Author Topic: Benjamin's DRSSTC3  (Read 702 times)
Offline Benjamin Lockhart
Benjamin's DRSSTC3
« on: November 27, 2023, 09:07:43 AM »
Hi all,
After having problems with the driver dying in my large freewheeling coil, I decided that I wasn't happy with the overall design. It's too heavy and difficult to set up. So I just built a whole new coil.
The plywood base is 16.75 inches in diameter and the whole coil stands about 5 feet tall
It's based heavily on Loneoceans DRSSTC3, and just so happens to be my 3rd coil build.
The specs are;
   8x36 inch chicken wire and plywood toroid (it's a cheap way to build), with 3.25x14 inch smaller toroid below
   6.3x27.5 inch secondary with 28AWG wire
   8 turn primary of 1/4 inch tube with 3/16 inch between turns and 0.8 inch clearance from secondary, 0.162 coupling, compressed air cooled, but I may need to upgrade to water cooling, I was melting primary supports!
   365nF 15kV 260A rms MMC using dawncaps, it stays completely cold. Javatc says the primary surge impedance is about 7.5 ohms and I think that number has quite an effect on the behavior of spark growth. Also I think that the primary and secondary geometry is more important than the exact coupling, however you should still try to maximize coupling for a given geometry. Play around with the primary outer diameter in javatc, you will find that there is a sweet spot that gives the most coupling. The exact diameter depends on other parameters as well.
   UD2.7C
   800A OCD for now, primary current peaks around 1000A
   130uS on time
   CM300du-24nfh full bridge, 680V DC bus voltage
   Approx 60kHz operating frequency with 7% primary detuning.
   4x 3300uF, 450V bus capacitors in doubler for 3300uF total, not shown are 2uF snubber caps across each IGBT brick.
   Onboard bus precharge circuit consisting of a 12 ohm resistor that gets bypassed by a 50A relay powered by the 24V SMPS. The SMPS has a 1/4 second turn- on delay which is enough for the caps to almost fully charge before the relay closes.
Here are some build pictures.
I don't know why some pictures are sideways?
Here is a tin can almost melting at half voltage.
And it makes 7 foot sparks!
The sparks really are incredibly bright!
What do you all think?
« Last Edit: November 27, 2023, 10:05:18 PM by Benjamin Lockhart »
Re: Benjamin's DRSSTC3
« Reply #1 on: November 29, 2023, 06:32:03 AM »
Looks like a very clean build with great performance!
Would have guessed you'd want a bit more than 7% for long arcs.  Arc length is already good.  Top load size helps with minimizing detuning, and coupling helps maintain performance in spite of secondary frequency drop.  That may be why 7% is sufficient.  Probably best for music.  Would be interesting to see if arc length could be any longer with a bit more detuning and a bit longer on time.  That's only if you want to risk pushing coil's limits.
« Reply #2 on: March 30, 2024, 08:03:00 AM »
I just ran the coil again and everything went well.
I made a shielded 10 gauge power cord for it and put a strike protection wire around the coil base.
