Author Topic: Strange? behaviour in a NST  (Read 2135 times)
Offline Alberto
« on: February 03, 2021, 08:52:57 PM »
Hi everyone.
I have bought this cheap NST on a Chinese website. It is supposed to give 10Kv but the arc can start at 6 cm. The other weird thing is if I connectit in when the wires are 6cm or less the arc start and keeps arcing. But if the wires are more than 6 cm they only generate a small spark at the tip and nothing else happens. Even if I get closer. I need to disconnect and reconnect to "restart"
And fortunately, I am very careful and never touch the wires in the plastic. They arc between them! Very good insulation ...
What you think? It is the first time that I have an NST and I do not do it if this is normal.
Thank you
Kind regards
Re: Strange? behaviour in a NST
« Reply #1 on: February 03, 2021, 09:08:54 PM »
Most NSTs now are inverter circuits feeding a high-frequency (~30kHz) transformer.  They have internal circuits to detect fault conditions and shut down on faults.  One fault is an arc not starting.  I'm surprised that it doesn't also shut down due to low arc voltage - but you did say that it was cheap.  (I expect that the 6cm air arc is lower voltage than a properly-working neon sign tube.)
Offline Alberto
« Reply #2 on: February 03, 2021, 10:15:55 PM »
Thank you for your answer.
Ok ok now I understand, but, if is 10kv rated, how can it generate 6cm arc? 6cm must be around 60 kv, isnĀ“t it?
« Reply #3 on: February 04, 2021, 01:49:42 AM »
Voltage depends on the shape of the electrodes (wire ends) besides distance.  However, 60kV may be reasonable.  If the 10kV rating is for operating, NSTs generate a higher starting voltage.  60kV sounds high for starting a 10kV neon tube, but I don't have much experience with this.
Offline Alberto
« Reply #4 on: February 04, 2021, 08:50:28 AM »
Ok ok, thanks, You are very helpful!
Offline Alberto
« Reply #5 on: February 04, 2021, 08:54:39 PM »
Ok, I have found that from wikipedia
All NSTs are designed to produce a high voltage starting pulse to a tube, then limit the current through the tube when it has started.
post Re: Kaizer VTTC 1
Today at 10:23:02 AM
post Re: Capacitor in Parallel with Primary Coil
Today at 10:17:34 AM
post Capacitor in Parallel with Primary Coil
Today at 10:01:41 AM
post Re: Re-chargeable 1.5 volt lithium ion AAA batteries
Today at 04:47:35 AM
Today at 03:59:27 AM
March 28, 2024, 09:15:11 PM
post Re: capacitor and diodes. Voltage values for a CW
Alberto
March 28, 2024, 01:01:12 PM
post Re: Big Coil Build Log
March 28, 2024, 05:47:34 AM
March 28, 2024, 04:45:07 AM
March 28, 2024, 04:18:27 AM
post Push Pull VTTC
janno288
March 28, 2024, 01:10:08 AM
Alberto
March 27, 2024, 10:54:52 PM
markus
March 27, 2024, 11:53:42 AM
post Re: OCD Triggering Early + Low Output
March 27, 2024, 05:14:36 AM
post Re: Is the UD2.7C under voltage lock out basically worthless?
March 27, 2024, 04:47:48 AM
post Re: DRSSTC Questions
March 27, 2024, 04:41:59 AM
March 27, 2024, 12:04:34 AM
post Re: Super flat QCW simulation (does this look reasonable?)
