Author Topic: WTS [DK]: NWL W00238 Capacitor 815 KVAR 1200 VAC 680 Ampere @ 10 kHz  (Read 558 times)
http://www.ebay.co.uk/itm/232306106373
Open to offers and can provide shipping costs on demand, else first see the shipping costs in the ebay link.
815 KVAR
1200 VAC
680 Ampere @ 10 kHz
Taps 1-2 @ 2.5 uF
Taps 3-6 @ 1.0 uF
weight 16 kg
Total capacitance with all taps in parallel 9 uF
Case is live!
« Last Edit: August 15, 2017, 08:53:43 AM by Mads Barnkob »
Dropped price 20%, additional savings available to forum members :)
Offline Max
Re: WTS [DK]: NWL W00238 Capacitor 815 KVAR 1200 VAC 680 Ampere @ 10 kHz
« Reply #2 on: November 30, 2017, 01:42:38 PM »
Hello Mads,
I‘d like to know if shipping to Luxembourg is as much as shipping to Germany. And are the „additional savings“ still available?  :)
Thank you!
« Reply #3 on: November 30, 2017, 02:28:47 PM »
Hello Mads,
Thank you!
Shipping to Luxemborg is the same as to Germany, 52 Euro, for a XL package with GLS just under 20kg
I will take off 10% of the price for forum members :)
« Reply #4 on: December 01, 2017, 01:00:44 PM »
FWIW, that's almost pennies on the dollar.  Those things go new for kilobucks!
I'd jump on it (even with shipping to here), if only I needed one. :P
Offline Max
« Reply #5 on: December 01, 2017, 01:35:40 PM »
I know that, but if you don‘t really need it, it‘s still a lot of money with shipping. However, because it‘s an excellent offer and knowing that I‘ll use it one day for sure, I couldn‘t resist ;)
One question: are the capacities of the tabs all against the case?
« Reply #6 on: December 01, 2017, 02:20:44 PM »
I only checked from terminals to water inlet connections, as these are where the brackets connect to. Case is mentioned to be live, but I am not sure which side of the capacitor that is, or it is undetermined due to capacitive coupling?
Ill check this weekend.
« Reply #7 on: December 05, 2017, 11:55:58 AM »
Hmm, that style is usually case = common.  Is there continuity between water pipes and case?
« Reply #8 on: December 05, 2017, 06:40:33 PM »
I tried measuring on two different sizes of these that I have, both on unused units and refurbished.
There is no connection between case and water connections, the water connections are also sitting on ceramic insulators.
Offline Max
« Reply #9 on: December 06, 2017, 11:04:26 AM »
Good morning,
Thank you for measuring! I tried to find datasheet, which should mention what „case live“ means exactly, but apparently NWL doesn‘t produce this unit anymore.
« Reply #10 on: December 06, 2017, 12:30:21 PM »
Good morning,
I also tried to locate a datasheet and writing them did not give any results.
They are custom made units and I think that I just found a datasheet for a similar capacitor and trusted it to be very much identical to that.
I can not find a datasheet for NWL on my NAS, so it does not seem like I saved it.
I looked at the WFC series capacitors: http://www.nwl.com/products/capacitors/wfc-series/
And from their datasheet they can actually both be live or dead, depending on design: http://www.nwl.com/wp-content/uploads/pdf/nwl-wfc-series-capacitors-product-data.pdf
Offline Max
« Reply #11 on: December 06, 2017, 01:56:20 PM »
You found the same documents and conclusions as I did ;)
However I wouldn‘t call that document a datasheet... It‘s nothing more than a overview of the WFC series.
Thanks for looking anyway!
Offline Max
« Reply #12 on: December 15, 2017, 07:46:42 AM »
Good morning,
Finally got my capacitor.
Everything seems fine - although it is apparently a bit older than I thought. Thus is of course no problem when it’s still working!
Unfortunately I can‘t test it soon, as I‘d have to build a serious induction heater first. ;)
« Last Edit: December 15, 2017, 07:49:13 AM by Max »
December 15, 2017, 05:52:37 PM
December 15, 2017, 11:28:43 AM
matt0852
December 14, 2017, 03:20:44 PM
matt0852
December 14, 2017, 03:06:07 PM
post Re: My first drsstc
December 14, 2017, 01:04:04 PM
December 14, 2017, 09:10:16 AM
chjarup
December 14, 2017, 06:53:35 AM
post Re: new problem
Garyf
December 14, 2017, 06:23:00 AM
matt0852
matt0852
post Re: Highway to DRSSTC
matt0852
matt0852
matt0852
post DRSSTC: IGBT selection
matt0852
matt0852
Garyf
post new problem
Garyf
matt0852
[High speed filming]
matt0852
chjarup
post FPS1000HD unboxing
post Re: Tardief's DRSSTC
Acid Byte
Tardief
