Author Topic: Performance issues regarding phase angle in SSTCs  (Read 260 times)
Offline Max Seiringer
  • electronics enthusiast
« on: January 08, 2022, 03:21:31 PM »
Hi folks!
I'm buildung a small solid state teslacoil using a 74HC14 feedbacksystem with a current transformer. First off some detail:
The circuit diagram is pretty similar to the Kaizer SSTC II. I am driving my coil with a IRFP460 fullbridge at 30VDC at the moment. Sadly, there is currently no safe way to conduct tests at higher voltages, the variac is out of order.
I use a sheet of aluminum foil as an earth plane, since i live in a small apartment and no proper ground is available.
The cores used for the GDT and the CT are 3E25 and N30. The primary coil features 8 windings and the secondary coil just above 1000 turns. The resonant frequency is about 270kHz.
The Interrupter is based on an Arduino Micro and has audio capabilities. It is connected to the driver logic via a fiber obtic cable.
The setup works to some extend. The arcs come in at about 1cm at 30VDC while drawing roughly 3A in CW mode. Not too great results considering the coil is driven by a fullbridge.
I measured across the primary with one probe and used a second probe as an antenna to pick up the signal from the secondary.
It seems that the voltage across the primary coil leads the voltage at the secondary. This results in a 60° phase angle between the two signals.
What phase angle would be ideal for a solid state teslacoil? Could the performance issues be fixed by adding phase compensation to the circuit or is there another culprit?
Kind regards
Re: Performance issues regarding phase angle in SSTCs
« Reply #1 on: January 09, 2022, 01:20:40 AM »
Nicely paired primary lead wires.  That keeps effective coupling high by avoiding parasitic inductance.
In general, your build looks fine.  My guess is that you just need more power (higher input bus voltage).  Ideal phasing between primary and secondary voltage is 90 degrees.  60 is close enough.  Adjusting to 90 would increase input current a bit (~15%) and therefore increase power a bit at your fixed 30Vdc input.
To avoid possible issues when increasing power, I suggest soldering GDT output leads closer to the FET packages, especially the FET source leads.  Otherwise wiring inductance is shared between high current path and gate drive, leading to unwanted voltage distortion of gate drive.
post Re: Muon Decay
Today at 10:11:21 AM
post Re: Muon Decay
January 19, 2022, 08:22:49 PM
post Re: Muon Decay
January 19, 2022, 06:49:36 PM
hardboiled99
January 19, 2022, 07:37:27 AM
January 18, 2022, 10:34:48 PM
post Re: Muon Decay
January 18, 2022, 08:46:53 PM
post Re: Muon Decay
January 18, 2022, 08:08:53 PM
post Re: GDT Testing
January 18, 2022, 07:15:22 PM
post Muon Decay
January 18, 2022, 06:49:48 PM
304er
January 18, 2022, 08:47:53 AM
January 17, 2022, 09:13:32 PM
January 17, 2022, 09:05:56 PM
January 17, 2022, 07:45:48 PM
post Re: General Questions
January 17, 2022, 07:41:34 PM
January 17, 2022, 07:38:25 PM
January 17, 2022, 07:31:03 PM
January 17, 2022, 07:28:02 PM
January 16, 2022, 09:00:02 PM
January 16, 2022, 07:35:26 PM
Bambinz
January 16, 2022, 12:21:40 PM
January 15, 2022, 07:10:03 PM
Bambinz
January 15, 2022, 06:31:33 PM
January 14, 2022, 08:47:43 PM
January 14, 2022, 08:39:07 PM
January 14, 2022, 08:14:17 PM
January 14, 2022, 08:12:13 PM
January 14, 2022, 05:51:52 PM
304er
January 14, 2022, 08:51:57 AM
Bambinz
January 13, 2022, 08:20:02 PM
January 13, 2022, 05:27:40 AM
January 13, 2022, 03:10:32 AM
304er
January 12, 2022, 06:18:15 PM
January 12, 2022, 05:45:26 PM
January 12, 2022, 03:29:04 PM
January 12, 2022, 01:30:38 PM
304er
January 12, 2022, 09:09:13 AM
January 11, 2022, 08:05:27 PM
January 11, 2022, 07:42:12 PM
January 11, 2022, 07:33:15 PM
January 11, 2022, 06:19:49 PM
304er
January 11, 2022, 05:19:46 PM
January 11, 2022, 04:31:28 PM
January 11, 2022, 03:21:37 PM
January 11, 2022, 06:50:49 AM
January 11, 2022, 06:34:20 AM
January 11, 2022, 06:24:13 AM
January 11, 2022, 06:15:08 AM
January 11, 2022, 05:25:31 AM
January 11, 2022, 12:07:22 AM
January 10, 2022, 10:56:48 PM
post Re: Hi! 811 A tesa coil
January 10, 2022, 09:38:53 PM
January 10, 2022, 07:50:13 PM
January 10, 2022, 07:19:17 PM
January 10, 2022, 03:13:08 PM
January 10, 2022, 04:21:46 AM
304er
January 10, 2022, 03:59:09 AM
January 10, 2022, 03:54:59 AM
January 09, 2022, 11:45:09 PM
jpvvv123
January 09, 2022, 11:04:25 PM
January 09, 2022, 04:22:11 PM
January 09, 2022, 05:52:11 AM
January 09, 2022, 05:10:50 AM
post GDT Testing
January 09, 2022, 12:38:28 AM
January 08, 2022, 06:36:28 PM
Max Seiringer
304er
January 08, 2022, 09:05:41 AM
jpvvv123
January 07, 2022, 10:20:10 PM
304er
January 07, 2022, 05:56:28 PM
January 07, 2022, 05:15:38 AM
post Re: DRSSTC tuning
January 07, 2022, 05:01:21 AM
January 07, 2022, 04:59:59 AM
post Tophat QCW 1
January 07, 2022, 02:27:35 AM
January 07, 2022, 02:19:40 AM
January 06, 2022, 09:33:06 PM
January 06, 2022, 06:09:39 PM
kubajed
January 06, 2022, 04:48:22 PM
SK1701
January 06, 2022, 03:05:55 PM
January 06, 2022, 08:17:09 AM
post General Questions
January 06, 2022, 04:42:25 AM
jpvvv123
January 06, 2022, 03:40:43 AM
January 06, 2022, 12:18:38 AM
SK1701
January 05, 2022, 08:37:13 PM
post Re: Bus Supply Questions
January 04, 2022, 05:58:10 PM
January 04, 2022, 01:37:02 PM
post Bus Supply Questions
January 04, 2022, 04:12:34 AM
post Re: ZVS Driven Teslacoil
January 04, 2022, 01:14:26 AM
January 03, 2022, 05:38:08 PM
January 02, 2022, 01:17:37 AM
paulj
January 01, 2022, 06:53:46 PM
MHV
January 01, 2022, 06:39:05 PM
January 01, 2022, 02:05:43 PM
post Re: Full Bridge SSTC
January 01, 2022, 11:54:25 AM
paulj
December 31, 2021, 07:19:02 PM
Zbig
