Author Topic: "LightningStorm" VTTC project  (Read 11019 times)
Offline Avenger
    • Mr Flybacker
Re: "LightningStorm" VTTC project
« Reply #20 on: December 28, 2022, 09:48:54 PM »
Work with coil continued. Power supply in the process of being assembled in the case. I hope to finish this long-term construction soon
All ingenious is simple
Offline Avenger
    • Mr Flybacker
« Reply #21 on: January 04, 2023, 03:15:44 AM »
Happy New Year everyone! A couple of days ago I finished installing the voltage shifter battery. Capacity as before, 8 microfarads. Capacitors are located on 2 "floors", fixed with fiberglass panels.
Also made the front panel of the unit. Three ammeters and a voltmeter are fixed on it. Ammeters will measure the current in the 230V mains, as well as the plate current and the tube filament current. Soviet ship ammeters Д1600
On the front panel there are circuit breakers that serve for primary switching and protection of cooling, filament and plate circuits. Switches for the first two circuits for 16A, for the plate transformer circuit - for 63A.
For switching loads (cooling fan, filament transformer, plate transformer), a switching unit (made on contactors) is assembled on top of the plate transformer.
The power supply will be equipped with a remote wired control panel, which will turn the circuits on and off. To connect to the remote control, aviation connectors ШР40 will be used. On the remote control - connectors for 16 pins, for connecting power 230v - for 3 pins (heavy duty). There are also two connectors for connecting an external variac for the possibility of regulating the plate voltage (the unit is assembled as a universal one for powering Big Vacuum Tube Tesla coils).
« Reply #22 on: January 04, 2023, 07:46:31 PM »
Very high quality of work, very tidy construction!
What is the purpose of the thin copper wire and thin black wire going off the back of the level shifter capacitors? Is it a ground wire to the chassis of capacitors?
Offline Avenger
    • Mr Flybacker
« Reply #23 on: January 04, 2023, 08:53:35 PM »
The thick black wires connect in parallel the capacitor sections located on two "floors". One of the taps goes to the transformer, the second one will be connected to the shifter diode (the diode has not been assembled yet).
Thin black wire to the left of the capacitors - connects their cases to the base of the unit.
« Last Edit: January 04, 2023, 10:50:25 PM by Avenger »
Offline Avenger
    • Mr Flybacker
« Reply #24 on: January 06, 2023, 10:06:33 PM »
Video (of course, speech is in Russian, but maybe someone will be interested in something PURE VISUALLY) ;D
Pre-assembly of the dashboard:
Assembly of the shifter battery and estimation of the switching unit:
Offline Avenger
    • Mr Flybacker
« Reply #25 on: January 30, 2023, 09:34:51 PM »
Soldered the shifter diode. So far without a case (the case is being made). The diode consists of 80 FR307 diodes, in parallel to each there is a 510k resistor. All diodes are connected in series. The power supply was turned on for the first time in the case. Tesla coil is tested. The consumption current was measured (it was more than 100A), after which the gridleak resistor was changed to 430 ohms (it was 200 ohms). After that, the current returned to normal (80A at a maximum frequency of 50Hz, without a staccato).
In the photo, the discharge hits the steel mesh, which is located on the sofa (the sofa itself does not suffer) and into the chandelier. The length of the discharge according to the photo remained unchanged - streamers up to 1.5 m long.
