Tesla coils => Dual Resonant Solid State Tesla coils (DRSSTC) => Topic started by: davekni on October 13, 2020, 01:50:43 AM
Title: QCW with replaceable ferrite-core primary
Post by: davekni on October 13, 2020, 01:50:43 AM
Inspired by Jan's impressive ferrite-core QCW coil here:
https://highvoltageforum.net/index.php?topic=1073.0
and his wishing that the primary could be adjusted, I'm starting a project to make a QCW with replaceable ferrite-core primary.  The idea is to pot the inside of the secondary with a cavity for the primary.  However, a plain cavity would form corona discharge between the inside surface of the cavity and the primary.  So, here's the secondary form and cavity I plan to pot inside in a couple days:
 [ Invalid Attachment ]
The cavity is a Faraday cage with no closed loops.  All the wires connect at only the top.  Wires will all be inside the potting material.  At the bottom, I'll connect ONE of the wires to ground.  That way the internal electric field of the secondary will return to the Faraday cage within potting material.  Internal electric field around the primary will be due to only the primary voltage, low enough to avoid corona.  Magnetic field will be free to pass between Faraday cage wires.
Anyone see any issues before I mix and pour epoxy?  I will be using vacuum to remove as much air as possible, per what I've learned on this forum.
This is the first step of a long project.  Haven't built any of the electronics yet.  My aim is to explore lower frequency and longer ramp times than typical for QCW, to see if slow ramps can compensate for lower frequency.  Somewhere around 170kHz and 100ms ramp.
Title: Re: QCW with replaceable ferrite-core primary
Post by: Uspring on October 17, 2020, 03:06:49 PM
Lovely idea to improve on dr. kilovolts design by making the primary removeable with a Faraday cage. I'm wondering, whether an iron core actually increases coupling. Have you any estimates on this?
I'm certainly fond of any research on arc behaviour.
Post by: davekni on October 17, 2020, 07:45:56 PM
I made a mock-up by winding old power cords into roughly the intended geometry.  Coupling for that was 0.875.  Didn't measure coupling without the ferrite core, but would guess around 0.7 or just under.
Potting had some problems.  Developed air leaks around the top seal (bottom during potting) during vacuum degassing.  Managed to mostly patch those before epoxy cured, but it's not degassed very well.  May still be OK.  I read that QCW voltage is around 50kV.  Even if low-frequency raises that to 100kV, this potting may be sufficient.  Radial distance is 21mm epoxy plus 5.8mm PVC pipe wall.  Axial distance at the top is 30mm epoxy plus 6.1mm polycarbonate.
Uspring, Thank you for your modeling too.  I've done a bit of magnetics modeling, but don't know enough about arcs to simulate those.
Post by: Mads Barnkob on October 18, 2020, 07:18:08 AM
Interesting project, something that has been talked about, especially the internal primary coils and potting, but the shielding and other measures of actually making it feasible are new to me, looking forward to follow this.
In regard to low frequency QCW, there might be a little knowledge to get out of my failed attempt of making it simple: http://kaizerpowerelectronics.dk/tesla-coils/kaizer-drsstc-iv/
Regarding shielding around magnetic components, perhaps you can find inspiration in the Pearson Current Monitor 1330 I took apart, I was surprised that it was fully copper shielded in 2 layers with only a small slot cut through it:  https://4hv.org/e107_plugins/forum/forum_viewtopic.php?p=1&id=175696#post-175696 (I can make a repost here on hvf with full size pictures if you want?)
Post by: davekni on October 19, 2020, 05:32:05 AM
Mads,
Thank you for reminding me about your simple line-power-cycle-ramped QCW.  I'd looked through that project when I first found this forum a year ago, but had forgotten that it was also low-frequency for a QCW.  For initial experiments, before I build a proper ramp generator, I'm thinking of trying a resonant ramp generator.  Charged bulk cap array feeds a large series inductor into another bulk cap array, with thyristor for trigger.  I have some MOT primary halves left from my eddy-current levitation demo.  Should make something similar to your line quarter-cycle without risk to other line-powered devices.  (I've seen a vacuum-tube coil powered by isolated line half-cycles as in your demo, behaving much like QCW coils.)
I use a somewhat similar slightly-over-one-wrap of insulated copper foil to shield the first stage of my DRSSTC current transformer.  Likely not needed.  For this QCW primary, copper foil could work around the circumference, but not at the top end.  Most of the primary magnetic field is passing out its top end.  There's no way to make a non-shorted turn in the plane where magnetic field passes through.  That's why the array of wires.
