Author Topic: Flashing the digispark with the oneTesla MIDI interrupter code  (Read 3955 times)
I managed to modify and flash the digispark with the oneTesla interrupter code.   Here's how to do it:
1.  Buy a Digispark (usually $5 to $10).
2.  Get an Arduino Uno to use as a programmer.
3.  Follow these instructions to plug in the Arduino as the ArduinoISP avrisp programmer:
http://www.instructables.com/id/How-to-Program-an-ATtiny-85-Digispark/
In particular, connect the following pins together
Uno 5V : Digispark Terminal VCC
Uno GND:  Digispark Terminal GND
Uno pin 13:  Digispark P2
Uno pin 12:  Digispark P1
Uno pin 11:  Digispark P0
Uno pin 10:  Digispark P5
4.  Install Arduino software to get avrdude
5.  Flash the Digispark with new code:
avrdude -C"C:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf" -v -pattiny85 -cavrisp -PCOM5 -b19200 -D -e -Uflash:w:main.hex:i make
using the main.hex file from the attached distribution, change the paths and the com port to match your configuration.
6.  Disconnect and plug in the digispark; it should be recognized as a OneTesla MIDI controller.
A single pole-single throw switch is attached to P0, the LED is attached to P2 through a 100 ohm resistor.
« Last Edit: May 11, 2018, 01:14:51 AM by profdc9 »
Re: Flashing the digispark with the oneTesla MIDI interrupter code
« Reply #1 on: May 17, 2018, 11:03:23 AM »
Thanks for the guide.
What are the advantages of the digispark over just a arduino uno? Is it just that its much smaller and cheaper?
« Reply #2 on: May 17, 2018, 04:02:53 PM »
It's smaller and cheaper.  I bought mine for $5 on ebay, but you can get Chinese ones for $2 if you want to wait for them.   There's no wiring to do except to add the LED for the fiber optic cable, so it's basically ready to go, it is essentially the same circuit as OneTesla's USB with the pins exchanged.   Also, you don't need a USB to MIDI interface for it, you just connect the USB directly to it.  The disadvantage is that it doesn't use the SD cards, which I wasn't going to use anyways.
I added a spot for the OneTesla USB midi interrupter to one of my interrupters so that it can share the same output LED and save some money there as well, as well as integrate both the test interrupter and the music interrupter into a single board.
« Last Edit: May 17, 2018, 04:13:05 PM by profdc9 »
« Reply #3 on: May 20, 2018, 12:09:36 PM »
Arduino boards will work the same, it depends on which one are you more comfortable using. Nano boards cost under 3$ delivered and if you use internal FTDI you also don't need MIDI-USB cable
Today at 04:57:47 AM
ethanwu0131
Today at 03:40:53 AM
post Re: First DRSSTC SKM100
Today at 01:31:17 AM
April 15, 2024, 11:19:52 PM
April 15, 2024, 11:10:19 PM
April 15, 2024, 11:04:19 PM
April 15, 2024, 11:02:05 PM
April 15, 2024, 10:57:59 PM
April 15, 2024, 10:55:46 PM
April 15, 2024, 10:37:32 PM
