Author Topic: Using dual-resonant Tesla Coils to create non-thermal resonant hydrogen plasma.  (Read 149 times)
Offline joabel1971
I am building device that potentially will generate resonant hydrogen plasma & have some suggestions that have not been offered - on how to make a better Tesla Coil (since the question was asked).    In my experiment - I am attempting multiple resonant conditions to create a non-thermal hydrogen plasma that is 100% ionized (a pair of non-flammable, room-temperature ICP jets).
a.  I started my design with Tesla Patent #512,340 (showing the potential advantages of interleaved cone-coils).  A diagram in the patent appears to be missing (showing a side view).  Only a top view is shown - implying a pancake coil.  However, I have tested helical versions of this coil (without external capacitors) to find resonant conditions for AM electrolysis experiments.  This interleaved method apparently stores 250,000 times as much energy as a 1-wire coil-winding method.   According to the patent, interleaved coils also have the ability to cancel out their own capacitive & inductive reactance at their resonant frequency (based on wire length formula for resonance of the secondary).
b.  To tune the coil & take advantage of superposition - I am using the rest frequency of hydrogen (1.42 Ghz @ 21 cm) and 6 more 1/4-wave wirelengths multilayered (lowest frequency is 346,778 Khz @ 865.104 meters).  The correct phase between frequencies to create constructive interference has been calculated at 3/2*pi, however, square-wave signaling appears to eliminate this requirement.
The summation formula is:
f(x) = 8 + ∑ sin((5.291423766936 * 4^n * x) + 3/2 *pi)
n = 7 - 14
This superposition calculation has been mathematically proven with graphing software.
FR @ 4^14 =   1,420,405,751.  766702882816 Hz
FR @ 4^13 =      355,101,437.  941675720704 Hz
FR @ 4^12 =        88,775,359.  485418930176 Hz
FR @ 4^11 =        22,193,839.  87354732544   Hz
FR @ 4^10 =          5,548,459.  967838683136 Hz
FR @ 4^9 =            1,387,114.   991959670784 Hz
FR @ 4^8 =              346,778.   747989917696 Hz
c.  To allow the use of 30 volt, 10 amp DC power supplies - I have also added 1/4-length PRIMARIES (in relation to the secondary lengths) & positioned them below the secondaries (not layered, but adjacently below) to try to fix any impedance mismatch.  1/4-wave transformers are documented ways of eliminating impedance mismatch.
d.  I am signaling the device with a new microcontroller that outputs 54 different frequencies at the same time (1 Hz - 25 Mhz) - called the Parallax Propeller 2.  It is tested.    The 3 highest frequencies will be generated using either Voltage Controlled Oscillators (VCOs) or output signals from a Vector Network Analyzer (NanaVNA-F V2 is capable of 1.42 Ghz).
e.  I am using a slant angle that causes the slant height of the cone-coils to be equal to the circumference of the cone.   This simplifies calculations in a number of ways.  The slant angle that does this is around 80.842150 degrees (depending on the size of the nozzle hole at the top).
f.  My 3 output nozzles are nested and contain 4 materials - water (to generate steam), hydrogen & graphite, and hydrogen & silica.  Due to the self-organizing properties of complex (dusty) plasma, my overall goal to to create a new material - a graphene/silicene hybrid.
g.  All non-hydrogen gasses (including ambient air) are being evacuated from the cone coil system using qty. 2 - 8" duct fans. The cones are internally bi-sected with a sheet of stainless steel to create a ducting system.  (1 fan to suck air in - 1 fan to suck air out).
h.  The entire frame is made of 304 stainless steel (non-magnetic & poorly conductive).  The coils are 18 AWG enameled copper for the primary & 30 AWG enameled copper for the secondary.
i.  No capacitors are being used - since the interleaving creates a certain amount of capacitance to reach resonant conditions.
j.  The highest voltage used is 300 volts at 1 amp for the lowest frequency (since the resistance of the secondary wire is 292 ohms).   Each successive voltage is 1/4 of the prior, but current should remain 1 amp for all superpositioned wires.
