Author Topic: Welding a MOT  (Read 2667 times)
Offline Alberto
Welding a MOT
« on: January 25, 2023, 09:37:27 PM »
Hi everyone. I´m making a spot welder so I have removed the secondary of a MOT and put 2 turns of 13mm wire.
To do that I removed the "lid" and weld it again, but I have realised that during the weld in one side  is slighly displaced. The "crack" starts in A and goes to B, with the shape of a wedge, so the plates don´t face with the rest of the plates
Does affect this to the performance of the transformer?
Thank you
Offline Da_Stier
Re: Welding a MOT
« Reply #1 on: January 25, 2023, 10:21:43 PM »
As far as I'm aware it shouldn't really matter, it would work the same even if you had two completely different cores.
The only thing is that it might rattle a bit if one piece is loose.
In that case some glue should fix that.
Greetings,
Michael
Re: Welding a MOT
« Reply #2 on: January 26, 2023, 03:42:01 AM »
Agree, that little separation of laminations is not any issue.
Not sure what you mean by "lid".  Can you show an image of the weld?  The possible issue would be weld shorting between laminations, defeating the purpose of having a laminated core.
Offline Alberto
Re: Welding a MOT
« Reply #3 on: January 26, 2023, 12:01:48 PM »
Thanks for your answers
I cut the original weld with the angle grinder and later weld it again with TIG (using steel rod)
I was careful with no overheat and at the end I checked that there was no contact beteewn the coils and the armature
Re: Welding a MOT
« Reply #4 on: January 27, 2023, 05:10:14 AM »
Looks fine, as the new weld isn't making a conductive loop around most of the magnetic path.  Probably will heat somewhat at the new weld, as it is likely deeper than the original.
Thank you for the pictures.  Now I understand what you did.
Offline Alberto
Re: Welding a MOT
« Reply #5 on: January 27, 2023, 01:30:02 PM »
Thanks to you for all your help!
Re: Welding a MOT
« Reply #6 on: January 27, 2023, 08:07:12 PM »
Just for future references, core parts are normally called I, E or C cores, as the letters represent their form when viewed from the side :)
Offline Alberto
Re: Welding a MOT
« Reply #7 on: January 27, 2023, 08:17:06 PM »
Ahh ok ok. Thank you for the explanation.
And one more question. I want to weld a pair of parts to attach the arms of the welder. Does that affect to the performance of the transformer? I mean 2 parts like m8 screws
Re: Welding a MOT
« Reply #8 on: January 27, 2023, 08:43:51 PM »
The feet or mounting plate of a transformer is often just spot welded onto the cores.
You do not have to worry that much about a spot welder transformer. It is very short on-times, not continues use. There is plenty of time for it to cool down between welds :)
Offline Alberto
Re: Welding a MOT
« Reply #9 on: January 28, 2023, 04:53:39 PM »
Thanbks for your answer. no no, I didn´t mean about the temperature of the welds. I mean since I´m attaching steel parts to the armature, they could change the flux of the magnetic field
Re: Welding a MOT
« Reply #10 on: January 28, 2023, 10:14:54 PM »
I meant the welds of the transformer being used for spot welding, not welds of attaching the M8 bolts.
Because spot welding is very short term load, the transformer might be unbalanced, but if that results in higher losses, its not a problem when spot welding is not a continues load.
Offline Alberto
Re: Welding a MOT
« Reply #11 on: January 28, 2023, 11:47:22 PM »
Ahh ok ok thank you!
Re: Welding a MOT
« Reply #12 on: January 30, 2023, 10:16:14 PM »
I agree with Mads and Dave: you can weld stuff to outside of MOT core block without much effect on its use in a spot welding machine.
Technically, the mounting plate connections in that stock picture and this one here are plug welds, not spot welds. Made by arc welding process similar to that which joins the E and I core blocks.  No welding tool pressure or intentional large current passing through the joint.
