Author Topic: DRSSTC V1 using BSM150  (Read 339 times)
Offline Unrealeous
« on: April 09, 2024, 04:04:47 AM »
Hi all,
First DRSSTC has just had a successful music test at full voltage.
I started building this in January, and its been evolving with new and upgraded components as my knowledge has grown and having a few failures along the way.  I eventually lucked out getting some cheap IGBT bricks after burning out some 60N60’s and then upgraded the secondary to bring the resonant frequency down.
Thanks everyone for all the help and support - there is a wealth of knowledge in this forum if you take the time to look for it.   I couldn't have done it without the myriad of posts/photos/vidoes of the members.  It certainly feels like quite an achievement to get one of these things finally working!
Final specification is as follows:
Bridge: 2x Eupec BSM150GB1200DN2 IGBT's in full bridge configuration
Supply: 240V AC 10A rectified bridge, 3x1800uF 420V capacitors in parallel
Primary: Inner diameter 15cm, 4.5 turns, 6mm copper at 6mm edge to edge spacing.
MMC: 0.22uF (8 Dawncap DTR 0.44uF 6000V in 2P4S configuration).
Secondary: 1500 turns of 0.31mm wire, 11cm diameter, 62cm long
Secondary Resonate Frequency: 138kHz    Primary at 130kHz.
Topload: 3d printed 15cm x 55cm covered in foil tape
Driver: UD2.7C. OCD set at 400amps.  IGBT’s stay fairly cool so I’m sure I can push it higher, but will need to water cool my primary as that is what currently gets hot and starting to melt my 3d printed supports.
First full power music test
First full power basic interrupter test
First light
« Last Edit: April 12, 2024, 12:53:38 PM by Unrealeous »
With enough voltage, everything becomes a conductor.  With enough current, everything becomes a fuse.
Offline markus
Re: DRSSTC V1 using BSM1500
« Reply #1 on: April 09, 2024, 05:15:19 PM »
Nice coil, and nice sparks! I like the size, it is small enough that it does not take too much space, basically a large tabletop coil.
I am building something similar right now, since I got the same IGBTs for cheap as well - well, actually I was building the coil till I got sidetracked with my induction heating project.
One thing I noticed however is the primary cable going in from above, which seems dangerous to me since it increases risk of flashovers / arcs hitting the primary cable. I recommend connecting from below instead, even if it is a bit more troublesome.
Offline flyingperson23
  • noob :)
« Reply #2 on: April 09, 2024, 06:14:27 PM »
Great build! Watercooling is a pain, maybe try making the supports out of wood?
Offline Unrealeous
« Reply #3 on: April 10, 2024, 01:32:17 AM »
Yes, good point, I will rectify.  I've been putting the breakout point on the opposite side to the cable, but realise this is just playing with fire.
I guess that's an easy first step, so I might as well give it a go.  To be honest I haven't measured the temperature of the primary, but I can smell the PLA after a decent run and it's too hot to touch.
Today at 05:22:43 AM
Today at 05:08:46 AM
Today at 04:49:16 AM
post Re: Ring Launcher AC vs DC?