Post by: Hydron on October 23, 2020, 05:36:02 PM
Hey I've moved the ping-pong/pumpkin shooting stuff to https://highvoltageforum.net/index.php?topic=1274.0 - hopefully I did it right (I think I might have screwed up renaming the topic!).
Dave - some of your posts are relevant to both threads - maybe worth copying/pasting the bits into a new post there, sorry I couldn't figure out how to make two copies of said posts when splitting the thread.
Gotta say the pumpkin discussion led to watching some fun youtube videos - I liked the visual spectacle of rubber band/trebuchet ones more than gas launched though to be honest.
Post by: davekni on November 22, 2020, 03:34:36 AM
I've now wound a secondary around the potted core and a primary to go inside.  Here's some measurements:
     Secondary winding:
299mm high
160.8mm diameter
27AWG wire
~700 turns
33.19mH w/o ferrites
156.7mH with ferrites
60 ohms DC
     Primary winding (at least this initial version):
270mm high
90mm diameter
28 x 27AWG home-made litz wire
Four interleaved 7-turn windings.  Can be connected in series or parallel or 2S2P.
307uH with ferrites and series (4S) connection.  (19.2uH for 4P connection.)
     Combination:
0.909 coupling with ferrites (0.51 w/o ferrites)
124kHz upper pole frequency w/o top-load, with 7x lower primary tuning (50x capacitance - 2.4uH primary using 4S connection)
106kHz upper pole frequency with 620mm OD top-load
The big surprise (my dumb mistake to miss initially) was all the extra capacitance from secondary winding to internal Faraday-cage shield.  I was aiming for 170kHz with top-load.  Capacitance through the potting epoxy has fairly-high loss too, acting as around 900k-ohms across the coil.  Still shouldn't be a killer issue compared to ~50k arc impedance.
Some images of construction, starting with secondary around potted Faraday cage, up-side-down view:
Primary coil with four interleaved 7-turn windings:
Secondary inside primary Faraday cage:
Ferrite stack, made of a total of 44 E-55 core halves, 3C92 material, plus four flat E-64-50-10 cores for spacing:
Primary around ferrite stack, with leads extending through bottom plate:
Secondary on primary and ferrites:
More ferrites on top, 3F4 material 64 x 51 x 5mm plates:
With 620mm OD top-load, which I won't be using since frequency is already too low:
I had one other problem with the potting besides vacuum issues.  Three connections of the Faraday cage broke, presumably due to stress of epoxy shrinking slightly during cure.  I connected them at the bottom, but with parallel R/C impedance.  The impedance is to avoid a shorted turn in case one of the bad connections reforms with thermal cycling or age or whatever.
Ran a quick test driven more like an SSTC, using a quick half-bridge I constructed for example layout.  Ran it up to ~100kV peak.  At least there's no immediate insulation breakdown issues.
Post by: Uspring on November 23, 2020, 01:08:46 PM
That's one huge coupling value. If you tune the primary tank to your secondary resonance frequency, the lower pole will be at 77 kHz and the upper one at 350 kHz. Choosing other primary fres's can extend this range. You could name the coil an AFTC (Any frequency Tesla coil).
Post by: davekni on November 23, 2020, 08:03:46 PM
Yes, coupling is large.  That was one of my design goals - as large coupling as possible.
I must have a mistake in my posted numbers for you to get a 350kHz upper pole option.  124kHz is upper pole with huge (call it infinite) primary capacitance and no top-load.  If I were to move to exactly in-tune, upper pole increases by only sqrt(2) to 175kHz.  However, I want to keep the primary capacitance somewhat large.  That minimizes primary voltage and minimizes flux in the ferrite core.  The 2.4uF in my first test is too large.  As the arc load grew, my simple ZCS driver switched to lower-pole.  (Spice simulation shows this too.)  About 32nF would be in tune with the 4S (28 turn) primary connection (with no top load and no arc).  I plan to drop from 2.4uF to about 0.33uF for the next test.
Post by: Uspring on November 24, 2020, 05:32:56 PM
I took a k of 0.9, which raises the frequency by a factor of 1/sqrt(1-k) ~ 3. You probably used the k=0.5 as for the coil without core. It should be possible to run your coil at the known frequencies for straight arcs and also explore lower frequencies. Nice  :)
Exotic experiments would be running the coil with lower and upper pole at the ratio of 1:3 simultaneously. That are the fundamental and first harmonic of the driving square wave. You'd have a square wave TC then. (SQWTC).