Today at 02:29:30 AM
April 16, 2024, 11:56:12 PM
April 16, 2024, 11:46:57 PM
Bobakman
April 16, 2024, 10:40:11 PM
April 16, 2024, 09:21:39 PM
April 16, 2024, 08:04:16 PM
post Re: First DRSSTC SKM100
April 16, 2024, 06:48:05 PM
April 16, 2024, 06:18:40 PM
April 16, 2024, 06:14:53 PM
April 16, 2024, 05:44:44 PM
April 16, 2024, 03:12:12 PM
April 16, 2024, 02:28:01 PM
April 16, 2024, 01:56:26 PM
April 16, 2024, 06:50:47 AM
April 16, 2024, 04:57:47 AM
ethanwu0131
April 16, 2024, 03:40:53 AM
April 16, 2024, 01:31:17 AM
April 15, 2024, 11:19:52 PM
April 15, 2024, 11:10:19 PM
April 15, 2024, 11:04:19 PM
April 15, 2024, 11:02:05 PM
April 15, 2024, 10:57:59 PM
April 15, 2024, 10:55:46 PM
April 15, 2024, 10:37:32 PM
April 15, 2024, 10:05:00 PM
April 15, 2024, 09:28:50 PM
April 15, 2024, 09:06:42 PM
April 15, 2024, 08:46:32 PM
April 15, 2024, 08:38:39 PM
sky-guided
April 15, 2024, 08:23:40 PM
Bobakman
April 15, 2024, 06:43:23 PM
April 15, 2024, 06:29:10 AM
April 15, 2024, 05:21:53 AM
April 15, 2024, 05:15:33 AM
April 15, 2024, 04:07:54 AM
April 15, 2024, 03:49:03 AM
April 14, 2024, 09:46:30 PM
April 14, 2024, 07:31:00 PM
April 14, 2024, 02:26:19 PM
post Re: mg75q2ys40 IGBT
April 14, 2024, 07:20:54 AM
April 14, 2024, 07:18:20 AM
April 13, 2024, 06:46:40 AM
April 13, 2024, 04:18:42 AM
April 13, 2024, 03:24:20 AM
April 13, 2024, 03:20:46 AM
April 13, 2024, 03:13:22 AM
post Re: Capacitor Blowout
lbattraw
April 12, 2024, 09:14:58 PM
post mg75q2ys40 IGBT
April 12, 2024, 08:40:18 PM
April 12, 2024, 07:20:30 PM
April 12, 2024, 07:12:43 PM
ethanwu0131
April 12, 2024, 04:47:33 PM
April 12, 2024, 11:43:36 AM
Egg
April 12, 2024, 12:49:02 AM
April 12, 2024, 12:41:16 AM
April 12, 2024, 12:22:41 AM
April 11, 2024, 10:45:53 PM
April 11, 2024, 07:39:30 PM
April 11, 2024, 07:24:52 PM
sky-guided
April 11, 2024, 06:09:30 PM
April 11, 2024, 12:55:16 PM
April 11, 2024, 03:40:00 AM
sky-guided
April 11, 2024, 03:05:07 AM
April 11, 2024, 02:57:33 AM
April 11, 2024, 01:44:32 AM
April 11, 2024, 01:31:40 AM
OmGigaTron
April 11, 2024, 01:11:00 AM
April 11, 2024, 12:58:52 AM
April 11, 2024, 12:31:37 AM
April 11, 2024, 12:30:21 AM
April 10, 2024, 11:41:46 PM
April 10, 2024, 11:33:32 PM
April 10, 2024, 10:41:33 PM
April 10, 2024, 10:31:31 PM
April 10, 2024, 09:56:35 PM
April 10, 2024, 08:59:26 PM
April 10, 2024, 06:35:30 PM
April 10, 2024, 05:35:14 PM
post Medium Drsstc question
April 10, 2024, 03:07:02 PM
April 10, 2024, 03:42:12 AM
April 10, 2024, 03:41:04 AM
sky-guided
April 10, 2024, 02:50:23 AM
Unrealeous
April 10, 2024, 01:32:17 AM
OmGigaTron
April 10, 2024, 01:26:29 AM
OmGigaTron
April 10, 2024, 01:18:35 AM
post Re: Big Coil Big Sparks
April 09, 2024, 07:34:19 PM
April 09, 2024, 06:14:27 PM
April 09, 2024, 06:08:53 PM
April 09, 2024, 05:15:19 PM
April 09, 2024, 05:11:04 PM
April 09, 2024, 06:32:16 AM
post DRSSTC V1 using BSM150
Unrealeous
April 09, 2024, 04:04:47 AM
April 09, 2024, 03:27:11 AM
April 09, 2024, 03:25:47 AM
OmGigaTron
April 09, 2024, 03:01:40 AM
sky-guided
April 09, 2024, 02:46:46 AM
OmGigaTron
April 08, 2024, 09:32:57 PM
OmGigaTron
April 08, 2024, 09:25:11 PM
April 08, 2024, 08:45:15 PM
OmGigaTron
April 08, 2024, 08:24:13 PM
post Big Coil Big Sparks
April 08, 2024, 04:02:48 PM
