Author Topic: Commercial vs Self-Made GDT Performance  (Read 765 times)
Offline bockett
« on: March 07, 2023, 06:01:40 PM »
Hello again! I've noticed that most people seem to be winding their own GDTs rather than buying commercially available ones. Is there a reason for avoiding commercial GDTs for use in tesla coils, or is it more about greater control or just wanting to build it themselves? I was planning on using a prebuilt GDT because I want to avoid making another potential point of failure for myself, but I also wanted to make sure I'm not overlooking any significant benefits of making my own.
If commercial GDTs are fine, then I would also appreciate any input on which one would be best. I have been looking mostly at the Vishay MGDT100125 and the Pulse P0584ANL. The Vishay one has lower leakage inductance and a 1:1.25:1.25 turn ratio, but it looks like an unconventional design and the Pulse one has better Et (Drive Excitation Max in the Vishay datasheet). I've tried looking into them myself but I don't have any reference points to help make sense of some of the numbers I've seen in their datasheets. If anyone would be able to provide good target values for things like leakage inductance and Et that would make a GDT suitable, that would also be really helpful.
Please let me know if I can explain any of my questions better, and thank you for your time!
Offline costas_p
Re: Commercial vs Self-Made GDT Performance
« Reply #1 on: March 07, 2023, 07:20:26 PM »
Personally, i am using 2x P0584NL for my TO247 full bridge drsstc running around 230kHz with no problems so far.
Calculating ET=(Vgate_drive * DutyOn) / Freq, then you can find that for 24V gate drive you can go as low as ~127kHz
Papadakis Costas
Offline Manz
« Reply #2 on: March 07, 2023, 08:35:25 PM »
I used a "self made" gdt because I was able to find plenty of cores at a really low price (just a couple of bucks per core) at my local electronics faire so I'm guessing price might be one of the reasons why GDTs are often DIY.
But Im a newbie so I might be wrong, lets wait for the experts :)
« Reply #3 on: March 07, 2023, 09:17:40 PM »
I think prices on commercial GDTs was just something different 15 years ago and that is the main reason for homemade GDTs.
« Reply #4 on: March 07, 2023, 10:48:27 PM »
You can also get leakage inductance lower if you DIY one (at the cost of higher inter-winding capacitance). Needs some care to do though - use the minimum number of turns and couple primary/secondary very well (I've used thin co-ax with shield for primary and core for secondary) and you can get <200nH leakage L. Not sure it's worth it though given the ease of using a COTS part that's not much worse!
Note that if you're using big long wires to or from your GDT then there is no reason to worry about the leakage L, as the wires will contribute a lot unless you're careful (the trick I use is to put the drive MOSFETs right next to the GDT, then connect to the IGBT gates via ribbon cable, with a number of alternating E/G lines in parallel giving low inductance, with the added bonus that ribbon cable is extremely easy to work with).
Offline bockett
« Reply #5 on: March 08, 2023, 06:06:30 AM »
Thank you so much for the feedback everyone! I think I'm only going to go with a 12V gate drive for my first coil, so I'll probably end up using the Vishay because it has lower leakage inductance, but maybe I'll try winding my own in the future. Thank you again and have a nice day!
« Reply #6 on: March 08, 2023, 10:05:08 AM »
That Vishay one is also pretty expensive, but seeing how it's built makes me thing that maybe it's a good chance to try some planar transformer design using JLCPCB's 6-layer promo (50*50mm for $2). Now I'm really annoyed that I sent off an order for work a week ago without whipping one up and adding it to it :(
Today at 02:31:59 PM
Today at 02:30:10 PM
PhotonLab
post Re: Ramped DRSSTC
post Re: Lathe Restauration
Keybored
PhotonLab
PhotonLab
Luca c.
Keybored
PhotonLab
Keybored
post Re: TNY265 flyback issue
Lucasww
cnichols
post TNY265 flyback issue
michaelrcolton
post Re: How much power?
Terry
post Anyone used iCCFL.com?
Lucasww
post Re: SSTC bus inductance
post SSTC bus inductance
January 31, 2024, 11:43:32 PM
Ranni81
January 31, 2024, 08:03:40 PM
Hysteresis
January 31, 2024, 03:34:48 PM
January 31, 2024, 05:08:10 AM
January 30, 2024, 10:17:45 PM
post How much power?
Terry
January 30, 2024, 08:07:39 PM
post Ultrasonic Plastic Welding experiments with TA-40CS transducer
January 28, 2024, 11:37:30 PM
January 28, 2024, 03:07:12 AM
post Re: First time DRSSTC Build
January 27, 2024, 02:27:29 PM
January 27, 2024, 01:26:34 PM
post Re: Determine output voltage of DRSSTC
January 27, 2024, 01:15:51 PM
January 27, 2024, 01:13:29 PM
post Determine output voltage of DRSSTC
Pavol
January 27, 2024, 11:35:35 AM
post is there a standard pinout of optical audio output connectors?
January 27, 2024, 01:47:13 AM
January 26, 2024, 11:26:11 PM
January 26, 2024, 08:24:30 PM
January 26, 2024, 05:19:18 PM
post Re: Anyone had success using analogue/digital HV panel meters?
January 26, 2024, 04:28:38 PM
Luca c.
January 26, 2024, 03:34:10 PM
January 26, 2024, 11:49:48 AM
TizianoBll
January 26, 2024, 11:04:37 AM
January 26, 2024, 06:26:58 AM
