Author Topic: How to wire my flyback?  (Read 510 times)
Offline kenw232
« on: August 22, 2024, 01:35:41 AM »
Hi, I'm new.  And a novice.  How do I wire in my flyback into my circuit?
This is my transformer: https://www.hv-experimental.com/image/cache/catalog/flyback_dc_wb-500x500.jpg
So I wrap 8 or 9 winds around the top of the core there.  then connect that primary wind to + and - from my circuits.  12V is pulsing through that.
now where does my high voltage come from?   The black wire is the negative and the main red wire in front there is the +?  the other red (the one with the black) goes no where?  There are no pins on the bottom of the transformer.  so my high voltage sparkgap is between the main red and black wires.. correct?
« Last Edit: August 22, 2024, 01:38:43 AM by kenw232 »
Re: How to wire my flyback?
« Reply #1 on: August 22, 2024, 03:23:48 PM »
Before you get much further you should check to see if the flyback is AC. If you connect a ohmmeter
between the red lead and the black lead you should measure about 200-500 ohms. If you can't measure
this then the flyback is most probably a DC unit and not any good for plasma (unless your plasma
has two electrodes).
(Added) the catalog you got the flyback from says that it is a DC unit. Can't drive plasma.
This one can
https://www.hv-experimental.com/product/accessories/flyback-transformer-ac
« Last Edit: August 22, 2024, 03:58:36 PM by alan sailer »
Offline kenw232
« Reply #2 on: August 22, 2024, 03:41:44 PM »
So this transformer cannot power a fluorescent tube?  Is that right?  Only an AC flyback can power a fluorescent tube?
« Reply #3 on: August 22, 2024, 06:15:03 PM »
It's really hard for me to figure out what you are trying to do. First you talked about
powering plasma tubes and now you are talking about powering a fluorescent tube.
I have never tried to apply HV DC to a florescent tube. I am not sure what will happen. My guess is
that you will get a glow discharge. Incidentally, FL tubes are powered with AC.
There are perfectly good electronic ballasts that power up fluorescent tubes. Cheap and easy to find.
Once again, without knowing what you are trying to accomplish it's hard to give meaningful advice.
The gas pressure in a FL tube is about 3 torr. At that pressure you will get a glow discharge.
That is what fluorescent tubes are supposed to do. A typical plasma tube has pressures of 100-500 torr.
Offline kenw232
« Reply #4 on: August 22, 2024, 06:58:03 PM »
Well, don't both fluorescent tubes and plasma tubes have plasma in them (eg. electrified helium)?   Same thing.  Was not aware of the pressure thing though, how does that change the performance between them then?
« Reply #5 on: August 22, 2024, 07:09:31 PM »
It would be a good thing if you looked up some information. Like what is a glow discharge,
what does a decorative plasma tube look like.
Helium is very rarely used.
At this point I am going to give up. You don't seem interested in telling anyone what
you are trying to do. Playing the game twenty questions has never appealed to me...
Offline kenw232
« Reply #6 on: August 23, 2024, 02:39:08 AM »
I am trying to electrify a plasma tube to generate radio waves.  Just trying to do it cheaply.  Fluorescent tubes won't work.  So a tube with neon from the local sign shop might do it I suspect.
« Reply #7 on: August 23, 2024, 05:23:58 AM »
Can you tell us why?
I'd start with that.   Normally it would come with cold-cathode electrodes glass welded onto each end.  Maybe the signmaker can give you a scrap tube that was rejected by customer for some cosmetic reason.  The gas fills are generally neon or argon + mercury; I have one with just argon.   A search for "undercar neon ccfl" (to exclude most LED products) shows some colored luminous tube sets on Amazon for $11.
You can light up your custom neon element with a $15 neon power supply, like I pointed to in your other thread, as well as you could ever light it up with that flyback you showed us.
