Author Topic: Does not name a type even though I made a typedef  (Read 3496 times)
Offline Zipdox
    • Zipdox
« on: March 27, 2020, 11:58:01 PM »
For some reason I can't compile this code for Arduino.
Code: [Select]
#include <MIDI.h>
#define samplingRate 62500
#define maxPlayingNotes 2
MIDI_CREATE_DEFAULT_INSTANCE();
float midiFrequency(float note){
  return 440*(pow(2, (note-69)/12));
typedef struct {
    byte pitch;
    int onTime;
    int offTime;
    int hasBeenOn;
} Note;
Note getNoteTimes(byte pitch, float dutyCycle){
  float period = samplingRate/midiFrequency(pitch);
  Note finalNote = {pitch, round(dutyCycle*period), round((1-dutyCycle)*period), 0};
  return finalNote;
volatile Note playingNotes[maxPlayingNotes];
void handleNoteOn(byte channel, byte pitch, byte velocity){
    for(int i = 0; i < maxPlayingNotes; i++){
        if(playingNotes[i].onTime == 0){ // 0 onTime means this note isn't in use
            playingNotes[i] = getNoteTimes(pitch, 0.1);
            break;
    digitalWrite(13, HIGH);
void handleNoteOff(byte channel, byte pitch, byte velocity){
        if(playingNotes[i].pitch == pitch){
            playingNotes[i] = {0,0,0,0}; // 0 onTime means it doesn't play
    digitalWrite(13, LOW);
//void handlePitchBend(byte channel, int bend){
//  float bendfactor = (1+ (float) bend/8190);
//  float dutyCycle = 0.1;
//  for(int i = 0; i < maxPlayingNotes; i++){
//      if(playingNotes[i].onTime == 0) continue;
//      float period = samplingRate/(bendfactor * midiNotes[playingNotes[i].pitch]);
//      playingNotes[i].onTime = round(dutyCycle*period);
//      playingNotes[i].offTime = round((1-dutyCycle)*period);
void setup(){
    for(int i = 0; i<(sizeof(playingNotes)/sizeof(playingNotes[0])); i++){
//  playingNotes[0] = getNoteTimes(261.6, 0.1);
//  playingNotes[1] = getNoteTimes(329.6, 0.1);
//  playingNotes[2] = getNoteTimes(392.0, 0.1);
    pinMode(9, OUTPUT);
    pinMode(13, OUTPUT);
  cli(); //stop interrupts
//  TCCR2A = 0; // set Timer/Counter Control Registers (TCCR2A/B) to 0
  TCCR2B = 0;
  OCR2A = 0; // = 16000000 / (freq*prescaler) - 1 (must be <256)
  // turn on CTC mode
  TCCR2A |= (1 << WGM21);
  // Set CS01 and CS00 bits for 64 prescaler
  TCCR2B |= (1 << CS20);
  // enable timer compare interrupt
  TIMSK2 |= (1 << OCIE2A);
  sei(); //allow interrupts
  MIDI.setHandleNoteOn(handleNoteOn);
  MIDI.setHandleNoteOff(handleNoteOff);
//  MIDI.setHandlePitchBend(handlePitchBend);
  MIDI.begin(MIDI_CHANNEL_OMNI);
void loop(){
    MIDI.read();
volatile bool shouldPlay;
ISR(TIMER2_COMPA_vect){
  shouldPlay = false;
    playingNotes[i].hasBeenOn++;
    if(playingNotes[i].hasBeenOn > playingNotes[i].onTime){
        playingNotes[i].hasBeenOn = -playingNotes[i].offTime;
    if(playingNotes[i].hasBeenOn >= 0){
        shouldPlay = true;
  if(shouldPlay){
    PORTB |= 1 << 1;
  }else{
    PORTB &= ~(1 << 1);
//  byte ^= 1 << bit_to_flip;
//  byte &= ~(1 << bit_to_clear);
//  byte |= 1 << bit_to_set;
polyphonic_midi_interrupter_pitchbend:19:1: error: 'Note' does not name a type; did you mean 'tone'?
 tone
exit status 1
Re: Does not name a type even though I made a typedef
« Reply #1 on: March 28, 2020, 04:14:17 AM »
A C instructor I am not.
Am kind of rusty with typedefs, but don't think you need one here.  What if you skip "typedef" ?
The way you said it,  Note seems to be an instance of a nameless kind of struct.
