Author Topic: First DRSSTC  (Read 208 times)
Offline pawlox98
First DRSSTC
« on: January 11, 2018, 12:58:55 AM »
Hi
I'm building a medium DRSSTC based on Mads Barnkob DRSSTC I
Here's how I see that:
 MMC: 6 strings in parallel of 2 in series 942C20P15K-F capacitors for 0.45uF at 4000VDC
 Bridge supply: 230V AC through a variac, full bridge rectifier, 2x ALS30A332NF450 KEMET capacitors 3300uF 450V ESR: 40mΩ Iripple: 21.2A for 10kHz
 Primary: Spiral coil made of copper tube ∅10, 9 turns
 Secondary: 2400 windings ∅160x768mm ∅0.3 double coated enamelled copper wire on PVC pipe
 Topload: 130x630mm aluminum flex tube
 Resonant frequency: 67-68kHz
 Driver: Finn's Hammer Predikter + GDT (if someone wants driver schematics, i can send them)
and here some numbers from JAVA TC :
For now I finished driver and almost topload, I just have to tape it with aluminium tape. Some pictures soon.
Questions:
 1- Transistors I want to use IXGN400N60B3 because they are easy to get for me (datasheet: http://www.mouser.com/ds/2/205/DS100156A(IXGN400N60B3)-311982.pdf) but
  they are rated for 40 kHz switching. According to Mads's DRSSTC design guide IGBT selection for Tesla coils part they can go faster even 4 times because of soft switching. So can I use them?
 2- Varnish  It is better to just use Polyurethane varnish for secondary or it will be better to use electro-insulating varnish for example mg chemicals red insulating varnish ?
 3- Primary Is acrylic a good material to hold primary coil ?
Offline Garyf
Re: First DRSSTC
« Reply #1 on: January 11, 2018, 03:44:10 AM »
It appears that the 400n60 doesnt have an anti-parallel diode.
Re: First DRSSTC
« Reply #2 on: January 11, 2018, 12:16:47 PM »
1: It depends entirely of the switching current and the temperature rise you can accept, you have to calculate all this, with help from the guide. 4 times faster is just a very rough estimate that does not take switching higher currents than specifications into account, switching losses just higher and only a temperature rise calculation can give you a good estimate.
2: I have only used polyurethane and 4-5 layers have always been enough, so far, the harder you plan to push things, the more layers are needed.
3: acrylic is not good, it easily deforms and melts from mildly high temperatures. So be sure to water cool it, only do short run times or switch a pretty low current to prevent that from happening. See a example of melted acrylic primary holder at the bottom here: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/busbar-and-primary-circuit/
That being said, I also used acrylic in my DRSSTC1, but that has never been used for more than 2 minutes at a time and only at 500Aprimary
Regarding the missing diodes, you will just have to buy some large and very fast diodes to mount externally and they will perform better than a built-in parasitic diode would.
Offline pawlox98
Re: First DRSSTC
« Reply #3 on: January 11, 2018, 12:40:05 PM »
When it comes to diodes, I was thinking the same but with
calculations, I got stuck witch Pdiss I don't know how to get TJ and TC
Re: First DRSSTC
« Reply #4 on: January 11, 2018, 01:12:18 PM »
It is explained in the part "Fmax1 and Fmax2 switching speeds" of http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/igbts/
We want Tjunction to stay below 80ºC and have Tcase cooled to stay below 50ºC. A advisable rule is to keep the temperature ripple below 30ºC, we often use second hand IGBT bricks and we do not know their usage history. To avoid real fast degeneration of die and bonding wires inside the IGBT, we will aim to reduce large temperature swings.
Further down where I do the calculations with real numbers is where it all happens.
Offline pawlox98
Re: First DRSSTC
« Reply #5 on: January 11, 2018, 08:27:35 PM »
I'm sorry I do not know how I could have missed it
I've done my calculations but Im not 100% sure about them
Re: First DRSSTC
« Reply #6 on: January 11, 2018, 09:55:31 PM »
That looks much better, the 15V on the upper part is the voltage for which the data is given in the datasheet, which typically is 15V, your supply voltage should be on the lower part. So the result should be 0.3mJ if the data is given at 15V and you drive them at 15V.
