Author Topic: 440kV Marx Generator with 120Hz repetition rate  (Read 225 times)
« on: November 14, 2023, 06:02:58 AM »
Retrospective post of my 440kV Marx generator built in 2017.
    12 stages
    2.7nF per stage, made from 8 series-connected 22nF 6kV WIMA FKP1 caps.
    2 * 68meg 10kV resistors across each 22nF cap
    170mH inductors instead of resistors.  Each made from series connection of 119 x 1mH inductors.  Magnetic proximity of cores increases total inductance from 119mH to 170mH.
    Spark gaps made from 3/4" copper pipe end caps.  Ends made spherical by cold forming, pounding bearing ball inside copper end cap into hollow recess carved into wood outside end cap, repeated for each cap.
    Gaps adjusted for 42kV breakdown.  Line-of-sight between gaps allows UV light to help synchronize triggering.
    Air flow directed at each gap.  Could achieve only ~40Hz repetition rate without forced air.
    Charged by +-21kV supply.  4-stage voltage multiplier (+- 2 stages) from +-11kV 30kHz ferrite transformer output.
    Resonant H-bridge drive to transformer primary.
    Charging supply shuts off for 1-2ms after each firing.  Allows time for arcs to extinguish.  This off time varies (increases) to control repeat rate.  No explicit triggering of spark gaps.  Charges to ~42kV breakdown voltage in ~7ms.  Each firing occurs ~7ms after charging starts.
    About 6kW average power.
Schematic:
Inductor/capacitor side:
Spark gap side:
Video of initial build with max repetition rate of 100Hz.  Updated PFC unit with higher power allowed 120Hz for 2018.
Initial version used hand-wound inductors, made like tapped TC secondaries on pipes up each side.  Too much corona and arcs between windings (racing sparks).  Second version used commercial automotive spark coils (secondaries only) rated for 50kV.  Fast rise times (much faster than normal engine spark generation) made internal voltage distribution uneven.  Worked for a few short demos (with replacing a few spark coils after every few minutes of operation).  Final version is as shown, using 24 170mH inductors each containing 119 small inductors.  Physical layout makes capacitive voltage division roughly even across each inductor.  No more inductor failures with this version.
« Last Edit: November 14, 2023, 05:42:17 PM by davekni »
Offline huntergroundmind
    • Huntergroundmind
Re: 440kV Marx Generator with 120Hz repetition rate
« Reply #1 on: November 16, 2023, 05:02:03 PM »
Great, and interesting build! I really like the idea with making air low inductance capacitor :)
post GDT magnetizing current
Today at 06:58:25 AM
Keybored
Today at 01:51:32 AM
Lucasww
bobfrancis1980
bobfrancis1980
Keybored
bobfrancis1980
post Re: 2 Layer primary coil
post 2 Layer primary coil
tazea
Hysteresis
nzoomed
post Segmented Primary Coil
tbbrune
post Chain reactions
post P5104 40kV 20MHz probes
Benjamin_collier
tazea
post Small Coil Build
post Re: GU-81 vs. GU-81M
thehay95
nzoomed
post Re: Benjamin's DRSSTC3
post Benjamin's DRSSTC3
bobfrancis1980
coilerer
coilerer
bobfrancis1980
November 24, 2023, 06:40:13 AM
tarak
November 24, 2023, 04:04:48 AM
post Re: First drsstc issues
November 23, 2023, 09:58:21 PM
post Re: My 9MHz hfsstc
cuteKaisa
November 23, 2023, 02:17:52 PM
post Re: My plasma ring
cuteKaisa
November 23, 2023, 11:11:59 AM
November 23, 2023, 07:25:26 AM
Hari33
November 23, 2023, 05:19:57 AM
November 23, 2023, 05:18:41 AM
November 23, 2023, 05:06:51 AM
November 23, 2023, 04:51:16 AM
November 23, 2023, 04:31:56 AM
post Single Photon Dual Slit Demonstartion
November 22, 2023, 09:15:36 PM
Hari33
November 22, 2023, 08:36:14 AM
November 22, 2023, 07:59:21 AM
