Author Topic: Which power supply should i use for my spark gap tesla coil  (Read 3343 times)
Offline ElectroNex
Hello im Nex, im currently building my first spark gap tesla coil. I am looking for a power supply. Im looking for something around 450-500 Watts of power and it has to be powered by 220v 50hz. I dont want it to be an NST since i cant find any affordable ones in my price range and countries shops plus MOTS in my country are needed so the scrapyard sells one for almost 60 us dollars any ideas what i could use. ive been at car ignition coils but i dont know since their also hard to find.
Contact Me Personally at: noahstoessel@icloud.com
Sincerely, Electro Nex
Re: Which power supply should i use for my spark gap tesla coil
« Reply #1 on: May 30, 2023, 04:05:24 PM »
For a SGTC these are your possibilities that I am aware of:
1. NST
2. MOT
3. OBIT (oil burner ignition transformer)
4. Instrumentation transformer
5. Distribution transformer (pole transformer)
Unfortunately, if $60 is too expensive then I don't think you can use any of these. Maybe you will get lucky and find a discarded one.
Offline Felix M.
« Reply #2 on: May 30, 2023, 06:32:46 PM »
Hi Nex,
The cheapest option is the MOT for sure but it comes with its downsides. They don't really have the voltage to fire the spark gap and they get way to hot. The large current output also heats up your spark gap. OBITs deliver the necessary voltage but they are designed for short operation. My OBIT died after about 2 minutes due to secondary overheating. My advice is to get an (old) and cheap NST because they have the voltage and the ability to operate continiously. Since most NST hardly reach the 500W mark and you probably want something more powerful, you can add multiple in parallel.
Greetings,
Felix
Offline ElectroNex
« Reply #3 on: May 30, 2023, 06:35:22 PM »
1. NST
2. MOT
if it is possible could you give me a site that sells NST's for 60 dollars since the NST im looking at are between 250-600 dollars a piece
Offline ElectroNex
« Reply #4 on: May 30, 2023, 06:36:54 PM »
Hi Nex,
Greetings,
Felix
understood do you have any recommendations for a budget of around 100-150 dollar budget max
Offline Felix M.
« Reply #5 on: May 30, 2023, 08:02:34 PM »
You should spend your money on the transformer because in my oppinion it's the most crucial part of small SGTCs since larger coils require a larger budget. You can for example make your tank cap from tinfoil and beer bottles which costs nothing. The transformer however is the base for a good operation. If you spend some time on ebay, you will find a NST for cheap. Please don't expect any large results like 1m arcs with a budget tesla coil.
Offline ElectroNex
« Reply #6 on: May 30, 2023, 08:15:12 PM »
i have discovered a good power supply only 420 watts but when i need more power i can always order another one  its 420 watts but should work just fine: Allanson SS1235ICH my only concern is that it needs a 120v input so i will need to buy a good very effective stepdown transformer since it demands high current input does it look good to you
Offline Felix M.
« Reply #7 on: May 30, 2023, 08:30:51 PM »
The transformer itself looks good. 12kV at 35mA is quite nice. I would however think twice since you live in a 220V country. Try to find one with a fitting primary voltage because in the end it'll probably be cheaper.
Offline ElectroNex
« Reply #8 on: May 30, 2023, 08:41:34 PM »
will do thanks for all the help btw will try to look for something
Offline ElectroNex
« Reply #9 on: May 30, 2023, 08:48:34 PM »
thank you for making me look farther i found something close enough 12kv 30mA plus its shipping from germany with amazon prime so i think this will be the one i go with https://www.amazon.de/-/en/EVTSCAN-NP-12000-30-Electronic-Transformer-Supply/dp/B092ZW4WWB/ref=sr_1_11?crid=30VQ74L8RC55S&keywords=neon+sign+transformer&qid=1685472264&sprefix=neon+sign+transformer%2Caps%2C128&sr=8-11 could you just confirm if this will work before i order it plus i like that its 220-240v input
« Reply #10 on: May 30, 2023, 09:19:37 PM »
Sorry that used NST are so expensive.
I don't know for a fact, but many modern electronic neon sign transformers have a lot of fault protection circuitry. This MAY mean that it will not react well to the more chaotic SGTC environment...
Sorry that I can't give you a more definitive answer.
In my own case I bought several of these modern high frequency neon sign supplies and they turn out to be useless for powering plasma tubes because of the fault circuity. They would start up, not get the expected load and shut down.
Offline ElectroNex
« Reply #11 on: May 30, 2023, 09:22:10 PM »
thank you very much with the help a nice guy on this forum i have been able to find something cheap and effective but thanks for the advice
Offline Felix M.
« Reply #12 on: May 30, 2023, 11:03:31 PM »
Yeah alan is right! That's why I wrote (old) just because the old designs are more resistent to abuse. Try to get an old one in good shape. You can find an example of a NST I would buy in the link: https://www.ebay.com/itm/115811984481?hash=item1af6eea461:g:SmEAAOSwdWNka7zB . If you allready bought the one you mentioned, it'll work fine I think. Just keep an eye on the clock while running and don't let it run for too long.
« Last Edit: May 30, 2023, 11:05:43 PM by Felix M. »
Offline ElectroNex
« Reply #13 on: May 30, 2023, 11:06:42 PM »
let me look at some stuff my look for something soviet idk
Offline Felix M.
« Reply #14 on: May 30, 2023, 11:20:23 PM »
Most of the time you get really nice things from the soviet union when it comes to electronic components. Back then they produced large vacuum tubes, pulse capacitors, doorknob capacitors, etc...
