Pulse power => Capacitor Banks => Topic started by: MrFox on August 16, 2019, 12:21:36 PM
Hey all
Newbie here so if it's a stupid question please say...
I have been asked to build a device for testing materials for resistance against static electric discharge. The spec says 10kV and 4 Joules.
So 10kV and 100nF looks about the right region.
Questions:
1) What sort of caps can I use for this? Or specifically, can I run 10x 1uF 1000V in series? With balancing resistors?
2) Whats the best way to switch the impulse from the cap to the test area? I was asked to look at Hydrogen Thyrotrons but surely there's a better way? Series IGBTs? HV relays? (2A current limit?)
3) 10kV power supply - one of those neon transformers? A £400 DC-DC module? Build my own multiplier?
Thanks in advance!
Fox
Hello!
Stupid question does not exist,
1) the best capacitors for this application is pulse film capacitor, as they can handle high pulse current ;
2) I would use a HV relay because current can't leak, and it is simple of operation (only a coil to actuate)
3) For the power supply, I suggest using a small HV transformer, and hook the output to a voltage multiplier.
Hope this helps :)
Does the spec give rise time and pulse width? Does it conform to, or resemble, any existing standards e.g. IEC 61000-4-5?
Just dumping a capacitor, without any impedance controlling the waveform, is likely to give extremely destructive results!
You may also need a coupling network so as to apply it to active e.g. mains connections properly.
Calling it ESD sounds very peculiar; only surge has energy levels like this. ESD as such is in the 10s mJ range (typically capacitors of 300 to 1500pF).
The standard is similar (apparently) to:
EN 13938-2 Part 2: Determination of resistance to electrostatic energy.
STANAG 4490: Electrostatic Discharge Sensitivity Tests
MIL-STD-1751A Safety and Performance Tests for the Qualification of Explosives - Methods 1031, 1032 & 1033.
But I am struggling to find the rise and fall times or impulse duration.
Any further ideas? Thx
I am not familiar with that standards and are not going to read them through for you.
But if you are struggling with rise/fall time and impulse duration, look into the design of heart-stoppers (defibrillators), this must be thoroughly documented which capacitance, impedance and output choke to form the desired pulse waveform and length.
You can also document on blumlein lines and pulse forming networks
