Author Topic: Bus Supply Questions  (Read 292 times)
Offline flyingperson23
« on: January 04, 2022, 04:12:34 AM »
 Hey, I built a vttc and I'm looking to try and build a drsstc, but I'm a bit of a noob. Out of the designs I've seen online, namely by kaiser and loneocean, I've seen two different general designs: half bridge with voltage doubler rectifier, and full bridge with standard rectifier. Are the two mutually exclusive? What are their benefits? I live in the US with access to 240vac and I'd like to build something similar in size and power to loneoceans' drsstc 2/3, probably with cm300's. Should I do a full bridge with 340v as the bus voltage or half bridge with 678v?
Thanks!
Offline AstRii
Re: Bus Supply Questions
« Reply #1 on: January 04, 2022, 01:37:02 PM »
I dont think there are any advantages of using half bridge with voltage doubler, to be honest I've never seen voltage doublers when using 240VAC input. Voltage doublers are usually used in US countries where mains voltage is only 120VAC to step it up higher.
Half bridge designs are usually used in lower power applications as they deliver only 1/4 of the power of a full bridge (assuming the same conditions in both cases). For smaller DRSSTCs half bridge configuration is usually easier to build and also cheaper to repair as only 2 IGBTs blow up instead of 4.
Using half bridge with voltage doubler when working with 240VAC seems contraproductive to me. If you have 340VDC bus available there is no need for voltage doubler unless you want to run very high DC bus voltages.
If you are a begginer, I would suggest to always work with lower voltages, not just for safety reasons but also because it's easier to work with.
Marek Novotny
www.uhvlab.org
« Reply #2 on: January 04, 2022, 05:58:10 PM »
Full bridge + 240VAC + voltage doubler is a pretty standard configuration for mid-large size coils with 1200V IGBTs. Most CM300s used in coils will likely be the 1200V version (part number CM300-24x, where x is the variant, 24 is the voltage rating divided by 50 = 1200V for some obscure reason, and 300 = an indication of the nominal hard current switching class).
The specs of loneoceanĀ“s DRSSTC 3 are pretty similar to my larger coil, and both he and I use a voltage doubler + full bridge running off 240VAC. I have tried running mine off non-doubled mains in the past and got reasonable results but I definitely prefer the doubled version.
The only reason that I'd do anything different is if I had a smaller coil which didn't benefit from extra bus voltage, or was very budget constrained (in which case you could save on bus capacitors and 1200V silicon by going for non-doubled mains and using 600V IGBTs, or save on IGBTs by going for a half bridge but doubled).
post Re: Muon Decay
Today at 10:11:21 AM
post Re: Muon Decay
January 19, 2022, 08:22:49 PM
post Re: Muon Decay
January 19, 2022, 06:49:36 PM
hardboiled99
January 19, 2022, 07:37:27 AM
January 18, 2022, 10:34:48 PM
post Re: Muon Decay
January 18, 2022, 08:46:53 PM
post Re: Muon Decay
January 18, 2022, 08:08:53 PM
post Re: GDT Testing
January 18, 2022, 07:15:22 PM
post Muon Decay
January 18, 2022, 06:49:48 PM
304er
January 18, 2022, 08:47:53 AM
January 17, 2022, 09:13:32 PM
January 17, 2022, 09:05:56 PM
January 17, 2022, 07:45:48 PM
post Re: General Questions
January 17, 2022, 07:41:34 PM
January 17, 2022, 07:38:25 PM
January 17, 2022, 07:31:03 PM
January 17, 2022, 07:28:02 PM
January 16, 2022, 09:00:02 PM
January 16, 2022, 07:35:26 PM
Bambinz
January 16, 2022, 12:21:40 PM
January 15, 2022, 07:10:03 PM
Bambinz
January 15, 2022, 06:31:33 PM
January 14, 2022, 08:47:43 PM
January 14, 2022, 08:39:07 PM
January 14, 2022, 08:14:17 PM
January 14, 2022, 08:12:13 PM
January 14, 2022, 05:51:52 PM
304er
January 14, 2022, 08:51:57 AM
Bambinz
January 13, 2022, 08:20:02 PM
January 13, 2022, 05:27:40 AM
January 13, 2022, 03:10:32 AM
304er
January 12, 2022, 06:18:15 PM
January 12, 2022, 05:45:26 PM
January 12, 2022, 03:29:04 PM
January 12, 2022, 01:30:38 PM
304er
January 12, 2022, 09:09:13 AM
January 11, 2022, 08:05:27 PM
January 11, 2022, 07:42:12 PM
January 11, 2022, 07:33:15 PM
January 11, 2022, 06:19:49 PM
304er
January 11, 2022, 05:19:46 PM
January 11, 2022, 04:31:28 PM
January 11, 2022, 03:21:37 PM
January 11, 2022, 06:50:49 AM
January 11, 2022, 06:34:20 AM
January 11, 2022, 06:24:13 AM
January 11, 2022, 06:15:08 AM
January 11, 2022, 05:25:31 AM
January 11, 2022, 12:07:22 AM
January 10, 2022, 10:56:48 PM
post Re: Hi! 811 A tesa coil
January 10, 2022, 09:38:53 PM
January 10, 2022, 07:50:13 PM
January 10, 2022, 07:19:17 PM
January 10, 2022, 03:13:08 PM
January 10, 2022, 04:21:46 AM
304er
January 10, 2022, 03:59:09 AM
January 10, 2022, 03:54:59 AM
January 09, 2022, 11:45:09 PM
jpvvv123
January 09, 2022, 11:04:25 PM
January 09, 2022, 04:22:11 PM
January 09, 2022, 05:52:11 AM
January 09, 2022, 05:10:50 AM
January 09, 2022, 01:20:40 AM
post GDT Testing
January 09, 2022, 12:38:28 AM
January 08, 2022, 06:36:28 PM
Max Seiringer
January 08, 2022, 03:21:31 PM
304er
January 08, 2022, 09:05:41 AM
jpvvv123
January 07, 2022, 10:20:10 PM
304er
January 07, 2022, 05:56:28 PM
January 07, 2022, 05:15:38 AM
post Re: DRSSTC tuning
January 07, 2022, 05:01:21 AM
January 07, 2022, 04:59:59 AM
post Tophat QCW 1
January 07, 2022, 02:27:35 AM
January 07, 2022, 02:19:40 AM
January 06, 2022, 09:33:06 PM
January 06, 2022, 06:09:39 PM
kubajed
January 06, 2022, 04:48:22 PM
SK1701
January 06, 2022, 03:05:55 PM
January 06, 2022, 08:17:09 AM
post General Questions
January 06, 2022, 04:42:25 AM
jpvvv123
January 06, 2022, 03:40:43 AM
January 06, 2022, 12:18:38 AM
SK1701
January 05, 2022, 08:37:13 PM
post Re: Bus Supply Questions
post Bus Supply Questions
post Re: ZVS Driven Teslacoil
January 04, 2022, 01:14:26 AM
January 03, 2022, 05:38:08 PM
January 02, 2022, 01:17:37 AM
paulj
January 01, 2022, 06:53:46 PM
MHV
January 01, 2022, 06:39:05 PM
January 01, 2022, 02:05:43 PM
post Re: Full Bridge SSTC
January 01, 2022, 11:54:25 AM
paulj
December 31, 2021, 07:19:02 PM
Zbig
