
August 26, 2024, 01:31:13 PM
post DIY X-RAY generator made of eBay parts - New pictures
PhotonLab
August 26, 2024, 01:10:18 PM
PhotonLab
August 26, 2024, 11:45:00 AM
post Found an old coil full bridge that i did't remember i had... will it work?
ItsChloeUwU
August 26, 2024, 09:00:16 AM
sky-guided
August 26, 2024, 06:47:35 AM
post Need feedback on this circuit (flyback driver)
Domo
August 26, 2024, 05:14:48 AM
post Best Wire for Step-up Transformer?
TheMadHatter
August 26, 2024, 04:29:12 AM
post Re: Big linear power supply and some design questions
August 26, 2024, 04:14:35 AM
post Re: 7809 IC Is Getting Super Hot on the UD 2.7 rev. C
verliebt_in_neukölln17
August 26, 2024, 03:01:07 AM
post Using the functional dies of a blown IGBT brick.
August 26, 2024, 02:31:29 AM
August 25, 2024, 07:53:51 PM
August 25, 2024, 06:49:37 PM
post 2800W server power supply help
August 25, 2024, 06:29:53 PM
August 25, 2024, 04:33:05 PM
post Teardown of a 3kVA APC Smart-UPS X SMX3000
August 25, 2024, 04:30:42 PM
August 25, 2024, 01:07:43 PM
August 25, 2024, 01:06:11 PM
August 24, 2024, 11:48:04 PM
August 24, 2024, 10:55:02 PM
August 24, 2024, 09:00:23 PM
August 24, 2024, 05:38:13 PM
post Oscilloscope recommendation for SSTC?
Damaged1
August 24, 2024, 03:52:15 PM
post Re: IFF Testset teardown and analysis
August 24, 2024, 11:19:59 AM
August 24, 2024, 11:11:09 AM
August 23, 2024, 06:40:03 AM
post Re: How to wire my flyback?
August 23, 2024, 05:23:58 AM
August 23, 2024, 04:21:47 AM
kenw232
August 23, 2024, 02:39:08 AM
post 7809 IC Is Getting Super Hot on the UD 2.7 rev. C
ItsChloeUwU
August 22, 2024, 10:33:43 PM
Matyáš Suchý
August 22, 2024, 09:30:42 PM
August 22, 2024, 07:09:31 PM
kenw232
August 22, 2024, 06:58:03 PM
August 22, 2024, 06:15:03 PM
kenw232
August 22, 2024, 03:41:44 PM
August 22, 2024, 03:23:48 PM
post How to wire my flyback?
kenw232
August 22, 2024, 01:35:41 AM
post Re: Repairing a pinhole in aluminum pot
August 21, 2024, 10:20:32 PM
August 21, 2024, 07:59:53 PM