« Last Edit: August 23, 2024, 05:38:48 AM by klugesmith »
Late
Today at 04:23:47 PM
Late
Today at 04:17:48 PM
post Re: My first QCW
Mathieu thm
Today at 02:59:35 PM
Today at 01:18:16 PM
JoeBusic
October 05, 2024, 10:56:17 PM
post Re: current transformers
October 05, 2024, 09:42:27 PM
October 05, 2024, 09:35:43 PM
October 05, 2024, 08:50:55 PM
October 05, 2024, 07:59:15 PM
October 05, 2024, 05:35:00 PM
October 05, 2024, 05:24:59 PM
post Crystal HFSSTC
Perolodzilla
October 05, 2024, 01:16:19 PM
October 05, 2024, 09:14:48 AM
October 05, 2024, 06:45:42 AM
October 05, 2024, 06:20:55 AM
October 05, 2024, 06:13:35 AM
October 05, 2024, 05:53:22 AM
October 05, 2024, 04:19:17 AM
October 05, 2024, 12:15:59 AM
Continuum
October 04, 2024, 11:12:20 PM
post current transformers
October 04, 2024, 10:25:43 PM
October 04, 2024, 07:15:58 PM
post Re: Shock box
October 04, 2024, 02:58:01 AM
Continuum
October 04, 2024, 01:27:07 AM
post Re: Shock box
October 04, 2024, 01:03:02 AM
post Re: Shock box
October 04, 2024, 12:44:17 AM
post Shock box
October 04, 2024, 12:21:09 AM
October 03, 2024, 07:38:36 AM
October 03, 2024, 12:45:51 AM
October 03, 2024, 12:15:29 AM
October 02, 2024, 10:49:03 PM
October 02, 2024, 06:27:22 PM
October 02, 2024, 05:41:09 PM
Alex_1996
October 02, 2024, 05:23:18 PM
radbloke
October 02, 2024, 05:57:37 AM
October 02, 2024, 05:00:12 AM
October 02, 2024, 03:01:15 AM
Alex_1996
October 01, 2024, 10:22:59 PM
October 01, 2024, 06:04:57 PM
post Re: gate connectors
Mathieu thm
September 30, 2024, 07:28:30 PM
September 30, 2024, 07:20:58 PM
drobotk
September 30, 2024, 12:43:47 PM
Mathieu thm
September 30, 2024, 06:53:24 AM
radbloke
September 30, 2024, 06:25:22 AM
September 30, 2024, 04:59:48 AM
September 30, 2024, 04:53:25 AM
Mathieu thm
September 29, 2024, 11:21:31 PM
post gate connectors
September 29, 2024, 10:52:56 PM
Mathieu thm
September 29, 2024, 08:30:21 PM
Mathieu thm
September 29, 2024, 05:33:59 PM
radbloke
September 29, 2024, 06:42:39 AM
September 29, 2024, 05:12:00 AM
radbloke
September 29, 2024, 01:17:44 AM
Mathieu thm
September 28, 2024, 03:15:56 PM
post An unexpected autotransformer
September 28, 2024, 03:58:22 AM
post Re: Choosing an SiC FET part
September 27, 2024, 05:21:00 AM
post Re: doubt capacitor
September 27, 2024, 03:36:01 AM
JoeBusic
September 26, 2024, 11:15:01 PM
September 26, 2024, 11:40:59 AM
post Choosing an SiC FET part
September 26, 2024, 06:27:56 AM
September 26, 2024, 02:35:32 AM
post Bertran Model 205A-03R High Voltage Power Supply
Burak
September 25, 2024, 07:47:05 PM
radbloke
September 25, 2024, 06:28:01 AM
September 25, 2024, 05:27:08 AM
post Re: Mystery CREE power module investigation
September 24, 2024, 07:32:46 PM
September 24, 2024, 07:25:04 PM
radbloke
September 24, 2024, 04:13:47 PM
radbloke
September 24, 2024, 03:02:13 PM
September 24, 2024, 05:55:20 AM
post Tested and working feedback induction heater driver with current limiter
radbloke
September 24, 2024, 04:40:40 AM
post New Feedback Induction Heater Control Driver- Working!
radbloke
September 24, 2024, 03:36:54 AM
September 24, 2024, 03:23:54 AM
fgytiyti7y66t
September 23, 2024, 10:20:20 PM
JoeBusic
September 23, 2024, 05:24:13 PM
September 23, 2024, 04:41:22 PM
JoeBusic
September 23, 2024, 11:20:47 AM
September 23, 2024, 05:01:36 AM
September 23, 2024, 12:54:28 AM
September 23, 2024, 12:40:26 AM
Mathieu thm
September 22, 2024, 11:42:10 PM
September 22, 2024, 11:30:42 PM
Mathieu thm
September 22, 2024, 10:48:43 PM
September 22, 2024, 10:35:01 PM
September 22, 2024, 10:21:33 PM
September 22, 2024, 09:29:57 PM
Mathieu thm
September 22, 2024, 09:25:53 PM
September 22, 2024, 09:14:59 PM
JoeBusic
September 22, 2024, 05:54:42 PM
JoeBusic
September 22, 2024, 05:46:12 PM
September 22, 2024, 04:56:49 PM
Mathieu thm
September 22, 2024, 04:11:59 PM
September 22, 2024, 04:02:24 PM
Mathieu thm
September 22, 2024, 03:17:23 PM
JoeBusic
September 22, 2024, 12:18:51 PM
Mathieu thm
September 22, 2024, 12:03:40 PM
September 22, 2024, 05:23:51 AM
September 22, 2024, 12:41:10 AM
September 21, 2024, 11:25:15 PM
post Re: dc blocking cap
September 21, 2024, 09:25:05 PM
JoeBusic
September 21, 2024, 09:11:55 PM