Post by: davekni on November 24, 2020, 07:52:01 PM
Uspring,
The 124kHz measured frequency (w/o top load) is upper pole, so includes the 1/sqrt(1-k) factor already.  This is with k=0.909.  The only tests I ran w/o the ferrite core were to measure secondary inductance and coupling - just for curiosity.  Nothing else is air-core.
Post by: Uspring on November 26, 2020, 12:07:11 PM
David, I'm sorry to have bothered you with this. I was under the mistaken impression, that the location of the poles don't depend much on coupling, if resonance frequencies of the (uncoupled) tanks are sufficiently distant. That is only true for the lower pole. I had assumed the upper pole in your measurement to be near the secondary fres. Actually the upper pole seems to vary from 1/sqrt(1-k^2) of the secondary fres at very low primary fres to 1/sqrt(1-k), when primary and secondary fres are equal.
Post by: davekni on November 26, 2020, 06:48:34 PM
No problem!  I appreciate people questioning my results, as I make careless mistakes more often than I'd like.
Post by: Mads Barnkob on November 29, 2020, 08:04:01 PM
That amount of ferrite blocks o_O
The bottom cross reminds me of how higher coupling is achieved in induction stoves
But what are the purpose of the plane of ferrite blocks living on top of the secondary coil and between that and topload? Surely the ferrite was all there to get the highest possible coupling between primary and secondary coils?
With a mind blowing coupling factor of k=0.909, that is extremely close to k=1 where the coils would take up the same physical space. Really looking forward to see where this project ends :)
Post by: davekni on November 30, 2020, 06:37:23 AM
The top ferrites make a small contribution to coupling factor.  They also allow the top-load to be placed close to the top of secondary winding.  However, since I already have too much capacitance, it may make sense to drop the top ferrites along with the top-load.  The ferrites are conductive enough that I need some form of corona ring to avoid arcing from the corners.  Without ferrites I might still need some small corona ring at the top, but it could likely be a non-shorted turn and still sufficiently effective.
Yes, lots of ferrites.  Cost was $158 for all the E-cores that make up the column and cross at the bottom.  The flat ferrites were in my old stash.
Post by: davekni on December 15, 2020, 06:05:32 AM
My guess had been that slow ramping could compensate for low frequency.  Initial low-power testing shows the opposite.
Until I build the real H-Bridge for this coil, I'm running with a smaller practice bridge I'd built as a layout example.  It uses obsolete 330V TO247 IGBTs, so bus voltage is 250V maximum for a bit of margin.  Primary is 2S2P (14 turns) here with 14uF primary series capacitance (roughly infinite).  Oscillation (upper pole) starts at 115kHz and drops only a bit to ~112kHz by the end of each ramp.  (Due to high secondary parasitic winding capacitance.)  The primary capacitance has 40uH + 1.8ohms in parallel to damp lower-pole resonance, keeping the simple ZCS oscillator running at the upper pole.
Arc shape varies drastically from shot to shot even with the same ramp.  However, it's clear that shorter steeper VBus ramps produce more instances of relatively-straight arcs.  Below are a few examples of arcs and associated scope traces.  (I'm not certain that each scope trace is for exactly the associated image, but they are at least with the same ramp settings.)  The cyan trace is Vbus at 50V/div.  The green shape is primary current at 110V/div (22A/volt at 5V/div).  These plots are zoomed-out, so only the current outline shows up.  For image sizing, the top-load is 30cm diameter.  Each image is of a single ramp manually triggered somewhere during a long exposure.  Also, notice that the scope plots have different horizontal scales, 5ms/div, 2ms/div, and 1ms/div.
The current envelope is interesting.  It seems that more dips in the current trace correlate to more branching.  That makes some sense, as current dropping while voltage is increasing indicates an increase arc loss.  Each loss increase may be caused by a new branch.  It makes me wonder if some active feedback could be useful.  Perhaps if the voltage backed off every time current drops, that could extinguish branches.  Not sure how much effort I want to put into testing that speculation, however.
Finally, I found it interesting that when an arc is relatively-straight and reaches the ceiling 82cm above, it tends to turn sideways and run along the ceiling.  Didn't have the camera pointed quite high enough, but looking at the top of these next two images, the tip of the arc is heading away from the camera along the ceiling.
Next steps will be building the real H-Bridge and the other half of the dual-buck-converter ramp generator and moving the coil off my dining-room table.
