Author Topic: My completed 14-stage Cockroft-Walton voltage multiplier  (Read 6625 times)
Offline 304er
  • "Always the hard way..."
Re: My completed 14-stage Cockroft-Walton voltage multiplier
« Reply #20 on: November 25, 2021, 12:42:59 AM »
Hi Steve,
Nice little convenient mod. Great clean integration in to the multiplier. Just as I would expect from you 👍
Chris Reeland
Ladd Illinois USA
Chris Reeland
Ladd Illinois USA
Former Printer
« Reply #21 on: November 25, 2021, 04:50:11 AM »
Thanks Chris!
« Reply #22 on: November 25, 2021, 05:51:03 AM »
I was concerned that the intense electric field might damage the circuitry or affect its operation but everything seems fine. I still have the option of using the hard-wired remote switch.
Similarly, I was amazed that wireless microphones worked for Tesla coil and Marx generator demonstrations.  My friend brought one to our Maker Faire exhibit and we each used it for our respective presentations.  In our use, the receiver was farther from interference and the transmitter closer, so that likely helped.
Ion motor powered by my completed 14-stage Cockroft-Walton voltage multiplier
« Reply #23 on: December 16, 2021, 10:22:08 PM »
I made a short video of an ion motor being powered by my voltage multiplier.  It took 3 attempts to make this video because I kept getting shocked by the intense electric field! I was successful on the third try because I moved back about 6 feet.
« Reply #24 on: January 25, 2023, 09:36:22 PM »
I added a new improvement to my voltage multiplier. It is a protection circuit that prevents damage caused by the accidental application of reverse-polarity power. If someone accidentally applies DC power from the external power supply with the incorrect polarity this circuit will not allow the current to flow. Without this my ZVS driver and RF receiver controller would be damaged.
You can do this with a diode but a regular silicon junction diode drops about 0.7 volts. With 10 amps of current this would be a 7 watt loss. In addition to wasting power, you would have to use a heat sink to cool the diode.
The next best method is to use a Schottky diode. These only drop about 0.5 volt. This is better but it still represents a loss of about 5 watts at 10 amps of current. I initially used this method.
The best method is to use 2 MOSFETs and some logic. This circuit is sometimes called an "ideal diode". This circuit drops less than 0.1 volts at 10 amps. This is a loss of less than 1 watt. This is what I currently use. It uses 2 MOSFETs and a LM74700-Q1 ideal diode controller chip. I could have built it myself but you can buy a complete circuit for less than $4 which is probably less than I would have spent if I bought the parts and made a circuit board.
I have attached a picture of the small circuit board as installed in my voltage multiplier. This protection circuit would be useful for any project that relies on an external DC power supply. This particular circuit can handle up to at least 30 volts and 15 amps.
« Last Edit: January 25, 2023, 11:43:55 PM by MRMILSTAR »
« Reply #25 on: January 26, 2023, 03:57:19 AM »
Nice find!  Doesn't appear to be any particular need for 2 FETs.  Looks like they are just paralleled for higher current capability.
I also see two-terminal versions on EBay.  Would be interesting to analyze how they work, measure the reverse current needed to cause turn-off, etc.  Claim is 2us turn-off time, but that is likely with high current such as connecting a reversed supply input.
https://www.ebay.com/itm/325423537248
« Reply #26 on: January 26, 2023, 04:55:24 AM »
The 2 MOSFETs are for greater current capacity. This one is rated for up to 15 amps. I didn't think the 2-terminal designs would have worked for my application. I also bought another 4-terminal one from E-Bay that only had the 2 MOSFETs but without the ideal diode controller IC. I measured its forward voltage drop and it was about 0.5 volts which wasn't any better than a Schottky diode. I didn't investigate why it performed so poorly. I just ditched it for the one with the controller IC which performed much better. The controller IC is a tiny 6-pin device and is hidden behind one of the blue wires in the picture.
« Last Edit: January 26, 2023, 05:02:18 AM by MRMILSTAR »
Offline IonWind
« Reply #27 on: March 02, 2023, 09:28:38 AM »
After 6 months of work I have finally finished my Cockroft-Walton voltage multiplier. It is a half-wave design with 14-stages. The specifications are: ...
Wow !!! Absolutely lovely to look at too :)
Gary.
I know a little about a lot and a lot about a little.
