Author Topic: My 160 (?)mm sstc  (Read 234 times)
My 160 (?)mm sstc
« on: July 26, 2017, 11:02:43 AM »
So I think it's time for my next coil... I'll be using the same basic driver everyone uses (22/21 pair) except the one thing I'm not sure of is to buffer the interrupter signal through the same 74hc14 as the antenna buffer or use a seperate chip to reduce on interference (this is an absolute guess)
My local hardware shop sells 150mm PVC pipe (I'm guessing around 160mm od) so I'm thinking about 450mm wind length using 30awg wire I have laying around, with this I should get about 1500 turns (the wire measures 0.3mm).
For the inverter I was going to go with a 40n60 fullbridge as I've ordered some igbt from AliExpress and am keen to see what they go like.
This coil is really just to use up the existing wire I have before I order more..... Any criticism is welcomed.
Re: My 160 (?)mm sstc
« Reply #1 on: July 27, 2017, 08:00:35 AM »
It will be a fairly large SSTC and you should at-least use a full-bridge and as high DC bus voltage as you can, in order to get long sparks.
SSTCs does not scale well in matter of spark length output when building them bigger, unless you make a inverter that can work into a few turns / low impedance primary coil.
If you are feeling adventurous, you could try to make a internal primary coil, I always wanted to try that, but never did :o
« Reply #2 on: July 27, 2017, 09:28:36 AM »
I was thinking with the DS bus supply voltage to make a simple inverter capable of 500v but would be current limited, and just run low bps.
I'm interested in a internal primary coil now! I can't seem to find any examples though.
« Reply #3 on: July 27, 2017, 01:51:32 PM »
I think there is some E-field issues which could result in flash overs between secondary and primary, but in a SSTC where the peak current/voltage is lower, it might not be an issue. The interesting part of a internal is that you can have a lower impedance with the same turns, compared to it being on the outside.
Offline ldm314
« Reply #4 on: July 27, 2017, 10:56:37 PM »
I am also considering running my primary on the inside. Biggest drawback I see is the difficulty tuning the primary.
« Reply #5 on: July 28, 2017, 12:05:41 AM »
A SSTC does not have a resonant primary circuit, so there is no need for tapping points on the primary coil. So that is not a problem.
« Reply #6 on: July 29, 2017, 01:26:30 PM »
Ok,
So got back from holiday on Friday and got started on the coil! I wound the secondary but roughly got 1230 turns..... I was hoping for 1500.... Tomorrow I'll get a few coats polyurethane on it.
« Last Edit: July 29, 2017, 02:32:09 PM by oneKone »
Online futurist
« Reply #7 on: July 29, 2017, 03:08:43 PM »
Looks great, how did you count turns?
« Reply #8 on: July 29, 2017, 05:11:06 PM »
i divide the wind length by the diameter of the wire. at the time i couldn't find the tape measure so the reading wasn't as accurate as i'd hoped.
Online futurist
« Reply #9 on: July 29, 2017, 05:26:56 PM »
I started making simple turns counter with STM32 and hall sensor, but somehow managed to fry the sensor
Just ordered few more sensors
Offline ldm314
« Reply #10 on: July 29, 2017, 09:12:26 PM »
Ok,
Looks great, just winding by hand it looks like?
« Reply #11 on: July 30, 2017, 05:07:22 PM »
Looks good oneKone :)
Most of the time its actually quite easy to control just by hand, and takes much less time than making a rig, a rig is however needed for the drying varnish, atleast for a good even result. It was only my large DRSSTC3 where we built a rig for winding.
« Reply #12 on: July 31, 2017, 04:45:50 PM »
I built a winding jig for both my coils. Building the jig took longer than winding, but I'm glad I did - as Mads mentioned, you also should have it for evenly coating the winding afterwards.
As for counting turns, I did such a poor job on centering the coil in my jig that the run-out was big enough (5mm or so) to activate a microswitch I placed underneath it once per revolution. A hacked together microcontroller program counted the turns (=1920 for my big coil), and I then used the resulting turns-per-length number to work out how many my next coil (using the same wire) had without bothering with the micro again. All very rough and ready but did the job well enough i think.