Post by: Uspring on December 15, 2020, 03:46:26 PM
A very interesting experiment ;D  A feature of the arcs seems to be, that they are much more zig zag on a smaller scale and straighter overall. Overall straightness can be explained by the toroid field. But that influence seems to less important on a smaller scale. Perhaps local deviations can come from the coils magnetic field, which might lead to helical forms. Since both the current in the arc and the field change synchronously, the helicity does not change with a reversal of the current. Longer bursts might enhance helicity effects. Do you have a high speed cam to watch slomos? And is it possible that the magnetic field leaks into the arc region?
Still, the lack of straightness is evident compared to the higher frequency arcs. The only real difference I can think of between high and low f arcs is, that the high f arcs are hotter due to the more frequent transfer of space charges.
Post by: davekni on December 16, 2020, 05:35:01 AM
I expected the stray magnetic field to be small since there is a ferrite plate on top, then a small aluminum pie tin inside the top-load.  Just to be sure, I made a different top today.  Ferrite plate is the same.  On top of that is a large aluminum pie tin encircled by a copper-pipe ring brazed together at the joint to form a solid shorted turn.  Behavior is still roughly the same:
As before, there are plenty of more-branched shots too:
Post by: Mads Barnkob on December 16, 2020, 10:55:03 AM
Are you perhaps draining your ramp inverter DC bus energy storage so bad that you have a voltage drop that is recharged by the front stage or mains and that causes the current spikes? The current waveform reminds me of my DRSSTCs when running in a "current limited equilibrium" mode due to too little DC bus capacitance. So it essentially just feeds whatever it can into the arc, there is no peak current storage energy to draw from.
Regarding current dropping, wouldn't it be a higher voltage? As we saw in Hydron's measurements of topload discharges: https://highvoltageforum.net/index.php?topic=117.msg784#msg784
Number of zig-zag edges to spark length seems to be consistent when looking at 170-400kHz QCW coils, it is just the amplitude of the zig-zags that is changing. It is however harder to count the zig-zags on the very bright and straight arcs of a high frequency coil, so its an observation with a lot of uncertainty.
Post by: davekni on December 16, 2020, 08:59:09 PM
"Are you perhaps draining your ramp inverter DC bus energy storage so bad that you have a voltage drop that is recharged by the front stage or mains and that causes the current spikes? The current waveform reminds me of my DRSSTCs when running in a "current limited equilibrium" mode due to too little DC bus capacitance. So it essentially just feeds whatever it can into the arc, there is no peak current storage energy to draw from."
By appearance that would make sense.  However, in this case the entire ramp is fed by a bulk cap (the 20mF one I accidentally shorted to cause hearing damage last July - wearing ear protection now).  The cyan trace is voltage out of the ramp generator (bus voltage to the H-Bridge).  Poor choice of colors, but if you look closely it is visible on top of the green current trace.  Voltage continues to ramp smoothly until the ramp ends.
"Regarding current dropping, wouldn't it be a higher voltage? As we saw in Hydron's measurements of topload discharges: https://highvoltageforum.net/index.php?topic=117.msg784#msg784"
Could you explain this more?  After the ground strike, voltage is low (topload shorted to ground through the arc) and currents are also low (low-Q secondary resonance due to arc short prevents secondary current from building up).  Although not plotted, primary current is likely increasing after the ground strike due to lack of secondary load.  For my QCW coil's high coupling and upper-pole operation, primary and secondary currents roughly track.  The dips in primary current plotted should correspond to dips in secondary current caused by dips in secondary voltage due to increased arc loading.  I wasn't measuring secondary current in these runs, so don't have explicit data for that.
Post by: Uspring on December 18, 2020, 12:46:06 PM
Thank you for checking out the idea that magnetic fields might influence arc shape. I've noticed from other pictures, that an increasing length of burst tends to curl up or meander the arcs near the bottom. Your images seem to point in the same direction. I'm quite mystified about the reason for this, since the effect of both magnetic and electric field of an arc on itself should straighten it out.
I still have a (remote) hope, that low frequencies could allow for branchless arcs, although the mechanism I'm thinking of requires a growth speed proportional to the frequency, i.e. a constant mm/cycle value. That would require even longer bursts at the frequencies you use. But then, these bursts cause curling or meandering.
BTW: You seem to operate the coil much like an SSTC with ZCS, like discussed in another thread.
