Author Topic: WTS [DK]: NWL W00238 Capacitor 815 KVAR 1200 VAC 680 Ampere @ 10 kHz  (Read 2012 times)
http://www.ebay.co.uk/itm/232306106373
Open to offers and can provide shipping costs on demand, else first see the shipping costs in the ebay link.
815 KVAR
1200 VAC
680 Ampere @ 10 kHz
Taps 1-2 @ 2.5 uF
Taps 3-6 @ 1.0 uF
weight 16 kg
Total capacitance with all taps in parallel 9 uF
Case is live!
« Last Edit: August 15, 2017, 08:53:43 AM by Mads Barnkob »
Dropped price 20%, additional savings available to forum members :)
Re: WTS [DK]: NWL W00238 Capacitor 815 KVAR 1200 VAC 680 Ampere @ 10 kHz
« Reply #2 on: November 30, 2017, 01:42:38 PM »
Hello Mads,
I‘d like to know if shipping to Luxembourg is as much as shipping to Germany. And are the „additional savings“ still available?  :)
Thank you!
« Reply #3 on: November 30, 2017, 02:28:47 PM »
Hello Mads,
Thank you!
Shipping to Luxemborg is the same as to Germany, 52 Euro, for a XL package with GLS just under 20kg
I will take off 10% of the price for forum members :)
« Reply #4 on: December 01, 2017, 01:00:44 PM »
FWIW, that's almost pennies on the dollar.  Those things go new for kilobucks!
I'd jump on it (even with shipping to here), if only I needed one. :P
« Reply #5 on: December 01, 2017, 01:35:40 PM »
I know that, but if you don‘t really need it, it‘s still a lot of money with shipping. However, because it‘s an excellent offer and knowing that I‘ll use it one day for sure, I couldn‘t resist ;)
One question: are the capacities of the tabs all against the case?
« Reply #6 on: December 01, 2017, 02:20:44 PM »
I only checked from terminals to water inlet connections, as these are where the brackets connect to. Case is mentioned to be live, but I am not sure which side of the capacitor that is, or it is undetermined due to capacitive coupling?
Ill check this weekend.
« Reply #7 on: December 05, 2017, 11:55:58 AM »
Hmm, that style is usually case = common.  Is there continuity between water pipes and case?
« Reply #8 on: December 05, 2017, 06:40:33 PM »
I tried measuring on two different sizes of these that I have, both on unused units and refurbished.
There is no connection between case and water connections, the water connections are also sitting on ceramic insulators.
« Reply #9 on: December 06, 2017, 11:04:26 AM »
Good morning,
Thank you for measuring! I tried to find datasheet, which should mention what „case live“ means exactly, but apparently NWL doesn‘t produce this unit anymore.
« Reply #10 on: December 06, 2017, 12:30:21 PM »
Good morning,
I also tried to locate a datasheet and writing them did not give any results.
They are custom made units and I think that I just found a datasheet for a similar capacitor and trusted it to be very much identical to that.
I can not find a datasheet for NWL on my NAS, so it does not seem like I saved it.
I looked at the WFC series capacitors: http://www.nwl.com/products/capacitors/wfc-series/
And from their datasheet they can actually both be live or dead, depending on design: http://www.nwl.com/wp-content/uploads/pdf/nwl-wfc-series-capacitors-product-data.pdf
« Reply #11 on: December 06, 2017, 01:56:20 PM »
You found the same documents and conclusions as I did ;)
However I wouldn‘t call that document a datasheet... It‘s nothing more than a overview of the WFC series.
Thanks for looking anyway!
« Reply #12 on: December 15, 2017, 07:46:42 AM »
Good morning,
Finally got my capacitor.
Everything seems fine - although it is apparently a bit older than I thought. Thus is of course no problem when it’s still working!
Unfortunately I can‘t test it soon, as I‘d have to build a serious induction heater first. ;)
« Last Edit: December 15, 2017, 07:49:13 AM by Max »
« Reply #13 on: December 16, 2017, 03:34:14 PM »
Good that it got there in one piece and hopefully without any bent connections.