toooldforthis
March 26, 2024, 11:08:14 PM
March 26, 2024, 11:07:20 PM
March 26, 2024, 10:46:29 PM
post OCD Triggering Early + Low Output
March 26, 2024, 09:03:43 PM
March 26, 2024, 08:46:59 PM
March 26, 2024, 05:02:18 PM
March 26, 2024, 03:16:03 PM
March 26, 2024, 01:41:49 PM
March 26, 2024, 04:48:22 AM
March 26, 2024, 04:16:37 AM
March 26, 2024, 04:16:24 AM
post Re: Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 26, 2024, 04:13:02 AM
March 26, 2024, 04:00:43 AM
March 26, 2024, 03:19:18 AM
March 26, 2024, 01:50:42 AM
March 25, 2024, 08:05:02 PM
March 25, 2024, 07:41:29 PM
March 25, 2024, 06:45:46 PM
March 25, 2024, 05:44:25 PM
March 25, 2024, 04:47:17 PM
March 25, 2024, 04:27:22 PM
post Re-chargeable 1.5 volt lithium ion AAA batteries
March 25, 2024, 03:57:34 PM
markus
March 25, 2024, 02:06:41 PM
March 25, 2024, 04:43:25 AM
March 25, 2024, 02:39:40 AM
March 25, 2024, 12:47:09 AM
Alberto
March 24, 2024, 07:36:32 PM
Alberto
March 24, 2024, 07:27:24 PM
March 24, 2024, 04:25:23 AM
Alberto
March 23, 2024, 10:47:35 PM
March 23, 2024, 09:30:21 PM
Alberto
March 23, 2024, 04:34:31 PM
March 23, 2024, 03:04:25 PM
Alberto
March 23, 2024, 01:38:34 PM
March 23, 2024, 04:20:03 AM
March 23, 2024, 12:54:30 AM
March 23, 2024, 12:05:57 AM
post capacitor and diodes. Voltage values for a CW
Alberto
March 22, 2024, 11:45:03 PM
OmGigaTron
March 22, 2024, 11:30:09 PM
post Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 22, 2024, 10:20:35 PM
post Re: Where's all this voltage coming from?
March 22, 2024, 09:21:13 PM
March 22, 2024, 03:37:11 PM
post What actually kills MOSFETs?
March 22, 2024, 05:09:20 AM
March 22, 2024, 03:57:54 AM
March 22, 2024, 02:59:25 AM
March 21, 2024, 06:31:42 PM
post Re: 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 21, 2024, 03:08:01 PM
post Re: [WTS] IGBT, Ferrite, Capacitors, Tools, PSU, Industrial components and parts
March 21, 2024, 01:37:32 PM
Alberto
March 21, 2024, 11:42:07 AM
post Re: Phase Lead Questions
March 21, 2024, 04:09:14 AM
March 21, 2024, 02:15:31 AM
post My Homemade Structural Analysis X-Ray Machine
March 21, 2024, 01:35:40 AM
March 20, 2024, 10:40:00 PM
March 20, 2024, 08:03:41 PM
March 20, 2024, 07:51:57 PM
March 20, 2024, 10:39:47 AM
March 20, 2024, 04:09:59 AM
March 20, 2024, 01:13:23 AM
March 20, 2024, 12:45:16 AM
March 20, 2024, 12:30:30 AM
March 19, 2024, 11:12:24 PM
Late
March 19, 2024, 09:47:49 PM
Late
March 19, 2024, 09:44:19 PM
post Phase Lead Questions
March 19, 2024, 06:52:09 PM
March 19, 2024, 05:02:44 PM
March 19, 2024, 05:01:41 PM
March 19, 2024, 04:31:02 PM
March 19, 2024, 03:59:54 PM
March 19, 2024, 06:41:39 AM
March 19, 2024, 04:05:49 AM
OmGigaTron
March 18, 2024, 09:08:35 PM
post Re: Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 09:07:35 PM
March 18, 2024, 08:57:06 PM
March 18, 2024, 03:51:33 PM
Late
March 18, 2024, 02:59:46 PM
Late
March 18, 2024, 02:33:25 PM
post Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 11:02:12 AM
March 18, 2024, 02:36:11 AM
post Re: Best forum for vacuum tube amplifiers?
March 17, 2024, 07:42:55 PM
Michelle_
March 17, 2024, 04:15:14 PM
Michelle_
March 17, 2024, 05:05:04 AM
March 17, 2024, 04:50:51 AM
March 17, 2024, 04:45:17 AM
