Author Topic: 833c Vttc not working  (Read 456 times)
Offline Thereuopoda
« on: March 30, 2024, 10:29:31 PM »
Hello, I have been making several changes to my 833c vttc, but no luck. I have tried reversing the feedback and primary coils, as well as reducing the tank capacitance. Unfortunately, my secondary coil is not developing any voltage at all. I also have tried using a Grid leak circuit, consisting of a 250ohm resistor and 2 1200pf rf caps. Any ideas?
« Last Edit: March 30, 2024, 10:32:14 PM by Thereuopoda »
Re: 833c Vttc not working
« Reply #1 on: March 31, 2024, 05:40:44 AM »
I think that your primary circuit capacitance is too small. You won't have enough turns on the primary coil to tune it with your secondary circuit. For the number of turns on your primary coil, you probably want around 2 nF in order to tune it with your primary coil inductance and secondary coil size. For a sanity check, use JAVATC to confirm that you can achieve resonance on the primary and secondary circuits with your design parameters. Remember to add a few extra turns for tuning due to inaccuracies. Running out of tuning turns is very inconvenient. You can ignore the spark gap portions of JAVATC.
« Last Edit: March 31, 2024, 05:58:11 AM by MRMILSTAR »
Offline Thereuopoda
« Reply #2 on: March 31, 2024, 07:22:05 AM »
Thank you for your reply, I have been messing around with the capacitance, unfortunately when I added caps to get 2.8nf, nothing. I finally discovered that my tube appeared to have an internal short. I hooked up my oscilloscope to the grid and discovered a 60hz AC wave, as well as one on the anode. I believe this means that the 60hz 10v AC is somehow on the grid and anode. Furthermore, I measured 1.2kv DC on the cathode, this leads me to believe that my tube is bad. Hooking up a continuity tester told me that the Grid and Anode are both shorted to the Cathode, but It only happens once the filament is hot. This is the second tube I have ordered, the first one had lost its vacuum due to a glass fracture sometime before I got it probably during shipping. How can I get an 833 A or C tube that works and also not spend too much money? Brand-new in-the-box tubes are pretty expensive, unfortunately. Thank you for your reply!
« Reply #3 on: March 31, 2024, 04:09:52 PM »
Bad tubes are always a possibility, especially if bought used. My first 833A was weak even though the filament glowed. I finally bought a NOS Ampex 833A and later a matched pair of NOS 833C tubes. Its always best to have two tubes on hand so that you can swap them out for testing. NOS 833A or 833C tubes aren't cheap though.
Offline janno288
« Reply #4 on: March 31, 2024, 04:31:54 PM »
Can you measure the voltage on the grid when b+ is on and filament voltage has been applied?
Preferebly with a scope and please post the waveform.
4 Pictures, 2 gridleak, both polarities , 2 no girdleak both polarities.
Wait if your schematic is accurate, you dont have the filament (cathode) attached to your power supply ground, the tube obviously doesnt conduct if there is possibility for it to conduct
Offline Thereuopoda
« Reply #5 on: April 01, 2024, 07:04:41 AM »
Thank you janno288 and MRMILSTAR,
Turns out the tube is fine. and after playing with the feedback we had some nice sparks. We also had to ground the filament, and also remove the grid leak resistor. We also ended up driving a ground pole into our garden. We still have one problem though, there is a nasty corona coming off the feedback coil, probably due to high coupling between the secondary and feedback. We will be away for a few days and won't be working on the coil, and we plan to make a spacer for a new feedback coil. For anybody wondering, the Feedback is at 25 turns of 24 AWG magnet wire, the primary is 27 turns of 8 AWG wire. We now have 6 470pf soviet RF caps for the tank circuit, and the secondary is ~1100 t of 27 AWG red magnet wire.
Here are the arcs it produces:
« Last Edit: April 01, 2024, 07:06:14 AM by Thereuopoda »
« Reply #6 on: April 01, 2024, 04:03:47 PM »
Glad to hear that you got it running. I had to add an acrylic spark shield to the top of my grid feedback coil because I was getting arcing between it and the top of the secondary coil.
Offline Thereuopoda
« Reply #7 on: April 06, 2024, 04:03:42 AM »
I have been working on tuning the coil, as well as making a new feedback coil that doesn't arc. I used 8 2'' long 3/4 PVC pipe sections to create space between the feedback and the secondary. I have gotten down from 25 to 12 turns on the feedback coil, this works very well. The system pulls around 25A and 120v at full power, as well as producing 16'' streamers without any staccato control. I have been pushing this 833c tube to the limit, with it red plating significantly at full power. The only problem is that the dual MOT setup gets hot after a while. My next idea is to make it able to play music, but I don't know where to start with that, any ideas?
