Author Topic: Inverter question  (Read 252 times)
Offline RoamingD
  • Self taught self sponsored 18yo enthusiast
Inverter question
« on: February 05, 2023, 05:42:44 PM »
Hello, I am starting to work on my first Drsstc :)
I plan to use an half bridge inverter with a single BSM150GB60DLC IGBT module so I started looking at different schematics and I have a question about capacitors C4 and C5/
Are they really needed? Because in full bridge inverter schematics that I saw, similar capacitors were not found.
Also, I plan to run the OCD set at about 300-350A, I dont know if this information helps, but I want to give as many details as I can.
Thank you for your time, dear reader  ;D
Re: Inverter question
« Reply #1 on: February 05, 2023, 10:23:12 PM »
Good circuit analysis.  You are correct that in an ideal world C4 and C5 could be left out.  (Presumes value of remaining C7 cap is reduced to achieve correct primary resonant frequency.)
In the real world, additional caps have value.  Electrolytic capacitors C1 and C2 are likely not rated to handle DRSSTC primary resonant current (high frequency and high current).  Also, wire inductance from IGBTs to C1 and C2 causes voltage spikes at the IGBTs, which can be enough to damage parts.  Smaller film capacitors are easier to connect directly adjacent IGBTs to minimize parasitic inductance.  If IGBT rated max voltage is far above bus voltage, spikes are less likely to damage IGBTs, but still increase switching energy loss.
Even with film capacitors, excess lead length can lead to issues.  If you want to be a perfectionist about this, here's my tutorial thread on low-inductance construction:
There are other topologies for adding film capacitors.  You could start with your version leaving off C4 and C5, then add film capacitors in parallel with C1 and C2 directly at IGBT terminals.  If you go that route, a further option is to split the resonant capacitor (C7 in your version, often called MMC) in half, with one half to each side of Vbus supply.  That reduces peak current through caps across Vbus (C1, C2, and mostly added film caps in parallel with these).  Since MMC is usually made from an array of smaller caps, splitting it in half is often free and easy.
Have fun with your build!
Offline RoamingD
« Reply #2 on: February 06, 2023, 02:40:42 PM »
Thank you so much for the help, sadly I can't implement the last idea of a split mmc as I already have a big resonance capacitor (I took inspiration from Franzoli Electronics last small DRSSTC)
I think i will buy a few WIMA film capacitors to use them as snubbers to suppress the spikes
Online MRMILSTAR
« Reply #3 on: February 06, 2023, 03:17:53 PM »
Does anyone know detailed specs of these Dawncaps? They look like ceramic doorknob capacitors. Are they? Those ridges on the side make me wonder. If so, are they Class 1 or Class 2?
« Last Edit: February 06, 2023, 08:32:02 PM by MRMILSTAR »
Offline RoamingD
« Reply #4 on: February 06, 2023, 05:18:47 PM »
Hello, this is their datasheet that I found on the manufacturers website, I chose to buy this capacitor for its peak rating of 1500 amps and fast rise voltage 3500 v/us I think
V-Troxi
Today at 02:42:03 PM
npmarshall
Today at 01:49:09 PM
Today at 03:59:13 AM
npmarshall
Today at 03:16:44 AM
