Author Topic: Mixing PID loops  (Read 374 times)
Offline Patrick
  • Mechatronics Technician, A.S.
Mixing PID loops
« on: January 24, 2022, 07:28:01 AM »
Id like to control pitch and yaw using PID loops but I dont know how to "blend" them for common control surfaces. The plane ill be using has two "tailerons" both responsible for pitch and yaw seen  in the following attachment.
Can it be as simple as running two independent PID loops, then linearizing the two results in micro controller memory and output to each motor by using percentages of physical travel?
If its too bright just squint more.
Re: Mixing PID loops
« Reply #1 on: January 24, 2022, 12:00:50 PM »
I guess you could just add the two output results together, but you'll have to make sure the system is stable and the two loops don't throw each other off.
Calculating that hard enough for me when using simple motors with intertia and a single PID, having two PIDs and control surfaces will be even harder I assume.
« Reply #2 on: January 25, 2022, 09:50:41 PM »
I agree with TMaxElectronics: just add the resulting actuator signals.  A properly tuned PID should be robust enough to deal with any funnies.  I would be inclined to make one of the PID loops slower than the other though - I have no math to back this up, just a gut feeling that its going to be more stable that way.
Offline Patrick
« Reply #3 on: January 26, 2022, 04:14:02 AM »
Ok Im thinking of adding and subtracting for direction then multiplying by less than 1.0 for scaling the actual throw. One website for 2.4.8 Ardupilot seems to suggest a v-tail command that does this by means means of :
( https://ardupilot.org/plane/docs/guide-vtail-plane.html )
"Mixing Gain:
The MIXING_GAIN parameter is critical for vtail aircraft. It is the gain used in mixing between yaw and pitch output and the vtail movement. For example, if MIXING_GAIN is 0.5, then the following outputs are used:
    LEFT_VTAIL = (yaw+pitch)*0.5
    RIGHT_VTAIL = (-yaw+pitch)*0.5
Adjusting the MIXING_GAIN controls the percentabe of throws from pitch vs yaw."
And pics of the real one and myself, and yes it's huge !
« Last Edit: January 26, 2022, 04:16:08 AM by Patrick »
Range4Harry
May 16, 2022, 11:25:14 PM
Robert3z
May 16, 2022, 02:21:11 PM
CwhyteKGMS
May 16, 2022, 07:29:15 AM
May 16, 2022, 04:53:18 AM
May 16, 2022, 04:36:44 AM
CwhyteKGMS
May 16, 2022, 03:53:48 AM
Robert3z
May 16, 2022, 02:20:58 AM
post Re: Problem with SSTC
May 15, 2022, 11:59:37 PM
Nunu00
May 15, 2022, 11:08:49 PM
May 15, 2022, 09:43:07 PM
post Re: Kaizer DRSSTC 3
May 15, 2022, 08:22:11 PM
Nunu00
May 15, 2022, 08:03:13 PM
May 15, 2022, 07:49:51 PM
Nunu00
May 15, 2022, 06:58:45 PM
May 15, 2022, 06:47:53 PM
May 15, 2022, 04:13:02 PM
Nunu00
May 15, 2022, 02:38:18 PM
May 15, 2022, 03:53:35 AM
post Bipolar CW
May 15, 2022, 03:46:25 AM
May 15, 2022, 03:40:42 AM
[Static Electricity]
May 15, 2022, 02:06:53 AM
May 14, 2022, 10:26:32 PM
Nunu00
May 14, 2022, 09:52:06 PM
May 14, 2022, 09:25:23 PM
Nunu00
May 14, 2022, 08:14:38 PM
May 14, 2022, 08:02:22 PM
Coileone
May 14, 2022, 06:15:59 PM
Coileone
May 14, 2022, 06:12:32 PM
post Problem with SSTC
Nunu00
May 14, 2022, 05:18:16 PM
post Re: Wago "Lever Nuts"?
May 14, 2022, 03:24:48 PM
May 13, 2022, 11:06:50 PM
May 13, 2022, 09:28:35 PM
May 13, 2022, 09:24:22 PM
Coileone
May 13, 2022, 02:13:19 PM
Coileone
May 13, 2022, 02:09:23 PM
May 13, 2022, 06:16:20 AM
May 13, 2022, 01:57:25 AM
Coileone
May 12, 2022, 10:05:32 PM
May 12, 2022, 09:41:04 PM
post Re: Thermometers
May 12, 2022, 09:33:38 PM
May 12, 2022, 09:27:40 PM
Robert3z
May 12, 2022, 02:13:03 PM
May 12, 2022, 06:39:55 AM
May 12, 2022, 06:27:47 AM
May 12, 2022, 06:22:48 AM
post Wago "Lever Nuts"?
May 12, 2022, 04:32:19 AM
post Re: Transistor choice
May 12, 2022, 03:32:22 AM
May 12, 2022, 12:00:11 AM
May 11, 2022, 09:53:15 PM
post Kaizer DRSSTC 3
May 11, 2022, 09:40:00 PM
CarldeLevis
May 11, 2022, 09:39:21 PM
post Thermometers
May 11, 2022, 09:36:59 PM
Nicolas
May 11, 2022, 09:29:45 PM
post Re: Litz Wire?
May 11, 2022, 08:45:57 PM
May 11, 2022, 08:43:38 PM
CarldeLevis
May 11, 2022, 05:44:40 PM
May 11, 2022, 04:17:34 PM
Robert3z
May 11, 2022, 03:10:27 PM
May 11, 2022, 01:46:57 PM
Robert3z
May 11, 2022, 12:37:19 PM
May 11, 2022, 11:33:30 AM
May 11, 2022, 11:00:59 AM
May 11, 2022, 06:30:45 AM
May 11, 2022, 06:11:08 AM
post Re: Litz Wire?
May 11, 2022, 04:00:41 AM
Robert3z
May 11, 2022, 02:06:34 AM
May 10, 2022, 07:52:45 PM
Nicolas
May 10, 2022, 10:04:27 AM
May 10, 2022, 09:31:39 AM
post Re: Litz Wire?
May 10, 2022, 09:29:19 AM
May 10, 2022, 09:23:38 AM
May 10, 2022, 07:24:33 AM
post Transistor choice
May 10, 2022, 03:33:10 AM
post Litz Wire?
May 10, 2022, 03:16:29 AM
May 09, 2022, 07:41:51 AM
May 09, 2022, 05:39:51 AM
May 09, 2022, 12:44:13 AM
Nicolas
May 09, 2022, 12:24:37 AM
Nicolas
May 09, 2022, 12:21:40 AM
May 09, 2022, 12:13:01 AM
post Re: QCW questions
May 08, 2022, 06:43:31 PM
May 08, 2022, 07:43:13 AM
May 07, 2022, 07:59:36 PM
Robert3z
May 07, 2022, 06:41:41 PM
post Re: Capacitor Esoterica
May 07, 2022, 05:57:22 PM
May 07, 2022, 03:43:57 PM
May 07, 2022, 03:21:16 PM
May 07, 2022, 06:52:29 AM
May 07, 2022, 04:57:41 AM
May 06, 2022, 08:54:52 AM
May 06, 2022, 02:54:44 AM
Dhaygoh
May 05, 2022, 05:26:27 PM
Dhaygoh
May 05, 2022, 05:14:32 PM
May 05, 2022, 06:29:00 AM
May 05, 2022, 05:56:01 AM
May 05, 2022, 05:11:45 AM
May 05, 2022, 04:37:42 AM
May 05, 2022, 04:19:47 AM
May 04, 2022, 11:22:09 PM
May 04, 2022, 11:04:19 PM