Offline Alberto
Re: Welding a MOT
« Reply #13 on: January 30, 2023, 10:36:01 PM »
Thank you
I always learn a lot in this forum. But I don´t have too much idea and I can only ask instead to contribute
Offline Alberto
Re: Welding a MOT
« Reply #14 on: February 12, 2023, 09:41:30 PM »
Done!!
Thank you again for all your advice.
And I know what are you thinking, I bought it because it looks like brand new but I really made it  ;D
Re: Welding a MOT
« Reply #15 on: February 13, 2023, 01:36:16 AM »
It does look like a successful project.  Is it working well?  Are you using commercial spot welding electrodes at the tips?
Offline Alberto
Re: Welding a MOT
« Reply #16 on: February 13, 2023, 09:30:29 AM »
Thank you!
I only tried once to weld 0,75 mm steel and did it fine.
The electrodes are 10mm the thick ones and 6mm the thin ones. They are regular copper bar
Offline breezetix
  • Trent Basden
    • Subscribe for High Voltage + other experiments
Re: Welding a MOT
« Reply #17 on: March 17, 2023, 06:12:08 PM »
Thank you
It's fine. Doesn't affect performance. Probably a VERY tiny amount.
I'm Trent and deaf. I like high voltage and try to make better YouTube content. Also a survivor of a PT explosion.
Re: Welding a MOT
post Re: UD+ debugging (randomly skipping pulses)
Today at 04:12:52 AM
Today at 03:22:21 AM
post Re: Success!!!
June 15, 2024, 09:03:06 PM
post Success!!!
June 15, 2024, 08:29:43 PM
post Re: Benjamin's DRSSTC3
June 15, 2024, 05:38:36 AM
Jj
June 15, 2024, 03:09:41 AM
post Re: Are TVS diodes necessary for full bridge?
Simranjit
June 15, 2024, 01:53:07 AM
June 15, 2024, 01:07:30 AM
June 15, 2024, 12:45:22 AM
June 14, 2024, 10:41:03 PM
post UD+ debugging (randomly skipping pulses)
June 14, 2024, 10:20:00 PM
June 14, 2024, 09:47:48 PM
post Fronius IG Plus 2LT-2 6kW Solar Inverter Teardown
June 14, 2024, 09:40:33 PM
Simranjit
June 14, 2024, 07:44:12 AM
June 14, 2024, 05:21:55 AM
Simranjit
June 14, 2024, 03:24:43 AM
June 14, 2024, 03:13:44 AM
Simranjit
June 14, 2024, 02:27:06 AM
June 14, 2024, 01:56:58 AM
post Are TVS diodes necessary for full bridge?
Simranjit
June 13, 2024, 11:21:46 PM
post Re: Bigger sparks?...
Teslaventje
June 13, 2024, 08:50:56 PM
post Re: Steve Ward's DRSSTC Interrupter stops working when adjusting pulse width
June 13, 2024, 07:43:37 PM
June 13, 2024, 04:52:08 PM
post Re: Turning SSTC into DRSSTC
Simranjit
June 13, 2024, 02:14:17 AM
June 12, 2024, 11:04:57 PM
post Turning SSTC into DRSSTC
Simranjit
June 12, 2024, 10:23:08 PM
post Re: UD2.7C constantly in OCP despite having signal
verliebt_in_neukölln17
June 12, 2024, 08:41:06 PM
June 12, 2024, 07:53:31 PM
post Re: Van de Graaf Voltage measurement with voltage sensor and voltage divider
[Static Electricity]
June 12, 2024, 06:57:13 PM
post UD2.7C constantly in OCP despite having signal
June 12, 2024, 06:54:49 PM
June 12, 2024, 03:47:28 PM
post Van de Graaf Voltage measurement with voltage sensor and voltage divider
vK
June 12, 2024, 03:42:18 AM
June 12, 2024, 03:32:22 AM
Teslaventje
June 11, 2024, 11:05:49 PM
June 11, 2024, 05:36:46 AM
post Re: Sling Psychrometer
June 11, 2024, 12:29:31 AM
post Bigger sparks?...