These maximum values does not take gate drive current into account! Just because the thermal calculation shows you can dissipate this heat at up to 1,1MHz, does not mean that you can actually drive the IGBT gate that hard :) But it is a valuable tool to examine if you will blow up your silicon or not.
Offline pawlox98
Re: First DRSSTC
« Reply #7 on: January 11, 2018, 10:07:19 PM »
So with this voltage correction Fmax2 is 726 366.67Hz which is way above, so it is possible but not 100% sure they will not blowup ? ???
Re: First DRSSTC
« Reply #8 on: January 12, 2018, 10:19:20 AM »
It means that there is no thermal limitations to run these with 500 A at 68 kHz, as 726 is many times higher. I would not worry about gate drive either at 68 kHz, as that is a very small amount of gate charge on these IGBTs.
Just get this build and let us see some sparks  8)
Offline pawlox98
Re: First DRSSTC
« Reply #9 on: January 14, 2018, 04:40:30 PM »
Hi Mads
In "Snubber capacitor selection" You said  ΔV/Δt should be at at least 500-5000 V/μs or above but 40L snubber You used have only 50 and all snubbers I have seen had only 30-400. I will probably use 2x WIMA MKP 5uF 1000V they had 300 V/us
Zener diodes on transistors gates Zener voltage should be at gate-emitter continuous voltage or at driver voltage i.e. 15V and  How many watts should they have ?
Re: First DRSSTC
post Re: My first drsstc
Today at 02:12:51 AM
post Re: Highway to DRSSTC
Garyf
January 15, 2018, 06:20:00 PM
January 15, 2018, 03:51:57 AM
post Re: First DRSSTC
pawlox98
January 14, 2018, 01:20:37 PM
January 14, 2018, 01:10:37 PM
January 14, 2018, 11:11:40 AM
January 13, 2018, 09:27:22 PM
post Re: Geissler tube with a contact problem
[Transformer (iron core)]
Physikfan
January 13, 2018, 07:27:55 PM
post Re: Building the OpenTheremin V3
January 13, 2018, 02:56:15 PM
January 13, 2018, 07:50:32 AM
post Re: Best core for GDT and FBT
January 13, 2018, 06:57:34 AM
post Re: AliExpress/ Chinese drsstc drivers
Garyf
January 12, 2018, 10:58:14 PM
January 12, 2018, 09:27:16 PM
January 12, 2018, 09:02:04 PM
January 12, 2018, 08:53:29 PM
January 12, 2018, 07:31:19 PM
January 12, 2018, 06:58:59 PM
post Re: My 160 (?)mm sstc
January 12, 2018, 01:17:52 PM
pawlox98
pawlox98
January 11, 2018, 03:17:44 PM
pawlox98
Garyf
Garyf
January 11, 2018, 03:36:40 AM
post First DRSSTC
pawlox98
January 11, 2018, 12:29:19 AM
January 11, 2018, 12:00:07 AM
January 10, 2018, 10:24:37 PM
post Re: Self-oscillating nano Tesla Coil (14.3 MHz)
tefatronix
January 10, 2018, 09:11:50 PM
post Re: Smartphone scientific oriented games: list your best!
January 10, 2018, 08:16:29 PM
NicholasTow
January 10, 2018, 06:02:54 PM
January 10, 2018, 05:12:25 PM
post My own SSTC Driver v1.0
January 10, 2018, 04:23:28 PM
January 10, 2018, 03:23:02 PM
January 10, 2018, 03:13:30 PM
post Re: Optical Connection Problems(HFBR-1531Z-2531Z)
January 10, 2018, 02:32:18 PM
January 10, 2018, 01:37:13 PM
post Optical Connection Problems(HFBR-1531Z-2531Z)
January 10, 2018, 12:27:39 PM
post Building the OpenTheremin V3
January 10, 2018, 11:18:42 AM
January 10, 2018, 08:55:47 AM
January 10, 2018, 08:32:14 AM
January 10, 2018, 08:24:46 AM
post Re: sstc drive method
January 10, 2018, 08:21:06 AM
January 10, 2018, 01:36:32 AM
January 10, 2018, 01:25:58 AM
