Author Topic: First SSTC based on profdc9 PCB Pack  (Read 558 times)
Offline SK1701
« on: January 05, 2022, 08:37:13 PM »
Hey guys.
After years of wanting to build an SSTC, I've started work on my first build. I am using the schematics kindly provided by profdc9 (https://github.com/profdc9/DRSSTC-PCB-Pack) for the driver and full bridge (with FGH60N60SMD). I had the PCBs fabricated at JLCPCB and I have started assembling them now. I thought I would make this thread to ask questions as well as document my progress. I had a couple questions to start off with:
  • This driver doesn't seem to have any sort of interrupter built in. Does this mean the coil will be operating in CW mode the whole time and so won't heat/ power be a concern?
  • I typically see ~30 AWG wire used for the secondary. The most readily available source here is 1/2 lb spools of 29 AWG. Would this still work, i was planning a secondary diameter of ~4 inche PVC pipe?
  • I am using the following bus capacitor - https://lcsc.com/product-detail/Aluminum-Electrolytic-Capacitors-Can-Screw-Terminals_Zeasset-TAG102M51080LVA_C432125.html with aa 100k 20 W bleeder resistor. How much of a concern is inrush current, and could you recommend appropriate NTC thermistors for current limiting? Would using a variac remove the need for inrush limiting?
Cheers!
Offline alan sailer
Re: First SSTC based on profdc9 PCB Pack
« Reply #1 on: January 06, 2022, 12:18:38 AM »
SK,
The profdc9 github package also has two boards for two types of interrupter normal and line interrupter. It couples to the UD board using optical fiber.
JavaTC will give the total wire length your proposed secondary will need. If the 1/2 lb spool has that amount of wire you are good. The wire length depends on
both the diameter and the length of the secondary.
The inrush current is a concern. I am not directly familiar with the NTC as an inrush current limiter. A Variac (and the discipline to always turn the Variac to zero after each run!)
will eliminate the need for inrush limiting. The capacitors will charge much faster than any rotation of the variac dial.
Cheers.
Offline SK1701
« Reply #2 on: January 06, 2022, 03:05:55 PM »
Thanks Alan!
I assumed his interrupter designs were for the UD board. This driver isn't the UD (which as I understood is for DRSSTCs). It is the regular SSTC driver posted here - https://github.com/profdc9/DRSSTC-PCB-Pack/tree/master/half-bridge-sstc There is no fiber optic input for an interrupter and the enable pins of the gate driver chips are left floating
Offline alan sailer
« Reply #3 on: January 06, 2022, 06:09:39 PM »
Sorry about overlooking the SSTC/DRSSTC distinction.
I have not built an SSTC like the design shown so I can't help. Hopefully a better experienced builder will help.
Cheers.
« Reply #4 on: January 07, 2022, 05:15:38 AM »
The schematic you posted does include an optical isolator, disabling operation when the isolator LED is energized.  You could use that for interruption.  I don't see any other interrupter functionality.  Continuous operation can be fine.  That is the way my SSTC runs.  Behavior is somewhat different relative to interrupted operation.
https://highvoltageforum.net/index.php?topic=1021.msg7119#msg7119
Either works.  Two NTC specification parameters are most important:  First is energy capability.  NTC must be rated to handle the energy stored in your bulk capacitor.  Look for units of Joules.  Second is continuous current (RMS amps).  Necessary rating depends on the power your coil will draw during operation.  Somewhat less important specification is cold (nominal) resistance.  That determines what the initial inrush current will be.  Building power circuits are designed to handle inrush of incandescent light bulbs and motors, often 10x rated continuous current.  Finally, most NTC inrush limiting designs use a relay to bypass (short across) the NTC a few seconds after power-up.  For home projects I often skip this, but NTC reliability isn't great when used continuously near rated current.