Teslaventje
June 10, 2024, 11:05:55 PM
June 10, 2024, 10:57:51 PM
June 10, 2024, 08:08:04 PM
Hi-Deff
June 10, 2024, 06:04:09 PM
post Sling Psychrometer
June 10, 2024, 04:43:59 PM
June 10, 2024, 03:35:28 PM
Jj
June 10, 2024, 01:36:41 PM
post Re: Is a 60UF 800VDC Dawncap good for an induction heater?
June 09, 2024, 05:44:29 PM
post Is a 60UF 800VDC Dawncap good for an induction heater?
June 09, 2024, 03:31:30 PM
June 09, 2024, 01:34:49 PM
post Steve Ward's DRSSTC Interrupter stops working when adjusting pulse width
June 09, 2024, 01:56:51 AM
June 08, 2024, 06:06:25 AM
post Re: Coulometric hourmeters
June 08, 2024, 05:38:14 AM
post Interrupter for SSTC
Simranjit
June 08, 2024, 12:47:47 AM
post Re: Adding capacitor to primary in SSTC
Michelle_
June 07, 2024, 03:59:57 PM
June 07, 2024, 06:42:26 AM
post Re: Space-X Starship test this week
June 07, 2024, 05:08:00 AM
post Re: Half bridge sstc different waveform on two mosfets
June 07, 2024, 03:16:31 AM
June 06, 2024, 11:37:20 PM
post Adding capacitor to primary in SSTC
Simranjit
June 06, 2024, 11:20:23 PM
June 06, 2024, 10:54:48 PM
June 06, 2024, 05:17:02 AM
Simranjit
June 06, 2024, 04:50:00 AM
June 06, 2024, 04:00:52 AM
June 06, 2024, 01:43:41 AM
Simranjit
June 05, 2024, 11:11:17 PM
Michelle_
June 05, 2024, 10:18:57 PM
Simranjit
June 05, 2024, 10:13:03 PM
June 05, 2024, 09:29:18 PM
post Half bridge sstc different waveform on two mosfets
Simranjit
June 05, 2024, 08:46:53 PM
post Re: Want to build HV HF oscilloscope probe.
June 05, 2024, 07:04:45 AM
Domo
June 05, 2024, 04:58:35 AM
post Re: Pearson current monitor model 1330 teardown (100kA)
June 05, 2024, 01:42:04 AM
June 04, 2024, 10:31:58 PM
pete_dl
June 04, 2024, 08:08:28 PM
June 03, 2024, 11:13:26 PM
post Re: First DRSSTC questions
June 03, 2024, 10:35:57 PM
Hi-Deff
June 03, 2024, 05:51:05 PM
Domo
June 03, 2024, 07:41:41 AM
June 03, 2024, 05:28:44 AM
June 03, 2024, 05:02:19 AM
June 03, 2024, 03:47:33 AM
June 03, 2024, 02:23:58 AM
Hi-Deff
June 03, 2024, 01:25:24 AM
June 03, 2024, 01:08:47 AM
June 02, 2024, 10:29:02 PM
post Re: Steve Ward SSTC5 build
Michelle_
June 02, 2024, 10:02:45 PM
post Re: Racing sparks
June 02, 2024, 08:25:37 PM
Michelle_
June 02, 2024, 04:51:58 PM
Michelle_
June 02, 2024, 04:44:30 PM
June 02, 2024, 03:25:11 PM
post APC Smart-UPS 1500VA Teardown
June 02, 2024, 01:36:11 PM
pete_dl
June 02, 2024, 11:43:40 AM
June 02, 2024, 08:49:11 AM
June 02, 2024, 08:36:07 AM
June 02, 2024, 12:41:50 AM
June 01, 2024, 08:24:35 PM
post Pearson current monitor model 1330 teardown (100kA)
June 01, 2024, 08:22:28 PM
Michelle_
June 01, 2024, 03:56:53 AM
June 01, 2024, 12:03:50 AM
Hi-Deff
May 31, 2024, 11:46:20 PM
Michelle_
May 31, 2024, 06:13:59 PM
May 31, 2024, 01:55:22 AM
May 30, 2024, 11:57:49 PM
