Author Topic: WTS [DK]: NWL W00238 Capacitor 815 KVAR 1200 VAC 680 Ampere @ 10 kHz  (Read 1767 times)
http://www.ebay.co.uk/itm/232306106373
Open to offers and can provide shipping costs on demand, else first see the shipping costs in the ebay link.
815 KVAR
1200 VAC
680 Ampere @ 10 kHz
Taps 1-2 @ 2.5 uF
Taps 3-6 @ 1.0 uF
weight 16 kg
Total capacitance with all taps in parallel 9 uF
Case is live!
« Last Edit: August 15, 2017, 08:53:43 AM by Mads Barnkob »
Dropped price 20%, additional savings available to forum members :)
Re: WTS [DK]: NWL W00238 Capacitor 815 KVAR 1200 VAC 680 Ampere @ 10 kHz
« Reply #2 on: November 30, 2017, 01:42:38 PM »
Hello Mads,
I‘d like to know if shipping to Luxembourg is as much as shipping to Germany. And are the „additional savings“ still available?  :)
Thank you!
« Reply #3 on: November 30, 2017, 02:28:47 PM »
Hello Mads,
Thank you!
Shipping to Luxemborg is the same as to Germany, 52 Euro, for a XL package with GLS just under 20kg
I will take off 10% of the price for forum members :)
« Reply #4 on: December 01, 2017, 01:00:44 PM »
FWIW, that's almost pennies on the dollar.  Those things go new for kilobucks!
I'd jump on it (even with shipping to here), if only I needed one. :P
« Reply #5 on: December 01, 2017, 01:35:40 PM »
I know that, but if you don‘t really need it, it‘s still a lot of money with shipping. However, because it‘s an excellent offer and knowing that I‘ll use it one day for sure, I couldn‘t resist ;)
One question: are the capacities of the tabs all against the case?
« Reply #6 on: December 01, 2017, 02:20:44 PM »
I only checked from terminals to water inlet connections, as these are where the brackets connect to. Case is mentioned to be live, but I am not sure which side of the capacitor that is, or it is undetermined due to capacitive coupling?
Ill check this weekend.
« Reply #7 on: December 05, 2017, 11:55:58 AM »
Hmm, that style is usually case = common.  Is there continuity between water pipes and case?
« Reply #8 on: December 05, 2017, 06:40:33 PM »
I tried measuring on two different sizes of these that I have, both on unused units and refurbished.
There is no connection between case and water connections, the water connections are also sitting on ceramic insulators.
« Reply #9 on: December 06, 2017, 11:04:26 AM »
Good morning,
Thank you for measuring! I tried to find datasheet, which should mention what „case live“ means exactly, but apparently NWL doesn‘t produce this unit anymore.
« Reply #10 on: December 06, 2017, 12:30:21 PM »
Good morning,
I also tried to locate a datasheet and writing them did not give any results.
They are custom made units and I think that I just found a datasheet for a similar capacitor and trusted it to be very much identical to that.
I can not find a datasheet for NWL on my NAS, so it does not seem like I saved it.
I looked at the WFC series capacitors: http://www.nwl.com/products/capacitors/wfc-series/
And from their datasheet they can actually both be live or dead, depending on design: http://www.nwl.com/wp-content/uploads/pdf/nwl-wfc-series-capacitors-product-data.pdf
« Reply #11 on: December 06, 2017, 01:56:20 PM »
You found the same documents and conclusions as I did ;)
However I wouldn‘t call that document a datasheet... It‘s nothing more than a overview of the WFC series.
Thanks for looking anyway!
« Reply #12 on: December 15, 2017, 07:46:42 AM »
Good morning,
Finally got my capacitor.
Everything seems fine - although it is apparently a bit older than I thought. Thus is of course no problem when it’s still working!
Unfortunately I can‘t test it soon, as I‘d have to build a serious induction heater first. ;)
« Last Edit: December 15, 2017, 07:49:13 AM by Max »
« Reply #13 on: December 16, 2017, 03:34:14 PM »
Good that it got there in one piece and hopefully without any bent connections.
