Author Topic: Is a 60UF 800VDC Dawncap good for an induction heater?  (Read 795 times)
Offline yourboi
« on: June 09, 2024, 03:31:30 PM »
thank you to all for reading this post. Should I go for one of the 60UF 800VDC variants or is the capacitance too high and voltage too low? Also Is it worth it to buy a premade snubber circuit or should I build my own? Circuit will be a half bridge or full bridge everything's in the purchasing stage. thank you guys for reading my post.
I will likely buy a 0.44UF 6KV for tesla coiling in the future as I am already paying for shipping.
Extra: If anyone has spare IGBT'S or capacitors I will gladly buy them off you If I get a deal I am from the USA.
Offline Anders Mikkelsen
Re: Is a 60UF 800VDC Dawncap good for an induction heater?
« Reply #1 on: June 09, 2024, 05:44:29 PM »
Too low ripple current rating and too high capacitance for practical use. Practically you want 10 µF or less, at hundreds of amps, for practical induction heating.
I would look at something like these: https://www.ebay.com/itm/266845269192
Offline yourboi
« Reply #2 on: June 20, 2024, 01:37:41 AM »
I ended up purchasing these from the seller. How did you find such a good deal? I can't find any similar deals on large induction heater capacitor. I actually can't find many at all.
I've been searching for used IGBTs for months with no luck. However, recently, after I bought that capacitor, I was looking around and found many mislabeled eBay listings for used IGBT modules some priced around $7 each. So, I bought a few.
I purchased 3 SKM200GB125D 1200v 160 @80c Igbt modules as I saw a video of the youtuber Jmartis 2 running an impressive 80khz tesla coil off of the skm100gb125dn and comparing the specs to the skm200gb125d they seemed very similar in switching speeds since I am making an induction heater which I plan to keep around 20khz-40khz I assumed they were capable of the task. I also found the datasheet mentioned soft switching at a maximum of 100khz for soft switching induction heating applications which gave me the go ahead to purchase 3 of them for $30 which I think is a deal.
Their specs are as follows:
1200V
Collector current: 200A @ 25°C
Collector current: 160A @ 80°C
td(on): 75 ns (turn-on delay time)
tr: 36 ns (rise time)
td(off): 420 ns (turn-off delay time)
tf: 25 ns (fall time)
I believe they are a good selection for my price range and in general. I plan to use a phase locked loop so I am looking at soft switching speeds.  I also purchased a SKM200GB12F4.
I was also looking at the CM300DY-13T which is a 650V 300A Igbt but much slower. I am wondering if it would be useful In a soft switching application as it was also at quite a cheap price. Its specs are as follows.
td(on): 400 ns (turn-on delay time)
tr: 200 ns (rise time)
td(off): 400 ns (turn-off delay time)
tf: 400 ns (fall time)
« Reply #3 on: June 20, 2024, 04:02:38 PM »
Good call, these caps will serve you well. I've been using eBay for almost 20 years and have some saved searches, so I do come across deals regularly. The trick as you discovered is to find listings that are not listed under the most obvious name.
All of those IGBTs should be fine for induction heating at 20 - 40 kHz, with preference to the 125D and 12F4 due to their speed. Losses in IGBTs during soft switching are not easy to calculate from datasheet numbers, so you just have to try and see what works best, but it's less critical at these frequencies.
How are you planning to do the power control? Are you going for a transformer coupled series resonant tank?
Offline yourboi
« Reply #4 on: June 21, 2024, 11:34:45 PM »
I’ve never heard of a series resonant tank induction heater. I was under the impression that induction heaters were always parallel lc circuits. I have seen a video of a dual resonant Tesla coil being used as an induction heater with a metal can as a dummy load. I thought that that was only possible from the short pulse width of the Tesla coil interrupter limiting the current. I attached a picture of my schematic. It still is just a rough schematic. From my testing a large heatsink on the gate drive ic massively increases the current capabilities and short circuit survivability of the 27425. Usually it overheats very fast in CW and burns up. Not only does adding a large heatsink allow it to run CW but also allows it to survive short circuits on the inverter bridge itself when they happen. Since adding a heatsink my Tesla coils have never had to deal with a failed gate driver even with the igbt’s fail short and the driving circuitry is left running for a few minutes while troubleshooting the issue.  Back to the point I am not to familiar why most induction heater designs use a coupling transformer besides mains isolation. I could imagine if using a series LC circuit I may need a coupling transformer. Is it a critical component to include in my circuit?