Today at 02:58:29 AM
Today at 01:48:38 AM
npmarshall
Today at 01:47:59 AM
post Re: A few questions
Today at 01:42:14 AM
Today at 01:31:51 AM
March 20, 2023, 11:59:01 PM
post Re: primary spacing
March 20, 2023, 11:10:11 PM
romy
March 20, 2023, 08:20:34 PM
V-Troxi
March 20, 2023, 06:57:34 PM
ako
March 20, 2023, 03:07:01 PM
npmarshall
March 20, 2023, 02:21:05 PM
post GDT output buffer
March 20, 2023, 04:32:07 AM
March 20, 2023, 02:26:02 AM
March 20, 2023, 12:02:52 AM
ako
March 19, 2023, 08:51:54 PM
March 19, 2023, 06:26:07 PM
post A few questions
ako
March 19, 2023, 05:16:46 AM
March 18, 2023, 05:58:34 PM
madhurya
March 18, 2023, 12:07:42 PM
March 18, 2023, 07:30:21 AM
March 18, 2023, 04:45:04 AM
March 18, 2023, 03:45:14 AM
March 18, 2023, 02:15:42 AM
March 17, 2023, 11:14:10 PM
March 17, 2023, 10:40:47 PM
post (distributed) air gap
romy
March 17, 2023, 07:47:14 PM
post Re: Plasma Toroid
March 17, 2023, 06:47:10 PM
[Hobby Sites]
breezetix
March 17, 2023, 06:37:48 PM
breezetix
March 17, 2023, 06:29:37 PM
breezetix
March 17, 2023, 06:13:48 PM
post Re: Welding a MOT
breezetix
March 17, 2023, 06:12:08 PM
breezetix
March 17, 2023, 06:04:53 PM
post primary spacing
March 17, 2023, 05:44:14 PM
post Re: My second DRSSTC
March 17, 2023, 04:48:59 AM
March 17, 2023, 04:42:07 AM
March 17, 2023, 02:55:19 AM
Hafting
March 17, 2023, 12:09:07 AM
March 16, 2023, 07:52:19 PM
March 16, 2023, 07:32:14 PM
post My second DRSSTC
Miki_407
March 16, 2023, 03:40:21 PM
March 16, 2023, 12:04:01 PM
post Re: induction heating
romy
March 16, 2023, 08:12:37 AM
March 16, 2023, 05:41:56 AM
March 16, 2023, 05:32:24 AM
March 16, 2023, 03:53:17 AM
March 16, 2023, 01:30:31 AM
March 16, 2023, 12:17:32 AM
March 15, 2023, 11:53:29 PM
March 15, 2023, 05:26:43 PM
romy
March 15, 2023, 03:56:29 PM
romy
March 15, 2023, 03:53:31 PM
romy
March 15, 2023, 03:51:10 PM
March 14, 2023, 11:00:41 PM
March 14, 2023, 10:28:05 PM
March 14, 2023, 05:01:44 PM
romy
March 14, 2023, 03:00:36 PM
romy
March 14, 2023, 02:03:42 PM
March 14, 2023, 04:04:32 AM
March 13, 2023, 10:41:49 PM
March 13, 2023, 08:25:38 PM
March 13, 2023, 05:59:40 PM
March 13, 2023, 09:08:46 AM
March 13, 2023, 06:15:51 AM
March 13, 2023, 02:10:47 AM
March 13, 2023, 12:21:01 AM
March 13, 2023, 12:17:09 AM
March 12, 2023, 11:43:38 PM
March 12, 2023, 10:39:41 PM
ColinHeath
March 12, 2023, 10:39:05 PM
March 12, 2023, 09:46:24 PM
post Re: 160mm DRSSTC project
Mathieu thm
March 12, 2023, 09:23:23 PM
March 12, 2023, 07:52:30 PM
dannybeckett
March 12, 2023, 06:45:50 PM
March 12, 2023, 09:04:53 AM
joabel1971
March 11, 2023, 10:03:58 PM
joabel1971
March 11, 2023, 09:15:23 PM
March 11, 2023, 02:20:13 AM
dannybeckett
March 11, 2023, 12:24:07 AM
March 11, 2023, 12:13:11 AM
March 10, 2023, 09:42:29 PM
March 10, 2023, 08:38:36 PM
March 10, 2023, 08:06:23 PM
March 10, 2023, 05:13:44 PM
Alex_1996
March 10, 2023, 05:07:20 PM
Alex_1996
March 10, 2023, 04:38:21 PM
March 10, 2023, 04:25:12 PM
Alex_1996
March 10, 2023, 03:53:56 PM
dannybeckett
March 10, 2023, 01:39:57 PM
romy
March 10, 2023, 10:27:36 AM
March 10, 2023, 09:48:10 AM
March 10, 2023, 03:51:40 AM
March 10, 2023, 03:00:09 AM
dannybeckett
March 10, 2023, 01:03:19 AM
March 09, 2023, 10:51:52 PM
March 09, 2023, 07:06:03 PM
dannybeckett
March 09, 2023, 02:25:33 PM
