Author Topic: Need feedback on this circuit (flyback driver)  (Read 632 times)
Offline Domo
« on: August 26, 2024, 05:14:48 AM »
Hello all,
I would like to request feedback on this design, maybe I am missing something that i am not aware about, and I do have few questions about it..
Basically, taking rectified AC voltage (170 VDC) feeding to R1/Q1, which acts as voltage regulator on source end. D2 prevents ringing voltage to return to Q1. D3 is a snubber diode. Q2 controls freq and PWM, which is listed nest to it. Q1,Q2 can handle 450V@20A. D2 and D3 can handle 1200V@8A
The question that i have, with D3 being in place, do I need to worry about ringing voltage? If so, what voltages can i expect? 1kvpp? 2kvpp?
Offline PhotonLab
Re: Need feedback on this circuit (flyback driver)
« Reply #1 on: August 26, 2024, 01:31:13 PM »
Hello,
first remove Q1 (is not working the way you think, i.e. a current regulator) and D2, they are not necessary for the purpose of making spark :)
D3 must be a fast diode if you really want a snubber network, diode + capacitor, there's some math involved, add a 10 kOhm resistor betwen gate and GND.
Cheers
M.
Offline Anders Mikkelsen
« Reply #2 on: August 26, 2024, 02:38:49 PM »
D3 will kill the flyback pulses on the primary and therefore also strongly limit the output voltage. RCD snubbers can work here, but the most common approach for simple drivers is to just let the flyback pulse go as high as it does, and dimension the MOSFET to handle it. This limits how high you can go with the input voltage without exceeding the breakdown voltage of your IRFPs.
Making a linear regulator with MOSFETs as shown in your diagram will lead to a lot of dissipation and likely blown transistors as MOSFETs often have very limited tolerance for linear mode operation at higher voltages (above some tens of volts). I don't recommend running anything directly off mains, especially if you have limited experience with switching circuits. Both due to the high voltage, lack of isolation from mains, high fault energy available and limited tolerance for faults. A power supply of some 20 - 40 V will be much better and safer here.
Offline Domo
« Reply #3 on: August 26, 2024, 11:01:55 PM »
The purpose of Q1 is a voltage regulator, it worked on smaller scale (lower current, but still over 100V DC). Purpose of it is to reduce voltage to coil, as some flybacks operate on 90V or 110V. Q1 and Q2 are on heatsink with fan.
Cheers
M.
D3 (and D2) will be RHRP8120 on heatsink.
That is my concern, wont the ringing voltage be 2x, 5x of input voltage? IRFP460 can only handle 500V..
Would you be able to recommend some sort of solid state regulation that does not involve transformer?
« Last Edit: August 26, 2024, 11:38:57 PM by Domo »
« Reply #4 on: August 27, 2024, 12:51:27 AM »
That's the whole point of original TV-set flyback circuits (and ignition circuits).   The primary voltage needs to "ring" to magnitude several times greater than power input voltage.   High output voltage depends on that;   the secondary/primary voltage ratio is the same in all phases of switching cycle.  As Anders says, D3 will clamp the primary winding voltage when switch is off.  Magnetic flux will decline slowly, as the primary current goes through D3 instead of the switch.
In the simplest model (of normal circuit), primary voltage with switch open is determined by secondary voltage at which the output rectifier diode conducts.  Operating with no load, the primary and secondary voltages "ring up" to the voltage at which something breaks down, and that voltage (divided by turns count) determines magnetic dF/dt.
It looks like you're on the way to running transient analysis in a simulation program.  That will be informative.  Start with a resistive load, or rectifier diode + HV capacitor, on the secondary side.
« Last Edit: August 27, 2024, 01:29:56 AM by klugesmith »
« Reply #5 on: August 27, 2024, 02:58:53 PM »
The voltage will ring up to a value determined by the sum of the supply voltage, the reflected secondary voltage (load voltage divided by transformer ratio) and the turn-off time multiplied by the transformer leakage inductance. This can easily be over ten times the supply voltage when unloaded. For reference, TVs often used a BU508a for flyback drive, rated for 900 V Vcb and 500 ns turn-off time, along with clamping and damping of the overshoot. Your MOSFET is ten times as fast as this, so without any clamping or snubbing I wouldn't go above some 30 - 40 V with an IRFP460.