I wrote this post earlier and wrote a lot about the missing components in the schematic then recently updated my schematic so its kind of a jumbled mess. I'm still posting it anyways how it is.
« Reply #5 on: June 22, 2024, 03:11:12 AM »
Looks like you are using LTSpice for drawing schematics.  Great start towards simulation.  Simulation will allow exploring topologies and seeing issues with some.
To start, simulate just the work coil and resonant parts (L4, cap above L4, C3, and C4).  Drive this network with a pulsed voltage source, simplest replacement for M1/M2 half-bridge.
Have fun learning!  Experimenting with simulation is much faster and less expensive than experimenting with actual electronics.  Then build something that works in simulation.
« Reply #6 on: June 23, 2024, 08:14:17 PM »
You can't use a voltage source inverter with a parallel resonant tank circuit. The inverter provides a square wave voltage rich in harmonics, while the parallel tank presents a very low impedance to all the harmonics, drawing large current peaks at each switching event. Another way to view it is that the switching devices would need to charge and discharge the tank cap to the full bus voltage on every switching cycle, incurring tens of kilowatts of losses.
You have a few options
You can make the tank series resonant, in this case it will present a low impedance at the fundamental frequency and a high impedance to the harmonics, which is what you want. Since the tank presents a very low impedance to the inverter, sqrt(L/C)/Q (typically 10 - 100 mohm), you need an impedance matching transformer to drive it with high voltage IGBTs. This would typically be in the range of 5:1 to 25:1, often with a single turn secondary.
Especially for low impedance tank circuits (Lwork less than 500 nH or so), LCLR can be a good option. This uses an inductor between the bridge and parallel tank circuit to make it appear like a series resonant tank to the inverter. This is my preferred option, as it allows the main work coil current to only circulate between the cap and coil without needing a transformer in line. This makes for more compact workheads and allows very low inductance work coils. Unlike the series resonant tank, LCLR matching will not present unity power factor to the bridge across a wide range of tank Q factors, so the inverter will have to deliver more reactive current (and higher turn-off current) if you plan to work with a wide range of loads. This topology is better suited for use with SiC MOSFETs than IGBTs, but can be made to work well with either.
The last practical option is to do a current source (or actually inductance-source) inverter to allow direct drive of a parallel resonant tank. This is essentially like the classic "ZVS/Mazzilli" driver (which is in reality a Baxandall oscillator), but it needs some extra refinements in order to work well at high power. Blocking diodes in series with your switches, some conduction overlap (analogous to dead time in a voltage source inverter), and a bit of phase lead (switching the devices before the tank voltage zero crossing) does wonders.
The last option is to not use a resonant tank, which is still better than driving a parallel resonant tank with a voltage source inverter. In this case, your switching devices will need to provide the entire reactive current of the tank, which is usually between 5 and 100 times the real power. This factor is the tank circuit Q factor, and it's determined by how well your load is matched to the coil size, the conductance and magnetic permeability. For a steel pipe inside a closely fitting coil, this can be as low as 3, but if trying to heat copper or aluminium then you're looking at more like 50 - 100. So if you want to process 10 kW for example, you need 500 - 1000 kVAR circulating in your tank circuit. If you have a 1 ohm tank (=sqrt(L/C), this would be between 700 A 700 V and 1000 A 1000 V.
post Re: Problem with SSTC
Nunu00
July 12, 2024, 10:17:36 PM
post Making a HV prove
July 12, 2024, 09:01:08 PM
July 12, 2024, 01:33:37 AM
Nunu00
July 12, 2024, 12:17:32 AM
July 11, 2024, 07:38:26 PM
July 11, 2024, 06:30:00 PM
ColinHeath
July 11, 2024, 06:08:30 PM
July 11, 2024, 12:24:56 PM
July 11, 2024, 06:42:23 AM
Cameron Prince
July 11, 2024, 05:46:07 AM
Cameron Prince
July 11, 2024, 05:26:51 AM
July 11, 2024, 02:50:54 AM
Coupling
July 11, 2024, 12:59:55 AM
July 10, 2024, 07:10:34 PM
July 10, 2024, 06:52:42 PM
July 10, 2024, 06:28:19 PM
Alex_1996
July 10, 2024, 01:34:09 PM
post Re: Silicon(e) plasma
July 10, 2024, 12:09:06 AM
Nunu00
July 09, 2024, 11:52:00 PM
July 09, 2024, 07:37:22 PM
MechatEng2023
July 09, 2024, 07:30:05 PM
July 09, 2024, 03:30:49 AM
verliebt_in_neukölln17
July 09, 2024, 12:51:02 AM
July 08, 2024, 11:30:44 PM
post Re: Why so cheap?
