Author Topic: First DRSSTC 1.3b DRIVER  (Read 459 times)
Offline Alex_1996
« on: February 04, 2023, 02:06:43 PM »
Hello! This question may be too quick to answer and at the moment it is the only one I have. Maybe in a few days I will have more questions, you know how it works  ;)
I am building a small DRSSTC, and for this I am using a half bridge from FGH60N60SMD and a driver and switch from Aliexpress (I attach picture of them).
I have tested the system with a dummy load (a metal can) and the system oscillates when I test it at 50VAC input. The can gets very hot. The system consumes at that voltage about 350W with the pulse width at maximum.
To cut to the chase, I was interested in measuring the voltage of the OCD resistor, which in this case is 10 ohms, and thus know how much current was flowing through the circuit using Ohm's Law. My TC's are 1:25:25, total 1:625. I limited the OCD comparator voltage to about 4.5V so that 300A max. When I tested the system at 50VAC and measured with my multimeter the voltage on the 10 ohms resistor of the OCD, the multimeter on DC voltage scale marked 0 volts and the voltage on the comparator also marked 0 volts, something very strange, because if the diodes at the output of the CT of the OCD rectify the AC current, my multimeter should throw some voltage value from the 10 ohms resistor of the ocd and it does not do it.
That has led me to think that this driver, which looks like a 2.7 (the manufacturer hardly gives any data), is in bad shape.
Should the OCD resistor of a DRSSTC driver give a DC voltage reading? And this could be measured with a multimeter / voltmeter on DC voltage scale?
I hope you can help me, so I can implement another driver or revise the one I have  :'(
Thanks a lot
« Last Edit: March 10, 2023, 03:42:08 PM by Alex_1996 »
Re: Voltage reading on the OCD resistor
« Reply #1 on: February 05, 2023, 09:21:30 PM »
Meter is measuring average voltage.  OCD trips on peak current (converted to voltage across 10 ohm resistor).  For a full wave rectified sine wave, average is 2/PI times peak.  If interrupter duty cycle is 1%, meter should read 0.01 * 2/PI of peak voltage.
« Last Edit: February 05, 2023, 10:12:02 PM by davekni »
Offline Alex_1996
« Reply #2 on: February 06, 2023, 01:04:33 PM »
Thank you very much for your quick response
It is a subject that I was curious about, so I really appreciate the explanation
Best regards  :)
« Reply #3 on: February 07, 2023, 03:43:21 AM »
You are welcome.
BTW, It is also possible that the driver board OCD circuitry is not just like UD2.7.  I've seen designs, at least one from EVR, that place the burden resistor directly across CT secondary, with bridge rectifier after burden resistor.  Minimum current limit is then 2 diode forward voltage drops across burden resistor.  And of course, voltage across burden resistor is all AC, no DC.
Offline Alex_1996
« Reply #4 on: February 07, 2023, 11:01:32 AM »
Hello, you are right! It had passed me by that there are two types of OCD circuits
I will keep all this in mind for this DRSSTC design and for other future designs  :)
Thank you very much for your explanation
Offline Alex_1996
Re: First DRSSTC 1.3b DRIVER
« Reply #5 on: March 10, 2023, 03:53:56 PM »
Hello, I have not found another post similar to the question I am asking.
I am building my first DRSSTC. Right now I am using the 1.3b driver schematic as is, without making any modifications. The only modification, so to speak, is the use of UCC27425 instead of UCC27423 as originally used in this driver.
When I feed the driver I can't get it to work. The GDT does not hum at all. In testing, I found that it only works if I electrically connect pins 3 and 4 of the 74HC14N externally. If I do the latter, the GDT does emit a hum. I have tested the OCD with this mode of leaving pins 3 and 4 of the 74HC14N electrically connected externally and when I supply a voltage higher than the OCD limit voltage, the red LED lights up, so it seems to work.
I don't know what is happening. The integrateds are new and original. I don't understand what could be happening.
I have followed the 1.3b driver schematic as originally designed.
I hope you can help me. Attached is an image of the driver
« Reply #6 on: March 10, 2023, 04:25:12 PM »
Did you pay attention to logic polarity difference between UCC27423 and UCC27425?
Offline Alex_1996
« Reply #7 on: March 10, 2023, 04:38:21 PM »
Thank you for your quick response
As I saw the internal diagrams of both UCC's I didn't seem to see any difference between them.
Attached is an image of the diagrams of the UCC27423 and UCC27425.
If you can explain a little more I would appreciate it
Offline Alex_1996
« Reply #8 on: March 10, 2023, 05:07:20 PM »
Okay. Checking as you told me, I have seen that in the UCC27425 pins 4 and 5 are connected by an IF gate, while in the UCC27423 they are connected by a NOT gate.
That is why when I connect electrically externally pins 3 and 4 of the 74HC14N the driver works completely, since I don't deny the signal coming in through pin 3 of the 74HC14N. Not being denied, it enters without problems through pin 4 of the UCC27425 and continues without being denied, leaving through pin 5 and going to one of the Mosfets.
