Author Topic: An unexpected autotransformer  (Read 434 times)
« on: September 28, 2024, 03:58:22 AM »
For a lab project I got several RF impedance-scaling transformers by Mini-Circuits.
First one is TC9-1-75+
It's got a ferrite binocular core like the one in my post about "4 mm cube microwave transformer". There are similar cores in consumer tv-antenna accessories like 300:75 ohm baluns (familiar to we boomers).
The datasheet https://www.minicircuits.com/pdfs/TC9-1-75+.pdf
says it's step-down, 9:1 impedance ratio (3:1 voltage ratio), 0.3 to 475 MHz, suggested application "matching laser diode".
I overlooked the word "autotransformer" until I'd studied a specimen under a microscope, before soldering it in.
Here shown as received in cut-tape form, with the cover tape peeled back.   Note unconventional direction of pin numbering; most devices (starting with vacuum tubes) have pins numbered clockwise when viewed from bottom.
Overlaid on photo is figure from datasheet (Config. D), with implied 3:1 turns ratio,
and a stock autotransformer schematic that matches the actual construction.
From pin 3 to pin 1 are 2 turns of both red and green magnet wire (bifilar).
Continuing from pin 1, in same clockwise direction, are 4 turns of yellow magnet wire; the end wraps outside left edge of core to pin 6 terminal.
Are any readers here familiar with materials and datasheets for cores like this?  Don't know if I'll have time to measure the ampere-turns or volt-seconds for core saturation.
The part served my purpose, which was adding MHz-range tones onto a 1-volt ASIC power net with more than 100 uF of MLCC's. Another transformer served better.
« Last Edit: September 28, 2024, 04:14:42 AM by klugesmith »
Offline haversin
Re: An unexpected autotransformer
« Reply #1 on: October 01, 2024, 06:04:57 PM »
 The phase dots on the left figure don't match the autotransformer on the right figure.  A positive voltage applied to pin 6 would give a positive voltage on pin 1 according to the left figure. But on the right figure a positive voltage applied to pin 6 would give negative voltage on pin 1.
« Reply #2 on: October 02, 2024, 06:27:22 PM »
Why would positive on 6 give a negative on 1, assuming 3 is common?
If you're confident, or not sure, I could check with an oscilloscope.
I've looked at that transformer only with a spectrum analyzer and a TDR scope (which verified the size & direction of impedance transformation).
Offline haversin
« Reply #3 on: October 02, 2024, 10:49:03 PM »
Oops! your right I thought 3 was common on the right figure.
« Reply #4 on: October 03, 2024, 12:15:29 AM »
In the photo and both diagrams, pin 3 is common to primary non-dot and secondary non-dot.
I was initially surprised to see pin 3 as one end of the whole winding.
Pin 1 is the "off center tap", one end of 2-turn winding (red&green) and one end of 4-turn winding (yellow).   It's electrically identified as secondary dot.  Can we agree that dotting is implicit in conventional schematic symbol for autotransformer?
Offline haversin
« Reply #5 on: October 03, 2024, 12:45:51 AM »
what I meant to say was I thought that the middle pin 1 on the right figure was common so that pin 3 would be go negative if pin 6 goes positive.  Yes I think the winding is assumed to be in the in same direction through out an autotransformer so the dots for it are implicit.
JoeBusic
Today at 05:35:53 PM
Today at 02:39:18 PM
Today at 02:26:49 PM
Today at 08:15:12 AM
Today at 05:32:32 AM
TXtesla
Late
JoeBusic
JoeBusic
adamcord
Frantisek
huntergroundmind
inanium
October 31, 2024, 09:54:55 PM
Hysteresis
October 31, 2024, 09:34:24 PM
post Proper capacitance size
BibberCoils
October 31, 2024, 06:46:32 PM
betalab99
October 31, 2024, 02:06:00 PM
Late
October 31, 2024, 07:32:50 AM
October 30, 2024, 08:12:44 PM
October 30, 2024, 08:05:46 PM
October 30, 2024, 07:19:07 PM
October 30, 2024, 03:16:41 PM
vvs2000
October 30, 2024, 02:43:01 PM
October 30, 2024, 12:45:19 PM
October 30, 2024, 08:17:10 AM
nzoomed
October 30, 2024, 07:47:59 AM
damion
October 30, 2024, 12:50:31 AM
October 29, 2024, 11:18:56 PM
nzoomed
October 29, 2024, 10:34:44 PM
Late
October 29, 2024, 06:40:34 PM
October 29, 2024, 06:15:51 PM
nzoomed
October 29, 2024, 10:07:32 AM
October 29, 2024, 01:57:49 AM
nzoomed
October 28, 2024, 10:27:13 PM
October 28, 2024, 07:17:39 PM
October 28, 2024, 10:04:46 AM
Late
October 28, 2024, 06:48:45 AM
October 28, 2024, 04:18:04 AM
October 28, 2024, 04:12:35 AM
thaumatichthys
October 28, 2024, 12:16:47 AM
nzoomed
October 27, 2024, 10:36:34 PM
October 27, 2024, 06:33:55 PM
betalab99
October 27, 2024, 06:05:04 PM
October 27, 2024, 05:32:16 PM
Late
October 27, 2024, 02:07:38 PM
Late
October 27, 2024, 12:51:21 PM
October 27, 2024, 11:38:24 AM
post Re: My first QCW
October 27, 2024, 06:24:25 AM
Frantisek
October 26, 2024, 08:49:05 PM
Mathieu thm
October 26, 2024, 07:49:37 PM
October 26, 2024, 03:51:05 PM
noahsarc
October 26, 2024, 03:46:13 PM
October 25, 2024, 11:18:22 PM
October 25, 2024, 11:13:29 PM
October 25, 2024, 10:52:23 PM
Avenger
October 25, 2024, 09:05:37 PM
Mathieu thm
October 25, 2024, 07:46:41 PM
October 25, 2024, 11:07:20 AM
AdamRozdrazewski
October 25, 2024, 10:28:43 AM
October 25, 2024, 06:26:52 AM
October 25, 2024, 05:53:02 AM
October 25, 2024, 05:23:14 AM
October 25, 2024, 05:17:02 AM
October 25, 2024, 04:40:47 AM
October 25, 2024, 01:23:27 AM
October 25, 2024, 01:17:18 AM
October 25, 2024, 01:14:28 AM
October 25, 2024, 12:32:31 AM
October 24, 2024, 08:21:32 PM
Glad_Yard
October 24, 2024, 08:05:34 AM
October 24, 2024, 04:56:50 AM
October 24, 2024, 04:48:31 AM
zgoode
October 24, 2024, 12:44:43 AM
October 23, 2024, 08:44:01 PM
October 23, 2024, 05:57:48 PM
kenw232
October 23, 2024, 05:02:59 PM
October 23, 2024, 08:04:42 AM
post Induction heater safety
thaumatichthys
October 23, 2024, 07:29:51 AM
October 23, 2024, 05:39:57 AM
October 23, 2024, 05:16:00 AM
October 23, 2024, 05:04:51 AM
