Author Topic: Bigger sparks?...  (Read 675 times)
Offline Teslaventje
Bigger sparks?...
« on: June 10, 2024, 11:05:55 PM »
I recently build a GU50 driven Tesla coil resonating at about 260KHZ for the prim and sec coil.
The prim coil has about 40 windings with the caps resonating at 260KHz. I wonder if I will get bigger sparks at less windings on the prim and still fit caps to resonate at 260KHz?...
Re: Bigger sparks?...
« Reply #1 on: June 11, 2024, 05:36:46 AM »
If you lower the primary coil inductance (fewer turns) you will have to raise the capacitance to maintain the same resonant frequency. You can use JAVATC to determine design parameters. I don't see how this will affect your spark length. Spark length is determined by input power.
Offline Teslaventje
« Reply #2 on: June 11, 2024, 11:05:49 PM »
I understand the resonance...But I wonder if the turn ratio of the coils wil result in a higher transformation in voltage and thus larger sparks?
« Reply #3 on: June 12, 2024, 03:32:22 AM »
Sparks might get larger or smaller.  Depends on how well coil load impedance matches GU50's drive capability.  Your GU50 circuit has an optimum load impedance determined by drive current and voltage.  If your TC has too high impedance now, lowering it will allow GU50 to transfer more power to coil.  If existing TC impedance is too low, then lowering it further will reduce power transfer.
I find it difficult to know ahead of time what impedance a given TC presents to a drive circuit.  If wire resistance were zero (ignored) and no arc present, then the primary impedance at a resonant frequencies is either zero or infinite.  Between resonant frequencies, impedance is purely reactive.  Arc resistance makes impedance non-zero and non-infinite at resonant frequencies.  Arc size affects impedance.  Impedance affects power transfer and therefore affects arc size.
Finding optimum is a matter of experiment.  You can get close by comparing other similar coil designs posted to this forum or elsewhere.
Offline Teslaventje
« Reply #4 on: June 13, 2024, 08:50:56 PM »
Understood.....See what I can do.....Thanks for the input
post Re: Problem with SSTC
Nunu00
Today at 10:17:36 PM
post Making a HV prove
Today at 09:01:08 PM
Today at 01:33:37 AM
Nunu00
Today at 12:17:32 AM
July 11, 2024, 07:38:26 PM
July 11, 2024, 06:30:00 PM
ColinHeath
July 11, 2024, 06:08:30 PM
July 11, 2024, 12:24:56 PM
July 11, 2024, 06:42:23 AM
Cameron Prince
July 11, 2024, 05:46:07 AM
Cameron Prince
July 11, 2024, 05:26:51 AM
July 11, 2024, 02:50:54 AM
Coupling
July 11, 2024, 12:59:55 AM
July 10, 2024, 07:10:34 PM
July 10, 2024, 06:52:42 PM
July 10, 2024, 06:28:19 PM
Alex_1996
July 10, 2024, 01:34:09 PM
post Re: Silicon(e) plasma
July 10, 2024, 12:09:06 AM
Nunu00
July 09, 2024, 11:52:00 PM
July 09, 2024, 07:37:22 PM
July 09, 2024, 07:30:05 PM
July 09, 2024, 03:30:49 AM
verliebt_in_neukölln17
July 09, 2024, 12:51:02 AM
July 08, 2024, 11:30:44 PM
post Re: Why so cheap?
July 08, 2024, 10:57:10 PM
July 08, 2024, 10:21:01 PM
post Why so cheap?
July 08, 2024, 09:55:24 PM
Cameron Prince
July 08, 2024, 09:18:21 PM
July 08, 2024, 05:17:49 PM
Cameron Prince
July 08, 2024, 04:49:20 PM
post Re: Tesla coil in FEMM
July 08, 2024, 04:28:43 AM
July 08, 2024, 04:06:53 AM
post Tesla coil in FEMM
July 08, 2024, 03:46:49 AM
July 08, 2024, 02:42:00 AM
July 08, 2024, 01:37:55 AM
Sebigamer
July 08, 2024, 12:53:08 AM
July 08, 2024, 12:49:48 AM
July 07, 2024, 11:15:35 PM
post Silicon(e) plasma
July 07, 2024, 11:04:43 PM
July 07, 2024, 09:39:07 PM
July 07, 2024, 05:32:56 PM
July 07, 2024, 02:52:19 PM
July 07, 2024, 02:50:04 PM
July 07, 2024, 02:20:11 PM
July 07, 2024, 10:02:22 AM
Sebigamer
July 07, 2024, 09:23:58 AM
July 07, 2024, 12:44:53 AM
July 07, 2024, 12:08:50 AM
July 06, 2024, 10:35:49 PM
July 06, 2024, 09:42:43 PM
July 06, 2024, 06:06:23 PM
July 06, 2024, 10:21:16 AM
July 06, 2024, 10:15:42 AM
July 06, 2024, 04:53:56 AM
July 06, 2024, 04:42:16 AM
July 06, 2024, 04:09:50 AM
July 06, 2024, 03:07:11 AM
July 06, 2024, 03:05:18 AM
July 06, 2024, 02:37:16 AM
July 06, 2024, 02:20:14 AM
July 06, 2024, 01:55:14 AM
July 05, 2024, 11:50:37 PM
July 05, 2024, 10:07:04 PM
gravitysrainbow
July 05, 2024, 07:13:25 PM
July 05, 2024, 06:17:13 PM
post Re: Phase lead inductors
July 04, 2024, 11:40:45 PM
post Re: Sling Psychrometer
July 04, 2024, 11:02:32 PM
post Phase lead inductors
July 04, 2024, 06:28:08 PM
July 04, 2024, 12:31:40 AM
Alex_1996
July 04, 2024, 12:07:21 AM
Alex_1996
July 04, 2024, 12:06:17 AM
July 03, 2024, 10:51:23 PM
July 03, 2024, 09:44:14 PM
July 03, 2024, 08:48:13 PM
July 03, 2024, 08:24:50 PM
Alex_1996
July 03, 2024, 08:12:55 PM
July 03, 2024, 07:29:53 PM
July 03, 2024, 07:21:38 PM
July 03, 2024, 05:05:39 PM
Alex_1996
July 03, 2024, 04:29:53 PM
July 03, 2024, 04:09:11 PM
Alex_1996
July 03, 2024, 02:47:18 PM
Alex_1996
July 03, 2024, 01:35:24 PM
July 03, 2024, 02:19:03 AM
July 03, 2024, 01:19:50 AM
July 02, 2024, 11:29:18 PM
July 02, 2024, 09:59:07 PM
July 02, 2024, 09:55:53 PM
July 02, 2024, 09:44:55 PM
July 02, 2024, 07:51:37 PM
July 02, 2024, 06:14:07 PM
July 02, 2024, 06:02:38 PM
July 02, 2024, 11:37:46 AM
July 02, 2024, 05:22:10 AM
July 02, 2024, 05:16:30 AM
drobotk
July 01, 2024, 11:50:12 PM
July 01, 2024, 08:48:53 PM
July 01, 2024, 08:40:59 AM
July 01, 2024, 08:09:42 AM
June 30, 2024, 06:49:45 AM