I also had a hard time determine the age of these, because they all look the same, the new ones and the refurbished, some of the refurbished also got new labels and some had a older one. The corrosion on the aluminium varies, but they all have some, not the new ones ofc.
I am really looking forward to see your induction heater!
« Reply #14 on: December 16, 2017, 09:24:41 PM »
As far as I can see, there‘re no damages by shipping. You did a good job!
Unfortunately the induction heater won‘t be realised soon. Maybe in some months... I first want to finish my DRSSTC and have no time at all for either one.
post Re: Slow rise & fall time
Today at 07:59:03 AM
post Re: Do you really know what 3, 6 and 9 stand for?
Today at 06:19:25 AM
post Re: Dual resonant, but why not go triple?
Today at 06:17:41 AM
TDAF
Today at 03:00:46 AM
Downunder35m
Today at 12:31:11 AM
August 15, 2018, 06:36:54 PM
post Re: Big filter caps obtainability
August 15, 2018, 06:05:47 PM
the_anomaly
August 15, 2018, 05:57:38 PM
post Offgrid 48V solar to 24V battery setup
August 15, 2018, 03:26:52 PM
August 15, 2018, 02:12:08 PM
August 15, 2018, 01:23:08 PM
August 15, 2018, 12:21:41 PM
August 15, 2018, 11:13:26 AM
DaiKen
August 15, 2018, 10:54:26 AM
post Dual resonant, but why not go triple?
Downunder35m
August 15, 2018, 10:26:49 AM
Downunder35m
August 15, 2018, 09:58:56 AM
August 14, 2018, 11:21:39 PM
post Re: EMI & placement of driver, interrupter and MIDI controller
August 14, 2018, 09:52:35 PM
August 14, 2018, 09:38:54 PM
August 14, 2018, 09:36:53 PM
DaiKen
August 14, 2018, 03:50:14 PM
August 13, 2018, 10:20:43 PM
August 13, 2018, 11:29:30 AM
post Do you really know what 3, 6 and 9 stand for?
Downunder35m
August 13, 2018, 05:19:03 AM
the_anomaly
August 13, 2018, 02:18:42 AM
August 12, 2018, 11:35:33 PM
the_anomaly
August 12, 2018, 10:25:17 PM
August 11, 2018, 10:19:18 PM
Downunder35m
August 11, 2018, 04:31:42 AM
the_anomaly
August 10, 2018, 10:36:15 PM
post EMI & placement of driver, interrupter and MIDI controller
DaiKen
August 10, 2018, 09:34:15 AM
Downunder35m
August 10, 2018, 05:18:22 AM
TDAF
August 10, 2018, 02:30:23 AM
August 10, 2018, 12:00:38 AM
August 09, 2018, 10:07:01 PM
August 09, 2018, 09:53:57 PM
Downunder35m
August 09, 2018, 07:11:40 PM
August 09, 2018, 06:21:27 PM
August 09, 2018, 03:07:50 PM
August 09, 2018, 02:52:15 PM
post Teardown of a Eaton PowerWare 60kVA UPS system
August 09, 2018, 12:25:32 PM
August 09, 2018, 09:10:09 AM
August 09, 2018, 04:23:26 AM
TDAF
August 09, 2018, 02:30:24 AM
Downunder35m
August 08, 2018, 11:34:19 PM
post Slow rise & fall time
August 08, 2018, 10:08:48 PM
post Re: Drsstc 3
August 08, 2018, 06:54:28 AM
post Trying to understand the inner workings of the resonance between coils
Downunder35m
August 07, 2018, 11:52:20 PM
post Re: Primary coil designs and configurations
Downunder35m
August 07, 2018, 04:27:26 AM
post Re: Is it possible...
[Light, lasers and optics]
August 07, 2018, 03:21:31 AM
