Author Topic: First drsstc issues  (Read 2737 times)
Offline AstRii
Re: First drsstc issues
« Reply #20 on: November 17, 2023, 08:19:20 PM »
But what if the the system is tuned and signal generator is used to produce sine waves having frequency of the primary?
That's never going to happen, as the primary frequency keeps ever so slightly changing with environment and load.
Bc. Marek Novotny
www.uhvlab.org
« Reply #21 on: November 17, 2023, 09:40:13 PM »
There is gdt output during the startup pulses, but its just that the bridge is not working at those pulses.
Sorry, I misread, thinking GDT rather than CT.  No CT output is what resistor is intended to fix.  Perhaps one or more of the IGBTs his high leakage current, more than 100k can overcome.  Measure bridge output voltage with a DMM while idle.  Ideally should be 0V.
If IGBT leakage current is the issue and more than 100k can fix, another option to fix:  Swap GDT primary leads.  Then opposite IGBTs will turn on during startup pulse, now the non-leaky IGBTs.  That should make a CT response.  If polarity is wrong, reverse CT leads to fix polarity.  (This fix presumes the same IGBT continues to have high leakage current, but that may be likely.)
« Last Edit: November 18, 2023, 06:46:41 AM by davekni »
Offline Hari33
« Reply #22 on: November 20, 2023, 07:30:40 PM »
Hi, thanks for all the guidance.
I was able to get feedback today!!. The issue solved when i used a 1:50 feedback ct instead of 1:500 ct.
I am planning to keep ocd at 300amps so the feedback current is going to be around 6 amps, which if i am right is way above what 1.3b driver can handle.
Is there any way to tackle this?, or is it a feedback ct issue at all?is there anything else i should be concerned about?.
« Reply #23 on: November 20, 2023, 09:18:25 PM »
This happens :)
« Reply #24 on: November 21, 2023, 04:41:17 AM »
You might get away with 50:1 if duty cycle is low enough and R4 is changed from 10 ohms to 0.5 ohm power resistor.
I'd recommend instead figuring out why 500:1 is failing.
Are you bypassing OCD now?   If so, how?  Is your OCD CT in the primary circuit with output unconnected?  That could be the cause of your startup issues.  Unconnected CT secondaries need to be shorted.
Offline Hari33
« Reply #25 on: November 21, 2023, 09:31:51 PM »
This happens :)
I wasnt aware about how running drsstc using signal generator leads to hard switching😅.
Its clear now🙌.
Offline Hari33
« Reply #26 on: November 21, 2023, 09:35:21 PM »
All the unused ct's were shorted👍.
I tried using a 1:100 ct, but the start up oscillations are only having an amplitude of 1 volts max, and its not increasing even with a bus voltage of 100V.
What all could be the reasons for such a weak feedback signal?
Offline Hari33
« Reply #27 on: November 22, 2023, 07:28:05 AM »
I tried scoping the igbt gates today.
The gate signals at the time of interrupter pulses are very low, in the range of millivolts.
When i gave feedback input from a signal generator without any voltage on bus,the gate signals are good.
Is this the reason for low feedback signal?
I am not sure about the gdt core material.
Dimensions are
34mm outer dia
22mm inner dia
12mm width
7 turns.
Gate resistance is 5 ohms.
Attaching the pics of waveforms with this
« Reply #28 on: November 22, 2023, 07:59:21 AM »
Dimensions are
34mm outer dia
22mm inner dia
12mm width
7 turns.
Feedback signal is needed for it to run. IC2C and IC2D are AND-gates which combines feedback and interrupter signal, to the gate driver ICs. This AND-gate is what insures ZCS and prevents hard switching as when you ran it with signal generator, this feedback needs to come from the primary LC circuit.
https://kaizerpowerelectronics.dk/tesla-coils/universal-driver-1-3b/
Offline Hari33
« Reply #29 on: November 22, 2023, 08:36:14 AM »
Okay,got it👍.
Shouldnt the gate startup pulses at igbt gates have the same amplitude of gate drive voltage?
In my case those pulses are very weak.
Is this normal?
Used 18v zener diodes for gate protection.
« Last Edit: November 22, 2023, 08:46:42 AM by Hari33 »
« Reply #30 on: November 23, 2023, 04:51:16 AM »
Is this normal?
Yes, start amplitude should be same as run amplitude, one Vge at +18V and other at -18V.  Low amplitude is not normal.
My guess is that your driver chip is the wrong part, not inverting.  Should be UCC27423, not UCC27424.
Either that or 74HC08 is inverting (74HC00), but I think that would cause other issues too.
Measure voltage of driver chip outputs when idle (not enabled).  They should be +9V.
Offline Hari33
« Reply #31 on: November 23, 2023, 05:19:57 AM »
Is this normal?
Hi, i am using TC4427 instead of UCC27423.
Mosfets are irf540 and 9540.
When i connect sg to the feedback, everything works well.
Then the outputs of driver IC is inverting too (i scoped them).
It looks like the bridge is not working well for the startup pulse from interrupter.The whole thing is working well when there is a x frequency pulses at the gates(when sg is connected to feedback input).
« Last Edit: November 23, 2023, 05:27:10 AM by Hari33 »
« Reply #32 on: November 23, 2023, 09:58:21 PM »
Scope through driver as I'd suggested in reply #16.  Given your scope capture of Vge startup pulse missing, the issue is in the driver.  (Hint:  TC4427 data sheet says it is non-inverting.  I think you need to scope carefully input and output of every chip and FETs on driver path from enable to GDT primary leads.)
ae7b
Today at 06:53:52 AM
Keybored
Today at 12:25:37 AM
Lucasww
bobfrancis1980
Lucasww
bobfrancis1980
post GDT magnetizing current
Keybored
Lucasww
bobfrancis1980
bobfrancis1980
Keybored
bobfrancis1980
post Re: 2 Layer primary coil
post 2 Layer primary coil
tazea
Hysteresis
nzoomed
post Segmented Primary Coil
tbbrune
post Chain reactions
post P5104 40kV 20MHz probes
Benjamin_collier
tazea
post Small Coil Build
post Re: GU-81 vs. GU-81M
thehay95
nzoomed
post Re: Benjamin's DRSSTC3
post Benjamin's DRSSTC3
MechatEng2023
bobfrancis1980
coilerer
coilerer
bobfrancis1980