When using a MOSFET as a linear regulator, the problem is not so much power dissipation but device destruction due to local thermal runaway in parts of the die. Making a linear regulator that drops more than 50 V is very difficult, and I would avoid it at all, and if I had to I would use a linear rated MOSFET like an IXYS L2 series. Note that these are some ten times as expensive as normal MOSFETs. You can potentially use a buck converter to power it, but then it would be simpler to just run the flyback from a halfbridge if you insist it has to be powered directly from rectified mains.
From the questions you are asking, I would strongly recommend you to avoid circuits connected directly to mains. The fault energy is dangerous, any error will lead to immediate destruction of multiple components, and the circuit can not be practically or safely probed with oscilloscopes. Is there any reason you can't use a low voltage supply to power it?
What are you planning to accomplish with the circuit? This sounds like a classical XY problem.
Offline Domo
« Reply #6 on: August 28, 2024, 12:44:17 AM »
The citcuit posted above is not complete, There is few more components included, but for simplicity, I just posted something simple. There is a 2A fuse, EMI filter, and I was planning an putting something for current limit before reaching rectifier. I would not be putting direct unprotected AC line into my project. I may be crazy, but not stupid ;D .
Purpose of that regulator using mosfet, is that some TV flybacks are designed to have B+ of 90V. For example, i have HR 8293 https://www.hrdiemen.com/reparation/flyback/scheme/8293 and if I put in 170VDC (Rectified US AC line), that is over 170W in transformer that was designed for 90W. If there is any other way to use solid state components to regulate 170VDC to at most 130 VDC. I would be glad to do it . I try to stay away from transformers, as they can be bulky and heavy, that's why I try to find a way using solid state.
For now, I want to make HV arc, even a Jacob's ladder for starters. Im aware it can be accomplished with lower voltages and current, but in future I will be needing higher current output.
« Reply #7 on: August 28, 2024, 11:59:34 PM »
Thank you for presenting a model fancier than mine.   We know that real flybacks (and engine ignitions) must not be immediately damaged by voltage stress from running unloaded.
How about if Domo experimentally runs his driver circuit with 15 or 30 volts DC, and uses an oscilloscope to measure the maximum voltage on Q2, to get that "ring up" factor with actual transformer and gate drive.  He could see how D3 kills the ring up.
Late
Today at 04:23:47 PM
Late
Today at 04:17:48 PM
post Re: My first QCW
Mathieu thm
Today at 02:59:35 PM
Today at 01:18:16 PM
JoeBusic
October 05, 2024, 10:56:17 PM
post Re: current transformers
October 05, 2024, 09:42:27 PM
October 05, 2024, 09:35:43 PM
October 05, 2024, 08:50:55 PM
October 05, 2024, 07:59:15 PM
October 05, 2024, 05:35:00 PM
October 05, 2024, 05:24:59 PM
post Crystal HFSSTC
Perolodzilla
October 05, 2024, 01:16:19 PM
October 05, 2024, 09:14:48 AM
October 05, 2024, 06:45:42 AM
October 05, 2024, 06:20:55 AM
October 05, 2024, 06:13:35 AM
October 05, 2024, 05:53:22 AM
October 05, 2024, 04:19:17 AM
October 05, 2024, 12:15:59 AM
Continuum
October 04, 2024, 11:12:20 PM
post current transformers