Don't we need to say something like:
struct Note {
 int x;
 int y;
struct Note Note1;
struct Note foo();
int bar( struct Note z );
Maybe the typedef lets you later say Note instead of struct Note, but I'm out of my element here.  STFI!
Here's one reference found immediately with DuckDuckGo:
https://stackoverflow.com/questions/9653072/return-a-struct-from-a-function-in-c
« Last Edit: March 28, 2020, 04:33:06 AM by klugesmith »
Offline Zipdox
    • Zipdox
« Reply #2 on: March 28, 2020, 01:29:53 PM »
struct Note {
 int x;
 int y;
struct Note Note1;
struct Note foo();
It's really weird because it used to work before, but somehow now that I changed some other code it no longer does.
Offline SteveN87
« Reply #3 on: March 28, 2020, 03:27:54 PM »
Does it work if you add a struct tag? e.g.:
Code: [Select]
typedef struct Note_t {
    byte pitch;
    int onTime;
    int offTime;
    int hasBeenOn;
} Note;
Offline Zipdox
    • Zipdox
« Reply #4 on: March 28, 2020, 04:47:45 PM »
Code: [Select]
    byte pitch;
    int onTime;
    int offTime;
    int hasBeenOn;
} Note;
No it doesn't. I also tried doing struct and typedef separately and it also doesn't work. I believe this might be a bug in the compiler because when I tried moving functions around it gave very weird output, there were words joined without spaces ans it was all very confusing. I may file a bug report later.
« Reply #5 on: March 28, 2020, 06:27:49 PM »
One rite of passage for coders is finding their first compiler bug,
where correct source code does not compile or behaves wrong.
Offline SteveN87
« Reply #6 on: March 28, 2020, 06:45:21 PM »
Have they changed the default C standard revision to C18? (Maybe knock it down to C11 if so.)
    • Seven Transistor Labs
« Reply #7 on: March 28, 2020, 10:15:20 PM »
Probably a missing semicolon somewhere then.
Also FYI, declarations are usually placed in headers so they are declared at the top right away; doesn't matter if you're only using it in just one file but it is a more organized style.
post Re: UD+ debugging (randomly skipping pulses)
Today at 04:12:52 AM
Today at 03:22:21 AM
post Re: Success!!!
June 15, 2024, 09:03:06 PM
post Success!!!
June 15, 2024, 08:29:43 PM
post Re: Benjamin's DRSSTC3
June 15, 2024, 05:38:36 AM
Jj
June 15, 2024, 03:09:41 AM
post Re: Are TVS diodes necessary for full bridge?
Simranjit
June 15, 2024, 01:53:07 AM
June 15, 2024, 01:07:30 AM
June 15, 2024, 12:45:22 AM
June 14, 2024, 10:41:03 PM
post UD+ debugging (randomly skipping pulses)
June 14, 2024, 10:20:00 PM
June 14, 2024, 09:47:48 PM
post Fronius IG Plus 2LT-2 6kW Solar Inverter Teardown
June 14, 2024, 09:40:33 PM
Simranjit
June 14, 2024, 07:44:12 AM
June 14, 2024, 05:21:55 AM
Simranjit
June 14, 2024, 03:24:43 AM
June 14, 2024, 03:13:44 AM
Simranjit
June 14, 2024, 02:27:06 AM
June 14, 2024, 01:56:58 AM
post Are TVS diodes necessary for full bridge?
Simranjit
June 13, 2024, 11:21:46 PM
post Re: Bigger sparks?...
Teslaventje
June 13, 2024, 08:50:56 PM
post Re: Steve Ward's DRSSTC Interrupter stops working when adjusting pulse width
June 13, 2024, 07:43:37 PM
June 13, 2024, 04:52:08 PM
post Re: Turning SSTC into DRSSTC
Simranjit
June 13, 2024, 02:14:17 AM
June 12, 2024, 11:04:57 PM
post Turning SSTC into DRSSTC
Simranjit
June 12, 2024, 10:23:08 PM
post Re: UD2.7C constantly in OCP despite having signal
verliebt_in_neukölln17
June 12, 2024, 08:41:06 PM
June 12, 2024, 07:53:31 PM
post Re: Van de Graaf Voltage measurement with voltage sensor and voltage divider
[Static Electricity]
June 12, 2024, 06:57:13 PM
post UD2.7C constantly in OCP despite having signal
June 12, 2024, 06:54:49 PM
June 12, 2024, 03:47:28 PM
post Van de Graaf Voltage measurement with voltage sensor and voltage divider
vK
June 12, 2024, 03:42:18 AM
June 12, 2024, 03:32:22 AM
Teslaventje
June 11, 2024, 11:05:49 PM
June 11, 2024, 05:36:46 AM
post Re: Sling Psychrometer
June 11, 2024, 12:29:31 AM
post Bigger sparks?...