Offline ldm314
« Reply #13 on: July 31, 2017, 11:25:53 PM »
That's a great idea on having something to do turn counting. I'm practicing with some recovered wire paper towel tubes. When I go to make a serious one, definitely will build up a jig.
Online futurist
« Reply #14 on: August 02, 2017, 06:21:29 PM »
This is what I came up with, couldn't be any simpler
For speed control I use 555 PWM from ebay
« Reply #15 on: August 10, 2017, 08:43:27 AM »
So after being busy working and fixing my car's! Damn harmonic balancer! I can finally give the Tesla coil some attention.
I've made the controller which is an updated version of the last, I think one more revision and they should be flawless! (To me anyways)
Hopefully this weekend I can make some real progress.
« Reply #16 on: August 14, 2017, 03:22:26 AM »
It's amazing how sometimes the most idiotic ideas outweigh logic. I connected a half bridge of the ixgn60n60 with no tvs or heatsinks just to see if the coil would run. After I got excited it overheated and a module died.
So lesson learnt..... Don't get too excited,  follow the basic rules... So just waiting on some more igbts now, I guess now I have time to make the Steve wards burst mode interrupter.
« Reply #17 on: August 14, 2017, 08:50:22 AM »
Haha, yeah no heat sinks are not a great idea when it comes to high current pulse work, that really needs something to take those peak temperature rises to a better average level.
Reminds of once I made a SSTC into a DRSSTC without feedback driver :o I just measured the frequency with a counter and adjusted a signal generator manually to drive the bridge, needless to say, it died from hard switching :)
post Re: Futurist's DRSSTC1
Today at 12:23:57 PM
Today at 08:44:02 AM
post Re: Boxing up the Loneoceans' midi2 controller
Today at 07:12:15 AM
Today at 05:44:31 AM
August 21, 2017, 03:39:14 PM
sparkydownunder
August 21, 2017, 12:58:30 PM
August 20, 2017, 09:32:01 PM
August 20, 2017, 08:06:42 PM
August 20, 2017, 07:50:59 PM
August 20, 2017, 09:07:33 AM
August 18, 2017, 09:32:26 PM
afk
August 18, 2017, 03:56:05 PM
ldm314
August 18, 2017, 06:14:26 AM
ldm314
August 17, 2017, 01:50:34 PM
August 17, 2017, 10:41:25 AM
August 16, 2017, 01:36:24 PM
August 16, 2017, 12:32:48 PM
ldm314
August 16, 2017, 07:52:09 AM
ldm314
August 15, 2017, 10:55:39 PM
August 15, 2017, 09:45:22 AM
August 15, 2017, 09:22:03 AM
August 15, 2017, 08:55:51 AM
August 15, 2017, 08:52:53 AM
August 15, 2017, 08:48:26 AM
August 14, 2017, 05:13:46 PM
post Re: Tardief's DRSSTC
August 14, 2017, 01:52:43 PM
ldm314
August 14, 2017, 11:35:30 AM
Tardief
August 14, 2017, 11:09:23 AM
August 14, 2017, 10:42:42 AM
August 14, 2017, 09:00:33 AM
post Re: My 160 (?)mm sstc
August 13, 2017, 01:47:51 PM
August 12, 2017, 11:19:16 PM
Tardief
August 12, 2017, 10:06:07 PM
August 11, 2017, 12:46:33 PM
ldm314
August 11, 2017, 09:54:15 AM
August 10, 2017, 01:41:47 PM
August 10, 2017, 12:44:12 PM
August 09, 2017, 10:11:42 AM
August 09, 2017, 09:08:45 AM
Bartos
August 09, 2017, 08:10:12 AM
TCWilliamson
August 08, 2017, 07:52:36 PM
RickyTerzis
August 08, 2017, 06:47:38 PM
August 08, 2017, 04:41:52 PM
August 08, 2017, 12:30:40 PM
August 08, 2017, 09:52:06 AM
August 08, 2017, 09:36:54 AM
August 08, 2017, 08:27:00 AM