April 15, 2024, 10:05:00 PM
April 15, 2024, 09:28:50 PM
April 15, 2024, 09:06:42 PM
April 15, 2024, 08:46:32 PM
April 15, 2024, 08:38:39 PM
sky-guided
April 15, 2024, 08:23:40 PM
Bobakman
April 15, 2024, 06:43:23 PM
April 15, 2024, 06:29:10 AM
April 15, 2024, 05:21:53 AM
April 15, 2024, 05:15:33 AM
April 15, 2024, 04:07:54 AM
April 15, 2024, 03:49:03 AM
April 14, 2024, 09:46:30 PM
April 14, 2024, 07:31:00 PM
April 14, 2024, 02:26:19 PM
post Re: mg75q2ys40 IGBT
April 14, 2024, 07:20:54 AM
April 14, 2024, 07:18:20 AM
April 13, 2024, 06:46:40 AM
April 13, 2024, 04:18:42 AM
April 13, 2024, 03:24:20 AM
April 13, 2024, 03:20:46 AM
April 13, 2024, 03:13:22 AM
post Re: Capacitor Blowout
lbattraw
April 12, 2024, 09:14:58 PM
post mg75q2ys40 IGBT
April 12, 2024, 08:40:18 PM
April 12, 2024, 07:20:30 PM
April 12, 2024, 07:12:43 PM
ethanwu0131
April 12, 2024, 04:47:33 PM
April 12, 2024, 11:43:36 AM
Egg
April 12, 2024, 12:49:02 AM
April 12, 2024, 12:41:16 AM
April 12, 2024, 12:22:41 AM
April 11, 2024, 10:45:53 PM
April 11, 2024, 07:39:30 PM
April 11, 2024, 07:24:52 PM
sky-guided
April 11, 2024, 06:09:30 PM
April 11, 2024, 12:55:16 PM
April 11, 2024, 03:40:00 AM
sky-guided
April 11, 2024, 03:05:07 AM
April 11, 2024, 02:57:33 AM
April 11, 2024, 01:44:32 AM
April 11, 2024, 01:31:40 AM
OmGigaTron
April 11, 2024, 01:11:00 AM
April 11, 2024, 12:58:52 AM
April 11, 2024, 12:31:37 AM
April 11, 2024, 12:30:21 AM
April 10, 2024, 11:41:46 PM
April 10, 2024, 11:33:32 PM
April 10, 2024, 10:41:33 PM
April 10, 2024, 10:31:31 PM
April 10, 2024, 09:56:35 PM
April 10, 2024, 08:59:26 PM
April 10, 2024, 06:35:30 PM
April 10, 2024, 05:35:14 PM
April 10, 2024, 03:07:02 PM
April 10, 2024, 03:42:12 AM
April 10, 2024, 03:41:04 AM
sky-guided
April 10, 2024, 02:50:23 AM
Unrealeous
April 10, 2024, 01:32:17 AM
OmGigaTron
April 10, 2024, 01:26:29 AM
OmGigaTron
April 10, 2024, 01:18:35 AM
post Re: Big Coil Big Sparks
April 09, 2024, 07:34:19 PM
April 09, 2024, 06:14:27 PM
April 09, 2024, 06:08:53 PM
April 09, 2024, 05:15:19 PM
April 09, 2024, 05:11:04 PM
April 09, 2024, 06:32:16 AM
post DRSSTC V1 using BSM150
Unrealeous
April 09, 2024, 04:04:47 AM
April 09, 2024, 03:27:11 AM
April 09, 2024, 03:25:47 AM
OmGigaTron
April 09, 2024, 03:01:40 AM
sky-guided
April 09, 2024, 02:46:46 AM
OmGigaTron
April 08, 2024, 09:32:57 PM
OmGigaTron
April 08, 2024, 09:25:11 PM
April 08, 2024, 08:45:15 PM
OmGigaTron
April 08, 2024, 08:24:13 PM
post Big Coil Big Sparks
April 08, 2024, 04:02:48 PM
April 08, 2024, 03:45:30 AM
April 08, 2024, 03:35:32 AM
April 08, 2024, 03:12:45 AM
April 08, 2024, 03:03:26 AM
April 08, 2024, 02:24:41 AM
April 08, 2024, 01:29:53 AM
April 08, 2024, 12:55:50 AM
April 08, 2024, 12:38:52 AM
April 07, 2024, 11:56:02 PM
April 07, 2024, 07:49:29 PM
April 07, 2024, 06:28:12 PM
post First DRSSTC SKM100
April 07, 2024, 06:13:59 PM
April 07, 2024, 05:44:55 AM
April 07, 2024, 12:45:52 AM
