Author Topic: Slayer exciter circuit - struggling with how it works  (Read 235 times)
Offline Tatranka
« on: November 28, 2022, 02:57:17 PM »
I'm trying to understand, How slayer exciter works, but there's some stuff I can't understand.
First, I don't understand, how induced current in the secondary coil and the capacitor can switch off the transistor. I'm trying to find out, what exactly happens inside, but most explanations are oversimplified. I've seen warnings some of them are even wrong.
I found one explanation by electro boom here https://www.electroboom.com/?p=521 where I struggle with points 4 and 5
Then, some of the circuits use a diode, but I found many schemes which don't use a diode at all.
Also, slayer exciter is famous for how it can autotune itself, but changing turns of the primary coil or secondary has effects on performance, so what happens inside?
And last, Tesla coil is a resonant transformer, bud I couldn't find any other explanation, of how it rises output voltage, then by the turns ratio of coils like a classic transformer. I know it can't be so simple and it has to do something with the resonance between coils.
I know my questions are quite chaotic, but I'm fascinated with Tesla coils, but I've tried my best a haven't found the answers I want. I would be grateful if you could help me.
Offline Twospoons
Re: Slayer exciter circuit - struggling with how it works
« Reply #1 on: November 30, 2022, 04:43:37 AM »
I agree electroboom's explanation is a bit odd at points 4 and 5.  Its much better to think in terms of current, since a BJT is controlled by its base current, not its base voltage.
So at the BJT base we have a DC bias current from the resistor + the AC current flowing in the LC tank formed by the secondary winding and its stray C.
That AC current gets amplified by the BJT, and drives the primary coil, driving more energy into the secondary resonant tank. On each cycle more energy is added to the tank, making the AC current bigger, and the AC voltage at the output terminal bigger too.  Eventually the AC current is large enough that the BJT turns off completely for half of each cycle - so its running in Class C.  You can see why the phasing is critical - get it backwards and the amplified signal will oppose the oscillation, instead of enhancing it.
 The reverse diode provides a path for the AC half cycle that would otherwise be blocked by the base-emitter junction being reverse biased. Without the diode the current has to find another path, and might blow the BJT in the process.
« Last Edit: November 30, 2022, 04:49:58 AM by Twospoons »
post Re: Teardown of General Electrics 3 Million Volt Lightning Laboratory
Avenger
February 07, 2023, 11:56:13 PM
February 07, 2023, 09:14:32 PM
February 07, 2023, 05:15:53 PM
TizianoBll
February 07, 2023, 04:50:10 PM
Avenger
February 07, 2023, 02:33:52 PM
post Re: Voltage reading on the OCD resistor
Alex_1996
February 07, 2023, 11:01:32 AM
post Re: Has anyone used PCB123 ?
February 07, 2023, 08:29:21 AM
post Re: Level of vacuum to purge transformer coils
February 07, 2023, 05:25:00 AM
February 07, 2023, 05:15:22 AM
February 07, 2023, 04:55:19 AM
post Has anyone used PCB123 ?