October 04, 2024, 10:25:43 PM
October 04, 2024, 07:15:58 PM
post Re: Shock box
October 04, 2024, 02:58:01 AM
Continuum
October 04, 2024, 01:27:07 AM
post Re: Shock box
October 04, 2024, 01:03:02 AM
post Re: Shock box
October 04, 2024, 12:44:17 AM
post Shock box
October 04, 2024, 12:21:09 AM
October 03, 2024, 07:38:36 AM
October 03, 2024, 12:45:51 AM
October 03, 2024, 12:15:29 AM
October 02, 2024, 10:49:03 PM
October 02, 2024, 06:27:22 PM
October 02, 2024, 05:41:09 PM
Alex_1996
October 02, 2024, 05:23:18 PM
radbloke
October 02, 2024, 05:57:37 AM
October 02, 2024, 05:00:12 AM
October 02, 2024, 03:01:15 AM
Alex_1996
October 01, 2024, 10:22:59 PM
October 01, 2024, 06:04:57 PM
post Re: gate connectors
Mathieu thm
September 30, 2024, 07:28:30 PM
September 30, 2024, 07:20:58 PM
drobotk
September 30, 2024, 12:43:47 PM
Mathieu thm
September 30, 2024, 06:53:24 AM
radbloke
September 30, 2024, 06:25:22 AM
September 30, 2024, 04:59:48 AM
September 30, 2024, 04:53:25 AM
Mathieu thm
September 29, 2024, 11:21:31 PM
post gate connectors
September 29, 2024, 10:52:56 PM
Mathieu thm
September 29, 2024, 08:30:21 PM
Mathieu thm
September 29, 2024, 05:33:59 PM
radbloke
September 29, 2024, 06:42:39 AM
September 29, 2024, 05:12:00 AM
radbloke
September 29, 2024, 01:17:44 AM
Mathieu thm
September 28, 2024, 03:15:56 PM
post An unexpected autotransformer
September 28, 2024, 03:58:22 AM
post Re: Choosing an SiC FET part
September 27, 2024, 05:21:00 AM
post Re: doubt capacitor
September 27, 2024, 03:36:01 AM
JoeBusic
September 26, 2024, 11:15:01 PM
September 26, 2024, 11:40:59 AM
post Choosing an SiC FET part
September 26, 2024, 06:27:56 AM
September 26, 2024, 02:35:32 AM
post Bertran Model 205A-03R High Voltage Power Supply
Burak
September 25, 2024, 07:47:05 PM
radbloke
September 25, 2024, 06:28:01 AM
September 25, 2024, 05:27:08 AM
post Re: Mystery CREE power module investigation
September 24, 2024, 07:32:46 PM
September 24, 2024, 07:25:04 PM
radbloke
September 24, 2024, 04:13:47 PM
radbloke
September 24, 2024, 03:02:13 PM
September 24, 2024, 05:55:20 AM
post Tested and working feedback induction heater driver with current limiter
radbloke
September 24, 2024, 04:40:40 AM
post New Feedback Induction Heater Control Driver- Working!
radbloke
September 24, 2024, 03:36:54 AM
September 24, 2024, 03:23:54 AM
fgytiyti7y66t
September 23, 2024, 10:20:20 PM
JoeBusic
September 23, 2024, 05:24:13 PM
September 23, 2024, 04:41:22 PM
JoeBusic
September 23, 2024, 11:20:47 AM
September 23, 2024, 05:01:36 AM
September 23, 2024, 12:54:28 AM
September 23, 2024, 12:40:26 AM
Mathieu thm
September 22, 2024, 11:42:10 PM
September 22, 2024, 11:30:42 PM
Mathieu thm
September 22, 2024, 10:48:43 PM
September 22, 2024, 10:35:01 PM
September 22, 2024, 10:21:33 PM
September 22, 2024, 09:29:57 PM
Mathieu thm
September 22, 2024, 09:25:53 PM
September 22, 2024, 09:14:59 PM
JoeBusic
September 22, 2024, 05:54:42 PM
JoeBusic
September 22, 2024, 05:46:12 PM
September 22, 2024, 04:56:49 PM
Mathieu thm
September 22, 2024, 04:11:59 PM
September 22, 2024, 04:02:24 PM
Mathieu thm
September 22, 2024, 03:17:23 PM
JoeBusic
September 22, 2024, 12:18:51 PM
Mathieu thm
September 22, 2024, 12:03:40 PM
September 22, 2024, 05:23:51 AM
September 22, 2024, 12:41:10 AM
September 21, 2024, 11:25:15 PM
post Re: dc blocking cap
September 21, 2024, 09:25:05 PM
JoeBusic
September 21, 2024, 09:11:55 PM