V-Troxi
Today at 02:42:03 PM
npmarshall
Today at 01:49:09 PM
Today at 03:59:13 AM
npmarshall
Today at 03:16:44 AM
Today at 02:58:29 AM
Today at 01:48:38 AM
npmarshall
Today at 01:47:59 AM
post Re: A few questions
Today at 01:42:14 AM
Today at 01:31:51 AM
March 20, 2023, 11:59:01 PM
post Re: primary spacing
March 20, 2023, 11:10:11 PM
romy
March 20, 2023, 08:20:34 PM
V-Troxi
March 20, 2023, 06:57:34 PM
ako
March 20, 2023, 03:07:01 PM
npmarshall
March 20, 2023, 02:21:05 PM
post GDT output buffer
March 20, 2023, 04:32:07 AM
March 20, 2023, 02:26:02 AM
March 20, 2023, 12:02:52 AM
ako
March 19, 2023, 08:51:54 PM
March 19, 2023, 06:26:07 PM
post A few questions
ako
March 19, 2023, 05:16:46 AM
March 18, 2023, 05:58:34 PM
madhurya
March 18, 2023, 12:07:42 PM
March 18, 2023, 07:30:21 AM
March 18, 2023, 04:45:04 AM
March 18, 2023, 03:45:14 AM
March 18, 2023, 02:15:42 AM
March 17, 2023, 11:14:10 PM
March 17, 2023, 10:40:47 PM
post (distributed) air gap
romy
March 17, 2023, 07:47:14 PM
post Re: Plasma Toroid
March 17, 2023, 06:47:10 PM
[Hobby Sites]
breezetix
March 17, 2023, 06:37:48 PM
breezetix
March 17, 2023, 06:29:37 PM
breezetix
March 17, 2023, 06:13:48 PM
post Re: Welding a MOT
breezetix
March 17, 2023, 06:12:08 PM
breezetix
March 17, 2023, 06:04:53 PM
post primary spacing
March 17, 2023, 05:44:14 PM
post Re: My second DRSSTC
March 17, 2023, 04:48:59 AM
March 17, 2023, 04:42:07 AM
March 17, 2023, 02:55:19 AM
Hafting
March 17, 2023, 12:09:07 AM
March 16, 2023, 07:52:19 PM
March 16, 2023, 07:32:14 PM
post My second DRSSTC
Miki_407
March 16, 2023, 03:40:21 PM
March 16, 2023, 12:04:01 PM
post Re: induction heating
romy
March 16, 2023, 08:12:37 AM
March 16, 2023, 05:41:56 AM
March 16, 2023, 05:32:24 AM
March 16, 2023, 03:53:17 AM
March 16, 2023, 01:30:31 AM
March 16, 2023, 12:17:32 AM
March 15, 2023, 11:53:29 PM
March 15, 2023, 05:26:43 PM
romy
March 15, 2023, 03:56:29 PM
romy
March 15, 2023, 03:53:31 PM
romy
March 15, 2023, 03:51:10 PM
March 14, 2023, 11:00:41 PM
March 14, 2023, 10:28:05 PM
March 14, 2023, 05:01:44 PM
romy
March 14, 2023, 03:00:36 PM
romy
March 14, 2023, 02:03:42 PM
March 14, 2023, 04:04:32 AM
March 13, 2023, 10:41:49 PM
March 13, 2023, 08:25:38 PM
March 13, 2023, 05:59:40 PM
March 13, 2023, 09:08:46 AM
March 13, 2023, 06:15:51 AM
March 13, 2023, 02:10:47 AM
March 13, 2023, 12:21:01 AM
March 13, 2023, 12:17:09 AM
March 12, 2023, 11:43:38 PM
March 12, 2023, 10:39:41 PM
ColinHeath
March 12, 2023, 10:39:05 PM
March 12, 2023, 09:46:24 PM
post Re: 160mm DRSSTC project
Mathieu thm
March 12, 2023, 09:23:23 PM
March 12, 2023, 07:52:30 PM
dannybeckett
March 12, 2023, 06:45:50 PM
March 12, 2023, 09:04:53 AM
joabel1971
March 11, 2023, 10:03:58 PM
joabel1971
March 11, 2023, 09:15:23 PM
March 11, 2023, 02:20:13 AM
dannybeckett
March 11, 2023, 12:24:07 AM
March 11, 2023, 12:13:11 AM
March 10, 2023, 09:42:29 PM
March 10, 2023, 08:38:36 PM
March 10, 2023, 08:06:23 PM
March 10, 2023, 05:13:44 PM
Alex_1996
March 10, 2023, 05:07:20 PM
Alex_1996
March 10, 2023, 04:38:21 PM
March 10, 2023, 04:25:12 PM
Alex_1996
March 10, 2023, 03:53:56 PM
dannybeckett
March 10, 2023, 01:39:57 PM
romy
March 10, 2023, 10:27:36 AM
March 10, 2023, 09:48:10 AM
March 10, 2023, 03:51:40 AM
March 10, 2023, 03:00:09 AM
dannybeckett
March 10, 2023, 01:03:19 AM
March 09, 2023, 10:51:52 PM
March 09, 2023, 07:06:03 PM
dannybeckett
March 09, 2023, 02:25:33 PM