February 07, 2023, 04:21:26 AM
February 07, 2023, 03:43:21 AM
February 06, 2023, 09:57:44 PM
February 06, 2023, 09:29:13 PM
February 06, 2023, 09:27:37 PM
February 06, 2023, 09:17:02 PM
February 06, 2023, 09:13:43 PM
February 06, 2023, 09:11:25 PM
February 06, 2023, 09:07:56 PM
February 06, 2023, 09:06:04 PM
February 06, 2023, 08:56:53 PM
February 06, 2023, 08:52:03 PM
February 06, 2023, 08:48:18 PM
February 06, 2023, 08:46:52 PM
post Teardown of General Electrics 3 Million Volt Lightning Laboratory
February 06, 2023, 08:41:13 PM
post Saving GE's 3 Million Volt Lightning Laboratory
[Crowdfunding]
February 06, 2023, 07:33:09 PM
post Re: Inverter question
RoamingD
February 06, 2023, 05:18:47 PM
February 06, 2023, 03:17:53 PM
RoamingD
February 06, 2023, 02:40:42 PM
Alex_1996
February 06, 2023, 01:04:33 PM
post Re: Chunky Windings From Distribution Transformer
February 06, 2023, 11:15:11 AM
post Re: 160mm DRSSTC project
Mathieu thm
February 05, 2023, 10:25:52 PM
February 05, 2023, 10:23:12 PM
February 05, 2023, 09:21:30 PM
post Inverter question
RoamingD
February 05, 2023, 05:42:44 PM
post Re: Another Huawei RRU3928 teardown but the 900MHz model this time
February 05, 2023, 04:17:25 PM
post Voltage reading on the OCD resistor
Alex_1996
February 04, 2023, 02:06:43 PM
Alex_1996
February 04, 2023, 01:45:58 PM
post Re: QCW questions
February 04, 2023, 05:14:57 AM
February 03, 2023, 07:39:37 AM
post Chunky Windings From Distribution Transformer
February 02, 2023, 08:48:05 PM
post Re: ud 2.7c poped caps
February 01, 2023, 04:25:30 AM
January 31, 2023, 05:20:38 PM
January 31, 2023, 04:49:32 AM
nzoomed
January 31, 2023, 02:25:40 AM
post Re: Welding a MOT
January 30, 2023, 10:36:01 PM
January 30, 2023, 10:16:14 PM
Avenger
January 30, 2023, 09:34:51 PM
January 30, 2023, 06:33:10 AM
post Re: improving zvs driver
January 30, 2023, 03:42:13 AM
January 30, 2023, 01:01:56 AM
x-rayLamp
January 30, 2023, 12:04:20 AM
January 29, 2023, 07:15:43 PM
January 29, 2023, 06:13:45 PM
Mike
January 29, 2023, 05:53:11 PM
post Please, help me (financially) build a DRSSTC
[Crowdfunding]
Pavol
January 29, 2023, 03:02:55 PM
post ud 2.7c poped caps
January 29, 2023, 02:04:59 PM
post Showa SP-103 Standalone Xray Head Teardown
January 29, 2023, 01:04:56 PM
January 29, 2023, 04:24:43 AM
January 29, 2023, 12:54:13 AM
January 28, 2023, 11:47:22 PM
January 28, 2023, 11:34:58 PM
January 28, 2023, 10:14:54 PM
January 28, 2023, 04:53:39 PM
January 28, 2023, 04:59:05 AM
post Re: First test of the SSTC
January 28, 2023, 04:44:51 AM
January 28, 2023, 04:35:22 AM
LoOdaK
January 28, 2023, 03:29:09 AM
January 27, 2023, 11:15:03 PM
January 27, 2023, 08:43:51 PM
January 27, 2023, 08:17:06 PM
January 27, 2023, 08:07:12 PM
January 27, 2023, 01:30:02 PM
x-rayLamp
January 27, 2023, 01:01:01 PM
post Re: Phase lead problems on ud2.7c
vince1
January 27, 2023, 12:49:46 PM
January 27, 2023, 06:07:49 AM
January 27, 2023, 05:22:46 AM
January 27, 2023, 05:10:14 AM
January 27, 2023, 05:05:40 AM
January 27, 2023, 04:44:24 AM
post Phase lead problems on ud2.7c
vince1
January 27, 2023, 01:26:20 AM
x-rayLamp
January 26, 2023, 08:13:24 PM
LoOdaK
January 26, 2023, 12:02:14 PM
January 26, 2023, 12:01:48 PM
post Re: Ramped SSTC - Power Supply Issues
January 26, 2023, 05:35:32 AM
January 26, 2023, 04:55:24 AM
January 26, 2023, 04:14:49 AM
January 26, 2023, 03:57:19 AM
January 26, 2023, 03:42:01 AM
January 25, 2023, 10:21:43 PM
post Welding a MOT
January 25, 2023, 09:37:27 PM
January 25, 2023, 09:36:22 PM
January 25, 2023, 08:35:49 PM
post improving zvs driver
x-rayLamp
January 25, 2023, 04:32:37 PM
nzoomed
January 25, 2023, 08:27:01 AM
January 25, 2023, 04:08:42 AM
January 24, 2023, 06:37:39 PM
January 24, 2023, 05:21:49 AM
post Re: 8 kW Induction Cooktop Teardown and Reverse engineering
January 24, 2023, 04:41:01 AM
post Ramped SSTC - Power Supply Question + General Improvements
January 23, 2023, 10:48:17 PM