post Re: Muon Decay
Today at 10:11:21 AM
post Re: Muon Decay
January 19, 2022, 08:22:49 PM
post Re: Muon Decay
January 19, 2022, 06:49:36 PM
hardboiled99
January 19, 2022, 07:37:27 AM
January 18, 2022, 10:34:48 PM
post Re: Muon Decay
January 18, 2022, 08:46:53 PM
post Re: Muon Decay
January 18, 2022, 08:08:53 PM
post Re: GDT Testing
January 18, 2022, 07:15:22 PM
post Muon Decay
January 18, 2022, 06:49:48 PM
304er
January 18, 2022, 08:47:53 AM
January 17, 2022, 09:13:32 PM
January 17, 2022, 09:05:56 PM
January 17, 2022, 07:45:48 PM
post Re: General Questions
January 17, 2022, 07:41:34 PM
January 17, 2022, 07:38:25 PM
January 17, 2022, 07:31:03 PM
January 17, 2022, 07:28:02 PM
January 16, 2022, 09:00:02 PM
January 16, 2022, 07:35:26 PM
Bambinz
January 16, 2022, 12:21:40 PM
January 15, 2022, 07:10:03 PM
Bambinz
January 15, 2022, 06:31:33 PM
January 14, 2022, 08:47:43 PM
January 14, 2022, 08:39:07 PM
January 14, 2022, 08:14:17 PM
January 14, 2022, 08:12:13 PM
January 14, 2022, 05:51:52 PM
304er
January 14, 2022, 08:51:57 AM
Bambinz
January 13, 2022, 08:20:02 PM
January 13, 2022, 05:27:40 AM
January 13, 2022, 03:10:32 AM
304er
January 12, 2022, 06:18:15 PM
January 12, 2022, 05:45:26 PM
January 12, 2022, 03:29:04 PM
January 12, 2022, 01:30:38 PM
304er
January 12, 2022, 09:09:13 AM
January 11, 2022, 08:05:27 PM
January 11, 2022, 07:42:12 PM
January 11, 2022, 07:33:15 PM
January 11, 2022, 06:19:49 PM
304er
January 11, 2022, 05:19:46 PM
January 11, 2022, 04:31:28 PM
January 11, 2022, 03:21:37 PM
January 11, 2022, 06:50:49 AM
January 11, 2022, 06:34:20 AM
January 11, 2022, 06:24:13 AM
January 11, 2022, 06:15:08 AM
January 11, 2022, 05:25:31 AM
January 11, 2022, 12:07:22 AM
January 10, 2022, 10:56:48 PM
post Re: Hi! 811 A tesa coil
January 10, 2022, 09:38:53 PM
January 10, 2022, 07:50:13 PM
January 10, 2022, 07:19:17 PM
January 10, 2022, 03:13:08 PM
January 10, 2022, 04:21:46 AM
304er
January 10, 2022, 03:59:09 AM
January 10, 2022, 03:54:59 AM
January 09, 2022, 11:45:09 PM
jpvvv123
January 09, 2022, 11:04:25 PM
January 09, 2022, 04:22:11 PM
January 09, 2022, 05:52:11 AM
January 09, 2022, 05:10:50 AM
January 09, 2022, 01:20:40 AM
post GDT Testing
January 09, 2022, 12:38:28 AM
January 08, 2022, 06:36:28 PM
Max Seiringer
January 08, 2022, 03:21:31 PM
304er
January 08, 2022, 09:05:41 AM
jpvvv123
January 07, 2022, 10:20:10 PM
304er
January 07, 2022, 05:56:28 PM
post Re: DRSSTC tuning
January 07, 2022, 05:01:21 AM
January 07, 2022, 04:59:59 AM
post Tophat QCW 1
January 07, 2022, 02:27:35 AM
January 07, 2022, 02:19:40 AM
January 06, 2022, 09:33:06 PM
kubajed
January 06, 2022, 04:48:22 PM
SK1701
January 06, 2022, 08:17:09 AM
post General Questions
January 06, 2022, 04:42:25 AM
jpvvv123
January 06, 2022, 03:40:43 AM
SK1701
post Re: Bus Supply Questions
January 04, 2022, 05:58:10 PM
January 04, 2022, 01:37:02 PM
post Bus Supply Questions
January 04, 2022, 04:12:34 AM
post Re: ZVS Driven Teslacoil
January 04, 2022, 01:14:26 AM
January 03, 2022, 05:38:08 PM
January 02, 2022, 01:17:37 AM
paulj
January 01, 2022, 06:53:46 PM
MHV
January 01, 2022, 06:39:05 PM
January 01, 2022, 02:05:43 PM
post Re: Full Bridge SSTC
January 01, 2022, 11:54:25 AM
paulj
December 31, 2021, 07:19:02 PM
Zbig