Post by: davekni on December 18, 2020, 07:43:27 PM
Uspring,
Yes, you are right, it is running just like an SSTC with ZCS.  I hadn't realized that until this morning after your comment.  My goal had been to run upper pole with ZCS by having high coupling.  Only now I realize that's what SSTCs do.  With H-Bridge primary drive being low impedance, SSTCs are effectively running upper-pole.  (At least for half-bridge designs that have capacitor(s) in the primary, so there actually are two poles.)  The only difference (besides higher coupling) of my design is that I'm using primary current feedback, not secondary as SSTCs do.
Unfortunately I don't have a high-speed camera.  Would love to have one.  I did explore arc development the only way that comes to mind:  keeping ramp parameters stable, but changing the ramp end time.  Each shot is different, but I get a general idea of what it looks like initially, a bit later, etc.  Yes, the beginning is always thinner and much less jagged.  The zigzag develops later as the ramp continues.  The beginning often has small branches that seem to sometimes extinguish later.
Yes, I'd hoped that stretching ramp times by 1/f or even 1/f^2 would make straight arcs.  Exploring that thought is the #1 reason I built this coil.  I still plan to finish it's high-power drive in spite of (I think) disproving that hope.  The first (slowest) ramp that I posted lasts 25ms.  The final version should be capable of 100ms ramps at higher power.  However, that lower-power 25ms ramp will be much like the first quarter of a high-power 100ms ramp.  I hope it will be interesting arcs to display, but have little expectation of achieving straight arcs now.
My guess as to the growth of large zigzags at the bottom is air turbulence caused by the column of hot low-density air surrounded by cold high-density air.  Just had an idea if I feel ambitious enough - wonder if I could talk Portland State University into letting me run this in their micro-gravity drop tower.  That would be fun and a bunch of work.
Post by: Uspring on December 19, 2020, 01:27:19 PM
Forum member Phoenix sent me a 960 fps video taken with his QCW coil. https://drive.google.com/file/d/1FH6-gjzs18cjbQTu9FdJ7u1WuvL1cjOf/view
A thank you from me for his permission to post the link. It is full of interesting details. Right at the start there is s small branch to the left, which vanishes again. Also some wiggles can be seen at the bottom of the arc, which become larger as time progresses. Near the top of the arc another small branch angles to the left, while the main arc turns right. I believe that to be due to the repulsion of the space charges of the branches. Toward the end of the sequence the wiggles at the bottom of the arcs become even larger.
A very plausible conjecture. I've been thinking of another cause, i.e. the mutual repulsion of the space charges that make up the arc. Consider e.g. a loose string. When you pull on it, it will straighten and will wrinkle again as you loosen it.The repulsion in the arc cause an internal pressure or in analogy with the string a negative tension. The (negative) force developed is of the order
1/(4*pi*eps0) * rho^2,
where rho is the charge per unit length of the arc. The above is basically the Coulomb force equation. For typical charge densities of arcs, around 1 uC/m, the force comes out to be about 0.01N. That is not very much, but the mass of air, that is pushed around is only about 1 mg. That would be 1 cm^3 of air. So considerable movement is possible within the duration of the arc.
Similar forces arise due to convection. A very hot cubic cm of air experiences an upward force of also 0.01N.
Post by: davekni on December 19, 2020, 08:06:23 PM
Your space-charge theory is looking much more likely than buoyancy.  I'm coming up with 0.00001N for buoyancy for 1cc of very-hot air, three orders of magnitude less than your space-charge estimate (which seems reasonable).  Space charge seems to set the upper limit for QCW ramp time.  My low-frequency coil requires more voltage for a given arc current, which increases space-charge issues.  It will still be interesting to see what effect I get from throwing more power at it eventually.  Need to order more SiC diodes to complete my ramp-generator buck converter pair first, and build a new H-Bridge.
The QCW high-speed video is much appreciated!  Yes, the bottom develops zigzags by the end that look much like what I get.
Post by: Uspring on December 20, 2020, 12:57:27 PM
You're right about the bouyancy force.
It'll be interesting to so what happens, when you lengthen burst and increase power.
Mads wrote:
I believe the zig zags to originate from tiny branches, which vanish again quickly, so they aren't visible, except maybe in high speed videos. With longer burst times the wiggles then increase in size.