The best thing is they are cheap relative to the components you get today.
Offline ElectroNex
« Reply #15 on: May 30, 2023, 11:21:52 PM »
couldnt find anything old with the ratings i need either too underpowered or in very very rough condition so idk
Offline NyaaX_X
« Reply #16 on: May 31, 2023, 04:25:19 AM »
If you are making a little SGTC. You can use a "ZVS oscillator". And the high voltage transformer can choose an arc welding machine or CRT TV "Flyback transformer".
Today at 02:14:17 AM
June 12, 2024, 11:04:57 PM
post Turning SSTC into DRSSTC
June 12, 2024, 10:23:08 PM
verliebt_in_neukölln17
June 12, 2024, 08:41:06 PM
June 12, 2024, 07:53:31 PM
[Static Electricity]
June 12, 2024, 06:57:13 PM
June 12, 2024, 06:54:49 PM
June 12, 2024, 03:47:28 PM
vK
June 12, 2024, 03:42:18 AM
post Re: Bigger sparks?...
June 12, 2024, 03:32:22 AM
Teslaventje
June 11, 2024, 11:05:49 PM
June 11, 2024, 05:36:46 AM
post Re: Sling Psychrometer
June 11, 2024, 12:29:31 AM
post Bigger sparks?...
Teslaventje
June 10, 2024, 11:05:55 PM
June 10, 2024, 10:57:51 PM
post Re: Benjamin's DRSSTC3
June 10, 2024, 08:08:04 PM
Hi-Deff
June 10, 2024, 06:04:09 PM
post Sling Psychrometer
June 10, 2024, 04:43:59 PM
June 10, 2024, 03:35:28 PM
Jj
June 10, 2024, 01:36:41 PM
June 09, 2024, 05:44:29 PM
June 09, 2024, 03:31:30 PM
June 09, 2024, 01:34:49 PM
June 09, 2024, 01:56:51 AM
June 08, 2024, 06:06:25 AM
June 08, 2024, 05:38:14 AM
post Interrupter for SSTC
June 08, 2024, 12:47:47 AM
June 07, 2024, 03:59:57 PM
June 07, 2024, 06:42:26 AM
June 07, 2024, 05:08:00 AM
June 07, 2024, 03:16:31 AM
June 06, 2024, 11:37:20 PM
June 06, 2024, 11:20:23 PM
June 06, 2024, 10:54:48 PM
June 06, 2024, 05:17:02 AM
June 06, 2024, 04:50:00 AM
June 06, 2024, 04:00:52 AM
June 06, 2024, 01:43:41 AM
June 05, 2024, 11:11:17 PM
June 05, 2024, 10:18:57 PM
June 05, 2024, 10:13:03 PM
June 05, 2024, 09:29:18 PM
June 05, 2024, 08:46:53 PM
June 05, 2024, 07:04:45 AM
Domo
June 05, 2024, 04:58:35 AM
June 05, 2024, 01:42:04 AM
June 04, 2024, 10:31:58 PM
pete_dl
June 04, 2024, 08:08:28 PM
June 03, 2024, 11:13:26 PM
June 03, 2024, 10:35:57 PM
Hi-Deff
June 03, 2024, 05:51:05 PM
Domo
June 03, 2024, 07:41:41 AM
June 03, 2024, 05:28:44 AM
June 03, 2024, 05:02:19 AM
June 03, 2024, 03:47:33 AM
June 03, 2024, 02:23:58 AM
Hi-Deff
June 03, 2024, 01:25:24 AM
June 03, 2024, 01:08:47 AM
June 02, 2024, 10:29:02 PM
June 02, 2024, 10:02:45 PM
post Re: Racing sparks
June 02, 2024, 08:25:37 PM
June 02, 2024, 04:51:58 PM
June 02, 2024, 04:44:30 PM
June 02, 2024, 03:25:11 PM
June 02, 2024, 01:36:11 PM
pete_dl
June 02, 2024, 11:43:40 AM
June 02, 2024, 08:49:11 AM
June 02, 2024, 08:36:07 AM
June 02, 2024, 12:41:50 AM
June 01, 2024, 08:24:35 PM
June 01, 2024, 08:22:28 PM
June 01, 2024, 03:56:53 AM
Terry
June 01, 2024, 12:03:50 AM
Hi-Deff
May 31, 2024, 11:46:20 PM
May 31, 2024, 06:13:59 PM
May 31, 2024, 01:55:22 AM
May 30, 2024, 11:57:49 PM
May 30, 2024, 11:50:06 PM
post First DRSSTC questions
Hi-Deff
May 30, 2024, 11:23:35 PM
May 30, 2024, 10:43:06 PM
May 30, 2024, 10:24:35 PM
May 30, 2024, 06:10:04 PM
May 30, 2024, 04:56:11 PM
May 30, 2024, 04:48:05 PM
May 30, 2024, 04:37:22 PM
May 30, 2024, 04:16:31 PM
May 30, 2024, 03:34:10 PM
May 30, 2024, 02:53:50 PM
May 30, 2024, 12:44:47 PM
May 30, 2024, 07:52:56 AM
May 30, 2024, 07:07:53 AM
May 30, 2024, 07:04:40 AM
May 30, 2024, 05:16:50 AM
May 30, 2024, 05:08:17 AM
May 30, 2024, 04:29:30 AM
May 30, 2024, 03:52:36 AM
May 30, 2024, 03:47:12 AM
May 30, 2024, 03:41:34 AM
May 30, 2024, 03:27:28 AM
May 29, 2024, 03:55:16 PM