Here is my feedback coil:
And Here are the streamers:
Today at 02:29:30 AM
April 16, 2024, 11:56:12 PM
April 16, 2024, 11:46:57 PM
Bobakman
April 16, 2024, 10:40:11 PM
April 16, 2024, 09:21:39 PM
April 16, 2024, 08:04:16 PM
post Re: First DRSSTC SKM100
April 16, 2024, 06:48:05 PM
April 16, 2024, 06:18:40 PM
April 16, 2024, 06:14:53 PM
April 16, 2024, 05:44:44 PM
April 16, 2024, 03:12:12 PM
April 16, 2024, 02:28:01 PM
April 16, 2024, 01:56:26 PM
April 16, 2024, 06:50:47 AM
April 16, 2024, 04:57:47 AM
ethanwu0131
April 16, 2024, 03:40:53 AM
April 16, 2024, 01:31:17 AM
April 15, 2024, 11:19:52 PM
April 15, 2024, 11:10:19 PM
April 15, 2024, 11:04:19 PM
April 15, 2024, 11:02:05 PM
April 15, 2024, 10:57:59 PM
April 15, 2024, 10:55:46 PM
April 15, 2024, 10:37:32 PM
April 15, 2024, 10:05:00 PM
April 15, 2024, 09:28:50 PM
April 15, 2024, 09:06:42 PM
April 15, 2024, 08:46:32 PM
April 15, 2024, 08:38:39 PM
sky-guided
April 15, 2024, 08:23:40 PM
Bobakman
April 15, 2024, 06:43:23 PM
April 15, 2024, 06:29:10 AM
April 15, 2024, 05:21:53 AM
April 15, 2024, 05:15:33 AM
April 15, 2024, 04:07:54 AM
April 15, 2024, 03:49:03 AM
April 14, 2024, 09:46:30 PM
April 14, 2024, 07:31:00 PM
April 14, 2024, 02:26:19 PM
post Re: mg75q2ys40 IGBT
April 14, 2024, 07:20:54 AM
April 14, 2024, 07:18:20 AM
April 13, 2024, 06:46:40 AM
April 13, 2024, 04:18:42 AM
April 13, 2024, 03:24:20 AM
April 13, 2024, 03:20:46 AM
April 13, 2024, 03:13:22 AM
post Re: Capacitor Blowout
lbattraw
April 12, 2024, 09:14:58 PM
post mg75q2ys40 IGBT
April 12, 2024, 08:40:18 PM
April 12, 2024, 07:20:30 PM
April 12, 2024, 07:12:43 PM
ethanwu0131
April 12, 2024, 04:47:33 PM
April 12, 2024, 11:43:36 AM
Egg
April 12, 2024, 12:49:02 AM
April 12, 2024, 12:41:16 AM
April 12, 2024, 12:22:41 AM
April 11, 2024, 10:45:53 PM
April 11, 2024, 07:39:30 PM
April 11, 2024, 07:24:52 PM
sky-guided
April 11, 2024, 06:09:30 PM
April 11, 2024, 12:55:16 PM
April 11, 2024, 03:40:00 AM
sky-guided
April 11, 2024, 03:05:07 AM
April 11, 2024, 02:57:33 AM
April 11, 2024, 01:44:32 AM
April 11, 2024, 01:31:40 AM
OmGigaTron
April 11, 2024, 01:11:00 AM
April 11, 2024, 12:58:52 AM
April 11, 2024, 12:31:37 AM
April 11, 2024, 12:30:21 AM
April 10, 2024, 11:41:46 PM
April 10, 2024, 11:33:32 PM
April 10, 2024, 10:41:33 PM
April 10, 2024, 10:31:31 PM
April 10, 2024, 09:56:35 PM
April 10, 2024, 08:59:26 PM
April 10, 2024, 06:35:30 PM
April 10, 2024, 05:35:14 PM
post Medium Drsstc question
April 10, 2024, 03:07:02 PM
April 10, 2024, 03:42:12 AM
April 10, 2024, 03:41:04 AM
sky-guided
April 10, 2024, 02:50:23 AM
Unrealeous
April 10, 2024, 01:32:17 AM
OmGigaTron
April 10, 2024, 01:26:29 AM
OmGigaTron
April 10, 2024, 01:18:35 AM
post Re: Big Coil Big Sparks
April 09, 2024, 07:34:19 PM
April 09, 2024, 06:14:27 PM
April 09, 2024, 06:08:53 PM
April 09, 2024, 05:15:19 PM
April 09, 2024, 05:11:04 PM
April 09, 2024, 06:32:16 AM
post DRSSTC V1 using BSM150
Unrealeous
April 09, 2024, 04:04:47 AM
April 09, 2024, 03:27:11 AM
April 09, 2024, 03:25:47 AM
OmGigaTron
April 09, 2024, 03:01:40 AM
sky-guided
April 09, 2024, 02:46:46 AM
OmGigaTron
April 08, 2024, 09:32:57 PM
OmGigaTron
April 08, 2024, 09:25:11 PM
April 08, 2024, 08:45:15 PM
OmGigaTron
April 08, 2024, 08:24:13 PM
post Big Coil Big Sparks
April 08, 2024, 04:02:48 PM
