Author Topic: Half Bridge IR2153 + IRFP460  (Read 604 times)
Offline PowerTech
« on: December 26, 2021, 07:33:33 PM »
Long time ago I assembled this half bridge, only low power test were made trough 100W lamp.
Both FETs heated too much, so decided freeze this project until I get oscilloscope, but forgot about it for 10 years 😊
Found that frequency is too high ~145kHz, IR2153 output is weak for this, replaced Rt timing resistor to correct value.
Test run through 200W lamp – FETs almost cold, all ok.
First direct AC run tripped home 20A circuit breaker, short circuit occurred on pcb, on AC in traces, cleaned pcb and no more fireworks.
Modifications -
Shorter trace from DC bus to FETs.
Changed burned out NTC to SCK-056 5R 6 А.
Used AlN insulator between FETs and heatsink.
Bootstrap capacitor 470uF film > 10uF tantalum.
Snubber film capacitor 2.2uF.
Connected my diy 10T/1000T transformer trough coupling transformer 15T/11T.
Running at 34kHz, max 350W(power factor 0.6) drawn from AC line, FETs heating very slow, with fan - cold.
Calculated primary turns is 12, now using 15.
Schematic, removed relay and indicator leds,  IR2153 power supply switched on manually.
Initial build -
After changes -
One turn over primary.
Low side FET D-S
High side FET D-S
« Last Edit: December 26, 2021, 08:55:50 PM by PowerTech »
Re: Half Bridge IR2153 + IRFP460
« Reply #1 on: December 28, 2021, 12:44:13 AM »
Great to see success!
Yes, overly-large bootstrap capacitor causes startup issues.  Partial gate voltage during power-up can cause problems depending on exact UVL thresholds of the driver chip.
Always a good change.
Offline PowerTech
« Reply #2 on: December 28, 2021, 10:05:33 AM »
Thank U.
Here is writing error from me, it was 470nF, not uF, so I changed it from 470 nano to 10 micro F.
Offline PowerTech
« Reply #3 on: December 30, 2021, 07:46:20 AM »
How to calculate/determine, freewheeling diode needed reverse recovery time Trr, for example for 35kHz DT50% ?
Trr must be less than a dead time ? This is wrong, just tested with 125nS diode = absolutely useless.
Like D1, D2 in Mads Barnkob circuit.
https://kaizerpowerelectronics.dk/wp-content/gallery/2009_05_24_-_TL494_flyback_driver/tl494flyback_driver_improved_rev_1.4.jpg
« Last Edit: January 01, 2022, 05:58:23 PM by PowerTech »
post Re: Muon Decay
Today at 10:11:21 AM
post Re: Muon Decay
January 19, 2022, 08:22:49 PM
post Re: Muon Decay
January 19, 2022, 06:49:36 PM
hardboiled99
January 19, 2022, 07:37:27 AM
January 18, 2022, 10:34:48 PM
post Re: Muon Decay
January 18, 2022, 08:46:53 PM
post Re: Muon Decay
January 18, 2022, 08:08:53 PM
post Re: GDT Testing
January 18, 2022, 07:15:22 PM
post Muon Decay
January 18, 2022, 06:49:48 PM
January 18, 2022, 08:47:53 AM
January 17, 2022, 09:13:32 PM
January 17, 2022, 09:05:56 PM
January 17, 2022, 07:45:48 PM
post Re: General Questions
January 17, 2022, 07:41:34 PM
January 17, 2022, 07:38:25 PM
January 17, 2022, 07:31:03 PM
January 17, 2022, 07:28:02 PM
January 16, 2022, 09:00:02 PM
January 16, 2022, 07:35:26 PM
Bambinz
January 16, 2022, 12:21:40 PM
January 15, 2022, 07:10:03 PM
Bambinz
January 15, 2022, 06:31:33 PM
January 14, 2022, 08:47:43 PM
January 14, 2022, 08:39:07 PM
January 14, 2022, 08:14:17 PM
January 14, 2022, 08:12:13 PM
January 14, 2022, 05:51:52 PM
January 14, 2022, 08:51:57 AM
Bambinz
January 13, 2022, 08:20:02 PM
January 13, 2022, 05:27:40 AM
January 13, 2022, 03:10:32 AM
January 12, 2022, 06:18:15 PM
January 12, 2022, 05:45:26 PM
January 12, 2022, 03:29:04 PM
AFreshLad
January 12, 2022, 01:30:38 PM
January 12, 2022, 09:09:13 AM
January 11, 2022, 08:05:27 PM
January 11, 2022, 07:42:12 PM
January 11, 2022, 07:33:15 PM
January 11, 2022, 06:19:49 PM
January 11, 2022, 05:19:46 PM
January 11, 2022, 04:31:28 PM
January 11, 2022, 03:21:37 PM
January 11, 2022, 06:50:49 AM
January 11, 2022, 06:34:20 AM
January 11, 2022, 06:24:13 AM
January 11, 2022, 06:15:08 AM
January 11, 2022, 05:25:31 AM
January 11, 2022, 12:07:22 AM
January 10, 2022, 10:56:48 PM
January 10, 2022, 09:38:53 PM
January 10, 2022, 07:50:13 PM
January 10, 2022, 07:19:17 PM
January 10, 2022, 03:13:08 PM
January 10, 2022, 04:21:46 AM
January 10, 2022, 03:59:09 AM
January 10, 2022, 03:54:59 AM
January 09, 2022, 11:45:09 PM
January 09, 2022, 11:04:25 PM
January 09, 2022, 04:22:11 PM
January 09, 2022, 05:52:11 AM
January 09, 2022, 05:10:50 AM
January 09, 2022, 01:20:40 AM
post GDT Testing
January 09, 2022, 12:38:28 AM
January 08, 2022, 06:36:28 PM
Max Seiringer
January 08, 2022, 03:21:31 PM
January 08, 2022, 09:05:41 AM
January 07, 2022, 10:20:10 PM
January 07, 2022, 05:56:28 PM
January 07, 2022, 05:15:38 AM
post Re: DRSSTC tuning
January 07, 2022, 05:01:21 AM
January 07, 2022, 04:59:59 AM
post Tophat QCW 1
January 07, 2022, 02:27:35 AM
January 07, 2022, 02:19:40 AM
January 06, 2022, 09:33:06 PM
January 06, 2022, 06:09:39 PM
kubajed
January 06, 2022, 04:48:22 PM
SK1701
January 06, 2022, 03:05:55 PM
January 06, 2022, 08:17:09 AM
post General Questions
January 06, 2022, 04:42:25 AM
January 06, 2022, 03:40:43 AM
January 06, 2022, 12:18:38 AM
SK1701
January 05, 2022, 08:37:13 PM
post Re: Bus Supply Questions
January 04, 2022, 05:58:10 PM
January 04, 2022, 01:37:02 PM
post Bus Supply Questions
January 04, 2022, 04:12:34 AM
post Re: ZVS Driven Teslacoil
January 04, 2022, 01:14:26 AM
January 03, 2022, 05:38:08 PM
January 02, 2022, 01:17:37 AM
January 01, 2022, 06:53:46 PM
MHV
January 01, 2022, 06:39:05 PM
January 01, 2022, 02:05:43 PM
post Re: Full Bridge SSTC
January 01, 2022, 11:54:25 AM
AFreshLad
Zbig