I hope I understood it well
npmarshall
Today at 01:49:09 PM
Today at 03:59:13 AM
npmarshall
Today at 03:16:44 AM
Today at 02:58:29 AM
Today at 01:48:38 AM
npmarshall
Today at 01:47:59 AM
post Re: A few questions
Today at 01:42:14 AM
Today at 01:31:51 AM
March 20, 2023, 11:59:01 PM
post Re: primary spacing
March 20, 2023, 11:10:11 PM
romy
March 20, 2023, 08:20:34 PM
V-Troxi
March 20, 2023, 06:57:34 PM
ako
March 20, 2023, 03:07:01 PM
npmarshall
March 20, 2023, 02:21:05 PM
post GDT output buffer
March 20, 2023, 04:32:07 AM
March 20, 2023, 02:26:02 AM
March 20, 2023, 12:02:52 AM
ako
March 19, 2023, 08:51:54 PM
March 19, 2023, 06:26:07 PM
post A few questions
ako
March 19, 2023, 05:16:46 AM
March 18, 2023, 05:58:34 PM
madhurya
March 18, 2023, 12:07:42 PM
March 18, 2023, 07:30:21 AM
March 18, 2023, 04:45:04 AM
March 18, 2023, 03:45:14 AM
March 18, 2023, 02:15:42 AM
March 17, 2023, 11:14:10 PM
March 17, 2023, 10:40:47 PM
post (distributed) air gap
romy
March 17, 2023, 07:47:14 PM
post Re: Plasma Toroid
March 17, 2023, 06:47:10 PM
[Hobby Sites]
breezetix
March 17, 2023, 06:37:48 PM
breezetix
March 17, 2023, 06:29:37 PM
breezetix
March 17, 2023, 06:13:48 PM
post Re: Welding a MOT
breezetix
March 17, 2023, 06:12:08 PM
breezetix
March 17, 2023, 06:04:53 PM
post primary spacing
March 17, 2023, 05:44:14 PM
post Re: My second DRSSTC
March 17, 2023, 04:48:59 AM
March 17, 2023, 04:42:07 AM
March 17, 2023, 02:55:19 AM
Hafting
March 17, 2023, 12:09:07 AM
March 16, 2023, 07:52:19 PM
March 16, 2023, 07:32:14 PM
post My second DRSSTC
Miki_407
March 16, 2023, 03:40:21 PM
March 16, 2023, 12:04:01 PM
post Re: induction heating
romy
March 16, 2023, 08:12:37 AM
March 16, 2023, 05:41:56 AM
March 16, 2023, 05:32:24 AM
March 16, 2023, 03:53:17 AM
March 16, 2023, 01:30:31 AM
March 16, 2023, 12:17:32 AM
March 15, 2023, 11:53:29 PM
March 15, 2023, 05:26:43 PM
romy
March 15, 2023, 03:56:29 PM
romy
March 15, 2023, 03:53:31 PM
romy
March 15, 2023, 03:51:10 PM
March 14, 2023, 11:00:41 PM
March 14, 2023, 10:28:05 PM
March 14, 2023, 05:01:44 PM
romy
March 14, 2023, 03:00:36 PM
romy
March 14, 2023, 02:03:42 PM
March 14, 2023, 04:04:32 AM
March 13, 2023, 10:41:49 PM
March 13, 2023, 08:25:38 PM
March 13, 2023, 05:59:40 PM
March 13, 2023, 09:08:46 AM
March 13, 2023, 06:15:51 AM
March 13, 2023, 02:10:47 AM
March 13, 2023, 12:21:01 AM
March 13, 2023, 12:17:09 AM
March 12, 2023, 11:43:38 PM
March 12, 2023, 10:39:41 PM
ColinHeath
March 12, 2023, 10:39:05 PM
March 12, 2023, 09:46:24 PM
post Re: 160mm DRSSTC project
Mathieu thm
March 12, 2023, 09:23:23 PM
March 12, 2023, 07:52:30 PM
dannybeckett
March 12, 2023, 06:45:50 PM
March 12, 2023, 09:04:53 AM
joabel1971
March 11, 2023, 10:03:58 PM
joabel1971
March 11, 2023, 09:15:23 PM
March 11, 2023, 02:20:13 AM
dannybeckett
March 11, 2023, 12:24:07 AM
March 11, 2023, 12:13:11 AM
March 10, 2023, 09:42:29 PM
March 10, 2023, 08:38:36 PM
March 10, 2023, 08:06:23 PM
March 10, 2023, 05:13:44 PM
Alex_1996
Alex_1996
Alex_1996
dannybeckett
March 10, 2023, 01:39:57 PM
romy
March 10, 2023, 10:27:36 AM
March 10, 2023, 09:48:10 AM
March 10, 2023, 03:51:40 AM
March 10, 2023, 03:00:09 AM
dannybeckett
March 10, 2023, 01:03:19 AM
March 09, 2023, 10:51:52 PM
March 09, 2023, 07:06:03 PM
dannybeckett
March 09, 2023, 02:25:33 PM
March 09, 2023, 10:11:27 AM