I also had a hard time determine the age of these, because they all look the same, the new ones and the refurbished, some of the refurbished also got new labels and some had a older one. The corrosion on the aluminium varies, but they all have some, not the new ones ofc.
I am really looking forward to see your induction heater!
« Reply #14 on: December 16, 2017, 09:24:41 PM »
As far as I can see, there‘re no damages by shipping. You did a good job!
Unfortunately the induction heater won‘t be realised soon. Maybe in some months... I first want to finish my DRSSTC and have no time at all for either one.
post My First DRSSTC
sjsimmo
Today at 05:31:36 AM
post What wrong is it, about my way to measure the secondary resonance frequency?
VNTC
Today at 04:46:17 AM
sjsimmo
Today at 02:52:27 AM
post Re: (DR)SSTC II
November 19, 2018, 09:24:54 PM
post Tesla coil is a quarter resonators, whether the coil man believes or not.
VNTC
November 19, 2018, 05:07:50 AM
November 18, 2018, 03:40:12 PM
November 18, 2018, 12:24:04 PM
November 18, 2018, 07:10:16 AM
post (DR)SSTC II
November 17, 2018, 01:05:45 PM
erdal
November 15, 2018, 07:52:09 PM
post Re: TO-247 IGBT for DRSSTC
dexter
November 13, 2018, 08:03:37 PM
November 13, 2018, 04:39:40 PM
dexter
November 13, 2018, 08:30:13 AM
November 12, 2018, 08:35:12 PM
erdal
November 12, 2018, 08:08:45 PM
post Re: My second DRSSTC
erdal
November 12, 2018, 06:58:26 PM
post Re: Usable vacuum tube?
[Vacuum tube Tesla coils]
November 12, 2018, 12:57:26 PM
November 11, 2018, 10:43:50 PM
post Re: SSTC II
November 11, 2018, 10:13:09 PM
post Re: Moving to a new lab!
[Laboratories ]
November 11, 2018, 09:47:17 PM
November 11, 2018, 11:51:56 AM
November 10, 2018, 10:45:28 PM
November 10, 2018, 08:34:16 PM
erdal
November 10, 2018, 06:20:21 PM
[Laboratories ]
November 10, 2018, 04:51:13 PM
post Re: Is this cheap DRSSTC driver from Aliexpress the 1.3b type?
HVTC
November 10, 2018, 07:35:33 AM
November 09, 2018, 11:45:02 PM
erdal
November 09, 2018, 09:53:28 PM
post Re: SSTC II
November 09, 2018, 06:20:53 PM
HVTC
November 09, 2018, 04:26:24 PM
November 09, 2018, 03:24:06 PM
HVTC
November 09, 2018, 02:56:00 PM
November 09, 2018, 02:48:37 PM
[Laboratories ]
November 09, 2018, 02:08:54 PM
HVTC
November 09, 2018, 02:05:55 PM
[Laboratories ]
the_anomaly
November 09, 2018, 01:42:06 PM
November 09, 2018, 01:29:42 PM
post Is this cheap DRSSTC driver from Aliexpress the 1.3b type?
HVTC
November 09, 2018, 09:19:13 AM
post Re: WTS [DK]: 6x Tesla coil ringed topload arms/holders (can ship worldwide)
November 09, 2018, 08:21:08 AM
post Primary coil cans generate 13MW peak power by 600V DC bus?
VNTC
November 09, 2018, 12:35:14 AM
post Re: Simple way for tuning a tesla coil
VNTC
November 08, 2018, 10:51:39 PM
November 08, 2018, 10:31:24 PM
[Laboratories ]
November 08, 2018, 08:56:33 PM
November 08, 2018, 12:06:08 PM
November 08, 2018, 05:45:56 AM
November 07, 2018, 11:26:27 PM
November 07, 2018, 10:29:18 PM
November 07, 2018, 09:50:32 PM
November 07, 2018, 09:43:57 PM
November 07, 2018, 06:03:26 PM
