Author Topic: Driverless SSTC  (Read 1676 times)
Offline bismallah
Driverless SSTC
« on: November 26, 2021, 11:59:27 PM »
I tried following the circuit from Labcoatz for a driverless SSTC but couldn't limit the current properly. I tried using a 375W ballast which I measured to be 4.4H across the primary, and nothing happened which I think is due to the high reactance? The ballast itself is shown below and in order to properly use it should I short the secondary (I saw some do this with microwave transformers)? I also tried using two 40W lightbulbs in parallel in place of a ballast, and the secondary coil produced a measly 120V (should I try a higher wattage setup?).
Anyway, I tried the circuit without a ballast and it worked for a bit before abruptly dying. The tesla coil build and schematics are shown below, can someone please help?
Re: Driverless SSTC
« Reply #1 on: November 28, 2021, 12:32:09 AM »
Slayer oscillators like this are simple, but also finicky.
As with most electronic circuits, wire length causes problems.  Wires have inductance.  Tight layout and construction is required.  Especially the 1.5ke12 diode needs to be soldered directly to the FET.  1.5ke400 should also be fairly close.
There are plenty of counterfeit IRFP460 parts available.  I have no experience with "Bojack".  Their FETs may or may not have the robustness of normal industry vendors such as Vishay/Siliconix.
If you have access to a variac or other way to reduce voltage, I'd start below 120V.
Offline Andrew321
Re: Driverless SSTC
« Reply #2 on: December 09, 2021, 04:12:30 AM »
I had some success with this circuit a while back. I wasn't able to get it to work at rectified mains because I couldn't seem to find a big enough inductor in my garage. I have a variac though and just started it at 12VDC and took it up to max current input. I think it was around 45VAC input for my setup. Still got some big parks off it, maybe 4 to 6"! Then I tried to audio modulate it with a 555 timer and ALMOST got it to work. but all my mosfets hated it and were killed :(
I could be misremembering, but make sure you have your coil directions correct. If noting is happening, try flipping your primary connections around. Also, as Dave mentioned, shorten long leads. I've had stuff not work for the life of me until I put the alligator clips away and soldered everything tight. Then it works like a charm!
Good luck!
Re: Driverless SSTC
Today at 06:31:32 AM
post Re: Big Coil Build Log
Today at 05:48:43 AM
post Re: Ferrite material for GDT SSTC/DRSSTC
Today at 04:49:39 AM
Today at 04:28:40 AM
Today at 03:05:44 AM
Today at 02:54:42 AM
post Ferrite material for GDT SSTC/DRSSTC
Today at 02:21:54 AM
Today at 01:46:25 AM
post Re: TVS diode vs RCD snubber for protect IGBT peak voltage
Today at 12:26:38 AM
May 04, 2024, 10:48:10 PM
May 04, 2024, 10:40:15 PM
post TVS diode vs RCD snubber for protect IGBT peak voltage
May 04, 2024, 09:30:32 PM
May 04, 2024, 08:56:27 PM
May 04, 2024, 04:25:00 AM
May 04, 2024, 04:21:02 AM
May 04, 2024, 01:33:40 AM
May 04, 2024, 01:02:48 AM
May 03, 2024, 11:39:10 PM
May 03, 2024, 10:59:34 PM
May 03, 2024, 09:59:22 AM
post What happened to ArcAttack?
rusirius
May 03, 2024, 02:34:36 AM
May 02, 2024, 05:18:56 AM
post Re: Adjustable High Voltage Electrostatic Precipitator Power Supply with 30KV 300W
dante
May 01, 2024, 10:06:40 PM
dante
May 01, 2024, 10:01:33 PM
post Re: Watercooling
May 01, 2024, 07:26:03 PM
May 01, 2024, 05:53:47 PM
May 01, 2024, 04:05:23 PM
post Re: X-ray generation from nixie bulbs?