V-Troxi
Today at 02:42:03 PM
npmarshall
Today at 01:49:09 PM
Today at 03:59:13 AM
npmarshall
Today at 03:16:44 AM
Today at 02:58:29 AM
Today at 01:48:38 AM
npmarshall
Today at 01:47:59 AM
post Re: A few questions
Today at 01:42:14 AM
Today at 01:31:51 AM
March 20, 2023, 11:59:01 PM
post Re: primary spacing
March 20, 2023, 11:10:11 PM
romy
March 20, 2023, 08:20:34 PM
V-Troxi
March 20, 2023, 06:57:34 PM
ako
March 20, 2023, 03:07:01 PM
npmarshall
March 20, 2023, 02:21:05 PM
post GDT output buffer
March 20, 2023, 04:32:07 AM
March 20, 2023, 02:26:02 AM
March 20, 2023, 12:02:52 AM
ako
March 19, 2023, 08:51:54 PM
March 19, 2023, 06:26:07 PM
post A few questions
ako
March 19, 2023, 05:16:46 AM
March 18, 2023, 05:58:34 PM
madhurya
March 18, 2023, 12:07:42 PM
March 18, 2023, 07:30:21 AM
March 18, 2023, 04:45:04 AM
March 18, 2023, 03:45:14 AM
March 18, 2023, 02:15:42 AM
March 17, 2023, 11:14:10 PM
March 17, 2023, 10:40:47 PM
post (distributed) air gap
romy
March 17, 2023, 07:47:14 PM
post Re: Plasma Toroid
March 17, 2023, 06:47:10 PM
[Hobby Sites]
breezetix
March 17, 2023, 06:37:48 PM
breezetix
March 17, 2023, 06:29:37 PM
breezetix
March 17, 2023, 06:13:48 PM
post Re: Welding a MOT
breezetix
March 17, 2023, 06:12:08 PM
breezetix
March 17, 2023, 06:04:53 PM
post primary spacing
March 17, 2023, 05:44:14 PM
post Re: My second DRSSTC
March 17, 2023, 04:48:59 AM
March 17, 2023, 04:42:07 AM
March 17, 2023, 02:55:19 AM
Hafting
March 17, 2023, 12:09:07 AM
March 16, 2023, 07:52:19 PM
March 16, 2023, 07:32:14 PM
post My second DRSSTC
Miki_407
March 16, 2023, 03:40:21 PM
March 16, 2023, 12:04:01 PM
post Re: induction heating
romy
March 16, 2023, 08:12:37 AM
March 16, 2023, 05:41:56 AM
March 16, 2023, 05:32:24 AM
March 16, 2023, 03:53:17 AM
March 16, 2023, 01:30:31 AM
March 16, 2023, 12:17:32 AM
March 15, 2023, 11:53:29 PM
March 15, 2023, 05:26:43 PM
romy
March 15, 2023, 03:56:29 PM
romy
March 15, 2023, 03:53:31 PM
romy
March 15, 2023, 03:51:10 PM
March 14, 2023, 11:00:41 PM
March 14, 2023, 10:28:05 PM
March 14, 2023, 05:01:44 PM
romy
March 14, 2023, 03:00:36 PM
romy
March 14, 2023, 02:03:42 PM
March 14, 2023, 04:04:32 AM
March 13, 2023, 10:41:49 PM
March 13, 2023, 08:25:38 PM
March 13, 2023, 05:59:40 PM
March 13, 2023, 09:08:46 AM
March 13, 2023, 06:15:51 AM
March 13, 2023, 02:10:47 AM
March 13, 2023, 12:21:01 AM
March 13, 2023, 12:17:09 AM
March 12, 2023, 11:43:38 PM
March 12, 2023, 10:39:41 PM
ColinHeath
March 12, 2023, 10:39:05 PM
March 12, 2023, 09:46:24 PM
post Re: 160mm DRSSTC project
Mathieu thm
March 12, 2023, 09:23:23 PM
March 12, 2023, 07:52:30 PM
dannybeckett
March 12, 2023, 06:45:50 PM
March 12, 2023, 09:04:53 AM
joabel1971
March 11, 2023, 10:03:58 PM
joabel1971
March 11, 2023, 09:15:23 PM
March 11, 2023, 02:20:13 AM
dannybeckett
March 11, 2023, 12:24:07 AM
March 11, 2023, 12:13:11 AM
March 10, 2023, 09:42:29 PM
March 10, 2023, 08:38:36 PM
March 10, 2023, 08:06:23 PM
March 10, 2023, 05:13:44 PM
Alex_1996
March 10, 2023, 05:07:20 PM
Alex_1996
March 10, 2023, 04:38:21 PM
March 10, 2023, 04:25:12 PM
Alex_1996
March 10, 2023, 03:53:56 PM
dannybeckett
March 10, 2023, 01:39:57 PM
romy
March 10, 2023, 10:27:36 AM
March 10, 2023, 09:48:10 AM
March 10, 2023, 03:51:40 AM
March 10, 2023, 03:00:09 AM
dannybeckett
March 10, 2023, 01:03:19 AM
March 09, 2023, 10:51:52 PM
March 09, 2023, 07:06:03 PM
dannybeckett
March 09, 2023, 02:25:33 PM
