Author Topic: Need info on Varian/Wallis CW multiplier  (Read 1454 times)
« on: October 04, 2020, 10:24:28 PM »
I saw this Varian/Wallis CW multiplier on E-Bay. The model number is H1260001. I am considering buying it but I can't find any information about it. I believe the maximum voltage output is 180 KV even though the description says 300 KV. It appears to be a 8-stage unit, possibly full-wave design. The capacitors are rated for 30 KV so am guessing that the required power supply would be around 10 KV RMS for good design margin. There also appear to be internal resistors on each stage. I would probably use a big flyback transformer and a ZVS to power it. I think that I would have to supply some external load resistance to avoid damage since I want to produce sparks to ground. Here is a link. Any info would be much appreciated.
https://www.ebay.com/itm/Varian-Extrion-Cockroft-Walton-Multiplier-High-Voltage-Power-Supply-300kV/154112197476?hash=item23e1cd8364:g:uuUAAOSwU~BfdSLx
« Last Edit: October 04, 2020, 10:48:28 PM by MRMILSTAR »
Offline plasma
Re: Need info on Varian/Wallis CW multiplier
« Reply #1 on: October 04, 2020, 11:54:22 PM »
It looks like 10-11 stages, should be all right to short to ground. You will need high frequency and high current source. The caps look like 10nF / 2 series * 10 stages 50nF charging current per cycle, about 500mA.
Just released that if its the design I think, every cap stages sees multiple of input voltage, you can only run it at 3kV
« Last Edit: October 05, 2020, 04:58:38 AM by plasma »
« Reply #2 on: October 05, 2020, 09:41:54 PM »
I'd agree that 300kV isn't realistic.  Not sure how the seller came up with 10 stages.  Looks like it might be 9.
The caps are likely 1nF (based on their "1n0 K" label) film caps.  Also agree that some form of output ballast is needed, as the caps aren't likely rated for extreme dV/dt.
Depending on the effect you are after, you could make an air-insulated capacitor to follow the ballast as I did for my Marx generator:
The long black tube is a 12mH inductor (ballast) wound around 3" PVC pipe.  Of course, parameters would be quite different for DC charging.  In my case, charge transfer takes 3us, just slow enough to keep the Marx generator pulse-rated caps within specification.  Output arcs are very loud with sudden discharge from the low-inductance output capacitor.
Today at 05:24:19 AM
Tesla Junior
Today at 04:24:09 AM
Michelle_
Today at 04:20:35 AM
Bobakman
Today at 04:05:28 AM
Today at 04:03:54 AM
Michelle_
Today at 03:19:19 AM
Today at 03:09:29 AM
unrealcrafter2
Today at 01:47:37 AM
Bobakman
Today at 12:19:21 AM
April 18, 2024, 11:33:01 PM
Bobakman
April 18, 2024, 11:15:15 PM
April 18, 2024, 10:59:36 PM
unrealcrafter2
April 18, 2024, 10:03:48 PM
April 18, 2024, 09:53:25 PM
unrealcrafter2
April 18, 2024, 09:50:09 PM
Michelle_
April 18, 2024, 09:15:55 PM
post Re: 100kHz CM300 gate resistor choice
April 18, 2024, 08:50:49 PM
unrealcrafter2
April 18, 2024, 08:11:27 PM
April 18, 2024, 07:28:05 PM
Bobakman
April 18, 2024, 06:30:30 PM
Michelle_
April 18, 2024, 06:03:57 PM
Michelle_
April 18, 2024, 05:26:13 PM
April 18, 2024, 04:03:38 PM
Michelle_
April 18, 2024, 02:56:40 PM
post Re: DIY induction guns? (warning:long)
April 18, 2024, 06:17:15 AM
Michelle_
April 18, 2024, 05:46:07 AM
April 18, 2024, 05:18:31 AM
April 18, 2024, 04:34:52 AM
April 18, 2024, 04:11:53 AM
Michelle_
April 18, 2024, 04:02:44 AM
April 18, 2024, 03:35:52 AM
April 17, 2024, 11:54:05 PM
post 100kHz CM300 gate resistor choice
April 17, 2024, 11:37:16 PM
post Re: Has anyone tried to build a TMT (extra coil) Tesla coil?