May 01, 2024, 03:58:29 PM
May 01, 2024, 12:00:01 PM
May 01, 2024, 11:45:53 AM
dante
May 01, 2024, 10:29:48 AM
May 01, 2024, 09:46:43 AM
May 01, 2024, 09:09:57 AM
post Re: Hobby site
[Hobby Sites]
Bart M
May 01, 2024, 08:15:07 AM
May 01, 2024, 04:44:58 AM
May 01, 2024, 04:38:56 AM
May 01, 2024, 02:41:56 AM
May 01, 2024, 01:07:46 AM
May 01, 2024, 12:43:46 AM
May 01, 2024, 12:35:48 AM
dante
April 30, 2024, 11:02:33 PM
post Recommendation for HV DC power supply
dante
April 30, 2024, 11:00:48 PM
April 30, 2024, 11:00:12 PM
April 30, 2024, 10:51:05 PM
post X-ray generation from nixie bulbs?
April 30, 2024, 10:46:46 PM
April 30, 2024, 08:46:32 PM
April 30, 2024, 07:28:52 PM
April 30, 2024, 07:16:09 PM
April 30, 2024, 05:52:20 PM
April 30, 2024, 04:54:38 PM
April 30, 2024, 05:37:38 AM
April 30, 2024, 04:31:01 AM
April 30, 2024, 04:25:55 AM
post Re: High Voltage from LG Microwave Inverter
April 29, 2024, 03:33:58 AM
post Re: What's an alternative to those dubious high voltage generators from Amazon?
April 28, 2024, 11:48:32 AM
post Re: CM300 Half bridge coil build log
April 28, 2024, 07:48:18 AM
April 28, 2024, 07:39:32 AM
April 28, 2024, 07:37:00 AM
April 28, 2024, 07:18:27 AM
post Watercooling
April 28, 2024, 07:13:48 AM
post High Voltage from LG Microwave Inverter
GLaDOS
April 28, 2024, 04:11:30 AM
Jj
April 28, 2024, 12:01:04 AM
April 27, 2024, 09:51:08 PM
April 27, 2024, 04:20:46 PM
Jj
April 27, 2024, 01:39:29 PM
post What's an alternative to those dubious high voltage generators from Amazon?
Devil Master
April 27, 2024, 05:32:59 AM
post Re: Tesla coil UV eye protection?
April 26, 2024, 08:46:40 PM
April 25, 2024, 06:30:43 PM
April 25, 2024, 06:14:35 PM
April 25, 2024, 05:13:46 PM
April 25, 2024, 11:40:08 AM
April 25, 2024, 06:01:50 AM
April 25, 2024, 05:55:45 AM
April 25, 2024, 05:47:36 AM
April 25, 2024, 05:45:36 AM
April 25, 2024, 05:41:05 AM
April 25, 2024, 04:33:57 AM
April 24, 2024, 08:02:47 PM
April 24, 2024, 06:51:17 PM
April 24, 2024, 06:45:00 PM
April 24, 2024, 05:18:27 PM
April 24, 2024, 05:14:27 PM
huntergroundmind
April 24, 2024, 02:51:23 PM
April 24, 2024, 05:58:27 AM
April 24, 2024, 05:17:22 AM
April 24, 2024, 12:39:59 AM
April 23, 2024, 11:07:41 PM
April 23, 2024, 10:57:39 PM
April 23, 2024, 09:33:49 PM
April 23, 2024, 06:00:42 PM
April 23, 2024, 03:50:49 AM
April 23, 2024, 03:13:31 AM
April 23, 2024, 12:50:40 AM
April 22, 2024, 11:21:06 PM
April 22, 2024, 08:11:00 PM
April 22, 2024, 06:15:30 PM
April 22, 2024, 05:52:50 PM
April 22, 2024, 05:52:13 PM
April 22, 2024, 04:31:52 PM
April 22, 2024, 04:05:34 PM
