Author Topic: Steve Ward's DRSSTC Interrupter stops working when adjusting pulse width  (Read 768 times)
Offline verliebt_in_neukölln17
So early today I've built Steve Ward's DRSSTC Interrupter for my upcoming Tesla coil project and I've ran into a little trouble, the circuit was operating fine the first time I hooked it up, everything was working normally so i hooked up a small 5mm LED with a 330 Ohm resistor to pin 3 of the rightmost 555 timerwhich is the output and is also responsible for adjusting the pulse width with a 5K potentiometer, up until not even 5 mins, mind that the circuit ran for for 5 whole minutes with no problems, the output of the interrupter started spazzing out uncontrollably (which is most likely a curse since that happens with any circuit that i build), i double checked my wiring to no avail, now hooked up the circuit again where everything is working semi-fine again EXCEPT the 555 timer IC which is responsible for controlling the pulse width is somehow not fine, adjusting the pot even a tiny bit causes the interrupter to shut down and seize working and noticably heats up THAT single 555 timer,
Any help on clarifying me on how I should troubleshoot this circuit would be gladly appreciated,
I will provide my sloppy wiring if anyone specifically wants to see that
My semiconductors went kapow, IGBTs are fried somehow.
With sparks and pops, they took a flight,
Turning day into night!
Offline NyaaX_X
Hello~
Please check the connection and soldering, if they match the schematic?
And if you replace the error one with a new 555, is the problem still there?
When you running the circuit without problem, is there any thing heating up?
Then if those are no help. I think the real photo for your circuit is good for online debugging.
« Last Edit: June 09, 2024, 01:36:46 PM by NyaaX_X »
Bad 5K pot?
Could be high frequency oscillations, from a bad potentiometer, that makes the circuit RC circuit for timing, suddenly have a very low R value or even also the C being defective, giving you a frequency in hundreds, maybe into MHz.
Hey, I’ve fixed the problem by placing a 1k resistor between the pot and pins 6 and 7, the bare pot was shorting the supply to gnd.
post Re: Problem with SSTC
Nunu00
July 12, 2024, 10:17:36 PM
post Making a HV prove
July 12, 2024, 09:01:08 PM
July 12, 2024, 01:33:37 AM
Nunu00
July 12, 2024, 12:17:32 AM
July 11, 2024, 07:38:26 PM
July 11, 2024, 06:30:00 PM
ColinHeath
July 11, 2024, 06:08:30 PM
July 11, 2024, 12:24:56 PM
July 11, 2024, 06:42:23 AM
Cameron Prince
July 11, 2024, 05:46:07 AM
Cameron Prince
July 11, 2024, 05:26:51 AM
July 11, 2024, 02:50:54 AM
Coupling
July 11, 2024, 12:59:55 AM
July 10, 2024, 07:10:34 PM
July 10, 2024, 06:52:42 PM
July 10, 2024, 06:28:19 PM
Alex_1996
July 10, 2024, 01:34:09 PM
post Re: Silicon(e) plasma
July 10, 2024, 12:09:06 AM
Nunu00
July 09, 2024, 11:52:00 PM
July 09, 2024, 07:37:22 PM
MechatEng2023
July 09, 2024, 07:30:05 PM
July 09, 2024, 03:30:49 AM
July 09, 2024, 12:51:02 AM
July 08, 2024, 11:30:44 PM
post Re: Why so cheap?
July 08, 2024, 10:57:10 PM
July 08, 2024, 10:21:01 PM
post Why so cheap?
July 08, 2024, 09:55:24 PM
Cameron Prince
July 08, 2024, 09:18:21 PM
July 08, 2024, 05:17:49 PM
Cameron Prince
July 08, 2024, 04:49:20 PM
post Re: Tesla coil in FEMM
July 08, 2024, 04:28:43 AM
July 08, 2024, 04:06:53 AM
post Tesla coil in FEMM
July 08, 2024, 03:46:49 AM
July 08, 2024, 02:42:00 AM
July 08, 2024, 01:37:55 AM
Sebigamer
July 08, 2024, 12:53:08 AM
July 08, 2024, 12:49:48 AM
July 07, 2024, 11:15:35 PM
post Silicon(e) plasma
MechatEng2023
July 07, 2024, 11:04:43 PM
July 07, 2024, 09:39:07 PM
July 07, 2024, 05:32:56 PM
July 07, 2024, 02:52:19 PM
July 07, 2024, 02:50:04 PM
July 07, 2024, 02:20:11 PM
July 07, 2024, 10:02:22 AM
Sebigamer
July 07, 2024, 09:23:58 AM
July 07, 2024, 12:44:53 AM
July 07, 2024, 12:08:50 AM
July 06, 2024, 10:35:49 PM
July 06, 2024, 09:42:43 PM
July 06, 2024, 06:06:23 PM
July 06, 2024, 10:21:16 AM
July 06, 2024, 10:15:42 AM
July 06, 2024, 04:53:56 AM
July 06, 2024, 04:42:16 AM
July 06, 2024, 04:09:50 AM
July 06, 2024, 03:07:11 AM
July 06, 2024, 03:05:18 AM
July 06, 2024, 02:37:16 AM
July 06, 2024, 02:20:14 AM
July 06, 2024, 01:55:14 AM
July 05, 2024, 11:50:37 PM
July 05, 2024, 10:07:04 PM
gravitysrainbow
July 05, 2024, 07:13:25 PM
July 05, 2024, 06:17:13 PM
post Re: Phase lead inductors
July 04, 2024, 11:40:45 PM
post Re: Sling Psychrometer
July 04, 2024, 11:02:32 PM
post Phase lead inductors
July 04, 2024, 06:28:08 PM
July 04, 2024, 12:31:40 AM
Alex_1996
July 04, 2024, 12:07:21 AM
Alex_1996
July 04, 2024, 12:06:17 AM
July 03, 2024, 10:51:23 PM
July 03, 2024, 09:44:14 PM
July 03, 2024, 08:48:13 PM
July 03, 2024, 08:24:50 PM
Alex_1996
July 03, 2024, 08:12:55 PM
July 03, 2024, 07:29:53 PM
July 03, 2024, 07:21:38 PM
July 03, 2024, 05:05:39 PM
Alex_1996
July 03, 2024, 04:29:53 PM
July 03, 2024, 04:09:11 PM
Alex_1996
July 03, 2024, 02:47:18 PM
Alex_1996
July 03, 2024, 01:35:24 PM
July 03, 2024, 02:19:03 AM
July 03, 2024, 01:19:50 AM
July 02, 2024, 11:29:18 PM
July 02, 2024, 09:59:07 PM
July 02, 2024, 09:55:53 PM
July 02, 2024, 09:44:55 PM
July 02, 2024, 07:51:37 PM
July 02, 2024, 06:14:07 PM
July 02, 2024, 06:02:38 PM
July 02, 2024, 11:37:46 AM
July 02, 2024, 05:22:10 AM
July 02, 2024, 05:16:30 AM
drobotk
July 01, 2024, 11:50:12 PM
July 01, 2024, 08:48:53 PM
July 01, 2024, 08:40:59 AM
July 01, 2024, 08:09:42 AM
June 30, 2024, 06:49:45 AM
