Author Topic: More induction heating  (Read 2235 times)
Offline Alberto
Re: More induction heating
« Reply #60 on: March 16, 2023, 12:04:01 PM »
Fuuuuuudge....
First of all, thank you again both of you for the advice, I knew it was a good idea to ask here before conecting it.
 I´ll use it only to heat getters, maybe 30 seconds long, i don´t know if that infromation matters.
The capacitors are linked with 2,5mm diameter copper wire. Removing all of them and resoldering in other support would be a PITA because now the legs are too short. I´m not sure if I have understood well, but a possible solution would be conct the ends of the bus in the other side?
I mean, close the llops and connect the induction coil to A and B? With no too much wire to stay close?
« Last Edit: March 16, 2023, 10:48:57 PM by Alberto »
« Reply #61 on: March 16, 2023, 07:32:14 PM »
>> I mean, close the loops and connect the induction coil to A and B? With no too much wire to stay close?
Yes, as Dave said.   That gets you most of the possible improvement, with very little work.
Offline Alberto
« Reply #62 on: March 17, 2023, 11:14:10 PM »
Thank you for your answer. Ok, I link the loops and the heater works, but cant get red hot the loop of titanium wire...
veeeery disappointing, until I tried spot welding the loop, and now is HOT AS HELL BABY!!! The problem was the loop of titanium has to have a good conection in the joint.
If any of you are ever in the south of Spain and need something induction heated, or a beer, you can count with me!
The mosfets or the chockes don´t get any warm. The 100ohm resistors are 5wats (ceramic) and get hot. The capacitors and the bus a little bit hot. But the coil gets veeeery hot. First I connect the 19volts power supply and then I set the main power supply at 34 volts and when I connet it the voltage drops to 20 volts and drain 11 amps. Now I´ll try with different coils, maybe with copper tubing. If I´m right, the high frequency produces skin effect and doesn´t matter very much if the tube is hollow right?
Offline Alberto
« Reply #63 on: March 20, 2023, 12:02:52 AM »
Hi again. Reading the message of the guy of the video, his induction heater drains 7 amps at 35votls. What could be the reason for mi draining 11 amps at 20 volts?
npmarshall
Today at 01:49:09 PM
Today at 03:59:13 AM
npmarshall
Today at 03:16:44 AM
Today at 02:58:29 AM
Today at 01:48:38 AM
npmarshall
Today at 01:47:59 AM
post Re: A few questions
Today at 01:42:14 AM
Today at 01:31:51 AM
March 20, 2023, 11:59:01 PM
post Re: primary spacing
March 20, 2023, 11:10:11 PM
romy
March 20, 2023, 08:20:34 PM
V-Troxi
March 20, 2023, 06:57:34 PM
ako
March 20, 2023, 03:07:01 PM
npmarshall
March 20, 2023, 02:21:05 PM
post GDT output buffer
March 20, 2023, 04:32:07 AM
March 20, 2023, 02:26:02 AM
ako
March 19, 2023, 08:51:54 PM
March 19, 2023, 06:26:07 PM
post A few questions
ako
March 19, 2023, 05:16:46 AM
March 18, 2023, 05:58:34 PM
madhurya
March 18, 2023, 12:07:42 PM
March 18, 2023, 07:30:21 AM
March 18, 2023, 04:45:04 AM
March 18, 2023, 03:45:14 AM
March 18, 2023, 02:15:42 AM
March 17, 2023, 10:40:47 PM
post (distributed) air gap
romy
March 17, 2023, 07:47:14 PM
post Re: Plasma Toroid
March 17, 2023, 06:47:10 PM
[Hobby Sites]
breezetix
March 17, 2023, 06:37:48 PM
breezetix
March 17, 2023, 06:29:37 PM
breezetix
March 17, 2023, 06:13:48 PM
post Re: Welding a MOT
breezetix
March 17, 2023, 06:12:08 PM
breezetix
March 17, 2023, 06:04:53 PM
post primary spacing
March 17, 2023, 05:44:14 PM
post Re: My second DRSSTC
March 17, 2023, 04:48:59 AM
March 17, 2023, 04:42:07 AM
March 17, 2023, 02:55:19 AM
Hafting
March 17, 2023, 12:09:07 AM
March 16, 2023, 07:52:19 PM
post My second DRSSTC
Miki_407
March 16, 2023, 03:40:21 PM
post Re: induction heating
romy
March 16, 2023, 08:12:37 AM
March 16, 2023, 05:41:56 AM
March 16, 2023, 05:32:24 AM
March 16, 2023, 03:53:17 AM
March 16, 2023, 01:30:31 AM
March 16, 2023, 12:17:32 AM
March 15, 2023, 11:53:29 PM
March 15, 2023, 05:26:43 PM
romy
March 15, 2023, 03:56:29 PM
romy
March 15, 2023, 03:53:31 PM
romy
March 15, 2023, 03:51:10 PM
March 14, 2023, 11:00:41 PM
March 14, 2023, 10:28:05 PM
March 14, 2023, 05:01:44 PM
romy
March 14, 2023, 03:00:36 PM
romy
March 14, 2023, 02:03:42 PM
March 14, 2023, 04:04:32 AM
March 13, 2023, 10:41:49 PM
March 13, 2023, 08:25:38 PM
March 13, 2023, 05:59:40 PM
March 13, 2023, 09:08:46 AM
March 13, 2023, 06:15:51 AM
March 13, 2023, 02:10:47 AM
March 13, 2023, 12:21:01 AM
March 13, 2023, 12:17:09 AM
March 12, 2023, 11:43:38 PM
March 12, 2023, 10:39:41 PM
ColinHeath
March 12, 2023, 10:39:05 PM
March 12, 2023, 09:46:24 PM
post Re: 160mm DRSSTC project
Mathieu thm
March 12, 2023, 09:23:23 PM
March 12, 2023, 07:52:30 PM
dannybeckett
March 12, 2023, 06:45:50 PM
March 12, 2023, 09:04:53 AM
joabel1971
March 11, 2023, 10:03:58 PM
joabel1971
March 11, 2023, 09:15:23 PM
March 11, 2023, 02:20:13 AM
dannybeckett
March 11, 2023, 12:24:07 AM
March 11, 2023, 12:13:11 AM
March 10, 2023, 09:42:29 PM
March 10, 2023, 08:38:36 PM
March 10, 2023, 08:06:23 PM
March 10, 2023, 05:13:44 PM
Alex_1996
March 10, 2023, 05:07:20 PM
Alex_1996
March 10, 2023, 04:38:21 PM
March 10, 2023, 04:25:12 PM
Alex_1996
March 10, 2023, 03:53:56 PM
dannybeckett
March 10, 2023, 01:39:57 PM
romy
March 10, 2023, 10:27:36 AM
March 10, 2023, 09:48:10 AM
March 10, 2023, 03:51:40 AM
March 10, 2023, 03:00:09 AM
dannybeckett
March 10, 2023, 01:03:19 AM
March 09, 2023, 10:51:52 PM
March 09, 2023, 07:06:03 PM
dannybeckett
March 09, 2023, 02:25:33 PM
March 09, 2023, 10:11:27 AM