July 08, 2024, 10:57:10 PM
July 08, 2024, 10:21:01 PM
post Why so cheap?
July 08, 2024, 09:55:24 PM
Cameron Prince
July 08, 2024, 09:18:21 PM
July 08, 2024, 05:17:49 PM
Cameron Prince
July 08, 2024, 04:49:20 PM
post Re: Tesla coil in FEMM
July 08, 2024, 04:28:43 AM
July 08, 2024, 04:06:53 AM
post Tesla coil in FEMM
July 08, 2024, 03:46:49 AM
July 08, 2024, 02:42:00 AM
July 08, 2024, 01:37:55 AM
Sebigamer
July 08, 2024, 12:53:08 AM
July 08, 2024, 12:49:48 AM
July 07, 2024, 11:15:35 PM
post Silicon(e) plasma
MechatEng2023
July 07, 2024, 11:04:43 PM
July 07, 2024, 09:39:07 PM
July 07, 2024, 05:32:56 PM
July 07, 2024, 02:52:19 PM
July 07, 2024, 02:50:04 PM
July 07, 2024, 02:20:11 PM
July 07, 2024, 10:02:22 AM
Sebigamer
July 07, 2024, 09:23:58 AM
July 07, 2024, 12:44:53 AM
July 07, 2024, 12:08:50 AM
July 06, 2024, 10:35:49 PM
July 06, 2024, 09:42:43 PM
July 06, 2024, 06:06:23 PM
July 06, 2024, 10:21:16 AM
July 06, 2024, 10:15:42 AM
July 06, 2024, 04:53:56 AM
July 06, 2024, 04:42:16 AM
July 06, 2024, 04:09:50 AM
July 06, 2024, 03:07:11 AM
July 06, 2024, 03:05:18 AM
July 06, 2024, 02:37:16 AM
July 06, 2024, 02:20:14 AM
July 06, 2024, 01:55:14 AM
July 05, 2024, 11:50:37 PM
July 05, 2024, 10:07:04 PM
gravitysrainbow
July 05, 2024, 07:13:25 PM
July 05, 2024, 06:17:13 PM
post Re: Phase lead inductors
July 04, 2024, 11:40:45 PM
post Re: Sling Psychrometer
July 04, 2024, 11:02:32 PM
post Phase lead inductors
July 04, 2024, 06:28:08 PM
July 04, 2024, 12:31:40 AM
Alex_1996
July 04, 2024, 12:07:21 AM
Alex_1996
July 04, 2024, 12:06:17 AM
July 03, 2024, 10:51:23 PM
July 03, 2024, 09:44:14 PM
July 03, 2024, 08:48:13 PM
July 03, 2024, 08:24:50 PM
Alex_1996
July 03, 2024, 08:12:55 PM
July 03, 2024, 07:29:53 PM
July 03, 2024, 07:21:38 PM
July 03, 2024, 05:05:39 PM
Alex_1996
July 03, 2024, 04:29:53 PM
July 03, 2024, 04:09:11 PM
Alex_1996
July 03, 2024, 02:47:18 PM
Alex_1996
July 03, 2024, 01:35:24 PM
July 03, 2024, 02:19:03 AM
July 03, 2024, 01:19:50 AM
July 02, 2024, 11:29:18 PM
July 02, 2024, 09:59:07 PM
July 02, 2024, 09:55:53 PM
July 02, 2024, 09:44:55 PM
July 02, 2024, 07:51:37 PM
July 02, 2024, 06:14:07 PM
July 02, 2024, 06:02:38 PM
July 02, 2024, 11:37:46 AM
July 02, 2024, 05:22:10 AM
July 02, 2024, 05:16:30 AM
drobotk
July 01, 2024, 11:50:12 PM
July 01, 2024, 08:48:53 PM
July 01, 2024, 08:40:59 AM
July 01, 2024, 08:09:42 AM
June 30, 2024, 06:49:45 AM