Post by: Mads Barnkob on December 20, 2020, 02:52:28 PM
Mads wrote:
Yeah, I agree on that. That is the same for conventional DRSSTC sparks. Here is one from my small DRSSTC (https://kaizerpowerelectronics.dk/tesla-coils/kaizer-drsstc-ii/) 2
I got some 1000FPS 720p recordings of my VTTC, but not even 1000FPS is enough to show growth details. I have not yet uploaded them to youtube as I was not really satisfied with the results, I will try to do some higher FPS recordings another time. I can do the following:
1280 x 720 @1,000fps
1280 x 360 @2,000fps
1280 x 180 @4,000fps
1280 x 60  @8,000fps
640 x 360 @4,000fps
640 x 180 @8,000fps
640 x 120 @10,000fps
640 x 60   @20,000fps
Post by: davekni on December 20, 2020, 06:57:33 PM
"I believe the zig zags to originate from tiny branches, which vanish again quickly, so they aren't visible, except maybe in high speed videos. With longer burst times the wiggles then increase in size."
Could it be the other way around?  Could the zigzags form, making points that start branches?
Post by: Uspring on December 21, 2020, 04:54:37 PM
Mads photo sure makes a point, that wiggles and branches correlate.
Quite possibly. Phoenixs video shows branches to originate at the tip of the arc. So I think of branches and bends to begin simultaneously. A possible cause might be 2  free and separate electrons near the tip, which form avalanches, which both then connect to the main arc channel. But there could be branches sprouting sideways from a curved part of the arc later, i.e. without the tip being involved. Not that I have seen enough high speed videos to judge.
Post by: davekni on April 06, 2021, 07:54:07 PM
Finally "finished" my planned high-power drive for this low-frequency QCW coil: dual buck-converter feeding CM600DY-13T bridge.  Moved the coil outside for testing last Friday.  Even at low power, behavior outside is very different than inside on my table.  Most arcs curve towards the ground.  Higher power for longer ramps didn't help.
Here are a couple videos.  I've edited out gaps between firings.  These cover a random range of ramp shapes.  I'm playing with four knobs adjusting a quadratic ramp generator.  Parameters are initial PWM duty cycle, linear ramp rate, quadratic rate, and end time.  Longest ramps here are 55ms with ending power about 100kW: ~320V at ~330Adc, ~530A primary coil peak current.  (Buck converter and bridge are capable of over twice this power, but the primary winding impedance is too high.  Power into the buck converter comes from a 0.2F 450V capacitor bank charged to 400V.  I'm wearing hearing protection now in case of a failure:)
Had a couple strikes to the secondary at the end of the afternoon video, making shorted turns.  Removed a few turns and patched, then added a ground strike ring before the evening video.  The evening (darker) video shows more of the internal discharge problems.  Potting ends a few cm above the bottom.  I though secondary field would be low enough there.  Not the case :(  There was charring along the bottom edge of potting.  Yellow glow flashes can be seen at the bottom of the coil.
The afternoon video had a 0.5mm copper wire breakout point which was slowly melting down. For the evening I switched to 0.5mm tungsten rod.  Instead of melting, it make bright white flashes from incandescence as in this frame:
No plans to extend this low-frequency QCW experiment.  Perhaps some day the dual buck converter can power a conventional QCW coil.
BTW, H-Bridge construction is described on this low-inductance-bridge thread:
https://highvoltageforum.net/index.php?topic=1324.msg11785#msg11785
Post by: Steve Ward on May 02, 2021, 04:49:48 AM
Those are some crazy sparks!  Might i suggest carbon "gouging" rod for breakout point?  I'd rate it as "bright, but much less bright than tungsten" and doesn't melt like metals.
Since its already a LF coil, could you try a bigger toroid to push the sparks up?  That seems to be my impression of how to control the spark direction.
Congrats on no transistor explosions, that's a tremendous energy reserve!
Post by: davekni on May 02, 2021, 05:54:32 AM
Steve, thank you for the compliment!  Yes, I just purchased a few 6mm diameter carbon rods after seeing that you started using those for your HFSSTC.  I'm trying to make a fixed ISM-frequency HFSSTC, at lower power than yours, for 120VAC 15A circuit.
Yes, a larger top-load would likely help keep arcs vertical a bit longer.  Then I'd be down to the ~80kHz of my larger DRSSTC.  The idea of this low-frequency QCW was to test a speculation that if ramp time were stretched in proportion to 1/frequency it might behave similarly to high-frequency QCW coils.  Answer is clearly "no".  Uspring and I have a long discussion here about the physics and I think a reasonable understanding as to why by the end.
The big 0.2F capacitor bank is eventually for my DRSSTC.  I'm working on a crazy experiment for long arcs.  448 BTB16 TRIACS will add MMC capacitance as the arc grows, just over doubling capacitance in 6 progressive steps, with switching timed at zero-crossings.