Michelle_
April 17, 2024, 02:29:30 AM
April 16, 2024, 11:56:12 PM
April 16, 2024, 11:46:57 PM
Bobakman
April 16, 2024, 10:40:11 PM
post Has anyone tried to build a TMT (extra coil) Tesla coil?
Michelle_
April 16, 2024, 09:21:39 PM
April 16, 2024, 08:04:16 PM
post Re: First DRSSTC SKM100
April 16, 2024, 06:48:05 PM
Michelle_
April 16, 2024, 06:18:40 PM
Michelle_
April 16, 2024, 06:14:53 PM
unrealcrafter2
April 16, 2024, 05:44:44 PM
April 16, 2024, 03:12:12 PM
unrealcrafter2
April 16, 2024, 02:28:01 PM
April 16, 2024, 01:56:26 PM
Michelle_
April 16, 2024, 06:50:47 AM
April 16, 2024, 04:57:47 AM
ethanwu0131
April 16, 2024, 03:40:53 AM
April 16, 2024, 01:31:17 AM
Michelle_
April 15, 2024, 11:19:52 PM
Michelle_
April 15, 2024, 11:10:19 PM
April 15, 2024, 11:04:19 PM
April 15, 2024, 11:02:05 PM
Michelle_
April 15, 2024, 10:57:59 PM
Michelle_
April 15, 2024, 10:55:46 PM
April 15, 2024, 10:37:32 PM
April 15, 2024, 10:05:00 PM
April 15, 2024, 09:28:50 PM
April 15, 2024, 09:06:42 PM
April 15, 2024, 08:46:32 PM
April 15, 2024, 08:38:39 PM
sky-guided
April 15, 2024, 08:23:40 PM
Bobakman
April 15, 2024, 06:43:23 PM
April 15, 2024, 06:29:10 AM
Michelle_
April 15, 2024, 05:21:53 AM
Michelle_
April 15, 2024, 05:15:33 AM
April 15, 2024, 04:07:54 AM
April 15, 2024, 03:49:03 AM
April 14, 2024, 09:46:30 PM
Michelle_
April 14, 2024, 07:31:00 PM
April 14, 2024, 02:26:19 PM
post Re: mg75q2ys40 IGBT
April 14, 2024, 07:20:54 AM
April 14, 2024, 07:18:20 AM
Michelle_
April 13, 2024, 06:46:40 AM
Michelle_
April 13, 2024, 04:18:42 AM
April 13, 2024, 03:24:20 AM
April 13, 2024, 03:20:46 AM
Michelle_
April 13, 2024, 03:13:22 AM
post Re: Capacitor Blowout
lbattraw
April 12, 2024, 09:14:58 PM
post mg75q2ys40 IGBT
thedark
April 12, 2024, 08:40:18 PM
April 12, 2024, 07:20:30 PM
April 12, 2024, 07:12:43 PM
ethanwu0131
April 12, 2024, 04:47:33 PM
April 12, 2024, 11:43:36 AM
April 12, 2024, 12:49:02 AM
April 12, 2024, 12:41:16 AM
April 12, 2024, 12:22:41 AM
Michelle_
April 11, 2024, 10:45:53 PM
April 11, 2024, 07:39:30 PM
April 11, 2024, 07:24:52 PM
sky-guided
April 11, 2024, 06:09:30 PM
April 11, 2024, 12:55:16 PM
April 11, 2024, 03:40:00 AM
sky-guided
April 11, 2024, 03:05:07 AM
Michelle_
April 11, 2024, 02:57:33 AM
April 11, 2024, 01:44:32 AM
Michelle_
April 11, 2024, 01:31:40 AM
OmGigaTron
April 11, 2024, 01:11:00 AM
April 11, 2024, 12:58:52 AM