Today at 03:55:37 AM
Today at 02:48:22 AM
Domo
Today at 02:05:05 AM
Today at 01:43:10 AM
May 18, 2024, 11:30:11 PM
May 18, 2024, 10:10:56 PM
Domo
May 18, 2024, 09:46:17 PM
May 18, 2024, 08:05:36 PM
post Re: Help an EE student
May 18, 2024, 05:59:21 AM
May 18, 2024, 05:44:41 AM
May 18, 2024, 01:55:42 AM
May 17, 2024, 11:49:33 PM
May 17, 2024, 10:18:46 PM
May 17, 2024, 07:24:22 PM
May 17, 2024, 07:14:35 PM
May 17, 2024, 08:35:38 AM
May 17, 2024, 05:34:10 AM
post Re: colored 50 Ohm coax
May 16, 2024, 10:53:53 PM
May 16, 2024, 10:37:50 PM
May 16, 2024, 10:29:30 PM
May 16, 2024, 08:26:41 PM
May 16, 2024, 06:54:05 PM
May 16, 2024, 05:04:41 PM
AntoineRcbs
May 16, 2024, 12:13:47 PM
Domo
May 16, 2024, 06:58:12 AM
May 16, 2024, 06:47:09 AM
May 16, 2024, 06:00:49 AM
May 16, 2024, 05:45:08 AM
May 16, 2024, 05:03:41 AM
May 16, 2024, 04:58:40 AM
May 16, 2024, 04:36:40 AM
May 16, 2024, 12:28:27 AM
post Re: Watercooling
May 15, 2024, 11:13:48 PM
May 15, 2024, 10:58:05 PM
post colored 50 Ohm coax
May 15, 2024, 08:31:48 PM
May 15, 2024, 07:56:38 PM
May 15, 2024, 06:29:59 PM
Felix B.
May 15, 2024, 04:04:14 PM
May 15, 2024, 03:32:57 PM
post DRSSTC grounding issues
Felix B.
May 15, 2024, 03:07:39 PM
samsonwilliams
May 15, 2024, 05:50:59 AM
Domo
May 15, 2024, 05:38:14 AM
May 15, 2024, 04:58:02 AM
post Re: Big Coil Build Log
May 15, 2024, 04:34:49 AM
May 15, 2024, 04:30:18 AM
May 15, 2024, 04:00:55 AM
May 15, 2024, 03:21:51 AM
May 14, 2024, 11:12:22 PM
May 14, 2024, 11:00:00 PM
May 14, 2024, 09:45:38 PM
May 14, 2024, 09:02:28 PM
May 14, 2024, 05:55:24 AM
May 14, 2024, 05:44:12 AM
May 14, 2024, 05:11:54 AM
May 13, 2024, 11:44:56 PM
Domo
May 13, 2024, 10:28:34 PM
May 13, 2024, 10:20:19 PM
Domo
May 13, 2024, 09:27:58 PM
May 13, 2024, 09:06:59 PM
Domo
May 13, 2024, 08:43:49 PM
May 13, 2024, 07:25:29 PM
May 13, 2024, 06:50:59 PM
May 13, 2024, 03:47:08 PM
May 13, 2024, 03:42:58 PM
May 13, 2024, 07:09:16 AM
May 13, 2024, 05:02:46 AM
May 13, 2024, 02:25:25 AM
May 13, 2024, 01:39:11 AM
post Re: Plasma Toroid
May 13, 2024, 01:33:21 AM
May 12, 2024, 10:56:53 PM
May 12, 2024, 05:10:40 PM
May 12, 2024, 04:24:44 PM
May 12, 2024, 04:10:54 PM
May 12, 2024, 04:04:11 PM
hal7rr
May 12, 2024, 03:56:57 PM
May 12, 2024, 03:46:45 PM
hal7rr
May 12, 2024, 02:59:16 PM
May 12, 2024, 02:51:27 PM
May 12, 2024, 02:49:42 PM
May 12, 2024, 08:34:39 AM
May 12, 2024, 08:30:29 AM
May 12, 2024, 02:35:17 AM
May 12, 2024, 02:07:32 AM
May 11, 2024, 09:55:59 PM
May 11, 2024, 06:16:22 PM
hal7rr
May 11, 2024, 05:24:34 PM
May 11, 2024, 10:39:24 AM
May 11, 2024, 07:02:20 AM
May 11, 2024, 06:40:50 AM
paulp1776
May 11, 2024, 06:23:59 AM
May 11, 2024, 05:27:22 AM
May 11, 2024, 01:37:37 AM
May 11, 2024, 12:10:44 AM
Luca c.
May 10, 2024, 09:38:05 PM
May 10, 2024, 09:24:21 PM
May 10, 2024, 08:43:11 PM
May 10, 2024, 08:33:47 PM