Teslaventje
June 10, 2024, 11:05:55 PM
June 10, 2024, 10:57:51 PM
June 10, 2024, 08:08:04 PM
Hi-Deff
June 10, 2024, 06:04:09 PM
post Sling Psychrometer
June 10, 2024, 04:43:59 PM
June 10, 2024, 03:35:28 PM
Jj
June 10, 2024, 01:36:41 PM
post Re: Is a 60UF 800VDC Dawncap good for an induction heater?
June 09, 2024, 05:44:29 PM
post Is a 60UF 800VDC Dawncap good for an induction heater?
June 09, 2024, 03:31:30 PM
June 09, 2024, 01:34:49 PM
post Steve Ward's DRSSTC Interrupter stops working when adjusting pulse width
June 09, 2024, 01:56:51 AM
June 08, 2024, 06:06:25 AM
post Re: Coulometric hourmeters
June 08, 2024, 05:38:14 AM
post Interrupter for SSTC
Simranjit
June 08, 2024, 12:47:47 AM
post Re: Adding capacitor to primary in SSTC
Michelle_
June 07, 2024, 03:59:57 PM
June 07, 2024, 06:42:26 AM
post Re: Space-X Starship test this week
June 07, 2024, 05:08:00 AM
post Re: Half bridge sstc different waveform on two mosfets
June 07, 2024, 03:16:31 AM
June 06, 2024, 11:37:20 PM
post Adding capacitor to primary in SSTC
Simranjit
June 06, 2024, 11:20:23 PM
June 06, 2024, 10:54:48 PM
June 06, 2024, 05:17:02 AM
Simranjit
June 06, 2024, 04:50:00 AM
June 06, 2024, 04:00:52 AM
June 06, 2024, 01:43:41 AM
Simranjit
June 05, 2024, 11:11:17 PM
Michelle_
June 05, 2024, 10:18:57 PM
Simranjit
June 05, 2024, 10:13:03 PM
June 05, 2024, 09:29:18 PM
post Half bridge sstc different waveform on two mosfets
Simranjit
June 05, 2024, 08:46:53 PM
post Re: Want to build HV HF oscilloscope probe.
June 05, 2024, 07:04:45 AM
Domo
June 05, 2024, 04:58:35 AM
post Re: Pearson current monitor model 1330 teardown (100kA)
June 05, 2024, 01:42:04 AM
June 04, 2024, 10:31:58 PM
pete_dl
June 04, 2024, 08:08:28 PM
June 03, 2024, 11:13:26 PM
post Re: First DRSSTC questions
June 03, 2024, 10:35:57 PM
Hi-Deff
June 03, 2024, 05:51:05 PM
Domo
June 03, 2024, 07:41:41 AM
June 03, 2024, 05:28:44 AM
June 03, 2024, 05:02:19 AM
June 03, 2024, 03:47:33 AM
June 03, 2024, 02:23:58 AM
Hi-Deff
June 03, 2024, 01:25:24 AM
June 03, 2024, 01:08:47 AM
June 02, 2024, 10:29:02 PM
post Re: Steve Ward SSTC5 build
Michelle_
June 02, 2024, 10:02:45 PM
post Re: Racing sparks
June 02, 2024, 08:25:37 PM
Michelle_
June 02, 2024, 04:51:58 PM
Michelle_
June 02, 2024, 04:44:30 PM
June 02, 2024, 03:25:11 PM
post APC Smart-UPS 1500VA Teardown
June 02, 2024, 01:36:11 PM
pete_dl
June 02, 2024, 11:43:40 AM
June 02, 2024, 08:49:11 AM
June 02, 2024, 08:36:07 AM
June 02, 2024, 12:41:50 AM
June 01, 2024, 08:24:35 PM
post Pearson current monitor model 1330 teardown (100kA)
June 01, 2024, 08:22:28 PM
Michelle_
June 01, 2024, 03:56:53 AM
June 01, 2024, 12:03:50 AM
Hi-Deff
May 31, 2024, 11:46:20 PM
Michelle_
May 31, 2024, 06:13:59 PM
May 31, 2024, 01:55:22 AM
May 30, 2024, 11:57:49 PM