« Last Edit: January 30, 2023, 09:36:35 PM by Avenger »
V-Troxi
Today at 02:42:03 PM
npmarshall
Today at 01:49:09 PM
Today at 03:59:13 AM
npmarshall
Today at 03:16:44 AM
Today at 02:58:29 AM
Today at 01:48:38 AM
npmarshall
Today at 01:47:59 AM
post Re: A few questions
Today at 01:42:14 AM
Today at 01:31:51 AM
March 20, 2023, 11:59:01 PM
post Re: primary spacing
March 20, 2023, 11:10:11 PM
romy
March 20, 2023, 08:20:34 PM
V-Troxi
March 20, 2023, 06:57:34 PM
ako
March 20, 2023, 03:07:01 PM
npmarshall
March 20, 2023, 02:21:05 PM
post GDT output buffer
March 20, 2023, 04:32:07 AM
March 20, 2023, 02:26:02 AM
March 20, 2023, 12:02:52 AM
ako
March 19, 2023, 08:51:54 PM
March 19, 2023, 06:26:07 PM
post A few questions
ako
March 19, 2023, 05:16:46 AM
March 18, 2023, 05:58:34 PM
madhurya
March 18, 2023, 12:07:42 PM
March 18, 2023, 07:30:21 AM
March 18, 2023, 04:45:04 AM
March 18, 2023, 03:45:14 AM
March 18, 2023, 02:15:42 AM
March 17, 2023, 11:14:10 PM
March 17, 2023, 10:40:47 PM
post (distributed) air gap
romy
March 17, 2023, 07:47:14 PM
post Re: Plasma Toroid
March 17, 2023, 06:47:10 PM
[Hobby Sites]
breezetix
March 17, 2023, 06:37:48 PM
breezetix
March 17, 2023, 06:29:37 PM
breezetix
March 17, 2023, 06:13:48 PM
post Re: Welding a MOT
breezetix
March 17, 2023, 06:12:08 PM
breezetix
March 17, 2023, 06:04:53 PM
post primary spacing
March 17, 2023, 05:44:14 PM
post Re: My second DRSSTC
March 17, 2023, 04:48:59 AM
March 17, 2023, 04:42:07 AM
March 17, 2023, 02:55:19 AM
Hafting
March 17, 2023, 12:09:07 AM
March 16, 2023, 07:52:19 PM
March 16, 2023, 07:32:14 PM
post My second DRSSTC
Miki_407
March 16, 2023, 03:40:21 PM
March 16, 2023, 12:04:01 PM
post Re: induction heating
romy
March 16, 2023, 08:12:37 AM
March 16, 2023, 05:41:56 AM
March 16, 2023, 05:32:24 AM
March 16, 2023, 03:53:17 AM
March 16, 2023, 01:30:31 AM
March 16, 2023, 12:17:32 AM
March 15, 2023, 11:53:29 PM
March 15, 2023, 05:26:43 PM
romy
March 15, 2023, 03:56:29 PM
romy
March 15, 2023, 03:53:31 PM
romy
March 15, 2023, 03:51:10 PM
March 14, 2023, 11:00:41 PM
March 14, 2023, 10:28:05 PM
March 14, 2023, 05:01:44 PM
romy
March 14, 2023, 03:00:36 PM
romy
March 14, 2023, 02:03:42 PM
March 14, 2023, 04:04:32 AM
March 13, 2023, 10:41:49 PM
March 13, 2023, 08:25:38 PM
March 13, 2023, 05:59:40 PM
March 13, 2023, 09:08:46 AM
March 13, 2023, 06:15:51 AM
March 13, 2023, 02:10:47 AM
March 13, 2023, 12:21:01 AM
March 13, 2023, 12:17:09 AM
March 12, 2023, 11:43:38 PM
March 12, 2023, 10:39:41 PM
ColinHeath
March 12, 2023, 10:39:05 PM
March 12, 2023, 09:46:24 PM
post Re: 160mm DRSSTC project
Mathieu thm
March 12, 2023, 09:23:23 PM
March 12, 2023, 07:52:30 PM
dannybeckett
March 12, 2023, 06:45:50 PM
March 12, 2023, 09:04:53 AM
joabel1971
March 11, 2023, 10:03:58 PM
joabel1971
March 11, 2023, 09:15:23 PM
March 11, 2023, 02:20:13 AM
dannybeckett
March 11, 2023, 12:24:07 AM
March 11, 2023, 12:13:11 AM
March 10, 2023, 09:42:29 PM
March 10, 2023, 08:38:36 PM
March 10, 2023, 08:06:23 PM
March 10, 2023, 05:13:44 PM
Alex_1996
March 10, 2023, 05:07:20 PM
Alex_1996
March 10, 2023, 04:38:21 PM
March 10, 2023, 04:25:12 PM
Alex_1996
March 10, 2023, 03:53:56 PM
dannybeckett
March 10, 2023, 01:39:57 PM
romy
March 10, 2023, 10:27:36 AM
March 10, 2023, 09:48:10 AM
March 10, 2023, 03:51:40 AM
March 10, 2023, 03:00:09 AM
dannybeckett
March 10, 2023, 01:03:19 AM
March 09, 2023, 10:51:52 PM
March 09, 2023, 07:06:03 PM
dannybeckett
March 09, 2023, 02:25:33 PM
